[U-Boot-Users] [ARM] TI DaVinci (TMS320DM644x) support [3/5]
Signed-off-by: Sergey Kubushyn ksi@koi8.net
=== Cut === diff -purN u-boot.git.orig/cpu/arm926ejs/davinci/dp83848.c u-boot.git/cpu/arm926ejs/davinci/dp83848.c --- u-boot.git.orig/cpu/arm926ejs/davinci/dp83848.c 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/cpu/arm926ejs/davinci/dp83848.c 2007-08-05 16:19:52.000000000 -0700 @@ -0,0 +1,156 @@ +/* + * National Semiconductor DP83848 PHY Driver for TI DaVinci + * (TMS320DM644x) based boards. + * + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * -------------------------------------------------------- + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <net.h> +#include <dp83848.h> +#include <asm/arch/emac_defs.h> + +#ifdef CONFIG_DRIVER_TI_EMAC + +#if (CONFIG_COMMANDS & CFG_CMD_NET) + +int dp83848_is_phy_connected(int phy_addr) +{ + u_int16_t id1, id2; + + if (!dm644x_eth_phy_read(phy_addr, DP83848_PHYID1_REG, &id1)) + return(0); + if (!dm644x_eth_phy_read(phy_addr, DP83848_PHYID2_REG, &id2)) + return(0); + + if ((id1 == DP83848_PHYID1_OUI) && (id2 == DP83848_PHYID2_OUI)) + return(1); + + return(0); +} + +int dp83848_get_link_speed(int phy_addr) +{ + u_int16_t tmp; + volatile emac_regs* emac = (emac_regs *)EMAC_BASE_ADDR; + + if (!dm644x_eth_phy_read(phy_addr, DP83848_STAT_REG, &tmp)) + return(0); + + if (!(tmp & DP83848_LINK_STATUS)) /* link up? */ + return(0); + + if (!dm644x_eth_phy_read(phy_addr, DP83848_PHY_STAT_REG, &tmp)) + return(0); + + /* Speed doesn't matter, there is no setting for it in EMAC... */ + if (tmp & DP83848_SPEED) { + if (tmp & DP83848_DUPLEX) { + /* set DM644x EMAC for Full Duplex */ + emac->MACCONTROL = EMAC_MACCONTROL_MIIEN_ENABLE | EMAC_MACCONTROL_FULLDUPLEX_ENABLE; + } else { + /*set DM644x EMAC for Half Duplex */ + emac->MACCONTROL = EMAC_MACCONTROL_MIIEN_ENABLE; + } + + return(1); + } else { + if (tmp & DP83848_DUPLEX) { + /* set DM644x EMAC for Full Duplex */ + emac->MACCONTROL = EMAC_MACCONTROL_MIIEN_ENABLE | EMAC_MACCONTROL_FULLDUPLEX_ENABLE; + } else { + /*set DM644x EMAC for Half Duplex */ + emac->MACCONTROL = EMAC_MACCONTROL_MIIEN_ENABLE; + } + + return(1); + } + + return(0); +} + + +int dp83848_init_phy(int phy_addr) +{ + int ret = 1; + + if (!dp83848_get_link_speed(phy_addr)) { + /* Try another time */ + udelay(100000); + ret = dp83848_get_link_speed(phy_addr); + } + + /* Disable PHY Interrupts */ + dm644x_eth_phy_write(phy_addr, DP83848_PHY_INTR_CTRL_REG, 0); + + return(ret); +} + + +int dp83848_auto_negotiate(int phy_addr) +{ + u_int16_t tmp; + + + if (!dm644x_eth_phy_read(phy_addr, DP83848_CTL_REG, &tmp)) + return(0); + + /* Restart Auto_negotiation */ + tmp &= ~DP83848_AUTONEG; /* remove autonegotiation enable */ + tmp |= DP83848_ISOLATE; /* Electrically isolate PHY */ + dm644x_eth_phy_write(phy_addr, DP83848_CTL_REG, tmp); + + /* Set the Auto_negotiation Advertisement Register + * MII advertising for Next page, 100BaseTxFD and HD, + * 10BaseTFD and HD, IEEE 802.3 + */ + tmp = DP83848_NP | DP83848_TX_FDX | DP83848_TX_HDX | + DP83848_10_FDX | DP83848_10_HDX | DP83848_AN_IEEE_802_3; + dm644x_eth_phy_write(phy_addr, DP83848_ANA_REG, tmp); + + + /* Read Control Register */ + if (!dm644x_eth_phy_read(phy_addr, DP83848_CTL_REG, &tmp)) + return(0); + + tmp |= DP83848_SPEED_SELECT | DP83848_AUTONEG | DP83848_DUPLEX_MODE; + dm644x_eth_phy_write(phy_addr, DP83848_CTL_REG, tmp); + + /* Restart Auto_negotiation */ + tmp |= DP83848_RESTART_AUTONEG; + dm644x_eth_phy_write(phy_addr, DP83848_CTL_REG, tmp); + + /*check AutoNegotiate complete */ + udelay(10000); + if (!dm644x_eth_phy_read(phy_addr, DP83848_STAT_REG, &tmp)) + return(0); + + if (!