[U-Boot] [PATCH v2] Support for multiple SGMII/TBI interfaces for TSEC ethernet
Fix TBI PHY accesses to use the proper offset in CPU register space. The previous code would incorrectly access the TBI PHY by reading/writing to CPU register space at the same location as would be used to access external PHYs.
Signed-off-by: Peter Tyser ptyser@xes-inc.com ---
I replaced the hardcoding of CFG_TBIPA_VALUE in the tsec_configure_serdes() to support possible changes of the TBI addressing down the road, but kept the default TBI PHY address at CFG_TBIPA_VALUE as Andy Flemming suggested.
drivers/net/tsec.c | 9 +++++---- 1 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/drivers/net/tsec.c b/drivers/net/tsec.c index f81211a..43e5dff 100644 --- a/drivers/net/tsec.c +++ b/drivers/net/tsec.c @@ -283,11 +283,13 @@ uint tsec_local_mdio_read(volatile tsec_t *phyregs, uint phyid, uint regnum) /* Configure the TBI for SGMII operation */ static void tsec_configure_serdes(struct tsec_private *priv) { - tsec_local_mdio_write(priv->phyregs, CFG_TBIPA_VALUE, TBI_ANA, + /* Access TBI PHY registers at given TSEC register offset as opposed to the + * register offset used for external PHY accesses */ + tsec_local_mdio_write(priv->regs, priv->regs->tbipa, TBI_ANA, TBIANA_SETTINGS); - tsec_local_mdio_write(priv->phyregs, CFG_TBIPA_VALUE, TBI_TBICON, + tsec_local_mdio_write(priv->regs, priv->regs->tbipa, TBI_TBICON, TBICON_CLK_SELECT); - tsec_local_mdio_write(priv->phyregs, CFG_TBIPA_VALUE, TBI_CR, + tsec_local_mdio_write(priv->regs, priv->regs->tbipa, TBI_CR, TBICR_SETTINGS); }
@@ -304,7 +306,6 @@ static int init_phy(struct eth_device *dev)
/* Assign a Physical address to the TBI */ regs->tbipa = CFG_TBIPA_VALUE; - phyregs->tbipa = CFG_TBIPA_VALUE; asm("sync");
/* Reset MII (due to new addresses) */
Peter Tyser
