[U-Boot] [PATCHv7 1/6] armv8: fsl-layerscape: add i/d-cache enable function to enable_caches
This function assume that the d-cache and MMU has been enabled earlier, so it just created MMU table in main memory. But the assumption is not always correct, for example, the early setup is done in EL3, while enable_caches() is called when the PE has turned into another EL.
Define the function mmu_setup() for fsl-layerscape to cover the weak one.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- V7: - no change
arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 14 ++++++++++---- 1 file changed, 10 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index 8062106..d5bcf67 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -422,15 +422,21 @@ int arch_cpu_init(void) return 0; }
+void mmu_setup(void) +{ + final_mmu_setup(); +} + /* - * This function is called from lib/board.c. - * It recreates MMU table in main memory. MMU and d-cache are enabled earlier. - * There is no need to disable d-cache for this operation. + * This function is called from common/board_r.c. + * It recreates MMU table in main memory. */ void enable_caches(void) { - final_mmu_setup(); + mmu_setup(); __asm_invalidate_tlb_all(); + icache_enable(); + dcache_enable(); } #endif
This framework is introduced for ARMv8 secure monitor mode firmware. The main functions of the framework are, on EL3, verify the firmware, load it to the secure memory and jump into it, and while it returned to U-Boot, do some necessary setups at the 'target exception level' that is determined by the respective secure firmware.
So far, the framework support only FIT format image, and need to define the name of which config node should be used in 'configurations' and the name of property for the raw secure firmware image in that config. The FIT image should be stored in Byte accessing memory, such as NOR Flash, or else it should be copied to main memory to use this framework.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- V7: - Moved gd->sec_firmware from gobal data structure to sec_firmware.c. - Decorated the sec fimware with 'const'. - Fixed some alignment issues.
V6: - Abstracted more code from PPA to this framework. - Introduced gd->sec_firmware to hold the load address. - Refactor the func sec_firmware_support_psci_version().
V5: - Added c file sec_firmware.c. - Added declaration of sec_firmware_init(). - Renamed the func sec_firmware_validate().
V4: - Reordered this patch. - Removed the FSL PPA related items.
arch/arm/cpu/armv8/Makefile | 1 + arch/arm/cpu/armv8/sec_firmware.c | 270 ++++++++++++++++++++++++++++++ arch/arm/cpu/armv8/sec_firmware_asm.S | 53 ++++++ arch/arm/include/asm/armv8/sec_firmware.h | 18 ++ 4 files changed, 342 insertions(+) create mode 100644 arch/arm/cpu/armv8/sec_firmware.c create mode 100644 arch/arm/cpu/armv8/sec_firmware_asm.S create mode 100644 arch/arm/include/asm/armv8/sec_firmware.h
diff --git a/arch/arm/cpu/armv8/Makefile b/arch/arm/cpu/armv8/Makefile index bf8644c..ee9e009 100644 --- a/arch/arm/cpu/armv8/Makefile +++ b/arch/arm/cpu/armv8/Makefile @@ -15,6 +15,7 @@ obj-y += cache.o obj-y += tlb.o obj-y += transition.o obj-y += fwcall.o +obj-$(CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT) += sec_firmware.o sec_firmware_asm.o
obj-$(CONFIG_FSL_LAYERSCAPE) += fsl-layerscape/ obj-$(CONFIG_S32V234) += s32v234/ diff --git a/arch/arm/cpu/armv8/sec_firmware.c b/arch/arm/cpu/armv8/sec_firmware.c new file mode 100644 index 0000000..e101eb3 --- /dev/null +++ b/arch/arm/cpu/armv8/sec_firmware.c @@ -0,0 +1,270 @@ +/* + * Copyright 2016 NXP Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <errno.h> +#include <linux/kernel.h> +#include <asm/io.h> +#include <asm/system.h> +#include <asm/types.h> +#include <asm/macro.h> +#include <asm/armv8/sec_firmware.h> + +DECLARE_GLOBAL_DATA_PTR; +extern void c_runtime_cpu_setup(void); + +#define SEC_FIRMWARE_LOADED 0x1 +#define SEC_FIRMWARE_RUNNING 0x2 +#define SEC_FIRMWARE_ADDR_MASK (~0x3) + /* + * Secure firmware load addr + * Flags used: 0x1 secure firmware has been loaded to secure memory + * 0x2 secure firmware is running + */ + phys_addr_t sec_firmware_addr; + +static int