(tmp & DP83848_AUTONEG_COMP)) + return(0); + + return (dp83848_get_link_speed(phy_addr)); +} + +#endif /* CONFIG_COMMANDS & CFG_CMD_NET */ + +#endif /* CONFIG_DRIVER_ETHER */ diff -purN u-boot.git.orig/cpu/arm926ejs/davinci/ether.c u-boot.git/cpu/arm926ejs/davinci/ether.c --- u-boot.git.orig/cpu/arm926ejs/davinci/ether.c 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/cpu/arm926ejs/davinci/ether.c 2007-08-05 16:19:52.000000000 -0700 @@ -0,0 +1,652 @@ +/* + * Ethernet driver for TI TMS320DM644x (DaVinci) chips. + * + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * Parts shamelessly stolen from TI's dm644x_emac.c. Original copyright + * follows: + * + * ---------------------------------------------------------------------------- + * + * dm644x_emac.c + * + * TI DaVinci (DM644X) EMAC peripheral driver source for DV-EVM + * + * Copyright (C) 2005 Texas Instruments. + * + * ---------------------------------------------------------------------------- + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + * ---------------------------------------------------------------------------- + + * Modifications: + * ver. 1.0: Sep 2005, Anant Gole - Created EMAC version for uBoot. + * ver 1.1: Nov 2005, Anant Gole - Extended the RX logic for multiple descriptors + * + */ +#include <common.h> +#include <command.h> +#include <net.h> +#include <miiphy.h> +#include <asm/arch/emac_defs.h> + +#ifdef CONFIG_DRIVER_TI_EMAC + +#if (CONFIG_COMMANDS & CFG_CMD_NET) + +unsigned int emac_dbg = 0; +#define debug_emac(fmt,args...) if (emac_dbg) printf(fmt,##args) + +/* Internal static functions */ +static int dm644x_eth_hw_init (void); +static int dm644x_eth_open (void); +static int dm644x_eth_close (void); +static int dm644x_eth_send_packet (volatile void *packet, int length); +static int dm644x_eth_rcv_packet (void); +static void dm644x_eth_mdio_enable(void); + +static int gen_init_phy(int phy_addr); +static int gen_is_phy_connected(int phy_addr); +static int gen_get_link_speed(int phy_addr); +static int gen_auto_negotiate(int phy_addr); + +/* Wrappers exported to the U-Boot proper */ +int eth_hw_init(void) +{ + return(dm644x_eth_hw_init()); +} + +int eth_init(bd_t * bd) +{ + return(dm644x_eth_open()); +} + +void eth_halt(void) +{ + dm644x_eth_close(); +} + +int eth_send(volatile void *packet, int length) +{ + return(dm644x_eth_send_packet(packet, length)); +} + +int eth_rx(void) +{ + return(dm644x_eth_rcv_packet()); +} + +void eth_mdio_enable(void) +{ + dm644x_eth_mdio_enable(); +} +/* End of wrappers */ + + +static u_int8_t dm644x_eth_mac_addr[] = { 0xff, 0xff, 0xff, 0xff, 0xff, 0xff }; + +/* + * This function must be called before emac_open() if you want to override + * the default mac address. + */ +void dm644x_eth_set_mac_addr(const u_int8_t *addr) +{ + int i; + + for (i = 0; i < sizeof (dm644x_eth_mac_addr); i++) { + dm644x_eth_mac_addr[i] = addr[i]; + } +} + +/* EMAC Addresses */ +static volatile emac_regs *adap_emac = (emac_regs *)EMAC_BASE_ADDR; +static volatile ewrap_regs *adap_ewrap = (ewrap_regs *)EMAC_WRAPPER_BASE_ADDR; +static volatile mdio_regs *adap_mdio = (mdio_regs *)EMAC_MDIO_BASE_ADDR; + +/* EMAC descriptors */ +static volatile emac_desc *emac_rx_desc = (emac_desc *)(EMAC_WRAPPER_RAM_ADDR + EMAC_RX_DESC_BASE); +static volatile emac_desc *emac_tx_desc = (emac_desc *)(EMAC_WRAPPER_RAM_ADDR + EMAC_TX_DESC_BASE); +static volatile emac_desc *emac_rx_active_head = 0; +static volatile emac_desc *emac_rx_active_tail = 0; +static int emac_rx_queue_active = 0; + +/* Receive packet buffers */ +static unsigned char