[U-Boot] [PATCH v3 1/3] arm: Fix SCFG ICID reg addresses
On the LS102x boards, in order to initialize the ICID values of masters, the dev_stream_id array holds absolute offsets from the base of SCFG.
In ls102xa_config_ssmu_stream_id, the base pointer is cast to uint32_t * before adding the offset, leading to an invalid address. Casting it to void * solves the issue.
Signed-off-by: Vincent Siles vincent.siles@provenrun.com ---
board/freescale/common/ls102xa_stream_id.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/freescale/common/ls102xa_stream_id.c b/board/freescale/common/ls102xa_stream_id.c index f434269..39e7b30 100644 --- a/board/freescale/common/ls102xa_stream_id.c +++ b/board/freescale/common/ls102xa_stream_id.c @@ -10,11 +10,11 @@
void ls102xa_config_smmu_stream_id(struct smmu_stream_id *id, uint32_t num) { - uint32_t *scfg = (uint32_t *)CONFIG_SYS_FSL_SCFG_ADDR; + void *scfg = (void *)CONFIG_SYS_FSL_SCFG_ADDR; int i;
for (i = 0; i < num; i++) - out_be32(scfg + id[i].offset, id[i].stream_id); + out_be32((u32 *)(scfg + id[i].offset), id[i].stream_id); }
void ls1021x_config_caam_stream_id(struct liodn_id_table *tbl, int size)
Mix usage of uint32_t and u32 fixed in favor of u32
board/freescale/common/ls102xa_stream_id.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/freescale/common/ls102xa_stream_id.c b/board/freescale/common/ls102xa_stream_id.c index 39e7b30..3d5404e 100644 --- a/board/freescale/common/ls102xa_stream_id.c +++ b/board/freescale/common/ls102xa_stream_id.c @@ -28,6 +28,6 @@ void ls1021x_config_caam_stream_id(struct liodn_id_table *tbl, int size) else liodn = tbl[i].id[0];
- out_le32((uint32_t *)(tbl[i].reg_offset), liodn); + out_le32((u32 *)(tbl[i].reg_offset), liodn); } }
LS102A ref manual dictates that ICID have to be written to the MSB of the ICID register, not to the LSB.
Changes in v3: - Fix another issue with ICID setup: the value is not written at the correct location (LSB instead of MSB)
Changes in v2: - Casting to void * instead of u8 * - Splitted commit into two seperate ones
board/freescale/common/ls102xa_stream_id.c | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/board/freescale/common/ls102xa_stream_id.c b/board/freescale/common/ls102xa_stream_id.c index 3d5404e..0abaffb 100644 --- a/board/freescale/common/ls102xa_stream_id.c +++ b/board/freescale/common/ls102xa_stream_id.c @@ -12,9 +12,12 @@ void ls102xa_config_smmu_stream_id(struct smmu_stream_id *id, uint32_t num) { void *scfg = (void *)CONFIG_SYS_FSL_SCFG_ADDR; int i; + u32 icid;
- for (i = 0; i < num; i++) - out_be32((u32 *)(scfg + id[i].offset), id[i].stream_id); + for (i = 0; i < num; i++) { + icid = (id[i].stream_id & 0xff) << 24; + out_be32((u32 *)(scfg + id[i].offset), icid); + } }
Changes in v3:
Changes in v2:
Applied to fsl-qoriq master branch. Awaiting upstream. Thanks.
York
Vincent Siles
York Sun
