[PATCH] doc: Move the generic memory-documentation to doc/
Move this section of the README into doc/ with some minor updates to mention SPL and user lower-case hex.
README | 45 ------------------------------------------ doc/develop/index.rst | 1 + doc/develop/memory.rst | 45 ++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 46 insertions(+), 45 deletions(-) create mode 100644 doc/develop/memory.rst
diff --git a/README b/README index 4be1e8c22a0..d73042406b6 100644 --- a/README +++ b/README @@ -2516,51 +2516,6 @@ On RISC-V, the following registers are used:
==> U-Boot will use gp to hold a pointer to the global data
-Memory Management: ------------------- - -U-Boot runs in system state and uses physical addresses, i.e. the -MMU is not used either for address mapping nor for memory protection. - -The available memory is mapped to fixed addresses using the memory -controller. In this process, a contiguous block is formed for each -memory type (Flash, SDRAM, SRAM), even when it consists of several -physical memory banks. - -U-Boot is installed in the first 128 kB of the first Flash bank (on -TQM8xxL modules this is the range 0x40000000 ... 0x4001FFFF). After -booting and sizing and initializing DRAM, the code relocates itself -to the upper end of DRAM. Immediately below the U-Boot code some -memory is reserved for use by malloc() [see CONFIG_SYS_MALLOC_LEN -configuration setting]. Below that, a structure with global Board -Info data is placed, followed by the stack (growing downward). - -Additionally, some exception handler code is copied to the low 8 kB -of DRAM (0x00000000 ... 0x00001FFF). - -So a typical memory configuration with 16 MB of DRAM could look like -this: - - 0x0000 0000 Exception Vector code - : - 0x0000 1FFF - 0x0000 2000 Free for Application Use - : - : - - : - : - 0x00FB FF20 Monitor Stack (Growing downward) - 0x00FB FFAC Board Info Data and permanent copy of global data - 0x00FC 0000 Malloc Arena - : - 0x00FD FFFF - 0x00FE 0000 RAM Copy of Monitor Code - ... eventually: LCD or video framebuffer - ... eventually: pRAM (Protected RAM - unchanged by reset) - 0x00FF FFFF [End of RAM] - - System Initialization: ----------------------
diff --git a/doc/develop/index.rst b/doc/develop/index.rst index 0d0e60ab56c..cbea38d4323 100644 --- a/doc/develop/index.rst +++ b/doc/develop/index.rst @@ -13,6 +13,7 @@ General codingstyle designprinciples docstyle + memory patman process release_cycle diff --git a/doc/develop/memory.rst b/doc/develop/memory.rst new file mode 100644 index 00000000000..fa1ae5e97ed --- /dev/null +++ b/doc/develop/memory.rst @@ -0,0 +1,45 @@ +.. SPDX-License-Identifier: GPL-2.0+: + +Memory Management +----------------- + +U-Boot runs in system state and uses physical addresses, i.e. the +MMU is not used either for address mapping nor for memory protection. + +The available memory is mapped to fixed addresses using the +memory-controller. In this process, a contiguous block is formed for each +memory type (Flash, SDRAM, SRAM), even when it consists of several +physical-memory banks. + +U-Boot is installed in XIP flash memory, or may be loaded into a lower region of +RAM by a secondary program loader (SPL). After +booting and sizing and initialising DRAM, the code relocates itself +to the upper end of DRAM. Immediately below the U-Boot code some +memory is reserved for use by malloc() [see CONFIG_SYS_MALLOC_LEN +configuration setting]. Below that, a structure with global Board-Info +data is placed, followed by the stack (growing downward). + +Additionally, some exception handler code may be copied to the low 8 kB +of DRAM (0x00000000 ... 0x00001fff). + +So a typical memory configuration with 16 MB of DRAM could look like +this:: + + 0x0000 0000 Exception Vector code + : + 0x0000 1fff + 0x0000 2000 Free for Application Use + : + : + + : + : + 0x00fb ff20 Monitor Stack (Growing downward) + 0x00fb ffac Board Info Data and permanent copy of global data + 0x00fc 0000 Malloc Arena + : + 0x00fd ffff + 0x00fe 0000 RAM Copy of Monitor Code + ... eventually: LCD or video framebuffer + ... eventually: pRAM (Protected RAM - unchanged by reset) + 0x00ff ffff [End of RAM]
Hello Simon,
Am Thu, Sep 19, 2024 at 05:14:22PM +0200 schrieb Simon Glass:
Maybe try not to rewrap unchanged paragraphs, so `git show --color-moved` can detect those as just moved?