emac_rx_buffers[EMAC_MAX_RX_BUFFERS * (EMAC_MAX_ETHERNET_PKT_SIZE + EMAC_PKT_ALIGN)]; + +/* PHY address for a discovered PHY (0xff - not found) */ +static volatile u_int8_t active_phy_addr = 0xff; + +phy_t phy; + +static void dm644x_eth_mdio_enable(void) +{ + u_int32_t clkdiv; + + clkdiv = (EMAC_MDIO_BUS_FREQ / EMAC_MDIO_CLOCK_FREQ) - 1; + + adap_mdio->CONTROL = (clkdiv & 0xff) | + MDIO_CONTROL_ENABLE | + MDIO_CONTROL_FAULT | + MDIO_CONTROL_FAULT_ENABLE; + + while (adap_mdio->CONTROL & MDIO_CONTROL_IDLE) {;} +} + +/* + * Tries to find an active connected PHY. Returns 1 if address if found. + * If no active PHY (or more than one PHY) found returns 0. + * Sets active_phy_addr variable. + */ +static int dm644x_eth_phy_detect(void) +{ + u_int32_t phy_act_state; + int i; + + active_phy_addr = 0xff; + + if ((phy_act_state = adap_mdio->ALIVE) == 0) + return(0); /* No active PHYs */ + + debug_emac("dm644x_eth_phy_detect(), ALIVE = 0x%08x\n", phy_act_state); + + for (i = 0; i < 32; i++) { + if (phy_act_state & (1 << i)) { + if (phy_act_state & ~(1 << i)) + return(0); /* More than one PHY */ + else { + active_phy_addr = i; + return(1); + } + } + } + + return(0); /* Just to make GCC happy */ +} + + +/* Read a PHY register via MDIO inteface. Returns 1 on success, 0 otherwise */ +int dm644x_eth_phy_read(u_int8_t phy_addr, u_int8_t reg_num, u_int16_t *data) +{ + int tmp; + + while (adap_mdio->USERACCESS0 & MDIO_USERACCESS0_GO) {;} + + adap_mdio->USERACCESS0 = MDIO_USERACCESS0_GO | + MDIO_USERACCESS0_WRITE_READ | + ((reg_num & 0x1f) << 21) | + ((phy_addr & 0x1f) << 16); + + /* Wait for command to complete */ + while ((tmp = adap_mdio->USERACCESS0) & MDIO_USERACCESS0_GO) {;} + + if (tmp & MDIO_USERACCESS0_ACK) { + *data = tmp & 0xffff; + return(1); + } + + *data = -1; + return(0); +} + +/* Write to a PHY register via MDIO inteface. Blocks until operation is complete. */ +int dm644x_eth_phy_write(u_int8_t phy_addr, u_int8_t reg_num, u_int16_t data) +{ + + while (adap_mdio->USERACCESS0 & MDIO_USERACCESS0_GO) {;} + + adap_mdio->USERACCESS0 = MDIO_USERACCESS0_GO | + MDIO_USERACCESS0_WRITE_WRITE | + ((reg_num & 0x1f) << 21) | + ((phy_addr & 0x1f) << 16) | + (data & 0xffff); + + /* Wait for command to complete */ + while (adap_mdio->USERACCESS0 & MDIO_USERACCESS0_GO) {;} + + return(1); +} + +/* PHY functions for a generic PHY */ +static int gen_init_phy(int phy_addr) +{ + int ret = 1; + + if (gen_get_link_speed(phy_addr)) { + /* Try another time */ + ret = gen_get_link_speed(phy_addr); + } + + return(ret); +} + +static int gen_is_phy_connected(int phy_addr) +{ + u_int16_t dummy; + + return(dm644x_eth_phy_read(phy_addr, PHY_PHYIDR1, &dummy)); +} + +static int gen_get_link_speed(int phy_addr) +{ + u_int16_t tmp; + + if (dm644x_eth_phy_read(phy_addr, MII_STATUS_REG, &tmp) && (tmp & 0x04)) + return(1); + + return(0); +} + +static int gen_auto_negotiate(int phy_addr) +{ + u_int16_t tmp; + + + if (!dm644x_eth_phy_read(phy_addr, PHY_BMCR, &tmp)) + return(0); + + /* Restart Auto_negotiation */ + tmp |= PHY_BMCR_AUTON; + dm644x_eth_phy_write(phy_addr, PHY_BMCR, tmp); + + /*check AutoNegotiate complete */ + udelay (10000); + if (!dm644x_eth_phy_read(phy_addr, PHY_BMSR, &tmp)) + return(0); + + if (!(tmp & PHY_BMSR_AUTN_COMP)) + return(0); + + return(gen_get_link_speed(phy_addr)); +} +/* End of generic PHY functions */ + + + +#if defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII) +static int dm644x_mii_phy_read(char *devname, unsigned char addr, unsigned char reg, unsigned short *value) +{ + return(dm644x_eth_phy_read(addr, reg, value) ? 