[U-Boot] [PATCH 1/3] arm64: zynqmp: Move TCM initialization to a separate routine
From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com
This patch moves TCM initialization to a separate routine to make it modular and can be reused if required. It also prints warning message now as it writes to TCM.
Signed-off-by: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/cpu/armv8/zynqmp/cpu.c | 10 ++++++++-- 1 file changed, 8 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv8/zynqmp/cpu.c b/arch/arm/cpu/armv8/zynqmp/cpu.c index 43ba739d2f7c..3ed631e505af 100644 --- a/arch/arm/cpu/armv8/zynqmp/cpu.c +++ b/arch/arm/cpu/armv8/zynqmp/cpu.c @@ -105,10 +105,16 @@ u64 get_page_table_size(void) }
#ifdef CONFIG_SYS_MEM_RSVD_FOR_MMU -int reserve_mmu(void) +static void tcm_init(u8 mode) { - initialize_tcm(TCM_LOCK); + puts("WARNING: Initializing TCM overwrites TCM content\n"); + initialize_tcm(mode); memset((void *)ZYNQMP_TCM_BASE_ADDR, 0, ZYNQMP_TCM_SIZE); +} + +int reserve_mmu(void) +{ + tcm_init(TCM_LOCK); gd->arch.tlb_size = PGTABLE_SIZE; gd->arch.tlb_addr = ZYNQMP_TCM_BASE_ADDR;
This patch adds new zynqmp command "zynqmp tcminit mode" to initialize TCM. TCM needs to be initialized before accessing to avoid ECC errors. This new command helps to perform the same. It also makes tcm_init() as global and uses it for doing the TCM initialization.
arch/arm/cpu/armv8/zynqmp/cpu.c | 6 +++-- arch/arm/include/asm/arch-zynqmp/sys_proto.h | 3 +++ board/xilinx/zynqmp/cmds.c | 37 +++++++++++++++++++++++++++- 3 files changed, 43 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv8/zynqmp/cpu.c b/arch/arm/cpu/armv8/zynqmp/cpu.c index 3ed631e505af..4ee8e3f627e9 100644 --- a/arch/arm/cpu/armv8/zynqmp/cpu.c +++ b/arch/arm/cpu/armv8/zynqmp/cpu.c @@ -104,14 +104,16 @@ u64 get_page_table_size(void) return 0x14000; }
-#ifdef CONFIG_SYS_MEM_RSVD_FOR_MMU -static void tcm_init(u8 mode) +#if defined(CONFIG_SYS_MEM_RSVD_FOR_MMU) || defined(CONFIG_DEFINE_TCM_OCM_MMAP) +void tcm_init(u8 mode) { puts("WARNING: Initializing TCM overwrites TCM content\n"); initialize_tcm(mode); memset((void *)ZYNQMP_TCM_BASE_ADDR, 0, ZYNQMP_TCM_SIZE); } +#endif
+#ifdef CONFIG_SYS_MEM_RSVD_FOR_MMU int reserve_mmu(void) { tcm_init(TCM_LOCK); diff --git a/arch/arm/include/asm/arch-zynqmp/sys_proto.h b/arch/arm/include/asm/arch-zynqmp/sys_proto.h index 9fa44d084c06..385c8825f2f6 100644 --- a/arch/arm/include/asm/arch-zynqmp/sys_proto.h +++ b/arch/arm/include/asm/arch-zynqmp/sys_proto.h @@ -68,5 +68,8 @@ int invoke_smc(u32 pm_api_id, u32 arg0, u32 arg1, u32 arg2, u32 arg3, void initialize_tcm(bool mode); void mem_map_fill(void); int chip_id(unsigned char id); +#if defined(CONFIG_SYS_MEM_RSVD_FOR_MMU) || defined(CONFIG_DEFINE_TCM_OCM_MMAP) +void tcm_init(u8 mode); +#endif
#endif /* _ASM_ARCH_SYS_PROTO_H */ diff --git a/board/xilinx/zynqmp/cmds.c b/board/xilinx/zynqmp/cmds.c index f8c8674f874c..3e039ccb13ea 100644 --- a/board/xilinx/zynqmp/cmds.c +++ b/board/xilinx/zynqmp/cmds.c @@ -6,6 +6,7 @@
#include <common.h> #include <malloc.h> +#include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> #include <asm/io.h>
@@ -102,10 +103,36 @@ static int do_zynqmp_mmio_write(cmd_tbl_t *cmdtp, int flag, int argc, return ret; }