sec_firmware_get_data(const void *sec_firmware_img, + const void **data, size_t *size) +{ + int conf_node_off, fw_node_off; + char *conf_node_name = NULL; + char *desc; + int ret; + + conf_node_name = SEC_FIRMEWARE_FIT_CNF_NAME; + + conf_node_off = fit_conf_get_node(sec_firmware_img, conf_node_name); + if (conf_node_off < 0) { + printf("SEC Firmware: %s: no such config\n", conf_node_name); + return -ENOENT; + } + + fw_node_off = fit_conf_get_prop_node(sec_firmware_img, conf_node_off, + SEC_FIRMWARE_FIT_IMAGE); + if (fw_node_off < 0) { + printf("SEC Firmware: No '%s' in config\n", + SEC_FIRMWARE_FIT_IMAGE); + return -ENOLINK; + } + + /* Verify secure firmware image */ + if (!(fit_image_verify(sec_firmware_img, fw_node_off))) { + printf("SEC Firmware: Bad firmware image (bad CRC)\n"); + return -EINVAL; + } + + if (fit_image_get_data(sec_firmware_img, fw_node_off, data, size)) { + printf("SEC Firmware: Can't get %s subimage data/size", + SEC_FIRMWARE_FIT_IMAGE); + return -ENOENT; + } + + ret = fit_get_desc(sec_firmware_img, fw_node_off, &desc); + if (ret) + printf("SEC Firmware: Can't get description\n"); + else + printf("%s\n", desc); + + return ret; +} + +/* + * SEC Firmware FIT image parser checks if the image is in FIT + * format, verifies integrity of the image and calculates raw + * image address and size values. + * + * Returns 0 on success and a negative errno on error task fail. + */ +static int sec_firmware_parse_image(const void *sec_firmware_img, + const void **raw_image_addr, + size_t *raw_image_size) +{ + int ret; + + ret = sec_firmware_get_data(sec_firmware_img, raw_image_addr, + raw_image_size); + if (ret) + return ret; + + debug("SEC Firmware: raw_image_addr = 0x%p, raw_image_size = 0x%lx\n", + *raw_image_addr, *raw_image_size); + + return 0; +} + +static int sec_firmware_copy_image(const char *title, + u64 image_addr, u32 image_size, u64 sec_firmware) +{ + debug("%s copied to address 0x%p\n", title, (void *)sec_firmware); + memcpy((void *)sec_firmware, (void *)image_addr, image_size); + flush_dcache_range(sec_firmware, sec_firmware + image_size); + + return 0; +} + +/* + * This function will parse the SEC Firmware image, and then load it + * to secure memory. + */ +static int sec_firmware_load_image(const void *sec_firmware_img) +{ + const void *raw_image_addr; + size_t raw_image_size = 0; + int ret; + + /* + * The Excetpion Level must be EL3 to load and initialize + * the SEC Firmware. + */ + if (current_el() != 3) { + ret = -EACCES; + goto out; + } + +#ifdef CONFIG_SYS_MEM_RESERVE_SECURE + /* + * The SEC Firmware must be stored in secure memory. + * Append SEC Firmware to secure mmu table. + */ + if (!(gd->secure_ram & MEM_RESERVE_SECURE_MAINTAINED)) { + ret = -ENXIO; + goto out; + } + + sec_firmware_addr = (gd->secure_ram & MEM_RESERVE_SECURE_ADDR_MASK) + + gd->arch.tlb_size; +#else +#error "The CONFIG_SYS_MEM_RESERVE_SECURE must be defined when enabled SEC Firmware support" +#endif + + /* Align SEC Firmware base address to 4K */ + sec_firmware_addr = (sec_firmware_addr + 0xfff) & ~0xfff; + debug("SEC Firmware: Load address: 0x%llx\n", + sec_firmware_addr & SEC_FIRMWARE_ADDR_MASK); + + ret = sec_firmware_parse_image(sec_firmware_img, &raw_image_addr, + &raw_image_size); + if (ret) + goto out; + + /* TODO: + * Check if the end addr of SEC Firmware has been extend the secure + * memory. + */ + + /* Copy the secure firmware to secure memory */ + ret = sec_firmware_copy_image("SEC Firmware", (u64)raw_image_addr, + raw_image_size, sec_firmware_addr & + SEC_FIRMWARE_ADDR_MASK); + if (ret) + goto out; + + sec_firmware_addr |= SEC_FIRMWARE_LOADED; + debug("SEC Firmware: Entry point: 0x%llx\n", + sec_firmware_addr & SEC_FIRMWARE_ADDR_MASK); + + return 0; + +out: + printf("SEC Firmware: error (%d)\n", ret); + sec_firmware_addr = 0; + + return ret; +} + +static int sec_firmware_entry(u32 *eret_hold_l, u32 *eret_hold_h) +{ + const void *entry = (void *)(sec_firmware_addr & + SEC_FIRMWARE_ADDR_MASK); + + return _sec_firmware_entry(entry, eret_hold_l, eret_hold_h); +} + +/* Check the secure firmware FIT image */ +__weak bool sec_firmware_is_valid(const void *sec_firmware_img) +{ + if (fdt_check_header(sec_firmware_img)) { + printf("SEC Firmware: Bad firmware image (not a FIT image)\n"); + return false; + } + + if (!fit_check_format(sec_firmware_img)) { + printf("SEC Firmware: Bad firmware image (bad FIT header)\n"); + return false; + } + + return true; +} + +#ifdef CONFIG_ARMV8_PSCI +/* + * The PSCI_VERSION function is added from PSCI v0.2. When the PSCI + * v0.1 received this function, the NOT_SUPPORTED (0xffff_ffff) error + * number will be returned according to SMC Calling Conventions. But + * when getting the NOT_SUPPORTED error number, we cannot ensure if + * the PSCI version is v0.1 or other error occurred. So, PSCI v0.1 + * won't be supported by this framework. + * And if the secure firmware isn't running, return NOT_SUPPORTED. + * + * The return value on success is PSCI version in format + * major[31:16]:minor[15:0]. + */ +unsigned int sec_firmware_support_psci_version(void) +{ + if (sec_firmware_addr & SEC_FIRMWARE_RUNNING) + return _sec_firmware_support_psci_version(); + + return 0xffffffff; +} +#endif + +/* + * sec_firmware_init - Initialize the SEC Firmware + * @sec_firmware_img: the SEC Firmware image address + * @eret_hold_l: the address to hold exception return address low + * @eret_hold_h: the address to hold exception return address high + */ +int sec_firmware_init(const void *sec_firmware_img, + u32 *eret_hold_l, + u32 *eret_hold_h) +{ + int ret; + + if (!sec_firmware_is_valid(sec_firmware_img)) + return -EINVAL; + + ret = sec_firmware_load_image(sec_firmware_img); + if (ret) { + printf("SEC Firmware: Failed to load image\n"); + return ret; + } else if (sec_firmware_addr & SEC_FIRMWARE_LOADED) { + ret = sec_firmware_entry(eret_hold_l, eret_hold_h); + if (ret) { + printf("SEC Firmware: Failed to initialize\n"); + return ret; + } + } + + debug("SEC Firmware: Return from SEC Firmware: current_el = %d\n", + current_el()); + + /* + * The PE will be turned into target EL when returned from + * SEC Firmware. + */ + if (current_el() != SEC_FIRMWARE_TARGET_EL) + return -EACCES; + + sec_firmware_addr |= SEC_FIRMWARE_RUNNING; + + /* Set exception table and enable caches if it isn't EL3 */ + if (current_el() != 3) { + c_runtime_cpu_setup(); + enable_caches(); + } + + return 0; +} diff --git a/arch/arm/cpu/armv8/sec_firmware_asm.S b/arch/arm/cpu/armv8/sec_firmware_asm.S new file mode 100644 index 0000000..0c6a462 --- /dev/null +++ b/arch/arm/cpu/armv8/sec_firmware_asm.S @@ -0,0 +1,53 @@ +/* + * Copyright 2016 NXP Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <linux/linkage.h> +#include <asm/system.h> +#include <asm/macro.h> + +WEAK(_sec_firmware_entry) + /* + * x0: Secure Firmware entry point + * x1: Exception return address Low + * x2: Exception return address High + */ + + /* Save stack pointer for EL2 */ + mov x3, sp + msr sp_el2, x3 + + /* Set exception return address hold pointer */ + adr x4, 1f + mov x3, x4 +#ifdef SEC_FIRMWARE_ERET_ADDR_REVERT + rev w3, w3 +#endif + str w3, [x1] + lsr x3, x4, #32 +#ifdef SEC_FIRMWARE_ERET_ADDR_REVERT + rev w3, w3 +#endif + str w3, [x2] + + /* Call SEC monitor */ + br x0 + +1: + mov x0, #0 + ret +ENDPROC(_sec_firmware_entry) + +#ifdef CONFIG_ARMV8_PSCI +ENTRY(_sec_firmware_support_psci_version) + mov x0, 0x84000000 + mov x1, 0x0 + mov x2, 0x0 + mov x3, 0x0 + smc #0 + ret +ENDPROC(_sec_firmware_support_psci_version) +#endif diff --git a/arch/arm/include/asm/armv8/sec_firmware.h b/arch/arm/include/asm/armv8/sec_firmware.h new file mode 100644 index 0000000..39a1333 --- /dev/null +++ b/arch/arm/include/asm/armv8/sec_firmware.h @@ -0,0 +1,18 @@ +/* + * Copyright 2016 NXP Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __SEC_FIRMWARE_H_ +#define __SEC_FIRMWARE_H_ + +int sec_firmware_init(const void *, u32 *, u32 *); +int _sec_firmware_entry(const void *, u32 *, u32 *); +bool sec_firmware_is_valid(const void *); +#ifdef CONFIG_ARMV8_PSCI +unsigned int sec_firmware_support_psci_version(void); +unsigned int _sec_firmware_support_psci_version(void); +#endif + +#endif /* __SEC_FIRMWARE_H_ */
The FSL Primary Protected Application (PPA) is a software component loaded during boot which runs in TrustZone and remains resident after boot.