0 : 1); +} + +static int dm644x_mii_phy_write(char *devname, unsigned char addr, unsigned char reg, unsigned short value) +{ + return(dm644x_eth_phy_write(addr, reg, value) ? 0 : 1); +} + +int dm644x_eth_miiphy_initialize(bd_t *bis) +{ + miiphy_register(phy.name, dm644x_mii_phy_read, dm644x_mii_phy_write); + + return(1); +} +#endif + +/* + * This function initializes the emac hardware. It does NOT initialize + * EMAC modules power or pin multiplexors, that is done by board_init() + * much earlier in bootup process. Returns 1 on success, 0 otherwise. + */ +static int dm644x_eth_hw_init(void) +{ + u_int32_t phy_id; + u_int16_t tmp; + int i; + + dm644x_eth_mdio_enable(); + + for (i = 0; i < 256; i++) { + if (adap_mdio->ALIVE) + break; + udelay(10); + } + + if (i >= 256) { + printf("No ETH PHY detected!!!\n"); + return(0); + } + + /* Find if a PHY is connected and get it's address */ + if (!dm644x_eth_phy_detect()) + return(0); + + /* Get PHY ID and initialize phy_ops for a detected PHY */ + if (!dm644x_eth_phy_read(active_phy_addr, PHY_PHYIDR1, &tmp)) { + active_phy_addr = 0xff; + return(0); + } + + phy_id = (tmp << 16) & 0xffff0000; + + if (!dm644x_eth_phy_read(active_phy_addr, PHY_PHYIDR2, &tmp)) { + active_phy_addr = 0xff; + return(0); + } + + phy_id |= tmp & 0x0000ffff; + + switch (phy_id) { + case PHY_LXT972: + sprintf(phy.name, "LXT972 @ 0x%02x", active_phy_addr); + phy.init = lxt972_init_phy; + phy.is_phy_connected = lxt972_is_phy_connected; + phy.get_link_speed = lxt972_get_link_speed; + phy.auto_negotiate = lxt972_auto_negotiate; + break; + case PHY_DP83848: + sprintf(phy.name, "DP83848 @ 0x%02x", active_phy_addr); + phy.init = dp83848_init_phy; + phy.is_phy_connected = dp83848_is_phy_connected; + phy.get_link_speed = dp83848_get_link_speed; + phy.auto_negotiate = dp83848_auto_negotiate; + break; + default: + sprintf(phy.name, "GENERIC @ 0x%02x", active_phy_addr); + phy.init = gen_init_phy; + phy.is_phy_connected = gen_is_phy_connected; + phy.get_link_speed = gen_get_link_speed; + phy.auto_negotiate = gen_auto_negotiate; + } + + return(1); +} + + +/* Eth device open */ +static int dm644x_eth_open(void) +{ + dv_reg_p addr; + u_int32_t clkdiv, cnt; + volatile emac_desc *rx_desc; + + debug_emac("+ emac_open\n"); + + /* Reset EMAC module and disable interrupts in wrapper */ + adap_emac->SOFTRESET = 1; + while (adap_emac->SOFTRESET != 0) {;} + adap_ewrap->EWCTL = 0; + for (cnt = 0; cnt < 5; cnt++) { + clkdiv = adap_ewrap->EWCTL; + } + + rx_desc = emac_rx_desc; + + adap_emac->TXCONTROL = 0x01; + adap_emac->RXCONTROL = 0x01; + + /* Set MAC Addresses & Init multicast Hash to 0 (disable any multicast receive) */ + /* Using channel 0 only - other channels are disabled */ + adap_emac->MACINDEX = 0; + adap_emac->MACADDRHI = + (dm644x_eth_mac_addr[3] << 24) | + (dm644x_eth_mac_addr[2] << 16) | + (dm644x_eth_mac_addr[1] << 8) | + (dm644x_eth_mac_addr[0]); + adap_emac->MACADDRLO = + (dm644x_eth_mac_addr[5] << 8) | + (dm644x_eth_mac_addr[4]); + + adap_emac->MACHASH1 = 0; + adap_emac->MACHASH2 = 0; + + /* Set source MAC address - REQUIRED */ + adap_emac->MACSRCADDRHI = + (dm644x_eth_mac_addr[3] << 24) | + (dm644x_eth_mac_addr[2] << 16) | + (dm644x_eth_mac_addr[1] << 8) | + (dm644x_eth_mac_addr[0]); + adap_emac->MACSRCADDRLO = + (dm644x_eth_mac_addr[4] << 8) | + (dm644x_eth_mac_addr[5]); + + /* Set DMA 8 TX / 8 RX Head pointers to 0 */ + addr = &adap_emac->TX0HDP; + for(cnt = 0; cnt < 16; cnt++) + *addr++ = 0; + + addr = &adap_emac->RX0HDP; + for(cnt = 0; cnt < 16; cnt++) + *addr++ = 0; + + /* Clear Statistics (do this before setting MacControl register) */ + addr = &adap_emac->RXGOODFRAMES; + for(cnt = 0; cnt < EMAC_NUM_STATS; cnt++) + *addr++ = 0; + + /* No multicast addressing */ + adap_emac->MACHASH1 = 0; + adap_emac->MACHASH2 = 0; + + /* Create RX queue and set receive process in place */ + emac_rx_active_head = emac_rx_desc; + for (cnt = 0; cnt < EMAC_MAX_RX_BUFFERS; cnt++) { + rx_desc->next = (u_int32_t)(rx_desc + 1); + rx_desc->buffer = &emac_rx_buffers[cnt * (EMAC_MAX_ETHERNET_PKT_SIZE + EMAC_PKT_ALIGN)]; + rx_desc->buff_off_len = EMAC_MAX_ETHERNET_PKT_SIZE; + rx_desc->pkt_flag_len = EMAC_CPPI_OWNERSHIP_BIT; + rx_desc++; + } + + /* Set the last descriptor's "next" parameter to 0 to end the RX desc list */ + rx_desc--; + rx_desc->next = 0; + emac_rx_active_tail = rx_desc; + emac_rx_queue_active = 1; + + /* Enable TX/RX */ + adap_emac->RXMAXLEN = EMAC_MAX_ETHERNET_PKT_SIZE; + adap_emac->RXBUFFEROFFSET = 0; + + /* No fancy configs - Use this for promiscous for debug - EMAC_RXMBPENABLE_RXCAFEN_ENABLE */ + adap_emac->RXMBPENABLE = EMAC_RXMBPENABLE_RXBROADEN; + + /* Enable ch 0 only */ + adap_emac->RXUNICASTSET = 0x01; + + /* Enable MII interface and Full duplex mode */ + adap_emac->MACCONTROL = (EMAC_MACCONTROL_MIIEN_ENABLE | EMAC_MACCONTROL_FULLDUPLEX_ENABLE); + + /* Init MDIO & get link state */ + clkdiv = (EMAC_MDIO_BUS_FREQ / EMAC_MDIO_CLOCK_FREQ) - 1; + adap_mdio->CONTROL = ((clkdiv & 0xff) | MDIO_CONTROL_ENABLE | MDIO_CONTROL_FAULT); + + if (!phy.get_link_speed(active_phy_addr)) + return(0); + + /* Start receive process */ + adap_emac->RX0HDP = (u_int32_t)emac_rx_desc; + + debug_emac("- emac_open\n"); + + return(1); +} + +/* EMAC Channel Teardown */ +static void dm644x_eth_ch_teardown(int ch) +{ + dv_reg dly = 0xff; + dv_reg cnt; + + debug_emac("+ emac_ch_teardown\n"); + + if (ch == EMAC_CH_TX) { + /* Init TX channel teardown */ + adap_emac->TXTEARDOWN = 1; + for(cnt = 0; cnt != 0xfffffffc; cnt = adap_emac->TX0CP) { + /* Wait here for Tx teardown completion interrupt to occur + * Note: A task delay can be called here to pend rather than + * occupying CPU cycles - anyway it has been found that teardown + * takes very few cpu cycles and does not affect functionality */ + dly--; + udelay(1); + if (dly == 0) + break; + } + adap_emac->TX0CP = cnt; + adap_emac->TX0HDP = 0; + } else { + /* Init RX channel teardown */ + adap_emac->RXTEARDOWN = 1; + for(cnt = 0; cnt != 0xfffffffc; cnt = adap_emac->RX0CP) { + /* Wait here for Rx teardown completion interrupt to occur + * Note: A task delay can be called here to pend rather than + * occupying CPU cycles - anyway it has been found that teardown + * takes very few cpu cycles and does not affect functionality */ + dly--; + udelay(1); + if (dly == 0) + break; + } + adap_emac->RX0CP = cnt; + adap_emac->RX0HDP = 0; + } + + debug_emac("- emac_ch_teardown\n"); +} + +/* Eth device close */ +static int dm644x_eth_close(void) +{ + debug_emac("+ emac_close\n"); + + dm644x_eth_ch_teardown(EMAC_CH_TX); /* TX Channel teardown */ + dm644x_eth_ch_teardown(EMAC_CH_RX); /* RX Channel teardown */ + + /* Reset EMAC module and disable interrupts in wrapper */ + adap_emac->SOFTRESET = 1; + adap_ewrap->EWCTL = 0; + + debug_emac("- emac_close\n"); + return(1); +} + +static int tx_send_loop = 0; + +/* + * This function sends a single packet on the network and returns + * positive number (number of bytes transmitted) or negative for error + */ +static int dm644x_eth_send_packet(volatile void *packet, int length) +{ + int ret_status = -1; + tx_send_loop = 0; + + /* Return error if no link */ + if (!phy.get_link_speed(active_phy_addr)) + { + printf("WARN: emac_send_packet: No link\n"); + return (ret_status); + } + + /* Check packet size and if < EMAC_MIN_ETHERNET_PKT_SIZE, pad it up */ + if (length < EMAC_MIN_ETHERNET_PKT_SIZE) + { + length = EMAC_MIN_ETHERNET_PKT_SIZE; + } + + /* Populate the TX descriptor */ + emac_tx_desc->next = 0; + emac_tx_desc->buffer = (u_int8_t *)packet; + emac_tx_desc->buff_off_len = (length & 0xffff); + emac_tx_desc->pkt_flag_len = ((length & 0xffff) | + EMAC_CPPI_SOP_BIT | + EMAC_CPPI_OWNERSHIP_BIT | + EMAC_CPPI_EOP_BIT); + /* Send the packet */ + adap_emac->TX0HDP = (unsigned int)emac_tx_desc; + + /* Wait for packet to complete or link down */ + while (1) { + if (!phy.get_link_speed(active_phy_addr)) { + dm644x_eth_ch_teardown(EMAC_CH_TX); + return (ret_status); + } + if (adap_emac->TXINTSTATRAW & 0x01) { + ret_status = length; + break; + } + tx_send_loop++; + } + + return(ret_status); +} + +/* + * This function handles receipt of a packet from the network + */ +static int dm644x_eth_rcv_packet(void) +{ + volatile emac_desc *rx_curr_desc; + volatile emac_desc *curr_desc; + volatile emac_desc *tail_desc; + int status, ret = -1; + + rx_curr_desc = emac_rx_active_head; + status = rx_curr_desc->pkt_flag_len; + if ((rx_curr_desc) && ((status & EMAC_CPPI_OWNERSHIP_BIT) == 0)) { + if (status & EMAC_CPPI_RX_ERROR_FRAME) { + /* Error in packet - discard it and requeue desc */ + printf("WARN: emac_rcv_pkt: Error in packet\n"); + } else { + NetReceive(rx_curr_desc->buffer, (rx_curr_desc->buff_off_len & 0xffff)); + ret = rx_curr_desc->buff_off_len & 0xffff; + } + + /* Ack received packet descriptor */ + adap_emac->RX0CP = (unsigned int)rx_curr_desc; + curr_desc = rx_curr_desc; + emac_rx_active_head = (volatile emac_desc *)rx_curr_desc->next; + + if (status & EMAC_CPPI_EOQ_BIT) { + if (emac_rx_active_head) { + adap_emac->RX0HDP = (unsigned int)emac_rx_active_head; + } else { + emac_rx_queue_active = 0; + printf("INFO:emac_rcv_packet: RX Queue not active\n"); + } + } + + /* Recycle RX descriptor */ + rx_curr_desc->buff_off_len = EMAC_MAX_ETHERNET_PKT_SIZE; + rx_curr_desc->pkt_flag_len = EMAC_CPPI_OWNERSHIP_BIT; + rx_curr_desc->next = 0; + + if (emac_rx_active_head == 0) { + printf("INFO: emac_rcv_pkt: active queue head = 0\n"); + emac_rx_active_head = curr_desc; + emac_rx_active_tail = curr_desc; + if (emac_rx_queue_active != 0) { + adap_emac->RX0HDP = (unsigned int)emac_rx_active_head; + printf("INFO: emac_rcv_pkt: active queue head = 0, HDP fired\n"); + emac_rx_queue_active = 1; + } + } else { + tail_desc = emac_rx_active_tail; + emac_rx_active_tail = curr_desc; + tail_desc->next = (unsigned int)curr_desc; + status = tail_desc->pkt_flag_len; + if (status & EMAC_CPPI_EOQ_BIT) { + adap_emac->RX0HDP = (unsigned int)curr_desc; + status &= ~EMAC_CPPI_EOQ_BIT; + tail_desc->pkt_flag_len = status; + } + } + return(ret); + } + return(0); +} + +#endif /* CONFIG_COMMANDS & CFG_CMD_NET */ + +#endif /* CONFIG_DRIVER_TI_EMAC */ diff -purN u-boot.git.orig/cpu/arm926ejs/davinci/lxt972.c u-boot.git/cpu/arm926ejs/davinci/lxt972.c --- u-boot.git.orig/cpu/arm926ejs/davinci/lxt972.c 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/cpu/arm926ejs/davinci/lxt972.c 2007-08-05 16:19:52.000000000 -0700 @@ -0,0 +1,142 @@ +/* + * Intel LXT971/LXT972 PHY Driver for TI DaVinci + * (TMS320DM644x) based boards. + * + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * -------------------------------------------------------- + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <net.h> +#include <lxt971a.h> +#include <asm/arch/emac_defs.h> + +#ifdef CONFIG_DRIVER_TI_EMAC + +#if (CONFIG_COMMANDS & CFG_CMD_NET) + +int lxt972_is_phy_connected(int phy_addr) +{ + u_int16_t id1, id2; + + if (!dm644x_eth_phy_read(phy_addr, PHY_COMMON_ID1, &id1)) + return(0); + if (!dm644x_eth_phy_read(phy_addr, PHY_COMMON_ID2, &id2)) + return(0); + + if ((id1 == (0x0013)) && ((id2 & 0xfff0) == 0x78e0)) + return(1); + + return(0); +} + +int lxt972_get_link_speed(int phy_addr) +{ + u_int16_t stat1, tmp; + volatile emac_regs* emac = (emac_regs *)EMAC_BASE_ADDR; + + if (!dm644x_eth_phy_read(phy_addr, PHY_LXT971_STAT2, &stat1)) + return(0); + + if (!