+#ifdef CONFIG_DEFINE_TCM_OCM_MMAP +static int do_zynqmp_tcm_init(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + u8 mode; + + if (argc != cmdtp->maxargs) + return CMD_RET_USAGE; + + mode = simple_strtoul(argv[2], NULL, 16); + if (mode != TCM_LOCK && mode != TCM_SPLIT) { + printf("Mode should be either 0(lock)/1(split)\n"); + return CMD_RET_FAILURE; + } + + dcache_disable(); + tcm_init(mode); + dcache_enable(); + + return CMD_RET_SUCCESS; +} +#endif + static cmd_tbl_t cmd_zynqmp_sub[] = { U_BOOT_CMD_MKENT(secure, 5, 0, do_zynqmp_verify_secure, "", ""), U_BOOT_CMD_MKENT(mmio_read, 3, 0, do_zynqmp_mmio_read, "", ""), U_BOOT_CMD_MKENT(mmio_write, 5, 0, do_zynqmp_mmio_write, "", ""), +#ifdef CONFIG_DEFINE_TCM_OCM_MMAP + U_BOOT_CMD_MKENT(tcminit, 3, 0, do_zynqmp_tcm_init, "", ""), +#endif };
/** @@ -145,7 +172,15 @@ static char zynqmp_help_text[] = " be used for decryption\n" "zynqmp mmio_read address - read from address\n" "zynqmp mmio_write address mask value - write value after masking to\n" - " address\n"; + " address\n" +#ifdef CONFIG_DEFINE_TCM_OCM_MMAP + "zynqmp tcminit mode - Initialize the TCM with zeros. TCM needs to be\n" + " initialized before accessing to avoid ECC\n" + " errors. mode specifies in which mode TCM has\n" + " to be initialized. Supported modes will be\n" + " lock(0)/split(1)\n" +#endif + ; #endif
U_BOOT_CMD(
Simplify defconfig for ZynqMP but keep option not to enable it for mini targets.
arch/arm/Kconfig | 1 + configs/avnet_ultra96_rev1_defconfig | 1 - configs/xilinx_zynqmp_mini_emmc0_defconfig | 1 + configs/xilinx_zynqmp_mini_emmc1_defconfig | 1 + configs/xilinx_zynqmp_mini_nand_defconfig | 1 + configs/xilinx_zynqmp_mini_qspi_defconfig | 1 - configs/xilinx_zynqmp_zc1232_revA_defconfig | 1 - configs/xilinx_zynqmp_zc1254_revA_defconfig | 1 - configs/xilinx_zynqmp_zc1275_revA_defconfig | 1 - configs/xilinx_zynqmp_zc1275_revB_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig | 1 - configs/xilinx_zynqmp_zcu100_revC_defconfig | 1 - configs/xilinx_zynqmp_zcu102_rev1_0_defconfig | 1 - configs/xilinx_zynqmp_zcu102_revA_defconfig | 1 - configs/xilinx_zynqmp_zcu102_revB_defconfig | 1 - configs/xilinx_zynqmp_zcu104_revA_defconfig | 1 - configs/xilinx_zynqmp_zcu104_revC_defconfig | 1 - configs/xilinx_zynqmp_zcu106_revA_defconfig | 1 - configs/xilinx_zynqmp_zcu111_revA_defconfig | 1 - 23 files changed, 4 insertions(+), 19 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index ccf2a844be8d..dddb2843e63f 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -911,6 +911,7 @@ config ARCH_ZYNQMP imply BOARD_LATE_INIT imply CMD_DM imply FAT_WRITE + imply MP
config TEGRA bool "NVIDIA Tegra" diff --git a/configs/avnet_ultra96_rev1_defconfig b/configs/avnet_ultra96_rev1_defconfig index 5a34cdeb7ef4..c49c9f23465d 100644 --- a/configs/avnet_ultra96_rev1_defconfig +++ b/configs/avnet_ultra96_rev1_defconfig @@ -36,7 +36,6 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y -CONFIG_MP=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y diff --git a/configs/xilinx_zynqmp_mini_emmc0_defconfig b/configs/xilinx_zynqmp_mini_emmc0_defconfig index c0ec79c98c95..917637ddacd0 100644 --- a/configs/xilinx_zynqmp_mini_emmc0_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc0_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +# CONFIG_MP is not set CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_EMBED=y diff --git a/configs/xilinx_zynqmp_mini_emmc1_defconfig b/configs/xilinx_zynqmp_mini_emmc1_defconfig index c1f5e64a04d8..1ffa528d6d54 100644 --- a/configs/xilinx_zynqmp_mini_emmc1_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc1_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +# CONFIG_MP is not set CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_EMBED=y diff --git a/configs/xilinx_zynqmp_mini_nand_defconfig b/configs/xilinx_zynqmp_mini_nand_defconfig index