[U-Boot-Users] [PATCH] FSL I2C driver programs the two I2C busses differently
The i2c_init() function in fsl_i2c.c programs the two I2C busses differently. The second I2C bus has its slave address programmed incorrectly and is missing a 5-us delay.
Signed-off-by: Timur Tabi timur@freescale.com --- drivers/fsl_i2c.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/drivers/fsl_i2c.c b/drivers/fsl_i2c.c index ebae5af..22485ea 100644 --- a/drivers/fsl_i2c.c +++ b/drivers/fsl_i2c.c @@ -69,9 +69,10 @@ i2c_init(int speed, int slaveadd) dev = (struct fsl_i2c *) (CFG_IMMR + CFG_I2C2_OFFSET);
writeb(0, &dev->cr); /* stop I2C controller */ + udelay(5); /* let it shutdown in peace */ writeb(0x3F, &dev->fdr); /* set bus speed */ writeb(0x3F, &dev->dfsrr); /* set default filter */ - writeb(slaveadd, &dev->adr); /* write slave address */ + writeb(slaveadd << 1, &dev->adr); /* write slave address */ writeb(0x0, &dev->sr); /* clear status register */ writeb(I2C_CR_MEN, &dev->cr); /* start I2C controller */ #endif /* CFG_I2C2_OFFSET */
Acked-by: Grant Likely grant.likely@secretlab.ca
g.
1.5.0.2.260.g2eb065
This SF.net email is sponsored by DB2 Express Download DB2 Express C - the FREE version of DB2 express and take control of your XML. No limits. Just data. Click to get it now. http://sourceforge.net/powerbar/db2/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Grant Likely
Timur Tabi
