[U-Boot] [PATCH] video: Add support for Arm's Mali Display Processors
Add support for Arm Mali Display Processors DP500, DP550 and DP650. Only one layer is being used to display the console or boot logo, even if more layers are supported in the hardware.
Signed-off-by: Liviu Dudau liviu.dudau@foss.arm.com --- drivers/video/Kconfig | 8 + drivers/video/Makefile | 1 + drivers/video/mali_dp.c | 387 ++++++++++++++++++++++++++++++++++++++++ 3 files changed, 396 insertions(+) create mode 100644 drivers/video/mali_dp.c
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 9f21ef30a9..66fc6641af 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -496,6 +496,14 @@ config VIDEO_FSL_DCU_MAX_FB_SIZE_MB
source "drivers/video/rockchip/Kconfig"
+config VIDEO_ARM_MALIDP + bool "Enable Arm Mali Display Processor support" + depends on DM_VIDEO && OF_CONTROL + select VEXPRESS_CLK + help + This enables support for Arm Ltd Mali Display Processors from + the DP500, DP550 and DP650 family. + config VIDEO_SANDBOX_SDL bool "Enable sandbox video console using SDL" depends on SANDBOX diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 4c130e179d..e19e6dad1f 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -35,6 +35,7 @@ obj-$(CONFIG_NXP_TDA19988) += tda19988.o obj-$(CONFIG_PXA_LCD) += pxa_lcd.o obj-$(CONFIG_S6E8AX0) += s6e8ax0.o obj-$(CONFIG_SCF0403_LCD) += scf0403_lcd.o +obj-$(CONFIG_VIDEO_ARM_MALIDP) += mali_dp.o obj-$(CONFIG_VIDEO_BCM2835) += bcm2835.o obj-$(CONFIG_VIDEO_BROADWELL_IGD) += broadwell_igd.o obj-$(CONFIG_VIDEO_COREBOOT) += coreboot.o diff --git a/drivers/video/mali_dp.c b/drivers/video/mali_dp.c new file mode 100644 index 0000000000..8e830e0fae --- /dev/null +++ b/drivers/video/mali_dp.c @@ -0,1 +1,387 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2016-2018 ARM Ltd. + * Author: Liviu Dudau liviu.dudau@foss.arm.com + * + */ +#define DEBUG +#include <common.h> +#include <video.h> +#include <dm.h> +#ifdef CONFIG_DISPLAY +#include <display.h> +#endif +#include <fdtdec.h> +#include <asm/io.h> +#include <os.h> +#include <fdt_support.h> +#include <clk.h> +#include <linux/sizes.h> + +#define MALIDP_CORE_ID 0x0018 +#define MALIDP_REG_BG_COLOR 0x0044 +#define MALIDP_LAYER_LV1 0x0100 +#define MALIDP_DC_STATUS 0xc000 +#define MALIDP_DC_CONTROL 0xc010 +#define MALIDP_DC_CFG_VALID 0xc014 + +/* offsets inside the modesetting register block */ +#define MALIDP_H_INTERVALS 0x0000 +#define MALIDP_V_INTERVALS 0x0004 +#define MALIDP_SYNC_CONTROL 0x0008 +#define MALIDP_HV_ACTIVESIZE 0x000c +#define MALIDP_OUTPUT_DEPTH 0x001c + +/* offsets inside the layer register block */ +#define MALIDP_LAYER_FORMAT 0x0000 +#define MALIDP_LAYER_CONTROL 0x0004 +#define MALIDP_LAYER_IN_SIZE 0x000c +#define MALIDP_LAYER_CMP_SIZE 0x0010 +#define MALIDP_LAYER_STRIDE 0x0018 +#define MALIDP_LAYER_PTR_LOW 0x0024 +#define MALIDP_LAYER_PTR_HIGH 0x0028 + +/* offsets inside the IRQ control blocks */ +#define MALIDP_REG_MASKIRQ 0x0008 +#define MALIDP_REG_CLEARIRQ 0x000c + +#define M1BITS 0x0001 +#define M2BITS 0x0003 +#define M4BITS 0x000f +#define M8BITS 0x00ff +#define M10BITS 0x03ff +#define M12BITS 0x0fff +#define M13BITS 0x1fff +#define M16BITS 0xffff +#define M17BITS 0x1ffff + +#define MALIDP_H_FRONTPORCH(x) (((x) & M12BITS) << 0) +#define