e119ec1c3b94..74ba0c97f399 100644 --- a/configs/xilinx_zynqmp_mini_nand_defconfig +++ b/configs/xilinx_zynqmp_mini_nand_defconfig @@ -39,6 +39,7 @@ CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +# CONFIG_MP is not set # CONFIG_PARTITIONS is not set CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-nand" diff --git a/configs/xilinx_zynqmp_mini_qspi_defconfig b/configs/xilinx_zynqmp_mini_qspi_defconfig index 9fcc7c2ea3de..db129b6ce7dd 100644 --- a/configs/xilinx_zynqmp_mini_qspi_defconfig +++ b/configs/xilinx_zynqmp_mini_qspi_defconfig @@ -42,7 +42,6 @@ CONFIG_CMD_SF=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_MISC is not set -CONFIG_MP=y # CONFIG_PARTITIONS is not set CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-qspi" diff --git a/configs/xilinx_zynqmp_zc1232_revA_defconfig b/configs/xilinx_zynqmp_zc1232_revA_defconfig index 2aeee193fa62..7521fc4e34e4 100644 --- a/configs/xilinx_zynqmp_zc1232_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1232_revA_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_FPGA_LOADBP=y CONFIG_CMD_FPGA_LOADP=y # CONFIG_CMD_NET is not set CONFIG_CMD_TIME=y -CONFIG_MP=y CONFIG_CMD_TIMER=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y diff --git a/configs/xilinx_zynqmp_zc1254_revA_defconfig b/configs/xilinx_zynqmp_zc1254_revA_defconfig index e72808d42887..e0822b931edb 100644 --- a/configs/xilinx_zynqmp_zc1254_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1254_revA_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_FPGA_LOADBP=y CONFIG_CMD_FPGA_LOADP=y # CONFIG_CMD_NET is not set CONFIG_CMD_TIME=y -CONFIG_MP=y CONFIG_CMD_TIMER=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y diff --git a/configs/xilinx_zynqmp_zc1275_revA_defconfig b/configs/xilinx_zynqmp_zc1275_revA_defconfig index c8746b9a98a8..3afed6973709 100644 --- a/configs/xilinx_zynqmp_zc1275_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1275_revA_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_FPGA_LOADBP=y CONFIG_CMD_FPGA_LOADP=y # CONFIG_CMD_NET is not set CONFIG_CMD_TIME=y -CONFIG_MP=y CONFIG_CMD_TIMER=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y diff --git a/configs/xilinx_zynqmp_zc1275_revB_defconfig b/configs/xilinx_zynqmp_zc1275_revB_defconfig index 053afa709575..7e31b1112f8f 100644 --- a/configs/xilinx_zynqmp_zc1275_revB_defconfig +++ b/configs/xilinx_zynqmp_zc1275_revB_defconfig @@ -27,7 +27,6 @@ CONFIG_CMD_FPGA_LOADP=y CONFIG_CMD_MMC=y # CONFIG_CMD_NET is not set CONFIG_CMD_TIME=y -CONFIG_MP=y CONFIG_CMD_TIMER=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y diff --git a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig index 28dabddfb3f9..ec26dd70fd57 100644 --- a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig @@ -35,7 +35,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y -CONFIG_MP=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index 89da50d1adbd..c2b3d189ec4d 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -35,7 +35,6 @@ CONFIG_CMD_NAND_LOCK_UNLOCK=y CONFIG_CMD_USB=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y -CONFIG_MP=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y diff --git a/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig b/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig index e9af979e0002..b853e2f56f62 100644 --- a/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig @@ -32,7 +32,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y -CONFIG_MP=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y diff --git a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig index 445b6b0180ed..a0bbc0fbde8b 100644 --- a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig @@ -27,7 +27,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y -CONFIG_MP=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y diff --git a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig index 491619cf0844..0625d195c913 100644 --- a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig @@ -28,7 +28,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y -CONFIG_MP=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y diff --git a/configs/xilinx_zynqmp_zcu100_revC_defconfig b/configs/xilinx_zynqmp_zcu100_revC_defconfig index abaaa34b55a2..dc1e7cd8240f 100644 --- a/configs/xilinx_zynqmp_zcu100_revC_defconfig +++ b/configs/xilinx_zynqmp_zcu100_revC_defconfig @@ -36,7 +36,6 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y -CONFIG_MP=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y diff --git a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig index 409067b4640a..e41366ecf7d0 100644 --- a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig +++ b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig @@ -39,7 +39,6 @@ CONFIG_CMD_SF=y CONFIG_CMD_USB=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y -CONFIG_MP=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y diff --git a/configs/xilinx_zynqmp_zcu102_revA_defconfig b/configs/xilinx_zynqmp_zcu102_revA_defconfig index 066d6de5c379..02dd5ed2b785 100644 --- a/configs/xilinx_zynqmp_zcu102_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revA_defconfig @@ -38,7 +38,6 @@ CONFIG_CMD_SF=y CONFIG_CMD_USB=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y -CONFIG_MP=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index bd0bc6dc8e70..78deb6a967f2 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -38,7 +38,6 @@ CONFIG_CMD_SF=y CONFIG_CMD_USB=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y -CONFIG_MP=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y diff --git a/configs/xilinx_zynqmp_zcu104_revA_defconfig b/configs/xilinx_zynqmp_zcu104_revA_defconfig index 86670e1e0ee9..ff57ca8674e6 100644 --- a/configs/xilinx_zynqmp_zcu104_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu104_revA_defconfig @@ -33,7 +33,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y -CONFIG_MP=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y diff --git a/configs/xilinx_zynqmp_zcu104_revC_defconfig b/configs/xilinx_zynqmp_zcu104_revC_defconfig index e566c4a94025..33258e41b201 100644 --- a/configs/xilinx_zynqmp_zcu104_revC_defconfig +++ b/configs/xilinx_zynqmp_zcu104_revC_defconfig @@ -33,7 +33,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y -CONFIG_MP=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y diff --git a/configs/xilinx_zynqmp_zcu106_revA_defconfig b/configs/xilinx_zynqmp_zcu106_revA_defconfig index f4f923e73934..210c9a347fb2 100644 --- a/configs/xilinx_zynqmp_zcu106_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu106_revA_defconfig @@ -34,7 +34,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y -CONFIG_MP=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y diff --git a/configs/xilinx_zynqmp_zcu111_revA_defconfig b/configs/xilinx_zynqmp_zcu111_revA_defconfig index e643d9f878da..8bace6d80883 100644 --- a/configs/xilinx_zynqmp_zcu111_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu111_revA_defconfig @@ -32,7 +32,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y -CONFIG_MP=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y
Michal Simek