-Memory Management:
- 0x0000 1FFF
- 0x00FD FFFF
- memory patman process release_cycle
- 0x0000 1fff
- 0x00fb ff20 Monitor Stack (Growing downward)
- 0x00fb ffac Board Info Data and permanent copy of global data
- 0x00fc 0000 Malloc Arena
Arena?
`make htmldocs` runs fine, page looks okay, thus:
Acked-by: Alexander Dahl ada@thorsis.com
Greets Alex
- 0x00fd ffff
- 0x00fe 0000 RAM Copy of Monitor Code
- 0x00ff ffff [End of RAM]
-- 2.43.0
Hi Alex,
On Thu, 19 Sept 2024 at 17:28, Alexander Dahl ada@thorsis.com wrote:
Hello Simon,
I did try to do that, but perhaps did a line wrong?
-Memory Management:
0x0000 1FFF
0x00FD FFFF
0x0000 1fff
Arena?
Yes, a strange choice of words perhaps, but fair enough.
Thanks.
Greets Alex
0x00fd ffff
-- 2.43.0
-Memory Management:
- 0x0000 1FFF
- 0x00FD FFFF
Hello Simon,
Thanks for getting the description moved.
The text that you are copying dates back to 2004 when U-Boot was focusing on the Power architecture. It needs some rework.
On RISC-V there is a physical memory protection (PMP) which is typically set up to guard against overwriting OpenSBI sitting at the lower end of RAM.
There is some ongoing work to implement NX protection via the MMU for ARM.
Can we simply say DRAM instead of SDRAM. We always refer to DRAM below. Whether the RAM frequency is synchronous or not is irrelevant here.
This does not describe U-Boot SPL as being a part of U-Boot.
Initialization of DRAM can be done in code running before U-Boot.
+to the upper end of DRAM. Immediately below the U-Boot code some +memory is reserved for use by malloc() [see CONFIG_SYS_MALLOC_LEN>
The exception handler code for RISC-V and ARMv8 is typically not located at 0x0.
On RISC-V stvec, the Supervisor Trap Vector Base Address Register, defines where the exception vectors are located in S-Mode.
On ARMv8 VBAR_EL2, the Vector Base Address Register (EL2), sets the location of the EL2 vector base.
%s/MB/MiB/
+this::
On RISC-V the lowest memory addresses in RAM are typically used by OpenSBI. On ARM you may have TF-A sitting there.
- 0x0000 1fff
- 0x00fd ffff
A description of the LMB and EFI should be added in a future patch.
Best regards
Heinrich
Hi Heinrich,
-Memory Management:
0x0000 1FFF
0x00FD FFFF
Hello Simon,
I don't believe we need to get into the weeds on this description. It is just setting some guiding principles. Yes, every architecture is different, but people can see the general idea.
Perhaps we should add details about each architecture at the end, i.e. provide a link to an arch-specific page which provides more information?
%s/MB/MiB/
+this::
0x0000 1fff
0x00fd ffff
With my two series we can clean up EFI so that it works within the above.
On Wed, Sep 25, 2024 at 02:50:45PM +0200, Simon Glass wrote:
Hi Heinrich,
-Memory Management:
0x0000 1FFF
0x00FD FFFF
Hello Simon,
Perhaps we should start by moving this content out of the top-level README and note at the start in the new document that the information is outdated and needs to be updated.
Alexander Dahl
