[U-Boot-Users] [PATCH] MPC5xxx: fix some compiler warnings in USB code
Fix the following warnings: - usb.c:xx: warning: function declaration isn't a prototype - usb_ohci.c:xxx: warning: passing argument 1 of '__fswab32' makes integer from pointer wihtout a cast
Signed-off-by: Martin Krause martin.krase@tqs.de --- Some remarks:
The patch fixes the compiler warnings, but I'm not sure, if the original code is correct. It seems, that in function periodic_unlink() the pointer ed_p is little/big endian swapped and not the content, the pointer is pointing to. Not sure if this was intended. Maybe some USB expert (Markus?) could take a look at this?
cpu/mpc5xxx/usb.c | 6 +++--- drivers/usb_ohci.c | 6 +++--- 2 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/cpu/mpc5xxx/usb.c b/cpu/mpc5xxx/usb.c index ce709fc..ed467ab 100644 --- a/cpu/mpc5xxx/usb.c +++ b/cpu/mpc5xxx/usb.c @@ -27,7 +27,7 @@
#include <mpc5xxx.h>
-int usb_cpu_init() +int usb_cpu_init(void) { /* Set the USB Clock */ *(vu_long *)MPC5XXX_CDM_48_FDC = CONFIG_USB_CLOCK; @@ -41,12 +41,12 @@ int usb_cpu_init() return 0; }
-int usb_cpu_stop() +int usb_cpu_stop(void) { return 0; }
-int usb_cpu_init_fail() +int usb_cpu_init_fail(void) { return 0; } diff --git a/drivers/usb_ohci.c b/drivers/usb_ohci.c index f0a37b2..14984a5 100644 --- a/drivers/usb_ohci.c +++ b/drivers/usb_ohci.c @@ -669,7 +669,7 @@ static int ep_link (ohci_t *ohci, ed_t *edi) ed_p = &(((ed_t *)ed_p)->hwNextED)) inter = ep_rev (6, ((ed_t *)ed_p)->int_interval); ed->hwNextED = *ed_p; - *ed_p = m32_swap(ed); + *ed_p = m32_swap((unsigned long)ed); } break; } @@ -687,11 +687,11 @@ static void periodic_unlink ( struct ohci *ohci, volatile struct ed *ed,
/* ED might have been unlinked through another path */ while (*ed_p != 0) { - if (((struct ed *)m32_swap (ed_p)) == ed) { + if (((struct ed *)m32_swap ((unsigned long)ed_p)) == ed) { *ed_p = ed->hwNextED; break; } - ed_p = & (((struct ed *)m32_swap (ed_p))->hwNextED); + ed_p = & (((struct ed *)m32_swap ((unsigned long)ed_p))->hwNextED); } } }
Hi Martin,
Martin Krause martin.krause@tqs.de writes:
Thanks, will be added to Custodian repo.
Some remarks:
Hmm, not sure. I'll try to take a look, but it'll take a while. Are you experiencing a problem you suspect is caused by this?
Best regards
Markus Klotzbuecher
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de
Hi Markus,
Markus Klotzbücher wrote on Thursday, August 23, 2007 6:26 PM:
No, no problems. I only found it strange to byte-swap a pointer and then compare it to another (unswapped) pointer. But maybe this is all OK for pointes included in USB data structures (because of little/big endian conversion).
Best Regards, Martin Krause
Applied, thanks.
Some remarks:
Markus, I accepted this patch to get rid of the warnings for the 2.3.0-rc1 version. Could you please check the code again it if needs to be changed as Martin suggests?
Markus Klotzbücher
Martin Krause
Martin Krause