Use the secure firmware framework to integrate FSL PPA into U-Boot.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- V7: - No change.
V6: - Use the secure firmware framework to integrate PPA.
V5: - Added API sec_firmware_init() implementation.
V4: - Moved secure firmware validation API to this patch. - Moved secure firmware getting supported PSCI version API to this patch.
V3: - Refactor the code. - Add PPA firmware version info output.
arch/arm/cpu/armv8/fsl-layerscape/Makefile | 1 + arch/arm/cpu/armv8/fsl-layerscape/ppa.c | 48 ++++++++++++++++++++++++++ arch/arm/include/asm/arch-fsl-layerscape/ppa.h | 16 +++++++++ arch/arm/include/asm/armv8/sec_firmware.h | 4 +++ 4 files changed, 69 insertions(+) create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/ppa.c create mode 100644 arch/arm/include/asm/arch-fsl-layerscape/ppa.h
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Makefile b/arch/arm/cpu/armv8/fsl-layerscape/Makefile index eb2cbc3..bcf6b48 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Makefile +++ b/arch/arm/cpu/armv8/fsl-layerscape/Makefile @@ -10,6 +10,7 @@ obj-y += soc.o obj-$(CONFIG_MP) += mp.o obj-$(CONFIG_OF_LIBFDT) += fdt.o obj-$(CONFIG_SPL) += spl.o +obj-$(CONFIG_FSL_LS_PPA) += ppa.o
ifneq ($(CONFIG_FSL_LSCH3),) obj-y += fsl_lsch3_speed.o diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ppa.c b/arch/arm/cpu/armv8/fsl-layerscape/ppa.c new file mode 100644 index 0000000..541b251 --- /dev/null +++ b/arch/arm/cpu/armv8/fsl-layerscape/ppa.c @@ -0,0 +1,48 @@ +/* + * Copyright 2016 NXP Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <config.h> +#include <errno.h> +#include <asm/system.h> +#include <asm/types.h> +#include <asm/arch/soc.h> +#ifdef CONFIG_FSL_LSCH3 +#include <asm/arch/immap_lsch3.h> +#elif defined(CONFIG_FSL_LSCH2) +#include <asm/arch/immap_lsch2.h> +#endif +#ifdef CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT +#include <asm/armv8/sec_firmware.h> +#endif + +int ppa_init(void) +{ + const void *ppa_fit_addr; + u32 *boot_loc_ptr_l, *boot_loc_ptr_h; + int ret; + +#ifdef CONFIG_SYS_LS_PPA_FW_IN_NOR + ppa_fit_addr = (void *)CONFIG_SYS_LS_PPA_FW_ADDR; +#else +#error "No CONFIG_SYS_LS_PPA_FW_IN_xxx defined" +#endif + +#ifdef CONFIG_FSL_LSCH3 + struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + boot_loc_ptr_l = &gur->bootlocptrl; + boot_loc_ptr_h = &gur->bootlocptrh; +#elif defined(CONFIG_FSL_LSCH2) + struct ccsr_scfg __iomem *scfg = (void *)(CONFIG_SYS_FSL_SCFG_ADDR); + boot_loc_ptr_l = &scfg->scratchrw[1]; + boot_loc_ptr_h = &scfg->scratchrw[0]; +#endif + + debug("fsl-ppa: boot_loc_ptr_l = 0x%p, boot_loc_ptr_h =0x%p\n", + boot_loc_ptr_l, boot_loc_ptr_h); + ret = sec_firmware_init(ppa_fit_addr, boot_loc_ptr_l, boot_loc_ptr_h); + + return ret; +} diff --git a/arch/arm/include/asm/arch-fsl-layerscape/ppa.h b/arch/arm/include/asm/arch-fsl-layerscape/ppa.h new file mode 100644 index 0000000..1f1442b --- /dev/null +++ b/arch/arm/include/asm/arch-fsl-layerscape/ppa.h @@ -0,0 +1,16 @@ +/* + * Copyright 2016 NXP Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __FSL_PPA_H_ +#define __FSL_PPA_H_ + +#define SEC_FIRMWARE_FIT_IMAGE "firmware" +#define SEC_FIRMEWARE_FIT_CNF_NAME "config@1" +#define SEC_FIRMWARE_TARGET_EL 2 + +int ppa_init(void); + +#endif diff --git a/arch/arm/include/asm/armv8/sec_firmware.h b/arch/arm/include/asm/armv8/sec_firmware.h index 39a1333..eb68185 100644 --- a/arch/arm/include/asm/armv8/sec_firmware.h +++ b/arch/arm/include/asm/armv8/sec_firmware.h @@ -7,6 +7,10 @@ #ifndef __SEC_FIRMWARE_H_ #define __SEC_FIRMWARE_H_
