[U-Boot] Please pull u-boot-dm
Hi Tom,
There several driver model series outstanding. This request tries to bring in what I think is ready for merging.
- at91 series - most of the SPL series, but as mentioned I need a revert of 1ee30aee before enabling this on Tegra (I know you are working on that) - the common parts of the I2C series. You may have seen Masahiro's suggestion to change the uclass <-> driver interface to something more like Linux. I would like to investigate this before merging the I2C series. - a few other fairly small clean-ups
This leaves about 12 patches to come from the above series, which is a more manageable level. If we can sort out the I2C uclass and revert then I should be able to do this in the next week or so.
One I2C is sorted out I can merge Thierry's Tegra PCI-e series which depends on it. Then there are a few remaining patches from Masahiro to integrate, and hopefully fixing up driver model to use Kconfig everywhere. That will complete the driver model work for 2015.01.
The following changes since commit 4d70b34d7f721d8b1d4d628e68c3a44ab7a10dff:
Merge branch 'master' of git://git.denx.de/u-boot-ubi (2014-11-19 23:18:29 -0500)
git://git.denx.de/u-boot-dm.git
for you to fetch changes up to 17b28edb37a33d0c89089faf36e4edd7084f65fa:
dm: core: remove unnecessary return condition in uclass lookup (2014-11-22 10:16:49 +0100)
---------------------------------------------------------------- Masahiro Yamada (4): dm: core: a trivial clean up dm: core: remove meaningless if conditional dm: core: remove unnecessary return condition in driver lookup dm: core: remove unnecessary return condition in uclass lookup
Simon Glass (29): dm: at91: Correct text base for snapper9260 dm: at91: Move snapper9260 to generic baord dm: at91: Add driver model support for atmel GPIO driver dm: at91: Add platform data for GPIO on at91sam9260-based boards dm: at91: Refactor serial driver slightly for driver model dm: at91: Add driver model support for the serial driver dm: at91: Convert snapper9260 to use driver model dm: at91: Add myself as maintainer for snapper9260 dm: serial: Support changing the baud rate dm: tegra: Avoid using arch-specific memcpy() in SPL dm: Split the simple malloc() implementation into its own file dm: arm: spl: Allow simple malloc() in SPL dm: spl: Make simple malloc() available when enabled dm: spl: Allow driver model to be used dm: Allow device removal features to be dropped dm: Allow stdio registration to be dropped dm: Disable dm_warn() in SPL dm: tegra: Add platform data for the SPL uart dm: tegra: Add platform data for the GPIO driver dm: arm: spl: Make driver model linker lists available dm: Update documentation to include CONFIG_DM... options dm: i2c: Move error reporting into a common function dm: core: Allow access to the device's driver_id data dm: core: Add functions to find parent and OF data dm: fdt: Correct handling of aliases with embedded digits dm: Add a function to bind a device by driver name dm: spi: Correct handling of SPI chip selects in sandbox dm: spi: Use device_bind_driver() instead of our own function cros_ec: Fix uninitialised variable in cros_ec.c
README | 119 +++++++++++++++++++++++++++ arch/arm/cpu/arm926ejs/at91/at91sam9260_devices.c | 14 ++++ arch/arm/cpu/u-boot-spl.lds | 7 ++ arch/arm/include/asm/arch-at91/at91sam9260.h | 4 +- arch/arm/include/asm/arch-at91/atmel_serial.h | 15 ++++ arch/arm/include/asm/arch-at91/gpio.h | 6 ++ arch/arm/lib/crt0.S | 2 +- board/bluewater/snapper9260/MAINTAINERS | 2 +- board/bluewater/snapper9260/snapper9260.c | 18 ++++- board/nvidia/common/board.c | 8 ++ common/Makefile | 3 + common/board_r.c | 3 +- common/cmd_i2c.c | 32 +++++--- common/dlmalloc.c | 19 ++--- common/malloc_simple.c | 39 +++++++++ common/spl/spl.c | 16 +++- doc/driver-model/README.txt | 44 +++++++--- drivers/core/Makefile | 3 +- drivers/core/device-remove.c | 187 ++++++++++++++++++++++++++++++++++++++++++ drivers/core/device.c | 178 +++------------------------------------- drivers/core/lists.c | 50 ++++++++---- drivers/core/root.c | 4 +- drivers/gpio/at91_gpio.c | 241 ++++++++++++++++++++++++++++++++++++++++++------------- drivers/misc/cros_ec.c | 1 + drivers/mtd/spi/sandbox.c | 4 +- drivers/serial/atmel_usart.c | 116 +++++++++++++++++++++++--- drivers/serial/serial-uclass.c | 77 +++++++++++++++++- drivers/serial/serial_tegra.c | 16 ++++ drivers/spi/spi-uclass.c | 34 +------- include/asm-generic/global_data.h | 1 + include/config_defaults.h | 6 ++ include/configs/snapper9260.h | 12 ++- include/configs/tegra-common.h | 2 + include/dm/device-internal.h | 10 +++ include/dm/device.h | 19 +++++ include/dm/lists.h | 13 +++ include/dm/util.h | 6 ++ include/malloc.h | 60 ++++++++------ include/spi.h | 14 ++-- lib/fdtdec.c | 6 +- scripts/Makefile.spl | 1 + 41 files changed, 1048 insertions(+), 364 deletions(-) create mode 100644 arch/arm/include/asm/arch-at91/atmel_serial.h create mode 100644 common/malloc_simple.c create mode 100644 drivers/core/device-remove.c
On Sun, Nov 23, 2014 at 08:17:23AM -0700, Simon Glass wrote:
Hi Tom,
- at91 series