MALIDP_H_BACKPORCH(x) (((x) & M10BITS) << 16) +#define MALIDP_V_FRONTPORCH(x) (((x) & M12BITS) << 0) +#define MALIDP_V_BACKPORCH(x) (((x) & M8BITS) << 16) +#define MALIDP_H_SYNCWIDTH(x) (((x) & M10BITS) << 0) +#define MALIDP_V_SYNCWIDTH(x) (((x) & M8BITS) << 16) +#define MALIDP_H_ACTIVE(x) (((x) & M13BITS) << 0) +#define MALIDP_V_ACTIVE(x) (((x) & M13BITS) << 16) + +#define MALIDP_CMP_V_SIZE(x) (((x) & M13BITS) << 16) +#define MALIDP_CMP_H_SIZE(x) (((x) & M13BITS) << 0) + +#define MALIDP_IN_V_SIZE(x) (((x) & M13BITS) << 16) +#define MALIDP_IN_H_SIZE(x) (((x) & M13BITS) << 0) + +#define MALIDP_DC_CM_CONTROL(x) ((x) & M1BITS) << 16, 1 << 16 +#define MALIDP_DC_STATUS_GET_CM(reg) (((reg) >> 16) & M1BITS) + +#define MALIDP_FORMAT_ARGB8888 0x08 +#define MALIDP_DEFAULT_BG_R 0x0 +#define MALIDP_DEFAULT_BG_G 0x0 +#define MALIDP_DEFAULT_BG_B 0x0 + +#define MALIDP_PRODUCT_ID(core_id) ((u32)(core_id) >> 16) + +#define MALIDP500 0x500 + +DECLARE_GLOBAL_DATA_PTR; + +struct malidp_priv { + phys_addr_t base_addr; + phys_addr_t dc_status_addr; + phys_addr_t dc_control_addr; + phys_addr_t cval_addr; + struct udevice *display; /* display device attached */ + struct clk aclk; + struct clk pxlclk; + u16 modeset_regs_offset; + u8 config_bit_shift; + u8 clear_irq; /* offset for IRQ clear register */ +}; + +static const struct video_ops malidp_ops = { +}; + +static int malidp_get_hwid(phys_addr_t base_addr) +{ + int hwid; + + /* reading from the old CORE_ID offset will only be 0x5000000 on DP500 */ + hwid = readl(base_addr + MALIDP_CORE_ID); + if (MALIDP_PRODUCT_ID(hwid) == MALIDP500) + return hwid; + /* otherwise try the other gen CORE_ID offset */ + hwid = readl(base_addr + MALIDP_DC_STATUS + MALIDP_CORE_ID); + + return hwid; +} + +/* + * wait for config mode bit setup to be acted upon by the hardware + */ +static int malidp_wait_configdone(struct malidp_priv *malidp) +{ + u32 status, tries = 300; + + while (tries--) { + status = readl(malidp->dc_status_addr); + if ((status >> malidp->config_bit_shift) & 1) + break; + udelay(500); + } + + if (!tries) + return -ETIMEDOUT; + + return 0; +} + +/* + * signal the hardware to enter configuration mode + */ +static int malidp_enter_config(struct malidp_priv *malidp) +{ + setbits_le32(malidp->dc_control_addr, 1 << malidp->config_bit_shift); + return malidp_wait_configdone(malidp); +} + +/* + * signal the hardware to exit configuration mode + */ +static int malidp_leave_config(struct malidp_priv *malidp) +{ + clrbits_le32(malidp->dc_control_addr, 1 << malidp->config_bit_shift); + return malidp_wait_configdone(malidp); +} + +static void malidp_setup_timings(struct malidp_priv *malidp, struct display_timing *timings) +{ + u32 val = MALIDP_H_SYNCWIDTH(timings->hsync_len.typ) | + MALIDP_V_SYNCWIDTH(timings->vsync_len.typ); + writel(val, malidp->base_addr + malidp->modeset_regs_offset + MALIDP_SYNC_CONTROL); + val = MALIDP_H_BACKPORCH(timings->hback_porch.typ) | + MALIDP_H_FRONTPORCH(timings->hfront_porch.typ); + writel(val, malidp->base_addr + malidp->modeset_regs_offset + MALIDP_H_INTERVALS); + val = MALIDP_V_BACKPORCH(timings->vback_porch.typ) | + MALIDP_V_FRONTPORCH(timings->vfront_porch.typ); + writel(val, malidp->base_addr + malidp->modeset_regs_offset + MALIDP_V_INTERVALS); + val = MALIDP_H_ACTIVE(timings->hactive.typ) | + MALIDP_V_ACTIVE(timings->vactive.typ); + writel(val, malidp->base_addr + malidp->modeset_regs_offset + MALIDP_HV_ACTIVESIZE); + /* default output bit-depth per colour is 8 bits */ + writel(0x080808, malidp->base_addr + malidp->modeset_regs_offset + MALIDP_OUTPUT_DEPTH); +} + +static int malidp_setup_mode(struct malidp_priv *malidp, struct display_timing *timings) +{ + int err; + + if (clk_set_rate(&malidp->pxlclk, timings->pixelclock.typ) == 0) + return -EIO; + + malidp_setup_timings(malidp, timings); + + err = display_enable(malidp->display, 8, timings); + if (err) + printf("display_enable failed with %d\n", err); + + return err; +} + +static void malidp_setup_layer(struct malidp_priv *malidp, + struct display_timing *timings, + u32 layer_offset, phys_addr_t fb_addr) +{ + u32 val; + + /* setup the base layer's pixel format to A8R8G8B8 */ + writel(MALIDP_FORMAT_ARGB8888, malidp->base_addr + layer_offset + MALIDP_LAYER_FORMAT); + /* setup layer composition size */ + val = MALIDP_CMP_V_SIZE(timings->vactive.typ) | + MALIDP_CMP_H_SIZE(timings->hactive.typ); + writel(val, malidp->base_addr + layer_offset + MALIDP_LAYER_CMP_SIZE); + /* setup layer input size */ + val = MALIDP_IN_V_SIZE(timings->vactive.typ) | + MALIDP_IN_H_SIZE(timings->hactive.typ); + writel(val, malidp->base_addr + layer_offset + MALIDP_LAYER_IN_SIZE); + /* setup layer stride in bytes */ + writel(timings->hactive.typ << 2, malidp->base_addr + layer_offset + MALIDP_LAYER_STRIDE); + /* set framebuffer address */ + writel(lower_32_bits(fb_addr), malidp->base_addr + layer_offset + MALIDP_LAYER_PTR_LOW); + writel(upper_32_bits(fb_addr), malidp->base_addr + layer_offset + MALIDP_LAYER_PTR_HIGH); + /* enable layer */ + setbits_le32(malidp->base_addr + layer_offset + MALIDP_LAYER_CONTROL, 1); +} + +static void malidp_set_configvalid(struct malidp_priv *malidp) +{ + setbits_le32(malidp->cval_addr, 1); +} + +static int malidp_update_timings_from_edid(struct udevice *dev, + struct display_timing *timings) +{ +#ifdef CONFIG_DISPLAY + struct malidp_priv *priv = dev_get_priv(dev); + struct udevice *disp_dev; + int err; + + err = uclass_first_device(UCLASS_DISPLAY, &disp_dev); + if (err) + return err; + + priv->display = disp_dev; + + err = display_read_timing(disp_dev, timings); + if (err) + return err; + +#endif + return 0; +} + +static int malidp_probe(struct udevice *dev) +{ + struct video_priv *uc_priv = dev_get_uclass_priv(dev); + struct video_uc_platdata *uc_plat = dev_get_uclass_platdata(dev); + ofnode framebuffer = ofnode_find_subnode(dev_ofnode(dev), "framebuffer"); + struct malidp_priv *priv = dev_get_priv(dev); + struct display_timing timings; + phys_addr_t fb_base, fb_size; + const char *format; + u32 value; + + if (!ofnode_valid(framebuffer)) + return -EINVAL; + + int err = clk_get_by_name(dev, "pxlclk", &priv->pxlclk); + if (err) { + dev_err(dev, "failed to get pixel clock\n"); + return err; + } + err = clk_get_by_name(dev, "aclk", &priv->aclk); + if (err) { + dev_err(dev, "failed to get AXI clock\n"); + goto fail_aclk; + } + + err = ofnode_decode_display_timing(dev_ofnode(dev), 1, &timings); + if (err) { + dev_err(dev, "failed to get any display timings\n"); + goto fail_timings; + } + + err = malidp_update_timings_from_edid(dev, &timings); + if (err) { + printf("malidp_update_timings_from_edid failed: %d\n", err); + goto fail_timings; + } + + fb_base = ofnode_get_addr_size(framebuffer, "reg", &fb_size); + if (fb_base != FDT_ADDR_T_NONE) { + uc_plat->base = fb_base; + uc_plat->size = fb_size; + } else { + printf("cannot get address size for framebuffer\n"); + } + + err = ofnode_read_u32(framebuffer, "width", &value); + if (err) + goto fail_timings; + uc_priv->xsize = (ushort)value; + + err = ofnode_read_u32(framebuffer, "height", &value); + if (err) + goto fail_timings; + uc_priv->ysize = (ushort)value; + + format = ofnode_read_string(framebuffer, "format"); + if (!format) { + err = -EINVAL; + goto fail_timings; + } else if (!strncmp(format, "a8r8g8b8", 8)) { + uc_priv->bpix = VIDEO_BPP32; + } + + uc_priv->rot = 0; + priv->base_addr = (phys_addr_t)dev_read_addr(dev); + + clk_enable(&priv->pxlclk); + clk_enable(&priv->aclk); + + value = malidp_get_hwid(priv->base_addr); + printf("Display: Arm Mali DP%3x r%dp%d\n", MALIDP_PRODUCT_ID(value), + (value >> 12) & 0xf, (value >> 8) & 0xf); + + if (MALIDP_PRODUCT_ID(value) == MALIDP500) { + /* DP500 is special */ + priv->modeset_regs_offset = 0x28; + priv->dc_status_addr = priv->base_addr; + priv->dc_control_addr = priv->base_addr + 0xc; + priv->cval_addr = priv->base_addr + 0xf00; + priv->config_bit_shift = 17; + priv->clear_irq = 0; + } else { + priv->modeset_regs_offset = 0x30; + priv->dc_status_addr = priv->base_addr + MALIDP_DC_STATUS; + priv->dc_control_addr = priv->base_addr + MALIDP_DC_CONTROL; + priv->cval_addr = priv->base_addr + MALIDP_DC_CFG_VALID; + priv->config_bit_shift = 16; + priv->clear_irq = MALIDP_REG_CLEARIRQ; + } + + /* enter config mode */ + err = malidp_enter_config(priv); + if (err) + return err; + + /* disable interrupts */ + writel(0, priv->dc_status_addr + MALIDP_REG_MASKIRQ); + writel(0xffffffff, priv->dc_status_addr + priv->clear_irq); + + err = malidp_setup_mode(priv, &timings); + if (err) + goto fail_timings; + + malidp_setup_layer(priv, &timings, MALIDP_LAYER_LV1, (phys_addr_t)uc_plat->base); + + err = malidp_leave_config(priv); + if (err) + goto fail_timings; + + malidp_set_configvalid(priv); + + return 0; + +fail_timings: + clk_free(&priv->aclk); +fail_aclk: + clk_free(&priv->pxlclk); + + return err; +} + +static int malidp_bind(struct udevice *dev) +{ + struct video_uc_platdata *uc_plat = dev_get_uclass_platdata(dev); + + /* choose max possible size: 2K x 2K, XRGB framebuffer */ + uc_plat->size = 4 * 2048 * 2048; + + return 0; +} + +static const struct udevice_id malidp_ids[] = { + { .compatible = "arm,mali-dp500" }, + { .compatible = "arm,mali-dp550" }, + { .compatible = "arm,mali-dp650" }, + { } +}; + +U_BOOT_DRIVER(mali_dp) = { + .name = "mali_dp", + .id = UCLASS_VIDEO, + .of_match = malidp_ids, + .bind = malidp_bind, + .probe = malidp_probe, + .priv_auto_alloc_size = sizeof(struct malidp_priv), + .ops = &malidp_ops, +};
On Mon, 17 Sep 2018 17:56:46 +0100 Liviu Dudau Liviu.Dudau@foss.arm.com wrote:
Please check the patches using ./scripts/checkpatch.pl and fix errors/warnings where it makes sense. This patch has some issues, too.
Thanks,
-- Anatolij
Signed-off-by: Liviu Dudau liviu.dudau@foss.arm.com --- Changelog: - v2: Added MAINTAINERS entry and fixed checkpatch warnings.