+#ifdef CONFIG_FSL_LS_PPA +#include <asm/arch/ppa.h> +#endif + int sec_firmware_init(const void *, u32 *, u32 *); int _sec_firmware_entry(const void *, u32 *, u32 *); bool sec_firmware_is_valid(const void *);
If the PSCI and PPA is ready, skip the fixup for spin-table and waking secondary cores. Otherwise, change SMP method to spin-table, and the device node of PSCI will be removed.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- V7: - Removed the redundant "? true : false".
V6: - no change
V5: - Changed the checking if the PSCI feature is ready to read the psci version.
arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 16 +++++++++++++--- arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 33 +++++++++++++++++++++++++++++++++ 2 files changed, 46 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index d5bcf67..9cd6232 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -23,6 +23,9 @@ #ifdef CONFIG_FSL_ESDHC #include <fsl_esdhc.h> #endif +#ifdef CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT +#include <asm/armv8/sec_firmware.h> +#endif
@@ -622,6 +625,7 @@ int arch_early_init_r(void) { #ifdef CONFIG_MP int rv = 1; + u32 psci_ver = 0xffffffff; #endif
#ifdef CONFIG_SYS_FSL_ERRATUM_A009635 @@ -629,9 +633,15 @@ int arch_early_init_r(void) #endif
#ifdef CONFIG_MP - rv = fsl_layerscape_wake_seconday_cores(); - if (rv) - printf("Did not wake secondary cores\n"); +#if defined(CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT) && defined(CONFIG_ARMV8_PSCI) + /* Check the psci version to determine if the psci is supported */ + psci_ver = sec_firmware_support_psci_version(); +#endif + if (psci_ver == 0xffffffff) { + rv = fsl_layerscape_wake_seconday_cores(); + if (rv) + printf("Did not wake secondary cores\n"); + } #endif
#ifdef CONFIG_SYS_HAS_SERDES diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c index d17227a..40d6a76 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c @@ -22,6 +22,9 @@ #endif #include <fsl_sec.h> #include <asm/arch-fsl-layerscape/soc.h> +#ifdef CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT +#include <asm/armv8/sec_firmware.h> +#endif
int fdt_fixup_phy_connection(void *blob, int offset, phy_interface_t phyc) { @@ -38,7 +41,37 @@ void ft_fixup_cpu(void *blob) int addr_cells; u64 val, core_id; size_t *boot_code_size = &(__secondary_boot_code_size); +#if defined(CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT) && defined(CONFIG_ARMV8_PSCI) + int node; + u32 psci_ver; + + /* Check the psci version to determine if the psci is supported */ + psci_ver = sec_firmware_support_psci_version(); + if (psci_ver == 0xffffffff) { + /* remove psci DT node */ + node = fdt_path_offset(blob, "/psci"); + if (node >= 0) + goto remove_psci_node; + + node = fdt_node_offset_by_compatible(blob, -1, "arm,psci"); + if (node >= 0) + goto remove_psci_node; + + node = fdt_node_offset_by_compatible(blob, -1, "arm,psci-0.2"); + if (node >= 0) + goto remove_psci_node;
+ node = fdt_node_offset_by_compatible(blob, -1, "arm,psci-1.0"); + if (node >= 0) + goto remove_psci_node; + +remove_psci_node: + if (node >= 0) + fdt_del_node(blob, node); + } else { + return; + } +#endif off = fdt_path_offset(blob, "/cpus"); if (off < 0) { puts("couldn't find /cpus node\n");
Set the enable-method in the cpu node to PSCI, and create device node for PSCI, when PSCI was enabled.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- V7: - Moved the PSCI device node fixup code of both armv7 and armv8 to arch/arm/lib/psci-dt.c. - Added PSCI_VERSION check if secure firmware is supported. - Changed the default PSCI version to v0.1.
