[PATCH v2] dm: i2c: Add a migration method for I2C
This probably should have been done a while back since it is a core system. Add a migration deadline of later this year, to catch the stragglers.
Signed-off-by: Simon Glass sjg@chromium.org
Changes in v2: - s/'network'/I2C/
Makefile | 11 +++++++++++ doc/driver-model/migration.rst | 8 ++++++++ 2 files changed, 19 insertions(+)
diff --git a/Makefile b/Makefile index b72d8d20c08..f60c7901a5b 100644 --- a/Makefile +++ b/Makefile @@ -1152,6 +1152,17 @@ ifneq ($(CONFIG_SPL_FIT_GENERATOR),) @echo >&2 "to binman instead, to avoid the proliferation of" @echo >&2 "arch-specific scripts with no tests." @echo >&2 "====================================================" +endif +ifneq ($(CONFIG_NET),) +ifneq ($(CONFIG_DM_ETH),y) + @echo >&2 "===================== WARNING ======================" + @echo >&2 "This board does not use CONFIG_DM_I2C (Driver Model" + @echo >&2 "for I2C drivers). Please update the board to use" + @echo >&2 "CONFIG_DM_I2C before the v2021.10 release. Failure to" + @echo >&2 "update by the deadline may result in board removal." + @echo >&2 "See doc/driver-model/migration.rst for more info." + @echo >&2 "====================================================" +endif endif @# Check that this build does not use CONFIG options that we do not @# know about unless they are in Kconfig. All the existing CONFIG diff --git a/doc/driver-model/migration.rst b/doc/driver-model/migration.rst index 2284e8a6f70..77a799a2700 100644 --- a/doc/driver-model/migration.rst +++ b/doc/driver-model/migration.rst @@ -99,3 +99,11 @@ Deadline: 2020.07 The network subsystem has supported the driver model since early 2015. Maintainers should submit patches switching over to using CONFIG_DM_ETH and other base driver model options in time for inclusion in the 2020.07 release. + +CONFIG_DM_I2C +------------- +Deadline: 2021.10 + +The network subsystem has supported the driver model since early 2015. +Maintainers should submit patches switching over to using CONFIG_DM_I2C and +other base driver model options in time for inclusion in the 2021.10 release.