(stat1 & PHY_LXT971_STAT2_LINK)) /* link up? */ + return(0); + + if (!dm644x_eth_phy_read(phy_addr, PHY_LXT971_DIG_CFG, &tmp)) + return(0); + + tmp |= PHY_LXT971_DIG_CFG_MII_DRIVE; + + dm644x_eth_phy_write(phy_addr, PHY_LXT971_DIG_CFG, tmp); + /* Read back */ + if (!dm644x_eth_phy_read(phy_addr, PHY_LXT971_DIG_CFG, &tmp)) + return(0); + + + /* Speed doesn't matter, there is no setting for it in EMAC... */ + if (stat1 & PHY_LXT971_STAT2_100BTX) { + if (stat1 & PHY_LXT971_STAT2_DUPLEX_MODE) { + /* set DM644x EMAC for Full Duplex */ + emac->MACCONTROL = EMAC_MACCONTROL_MIIEN_ENABLE | EMAC_MACCONTROL_FULLDUPLEX_ENABLE; + } else { + /*set DM644x EMAC for Half Duplex */ + emac->MACCONTROL = EMAC_MACCONTROL_MIIEN_ENABLE; + } + + return(1); + } else { + if (stat1 & PHY_LXT971_STAT2_DUPLEX_MODE) { + /* set DM644x EMAC for Full Duplex */ + emac->MACCONTROL = EMAC_MACCONTROL_MIIEN_ENABLE | EMAC_MACCONTROL_FULLDUPLEX_ENABLE; + } else { + /*set DM644x EMAC for Half Duplex */ + emac->MACCONTROL = EMAC_MACCONTROL_MIIEN_ENABLE; + } + + return(1); + } + + return(0); +} + + +int lxt972_init_phy(int phy_addr) +{ + int ret = 1; + + if (!lxt972_get_link_speed(phy_addr)) { + /* Try another time */ + ret = lxt972_get_link_speed(phy_addr); + } + + /* Disable PHY Interrupts */ + dm644x_eth_phy_write(phy_addr, PHY_LXT971_INT_ENABLE, 0); + + return(ret); +} + + +int lxt972_auto_negotiate(int phy_addr) +{ + u_int16_t tmp; + + + if (!dm644x_eth_phy_read(phy_addr, PHY_COMMON_CTRL, &tmp)) + return(0); + + /* Restart Auto_negotiation */ + tmp |= PHY_COMMON_CTRL_RES_AUTO; + dm644x_eth_phy_write(phy_addr, PHY_COMMON_CTRL, tmp); + + /*check AutoNegotiate complete */ + udelay (10000); + if (!dm644x_eth_phy_read(phy_addr, PHY_COMMON_STAT, &tmp)) + return(0); + + if (!(tmp & PHY_COMMON_STAT_AN_COMP)) + return(0); + + return (lxt972_get_link_speed(phy_addr)); +} + +#endif /* CONFIG_COMMANDS & CFG_CMD_NET */ + +#endif /* CONFIG_DRIVER_ETHER */ diff -purN u-boot.git.orig/cpu/arm926ejs/davinci/Makefile u-boot.git/cpu/arm926ejs/davinci/Makefile --- u-boot.git.orig/cpu/arm926ejs/davinci/Makefile 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/cpu/arm926ejs/davinci/Makefile 2007-08-05 16:19:52.000000000 -0700 @@ -0,0 +1,49 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).a + +COBJS = timer.o ether.o lxt972.o dp83848.o i2c.o +SOBJS = reset.o + +SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) +START := $(addprefix $(obj),$(START)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff -purN u-boot.git.orig/cpu/arm926ejs/davinci/reset.S u-boot.git/cpu/arm926ejs/davinci/reset.S --- u-boot.git.orig/cpu/arm926ejs/davinci/reset.S 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/cpu/arm926ejs/davinci/reset.S 2007-08-05 16:19:52.000000000 -0700 @@ -0,0 +1,77 @@ +/* + * Processor reset using WDT for TI TMS320DM644x SoC. + * + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * ----------------------------------------------------- + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +.globl reset_cpu +reset_cpu: + ldr r0, WDT_TGCR + mov r1, $0x08 + str r1, [r0] + ldr r1, [r0] + orr r1, r1, $0x03 + str r1, [r0] + mov r1, $0 + ldr r0, WDT_TIM12 + str r1, [r0] + ldr