V6: - Removed PSCI version 0.1 support.
V5: - Moved the weak func sec_firmware_support_psci_version to sec_firmware.c. - Correct the PSCI version value in switch-case. The right version format is marjor[31:16]:minor[15:0].
arch/arm/cpu/armv7/virt-dt.c | 63 ---------------------- arch/arm/cpu/armv8/Makefile | 1 + arch/arm/cpu/armv8/cpu-dt.c | 31 +++++++++++ arch/arm/include/asm/psci.h | 1 + arch/arm/lib/Makefile | 2 + arch/arm/lib/bootm-fdt.c | 2 +- arch/arm/lib/psci-dt.c | 123 +++++++++++++++++++++++++++++++++++++++++++ 7 files changed, 159 insertions(+), 64 deletions(-) create mode 100644 arch/arm/cpu/armv8/cpu-dt.c create mode 100644 arch/arm/lib/psci-dt.c
diff --git a/arch/arm/cpu/armv7/virt-dt.c b/arch/arm/cpu/armv7/virt-dt.c index 32c368f..707dad4 100644 --- a/arch/arm/cpu/armv7/virt-dt.c +++ b/arch/arm/cpu/armv7/virt-dt.c @@ -26,69 +26,6 @@ #include <asm/armv7.h> #include <asm/psci.h>
-static int fdt_psci(void *fdt) -{ -#ifdef CONFIG_ARMV7_PSCI - int nodeoff; - int tmp; - - nodeoff = fdt_path_offset(fdt, "/cpus"); - if (nodeoff < 0) { - printf("couldn't find /cpus\n"); - return nodeoff; - } - - /* add 'enable-method = "psci"' to each cpu node */ - for (tmp = fdt_first_subnode(fdt, nodeoff); - tmp >= 0; - tmp = fdt_next_subnode(fdt, tmp)) { - const struct fdt_property *prop; - int len; - - prop = fdt_get_property(fdt, tmp, "device_type", &len); - if (!prop) - continue; - if (len < 4) - continue; - if (strcmp(prop->data, "cpu")) - continue; - - fdt_setprop_string(fdt, tmp, "enable-method", "psci"); - } - - nodeoff = fdt_path_offset(fdt, "/psci"); - if (nodeoff < 0) { - nodeoff = fdt_path_offset(fdt, "/"); - if (nodeoff < 0) - return nodeoff; - - nodeoff = fdt_add_subnode(fdt, nodeoff, "psci"); - if (nodeoff < 0) - return nodeoff; - } - - tmp = fdt_setprop_string(fdt, nodeoff, "compatible", "arm,psci"); - if (tmp) - return tmp; - tmp = fdt_setprop_string(fdt, nodeoff, "method", "smc"); - if (tmp) - return tmp; - tmp = fdt_setprop_u32(fdt, nodeoff, "cpu_suspend", ARM_PSCI_FN_CPU_SUSPEND); - if (tmp) - return tmp; - tmp = fdt_setprop_u32(fdt, nodeoff, "cpu_off", ARM_PSCI_FN_CPU_OFF); - if (tmp) - return tmp; - tmp = fdt_setprop_u32(fdt, nodeoff, "cpu_on", ARM_PSCI_FN_CPU_ON); - if (tmp) - return tmp; - tmp = fdt_setprop_u32(fdt, nodeoff, "migrate", ARM_PSCI_FN_MIGRATE); - if (tmp) - return tmp; -#endif - return 0; -} - int armv7_apply_memory_carveout(u64 *start, u64 *size) { #ifdef CONFIG_ARMV7_SECURE_RESERVE_SIZE diff --git a/arch/arm/cpu/armv8/Makefile b/arch/arm/cpu/armv8/Makefile index ee9e009..33e6db0 100644 --- a/arch/arm/cpu/armv8/Makefile +++ b/arch/arm/cpu/armv8/Makefile @@ -15,6 +15,7 @@ obj-y += cache.o obj-y += tlb.o obj-y += transition.o obj-y += fwcall.o +obj-y += cpu-dt.o obj-$(CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT) += sec_firmware.o sec_firmware_asm.o
