[PATCH] imx8mm_evk: Adjust the environment for booting a mainline kernel
Adjust the environment for booting a mainline kernel by default.
Signed-off-by: Fabio Estevam festevam@gmail.com --- configs/imx8mm_evk_defconfig | 1 - include/configs/imx8mm_evk.h | 8 ++++---- 2 files changed, 4 insertions(+), 5 deletions(-)
diff --git a/configs/imx8mm_evk_defconfig b/configs/imx8mm_evk_defconfig index 87560ef989..e007766e84 100644 --- a/configs/imx8mm_evk_defconfig +++ b/configs/imx8mm_evk_defconfig @@ -21,7 +21,6 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" CONFIG_OF_SYSTEM_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/imx8m/imximage-8mm-lpddr4.cfg" -CONFIG_DEFAULT_FDT_FILE="fsl-imx8mm-evk.dtb" CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SEPARATE_BSS=y diff --git a/include/configs/imx8mm_evk.h b/include/configs/imx8mm_evk.h index acbab05ae9..b134351c8c 100644 --- a/include/configs/imx8mm_evk.h +++ b/include/configs/imx8mm_evk.h @@ -38,12 +38,12 @@ /* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ "script=boot.scr\0" \ - "image=Image.itb\0" \ + "image=Image\0" \ "console=ttymxc1,115200 earlycon=ec_imx6q,0x30890000,115200\0" \ "fdt_addr=0x43000000\0" \ "fdt_high=0xffffffffffffffff\0" \ - "boot_fit=try\0" \ - "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "boot_fit=no\0" \ + "fdt_file=imx8mm-evk.dtb\0" \ "initrd_addr=0x43800000\0" \ "initrd_high=0xffffffffffffffff\0" \ "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \ @@ -113,7 +113,7 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
#define CONFIG_ENV_OVERWRITE -#define CONFIG_SYS_MMC_ENV_DEV 0 /* USDHC2 */ +#define CONFIG_SYS_MMC_ENV_DEV 1 /* USDHC2 */ #define CONFIG_MMCROOT "/dev/mmcblk1p2" /* USDHC2 */
/* Size of malloc() pool */
Subject: [PATCH] imx8mm_evk: Adjust the environment for booting a mainline kernel
Reviewed-by: Peng Fan peng.fan@nxp.com
CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/imx8m/i mximage-8mm-lpddr4.cfg" -CONFIG_DEFAULT_FDT_FILE="fsl-imx8mm-evk.dtb" CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SEPARATE_BSS=y diff --git a/include/configs/imx8mm_evk.h b/include/configs/imx8mm_evk.h index acbab05ae9..b134351c8c 100644 --- a/include/configs/imx8mm_evk.h +++ b/include/configs/imx8mm_evk.h @@ -38,12 +38,12 @@ /* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ "script=boot.scr\0" \
- "image=Image\0" \ "console=ttymxc1,115200 earlycon=ec_imx6q,0x30890000,115200\0" \ "fdt_addr=0x43000000\0" \ "fdt_high=0xffffffffffffffff\0" \
- "boot_fit=no\0" \
- "fdt_file=imx8mm-evk.dtb\0" \ "initrd_addr=0x43800000\0" \ "initrd_high=0xffffffffffffffff\0" \ "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \ @@ -113,7
2.17.1
Adjust the environment for booting a mainline kernel by default. Signed-off-by: Fabio Estevam festevam@gmail.com Reviewed-by: Peng Fan peng.fan@nxp.com
Applied to u-boot-imx, -next, thanks !
Best regards, Stefano Babic
Fabio Estevam
Peng Fan
sbabic@denx.de