r0, WDT_TIM34 + str r1, [r0] + ldr r0, WDT_PRD12 + str r1, [r0] + ldr r0, WDT_PRD34 + str r1, [r0] + ldr r0, WDT_TCR + ldr r1, [r0] + orr r1, r1, $0x40 + str r1, [r0] + ldr r0, WDT_WDTCR + ldr r1, [r0] + orr r1, r1, $0x4000 + str r1, [r0] + ldr r1, WDTCR_VAL1 + str r1, [r0] + ldr r1, WDTCR_VAL2 + str r1, [r0] + nop + nop + nop + nop +reset_cpu_loop: + b reset_cpu_loop + +WDT_TGCR: + .word 0x01c21c24 +WDT_TIM12: + .word 0x01c21c10 +WDT_TIM34: + .word 0x01c21c14 +WDT_PRD12: + .word 0x01c21c18 +WDT_PRD34: + .word 0x01c21c1c +WDT_TCR: + .word 0x01c21c20 +WDT_WDTCR: + .word 0x01c21c28 +WDTCR_VAL1: + .word 0xa5c64000 +WDTCR_VAL2: + .word 0xda7e4000 diff -purN u-boot.git.orig/cpu/arm926ejs/davinci/timer.c u-boot.git/cpu/arm926ejs/davinci/timer.c --- u-boot.git.orig/cpu/arm926ejs/davinci/timer.c 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/cpu/arm926ejs/davinci/timer.c 2007-08-05 16:19:52.000000000 -0700 @@ -0,0 +1,165 @@ +/* + * (C) Copyright 2003 + * Texas Instruments <www.ti.com> + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Alex Zuepke azu@sysgo.de + * + * (C) Copyright 2002-2004 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * (C) Copyright 2004 + * Philippe Robin, ARM Ltd. philippe.robin@arm.com + * + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <arm926ejs.h> + +typedef volatile struct { + u_int32_t pid12; + u_int32_t emumgt_clksped; + u_int32_t gpint_en; + u_int32_t gpdir_dat; + u_int32_t tim12; + u_int32_t tim34; + u_int32_t prd12; + u_int32_t prd34; + u_int32_t tcr; + u_int32_t tgcr; + u_int32_t wdtcr; + u_int32_t tlgc; + u_int32_t tlmr; +} davinci_timer; + +davinci_timer *timer = (davinci_timer *)CFG_TIMERBASE; + +#define TIMER_LOAD_VAL (CFG_HZ_CLOCK / CFG_HZ) +#define READ_TIMER timer->tim34 + +static ulong timestamp; +static ulong lastinc; + +int timer_init(void) +{ + /* We are using timer34 in unchained 32-bit mode, full speed */ + timer->tcr = 0x0; + timer->tgcr = 0x0; + timer->tgcr = 0x06; + timer->tim34 = 0x0; + timer->prd34 = TIMER_LOAD_VAL; + lastinc = 0; + timer->tcr = 0x80 << 16; + timestamp = 0; + + return(0); +} + +void reset_timer(void) +{ + reset_timer_masked(); +} + +ulong get_timer(ulong base) +{ + return(get_timer_masked() - base); +} + +void set_timer(ulong t) +{ + timestamp = t; +} + +void udelay(unsigned long usec) +{ + udelay_masked(usec); +} + +void reset_timer_masked(void) +{ + lastinc = READ_TIMER; + timestamp = 0; +} + +ulong get_timer_raw(void) +{ + ulong now = READ_TIMER; + + if (now >= lastinc) { + /* normal mode */ + timestamp += now - lastinc; + } else { + /* overflow ... */ + timestamp += now + TIMER_LOAD_VAL - lastinc; + } + lastinc = now; + return timestamp; +} + +ulong get_timer_masked(void) +{ + return(get_timer_raw() / TIMER_LOAD_VAL); +} + +void udelay_masked(unsigned long usec) +{ + ulong tmo; + ulong endtime; + signed long diff; + + tmo = CFG_HZ_CLOCK / 1000; + tmo *= usec; + tmo /= 1000; + + endtime = get_timer_raw() + tmo; + + do { + ulong now = get_timer_raw(); + diff = endtime - now; + } while (diff >= 0); +} + +/* + * This function is derived from PowerPC code (read timebase as long long). + * On ARM it just returns the timer value. + */ +unsigned long long get_ticks(void) +{ + return(get_timer(0)); +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + ulong tbclk; + + tbclk = CFG_HZ; + return(tbclk); +} === Cut ===
--- ****************************************************************** * KSI@home KOI8 Net < > The impossible we do immediately. * * Las Vegas NV, USA < > Miracles require 24-hour notice. * ******************************************************************
ksi@koi8.net