obj-$(CONFIG_FSL_LAYERSCAPE) += fsl-layerscape/ diff --git a/arch/arm/cpu/armv8/cpu-dt.c b/arch/arm/cpu/armv8/cpu-dt.c new file mode 100644 index 0000000..9ffb49c --- /dev/null +++ b/arch/arm/cpu/armv8/cpu-dt.c @@ -0,0 +1,31 @@ +/* + * Copyright 2016 NXP Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/psci.h> +#ifdef CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT +#include <asm/armv8/sec_firmware.h> +#endif + +int psci_update_dt(void *fdt) +{ +#ifdef CONFIG_MP +#if defined(CONFIG_ARMV8_PSCI) +#ifdef CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT + /* + * If the PSCI in SEC Firmware didn't work, avoid to update the + * device node of PSCI. But still return 0 instead of an error + * number to support detecting PSCI dynamically and then switching + * the SMP boot method between PSCI and spin-table. + */ + if (sec_firmware_support_psci_version() == 0xffffffff) + return 0; +#endif + fdt_psci(fdt); +#endif +#endif + return 0; +} diff --git a/arch/arm/include/asm/psci.h b/arch/arm/include/asm/psci.h index bc5edda..f92633b 100644 --- a/arch/arm/include/asm/psci.h +++ b/arch/arm/include/asm/psci.h @@ -57,6 +57,7 @@ void psci_cpu_off_common(void);
int psci_update_dt(void *fdt); void psci_board_init(void); +int fdt_psci(void *fdt); #endif /* ! __ASSEMBLY__ */
#endif /* __ARM_PSCI_H__ */ diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index 0e05e87..f406419 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -55,6 +55,8 @@ ifndef CONFIG_ARM64 obj-y += cache-cp15.o endif
+obj-y += psci-dt.o + obj-$(CONFIG_DEBUG_LL) += debug.o
# For EABI conformant tool chains, provide eabi_compat() diff --git a/arch/arm/lib/bootm-fdt.c b/arch/arm/lib/bootm-fdt.c index 76b75d8..fe5b488 100644 --- a/arch/arm/lib/bootm-fdt.c +++ b/arch/arm/lib/bootm-fdt.c @@ -45,7 +45,7 @@ int arch_fixup_fdt(void *blob) if (ret) return ret;
-#ifdef CONFIG_ARMV7_NONSEC +#if defined(CONFIG_ARMV7_NONSEC) || defined(CONFIG_ARMV8_PSCI) ret = psci_update_dt(blob); if (ret) return ret; diff --git a/arch/arm/lib/psci-dt.c b/arch/arm/lib/psci-dt.c new file mode 100644 index 0000000..8dc31d4 --- /dev/null +++ b/arch/arm/lib/psci-dt.c @@ -0,0 +1,123 @@ +/* + * Copyright 2016 NXP Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <libfdt.h> +#include <fdt_support.h> +#include <linux/sizes.h> +#include <linux/kernel.h> +#include <asm/psci.h> +#ifdef CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT +#include <asm/armv8/sec_firmware.h> +#endif + +int fdt_psci(void *fdt) +{ +#if defined(CONFIG_ARMV8_PSCI) || defined(CONFIG_ARMV7_PSCI) + int nodeoff; + unsigned int psci_ver = 0; + char *psci_compt; + int tmp; + + nodeoff = fdt_path_offset(fdt, "/cpus"); + if (nodeoff < 0) { + printf("couldn't find /cpus\n"); + return nodeoff; + } + + /* add 'enable-method = "psci"' to each cpu node */ + for (tmp = fdt_first_subnode(fdt, nodeoff); + tmp >= 0; + tmp = fdt_next_subnode(fdt, tmp)) { + const struct fdt_property *prop; + int len; + + prop = fdt_get_property(fdt, tmp, "device_type", &len); + if (!prop) + continue; + if (len < 4) + continue; + if (strcmp(prop->data, "cpu")) + continue; + + /* + * Not checking rv here, our approach is to skip over errors in + * individual cpu nodes, hopefully some of the nodes are + * processed correctly and those will boot + */ + fdt_setprop_string(fdt, tmp, "enable-method", "psci"); + } + + /* + * The PSCI node might be called "/psci" or might be called something + * else but contain either of the compatible strings + * "arm,psci"/"arm,psci-0.2" + */ + nodeoff = fdt_path_offset(fdt, "/psci"); + if (nodeoff >= 0) + goto init_psci_node; + + nodeoff = fdt_node_offset_by_compatible(fdt, -1, "arm,psci"); + if (nodeoff >= 0) + goto init_psci_node; + + nodeoff = fdt_node_offset_by_compatible(fdt, -1, "arm,psci-0.2"); + if (nodeoff >= 0) + goto init_psci_node; + + nodeoff = fdt_node_offset_by_compatible(fdt, -1, "arm,psci-1.0"); + if (nodeoff >= 0) + goto init_psci_node; + + nodeoff = fdt_path_offset(fdt, "/"); + if (nodeoff < 0) + return nodeoff; + + nodeoff = fdt_add_subnode(fdt, nodeoff, "psci"); + if (nodeoff < 0) + return nodeoff; + +init_psci_node: +#ifdef CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT + psci_ver = sec_firmware_support_psci_version(); +#endif + switch (psci_ver) { + case 0x00010000: + psci_compt = "arm,psci-1.0"; + break; + case 0x00000002: + psci_compt = "arm,psci-0.2"; + break; + default: + psci_compt = "arm,psci"; + break; + } + + tmp = fdt_setprop_string(fdt, nodeoff, "compatible", psci_compt); + if (tmp) + return tmp; + tmp = fdt_setprop_string(fdt, nodeoff, "method", "smc"); + if (tmp) + return tmp; + +#ifdef CONFIG_ARMV7_PSCI + tmp = fdt_setprop_u32(fdt, nodeoff, "cpu_suspend", + ARM_PSCI_FN_CPU_SUSPEND); + if (tmp) + return tmp; + tmp = fdt_setprop_u32(fdt, nodeoff, "cpu_off", ARM_PSCI_FN_CPU_OFF); + if (tmp) + return tmp; + tmp = fdt_setprop_u32(fdt, nodeoff, "cpu_on", ARM_PSCI_FN_CPU_ON); + if (tmp) + return tmp; + tmp = fdt_setprop_u32(fdt, nodeoff, "migrate", ARM_PSCI_FN_MIGRATE); + if (tmp) + return tmp; +#endif +#endif + return 0; +}
The PPA use PSCI to make secondary cores bootup. So when PPA was enabled, add the CONFIG_ARMV8_PSCI to identify the SMP boot-method between PSCI and spin-table.
V6: - Refactor the integration of PPA.
V5: - Merged the 7th patch of this patchset in v4 to this patch. - Enalbed secure monitor framework support.
V4: - Reordered this patch. - Added checking the returned value of func ppa_init_pre().
board/freescale/ls1043ardb/ls1043ardb.c | 8 +++++++- include/configs/ls1043ardb.h | 11 +++++++++++ 2 files changed, 18 insertions(+), 1 deletion(-)
diff --git a/board/freescale/ls1043ardb/ls1043ardb.c b/board/freescale/ls1043ardb/ls1043ardb.c index 1436520..d3e37b4 100644 --- a/board/freescale/ls1043ardb/ls1043ardb.c +++ b/board/freescale/ls1043ardb/ls1043ardb.c @@ -24,7 +24,9 @@ #ifdef CONFIG_U_QE #include <fsl_qe.h> #endif - +#ifdef CONFIG_FSL_LS_PPA +#include <asm/arch/ppa.h> +#endif
@@ -92,6 +94,10 @@ int board_init(void) enable_layerscape_ns_access(); #endif
+#ifdef CONFIG_FSL_LS_PPA + ppa_init(); +#endif + #ifdef CONFIG_U_QE u_qe_init(); #endif diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 94ddfb1..44f86fa 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -9,6 +9,17 @@
#include "ls1043a_common.h"
+#if defined(CONFIG_FSL_LS_PPA) +#define CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT +#define SEC_FIRMWARE_ERET_ADDR_REVERT +#define CONFIG_ARMV8_PSCI + +#define CONFIG_SYS_LS_PPA_FW_IN_NOR +#ifdef CONFIG_SYS_LS_PPA_FW_IN_NOR +#define CONFIG_SYS_LS_PPA_FW_ADDR 0x60500000 +#endif +#endif + #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO
V7:
- no change
This set is applied to fsl-qoriq master. Awaiting upstream. Thanks.
York
york sun
Zhiqiang Hou
