[U-Boot] [PATCH] armv8: fix gd after relocation
Commit 21f4486faa5d ("armv8: update gd after relocate") sets x18 without checking the return value of spl_relocate_stack_gd().
Signed-off-by: York Sun york.sun@nxp.com CC: Kever Yang kever.yang@rock-chips.com CC: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
arch/arm/lib/crt0_64.S | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/arch/arm/lib/crt0_64.S b/arch/arm/lib/crt0_64.S index ccefce0..9cb7055 100644 --- a/arch/arm/lib/crt0_64.S +++ b/arch/arm/lib/crt0_64.S @@ -120,8 +120,9 @@ relocation_return: #endif /* !CONFIG_SPL_BUILD */ #if defined(CONFIG_SPL_BUILD) bl spl_relocate_stack_gd /* may return NULL */ - /* set up gd here, outside any C code */ - mov x18, x0 + /* set up gd here, outside any C code, if new stack is returned */ + cmp x0, #0 + csel x18, x0, x18, ne /* * Perform 'sp = (x0 != NULL) ? x0 : sp' while working * around the constraint that conditional moves can not
Reviewed-by: Stephen Warren swarren@nvidia.com
This matches what the 32-bit ARM code does, so I guess it's right.
Stephen Warren
York Sun
