Please pull u-boot-net/next
this PR includes the following net changes for next:
- Various DSA additions - bootp: fix for VCI string - tsec: support for promiscuous mode - add Aspeed MDIO driver The following changes since commit 2ad8d0cb950da2233a2ec030533f4e54c6d04126:
Merge branch 'efi-2022-01' of https://source.denx.de/u-boot/custodians/u-boot-efi (2021-11-20 09:36:37 -0500)
https://source.denx.de/u-boot/custodians/u-boot-net.git/
for you to fetch changes up to 8fc7def2838f40298ba2d86447dc8974de94a243:
net: phy: realtek: Add tx/rx delay config for 8211e (2021-11-21 21:32:32 +0200)
---------------------------------------------------------------- Bin Meng (3): net: dsa: Use true instead of 1 in the set_promisc() call net: fec_mxc: Declare 'promisc' as bool net: tsec: Make redundant_init() static
Dylan Hung (1): drivers: net: add Aspeed MDIO driver
Peter Hoyes (1): cmd: pxe_utils: Check fdtcontroladdr in label_boot
Samuel Holland (1): net: phy: realtek: Add tx/rx delay config for 8211e
Vladimir Oltean (11): net: phy: mscc: add support for VSC8502 in dual RGMII mode net: tsec: add support for promiscuous mode include: import if_vlan.h from Linux net: dsa: allow drivers to get the port OF node net: introduce a helper to determine whether to use in-band autoneg net: dsa: felix: configure the in-band autoneg property based on OF node info net: dsa: add driver for NXP SJA1105 L2 switch net: dsa: sja1105: add support for SGMII arm: dts: ls1021a-tsn: add sja1105 and eth2 bindings configs: ls1021a-tsn: enable sja1105 switch driver configs: ls1021a-tsn: enable the generation of random Ethernet MAC addresses
Walter Stoll (1): net: bootp: Correct VCI string transmission
arch/arm/dts/ls1021a-tsn.dts | 103 + boot/pxe_utils.c | 8 +- configs/ls1021atsn_qspi_defconfig | 3 + configs/ls1021atsn_sdcard_defconfig | 3 + configs/pine64_plus_defconfig | 1 - drivers/core/of_extra.c | 12 + drivers/net/Kconfig | 23 + drivers/net/Makefile | 2 + drivers/net/aspeed_mdio.c | 128 ++ drivers/net/fec_mxc.h | 2 +- drivers/net/mscc_eswitch/felix_switch.c | 10 +- drivers/net/phy/Kconfig | 10 - drivers/net/phy/mscc.c | 56 + drivers/net/phy/realtek.c | 69 +- drivers/net/sja1105.c | 3376 +++++++++++++++++++++++++++++++ drivers/net/tsec.c | 22 +- include/dm/of_extra.h | 14 + include/linux/if_vlan.h | 26 + include/net/dsa.h | 12 + include/tsec.h | 2 + net/bootp.c | 2 +- net/dsa-uclass.c | 22 +- 22 files changed, 3854 insertions(+), 52 deletions(-) create mode 100644 drivers/net/aspeed_mdio.c create mode 100644 drivers/net/sja1105.c create mode 100644 include/linux/if_vlan.h
Thanks, Ramon
Since this is for next please make it based on -next and not master, thanks!
-- Tom
Will do.
Ramon Fried