MAINTAINERS | 6 + drivers/video/Kconfig | 8 + drivers/video/Makefile | 1 + drivers/video/mali_dp.c | 405 ++++++++++++++++++++++++++++++++++++++++ 4 files changed, 420 insertions(+) create mode 100644 drivers/video/mali_dp.c
diff --git a/MAINTAINERS b/MAINTAINERS index 112e41d2c3..fe08365ca8 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -449,6 +449,12 @@ F: cmd/log.c F: test/log/log_test.c F: test/py/tests/test_log.py
+MALI DISPLAY PROCESSORS +M: Liviu Dudau liviu.dudau@foss.arm.com +S: Supported +T: git git://github.com/ARM-software/u-boot.git +F: drivers/video/mali_dp.c + MICROBLAZE M: Michal Simek monstr@monstr.eu S: Maintained diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 5d932072a8..ccf7cf83ed 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -497,6 +497,14 @@ config VIDEO_FSL_DCU_MAX_FB_SIZE_MB
+config VIDEO_ARM_MALIDP + bool "Enable Arm Mali Display Processor support" + depends on DM_VIDEO && OF_CONTROL + select VEXPRESS_CLK + help + This enables support for Arm Ltd Mali Display Processors from + the DP500, DP550 and DP650 family. + config VIDEO_SANDBOX_SDL bool "Enable sandbox video console using SDL" depends on SANDBOX diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 4c130e179d..e19e6dad1f 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -35,6 +35,7 @@ obj-$(CONFIG_NXP_TDA19988) += tda19988.o obj-$(CONFIG_PXA_LCD) += pxa_lcd.o obj-$(CONFIG_S6E8AX0) += s6e8ax0.o obj-$(CONFIG_SCF0403_LCD) += scf0403_lcd.o +obj-$(CONFIG_VIDEO_ARM_MALIDP) += mali_dp.o obj-$(CONFIG_VIDEO_BCM2835) += bcm2835.o obj-$(CONFIG_VIDEO_BROADWELL_IGD) += broadwell_igd.o obj-$(CONFIG_VIDEO_COREBOOT) += coreboot.o diff --git a/drivers/video/mali_dp.c b/drivers/video/mali_dp.c new file mode 100644 index 0000000000..71151a87aa --- /dev/null +++ b/drivers/video/mali_dp.c @@ -0,0 +1,405 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2016-2018 ARM Ltd. + * Author: Liviu Dudau liviu.dudau@foss.arm.com + * + */ +#define DEBUG +#include <common.h> +#include <video.h> +#include <dm.h> +#ifdef CONFIG_DISPLAY +#include <display.h> +#endif +#include <fdtdec.h> +#include <asm/io.h> +#include <os.h> +#include <fdt_support.h> +#include <clk.h> +#include <linux/sizes.h> + +#define MALIDP_CORE_ID 0x0018 +#define MALIDP_REG_BG_COLOR 0x0044 +#define MALIDP_LAYER_LV1 0x0100 +#define MALIDP_DC_STATUS 0xc000 +#define MALIDP_DC_CONTROL 0xc010 +#define MALIDP_DC_CFG_VALID 0xc014 + +/* offsets inside the modesetting register block */ +#define MALIDP_H_INTERVALS 0x0000 +#define MALIDP_V_INTERVALS 0x0004 +#define MALIDP_SYNC_CONTROL 0x0008 +#define MALIDP_HV_ACTIVESIZE 0x000c +#define MALIDP_OUTPUT_DEPTH 0x001c + +/* offsets inside the layer register block */ +#define MALIDP_LAYER_FORMAT 0x0000 +#define MALIDP_LAYER_CONTROL 0x0004 +#define MALIDP_LAYER_IN_SIZE 0x000c +#define MALIDP_LAYER_CMP_SIZE 0x0010 +#define MALIDP_LAYER_STRIDE 0x0018 +#define MALIDP_LAYER_PTR_LOW 0x0024 +#define MALIDP_LAYER_PTR_HIGH 0x0028 + +/* offsets inside the IRQ control blocks */ +#define MALIDP_REG_MASKIRQ 0x0008 +#define MALIDP_REG_CLEARIRQ 0x000c + +#define M1BITS 0x0001 +#define M2BITS 0x0003 +#define M4BITS 0x000f +#define M8BITS 0x00ff +#define M10BITS 0x03ff +#define M12BITS 0x0fff +#define M13BITS 0x1fff +#define M16BITS 0xffff +#define