[U-Boot-Users] RE: Trouble booting uboot on 440GX (ocotea) eval board afterinitial power-up boot
What works is using a supported flash device. I had swapped out the AMD parts for SST 39VF040. They program like AMDs but the sector sizes are different. Putting in the AMDs and re-flashing U-Boot solved the problem.
Thanks to all,
Marc W. Howard
-----Original Message----- From: David Adair [mailto:dadair@ariodata.com] Sent: Friday, November 12, 2004 3:47 PM To: Howard, Marc Cc: u-boot-users@lists.sourceforge.net Subject: RE: Trouble booting uboot on 440GX (ocotea) eval board afterinitial power-up boot
-----Original Message----- On Thu, Nov 11, 2004 at 06:19:02PM -0800, Howard, Marc wrote:
I've built and installed U-Boot 1.1.2 on an IBM 440GX eval board (ocotea). After powering the board I can get the uboot interactive prompt. If I type 'reset' or hit the reset button it hangs. I get
the
same results whether or not I use the BDI2000. Doing a power cycle
of
the board is the only way to get back to the prompt.
Is there some reconfiguation U-Boot does that causes the processor
boot
address to change after the initial power-up? Am I missing
something
here?
You might find more help on the u-boot users list.
-Matt
Does resetting the SDRAM controller help?
http://sourceforge.net/mailarchive/forum.php?thread_id=5843422&forum_id= 1289 8
Howard, Marc
