[U-Boot] [PATCH 1/1] tests: enable DT overlay tests by default
Enable device tree overlay tests by default if unit tests are selected.
Overlays have been mainlined in the device tree compiler so there is no reason anymore to disable the tests by default.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- test/overlay/Kconfig | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/test/overlay/Kconfig b/test/overlay/Kconfig index 13c85428cba..f39966623dc 100644 --- a/test/overlay/Kconfig +++ b/test/overlay/Kconfig @@ -1,11 +1,10 @@ config UT_OVERLAY bool "Enable Device Tree Overlays Unit Tests" - depends on OF_LIBFDT_OVERLAY depends on UNIT_TEST + default y + select OF_LIBFDT_OVERLAY help This enables the 'ut overlay' command which runs a series of unit tests on the fdt overlay code. If all is well then all tests pass although there will be a few messages printed along the way. - Be warned that it requires an out-of-tree dtc compiler with patches - to support the DT overlays, otherwise it will fail.