M17BITS 0x1ffff + +#define MALIDP_H_FRONTPORCH(x) (((x) & M12BITS) << 0) +#define MALIDP_H_BACKPORCH(x) (((x) & M10BITS) << 16) +#define MALIDP_V_FRONTPORCH(x) (((x) & M12BITS) << 0) +#define MALIDP_V_BACKPORCH(x) (((x) & M8BITS) << 16) +#define MALIDP_H_SYNCWIDTH(x) (((x) & M10BITS) << 0) +#define MALIDP_V_SYNCWIDTH(x) (((x) & M8BITS) << 16) +#define MALIDP_H_ACTIVE(x) (((x) & M13BITS) << 0) +#define MALIDP_V_ACTIVE(x) (((x) & M13BITS) << 16) + +#define MALIDP_CMP_V_SIZE(x) (((x) & M13BITS) << 16) +#define MALIDP_CMP_H_SIZE(x) (((x) & M13BITS) << 0) + +#define MALIDP_IN_V_SIZE(x) (((x) & M13BITS) << 16) +#define MALIDP_IN_H_SIZE(x) (((x) & M13BITS) << 0) + +#define MALIDP_DC_CM_CONTROL(x) ((x) & M1BITS) << 16, 1 << 16 +#define MALIDP_DC_STATUS_GET_CM(reg) (((reg) >> 16) & M1BITS) + +#define MALIDP_FORMAT_ARGB8888 0x08 +#define MALIDP_DEFAULT_BG_R 0x0 +#define MALIDP_DEFAULT_BG_G 0x0 +#define MALIDP_DEFAULT_BG_B 0x0 + +#define MALIDP_PRODUCT_ID(core_id) ((u32)(core_id) >> 16) + +#define MALIDP500 0x500 + +DECLARE_GLOBAL_DATA_PTR; + +struct malidp_priv { + phys_addr_t base_addr; + phys_addr_t dc_status_addr; + phys_addr_t dc_control_addr; + phys_addr_t cval_addr; + struct udevice *display; /* display device attached */ + struct clk aclk; + struct clk pxlclk; + u16 modeset_regs_offset; + u8 config_bit_shift; + u8 clear_irq; /* offset for IRQ clear register */ +}; + +static const struct video_ops malidp_ops = { +}; + +static int malidp_get_hwid(phys_addr_t base_addr) +{ + int hwid; + + /* + * reading from the old CORE_ID offset will always + * return 0x5000000 on DP500 + */ + hwid = readl(base_addr + MALIDP_CORE_ID); + if (MALIDP_PRODUCT_ID(hwid) == MALIDP500) + return hwid; + /* otherwise try the other gen CORE_ID offset */ + hwid = readl(base_addr + MALIDP_DC_STATUS + MALIDP_CORE_ID); + + return hwid; +} + +/* + * wait for config mode bit setup to be acted upon by the hardware + */ +static int malidp_wait_configdone(struct malidp_priv *malidp) +{ + u32 status, tries = 300; + + while (tries--) { + status = readl(malidp->dc_status_addr); + if ((status >> malidp->config_bit_shift) & 1) + break; + udelay(500); + } + + if (!tries) + return -ETIMEDOUT; + + return 0; +} + +/* + * signal the hardware to enter configuration mode + */ +static int malidp_enter_config(struct malidp_priv *malidp) +{ + setbits_le32(malidp->dc_control_addr, 1 << malidp->config_bit_shift); + return malidp_wait_configdone(malidp); +} + +/* + * signal the hardware to exit configuration mode + */ +static int malidp_leave_config(struct malidp_priv *malidp) +{ + clrbits_le32(malidp->dc_control_addr, 1 << malidp->config_bit_shift); + return malidp_wait_configdone(malidp); +} + +static void malidp_setup_timings(struct malidp_priv *malidp, + struct display_timing *timings) +{ + u32 val = MALIDP_H_SYNCWIDTH(timings->hsync_len.typ) | + MALIDP_V_SYNCWIDTH(timings->vsync_len.typ); + writel(val, malidp->base_addr + malidp->modeset_regs_offset + + MALIDP_SYNC_CONTROL); + val = MALIDP_H_BACKPORCH(timings->hback_porch.typ) | + MALIDP_H_FRONTPORCH(timings->hfront_porch.typ); + writel(val, malidp->base_addr + malidp->modeset_regs_offset + + MALIDP_H_INTERVALS); + val = MALIDP_V_BACKPORCH(timings->vback_porch.typ) | + MALIDP_V_FRONTPORCH(timings->vfront_porch.typ); + writel(val, malidp->base_addr + malidp->modeset_regs_offset + + MALIDP_V_INTERVALS); + val = MALIDP_H_ACTIVE(timings->hactive.typ) | + MALIDP_V_ACTIVE(timings->vactive.typ); + writel(val, malidp->base_addr + malidp->modeset_regs_offset + + MALIDP_HV_ACTIVESIZE); + /* default output bit-depth per colour is 8 bits */ + writel(0x080808, malidp->base_addr + malidp->modeset_regs_offset + + MALIDP_OUTPUT_DEPTH); +} + +static int malidp_setup_mode(struct malidp_priv *malidp, + struct display_timing *timings) +{ + int err; + + if (clk_set_rate(&malidp->pxlclk, timings->pixelclock.typ) == 0) + return -EIO; + + malidp_setup_timings(malidp, timings); + + err = display_enable(malidp->display, 8, timings); + if (err) + printf("display_enable failed with %d\n", err); + + return err; +} + +static void malidp_setup_layer(struct malidp_priv *malidp, + struct display_timing *timings, + u32 layer_offset, phys_addr_t fb_addr) +{ + u32 val; + + /* setup the base layer's pixel format to A8R8G8B8 */ + writel(MALIDP_FORMAT_ARGB8888, malidp->base_addr + layer_offset + + MALIDP_LAYER_FORMAT); + /* setup layer composition size */ + val = MALIDP_CMP_V_SIZE(timings->vactive.typ) | + MALIDP_CMP_H_SIZE(timings->hactive.typ); + writel(val, malidp->base_addr + layer_offset + + MALIDP_LAYER_CMP_SIZE); + /* setup layer input size */ + val = MALIDP_IN_V_SIZE(timings->vactive.typ) | + MALIDP_IN_H_SIZE(timings->hactive.typ); + writel(val, malidp->base_addr + layer_offset + MALIDP_LAYER_IN_SIZE); + /* setup layer stride in bytes */ + writel(timings->hactive.typ << 2, malidp->base_addr + layer_offset + + MALIDP_LAYER_STRIDE); + /* set framebuffer address */ + writel(lower_32_bits(fb_addr), malidp->base_addr + layer_offset + + MALIDP_LAYER_PTR_LOW); + writel(upper_32_bits(fb_addr), malidp->base_addr + layer_offset + + MALIDP_LAYER_PTR_HIGH); + /* enable layer */ + setbits_le32(malidp->base_addr + layer_offset + + MALIDP_LAYER_CONTROL, 1); +} + +static void malidp_set_configvalid(struct malidp_priv *malidp) +{ + setbits_le32(malidp->cval_addr, 1); +} + +static int malidp_update_timings_from_edid(struct udevice *dev, + struct display_timing *timings) +{ +#ifdef CONFIG_DISPLAY + struct malidp_priv *priv = dev_get_priv(dev); + struct udevice *disp_dev; + int err; + + err = uclass_first_device(UCLASS_DISPLAY, &disp_dev); + if (err) + return err; + + priv->display = disp_dev; + + err = display_read_timing(disp_dev, timings); + if (err) + return err; + +#endif + return 0; +} + +static int malidp_probe(struct udevice *dev) +{ + struct video_priv *uc_priv = dev_get_uclass_priv(dev); + struct video_uc_platdata *uc_plat = dev_get_uclass_platdata(dev); + ofnode framebuffer = ofnode_find_subnode(dev_ofnode(dev), "framebuffer"); + struct malidp_priv *priv = dev_get_priv(dev); + struct display_timing timings; + phys_addr_t fb_base, fb_size; + const char *format; + u32 value; + int err; + + if (!ofnode_valid(framebuffer)) + return -EINVAL; + + err = clk_get_by_name(dev, "pxlclk", &priv->pxlclk); + if (err) { + dev_err(dev, "failed to get pixel clock\n"); + return err; + } + err = clk_get_by_name(dev, "aclk", &priv->aclk); + if (err) { + dev_err(dev, "failed to get AXI clock\n"); + goto fail_aclk; + } + + err = ofnode_decode_display_timing(dev_ofnode(dev), 1, &timings); + if (err) { + dev_err(dev, "failed to get any display timings\n"); + goto fail_timings; + } + + err = malidp_update_timings_from_edid(dev, &timings); + if (err) { + printf("malidp_update_timings_from_edid failed: %d\n", err); + goto fail_timings; + } + + fb_base = ofnode_get_addr_size(framebuffer, "reg", &fb_size); + if (fb_base != FDT_ADDR_T_NONE) { + uc_plat->base = fb_base; + uc_plat->size = fb_size; + } else { + printf("cannot get address size for framebuffer\n"); + } + + err = ofnode_read_u32(framebuffer, "width", &value); + if (err) + goto fail_timings; + uc_priv->xsize = (ushort)value; + + err = ofnode_read_u32(framebuffer, "height", &value); + if (err) + goto fail_timings; + uc_priv->ysize = (ushort)value; + + format = ofnode_read_string(framebuffer, "format"); + if (!format) { + err = -EINVAL; + goto fail_timings; + } else if (!strncmp(format, "a8r8g8b8", 8)) { + uc_priv->bpix = VIDEO_BPP32; + } + + uc_priv->rot = 0; + priv->base_addr = (phys_addr_t)dev_read_addr(dev); + + clk_enable(&priv->pxlclk); + clk_enable(&priv->aclk); + + value = malidp_get_hwid(priv->base_addr); + printf("Display: Arm Mali DP%3x r%dp%d\n", MALIDP_PRODUCT_ID(value), + (value >> 12) & 0xf, (value >> 8) & 0xf); + + if (MALIDP_PRODUCT_ID(value) == MALIDP500) { + /* DP500 is special */ + priv->modeset_regs_offset = 0x28; + priv->dc_status_addr = priv->base_addr; + priv->dc_control_addr = priv->base_addr + 0xc; + priv->cval_addr = priv->base_addr + 0xf00; + priv->config_bit_shift = 17; + priv->clear_irq = 0; + } else { + priv->modeset_regs_offset = 0x30; + priv->dc_status_addr = priv->base_addr + MALIDP_DC_STATUS; + priv->dc_control_addr = priv->base_addr + MALIDP_DC_CONTROL; + priv->cval_addr = priv->base_addr + MALIDP_DC_CFG_VALID; + priv->config_bit_shift = 16; + priv->clear_irq = MALIDP_REG_CLEARIRQ; + } + + /* enter config mode */ + err = malidp_enter_config(priv); + if (err) + return err; + + /* disable interrupts */ + writel(0, priv->dc_status_addr + MALIDP_REG_MASKIRQ); + writel(0xffffffff, priv->dc_status_addr + priv->clear_irq); + + err = malidp_setup_mode(priv, &timings); + if (err) + goto fail_timings; + + malidp_setup_layer(priv, &timings, MALIDP_LAYER_LV1, + (phys_addr_t)uc_plat->base); + + err = malidp_leave_config(priv); + if (err) + goto fail_timings; + + malidp_set_configvalid(priv); + + return 0; + +fail_timings: + clk_free(&priv->aclk); +fail_aclk: + clk_free(&priv->pxlclk); + + return err; +} + +static int malidp_bind(struct udevice *dev) +{ + struct video_uc_platdata *uc_plat = dev_get_uclass_platdata(dev); + + /* choose max possible size: 2K x 2K, XRGB888 framebuffer */ + uc_plat->size = 4 * 2048 * 2048; + + return 0; +} + +static const struct udevice_id malidp_ids[] = { + { .compatible = "arm,mali-dp500" }, + { .compatible = "arm,mali-dp550" }, + { .compatible = "arm,mali-dp650" }, + { } +}; + +U_BOOT_DRIVER(mali_dp) = { + .name = "mali_dp", + .id = UCLASS_VIDEO, + .of_match = malidp_ids, + .bind = malidp_bind, + .probe = malidp_probe, + .priv_auto_alloc_size = sizeof(struct malidp_priv), + .ops = &malidp_ops, +};
On Fri, 28 Sep 2018 13:50:53 +0100 Liviu Dudau Liviu.Dudau@foss.arm.com wrote:
Changelog:
Applied to u-boot-video/master, thanks!
-- Anatolij
Anatolij Gustschin
Liviu Dudau
