[U-Boot] [PATCH 6/7] [v5] powerpc/85xx: Add P5040 processor support
Add support for the Freescale P5040 SOC, which is similar to the P5020. Features of the P5040 are:
Four P5040 single-threaded e5500 cores built Up to 2.4 GHz with 64-bit ISA support Three levels of instruction: user, supervisor, hypervisor CoreNet platform cache (CPC) 2.0 MB configures as dual 1 MB blocks hierarchical interconnect fabric Two 64-bit DDR3/3L SDRAM memory controllers with ECC and interleaving support Up to 1600MT/s Memory pre-fetch engine DPAA incorporating acceleration for the following functions Packet parsing, classification, and distribution (FMAN) Queue management for scheduling, packet sequencing and congestion management (QMAN) Hardware buffer management for buffer allocation and de-allocation (BMAN) Cryptography acceleration (SEC 5.2) at up to 40 Gbps SerDes 20 lanes at up to 5 Gbps Supports SGMII, XAUI, PCIe rev1.1/2.0, SATA Ethernet interfaces Two 10 Gbps Ethernet MACs Ten 1 Gbps Ethernet MACs High-speed peripheral interfaces Two PCI Express 2.0/3.0 controllers Additional peripheral interfaces Two serial ATA (SATA 2.0) controllers Two high-speed USB 2.0 controllers with integrated PHY Enhanced secure digital host controller (SD/MMC/eMMC) Enhanced serial peripheral interface (eSPI) Two I2C controllers Four UARTs Integrated flash controller supporting NAND and NOR flash DMA Dual four channel Support for hardware virtualization and partitioning enforcement Extra privileged level for hypervisor support QorIQ Trust Architecture 1.1 Secure boot, secure debug, tamper detection, volatile key storage
Signed-off-by: Timur Tabi timur@freescale.com --- v5: fixed all the LIODNs, for real this time.
arch/powerpc/cpu/mpc85xx/Makefile | 3 + arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c | 70 ++++++++++++++ arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.h | 5 + arch/powerpc/cpu/mpc85xx/p5040_ids.c | 127 +++++++++++++++++++++++++ arch/powerpc/cpu/mpc85xx/p5040_serdes.c | 117 +++++++++++++++++++++++ arch/powerpc/cpu/mpc85xx/speed.c | 2 + arch/powerpc/cpu/mpc8xxx/cpu.c | 2 + arch/powerpc/include/asm/config_mpc85xx.h | 29 ++++++ arch/powerpc/include/asm/immap_85xx.h | 15 +++ arch/powerpc/include/asm/processor.h | 2 + 10 files changed, 372 insertions(+), 0 deletions(-) create mode 100644 arch/powerpc/cpu/mpc85xx/p5040_ids.c create mode 100644 arch/powerpc/cpu/mpc85xx/p5040_serdes.c
diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index 33e93c8..aad50f3 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -66,6 +66,7 @@ COBJS-$(CONFIG_PPC_P2041) += ddr-gen3.o COBJS-$(CONFIG_PPC_P3041) += ddr-gen3.o COBJS-$(CONFIG_PPC_P4080) += ddr-gen3.o COBJS-$(CONFIG_PPC_P5020) += ddr-gen3.o +COBJS-$(CONFIG_PPC_P5040) += ddr-gen3.o COBJS-$(CONFIG_BSC9131) += ddr-gen3.o
COBJS-$(CONFIG_CPM2) += ether_fcc.o @@ -80,6 +81,7 @@ COBJS-$(CONFIG_PPC_P2041) += p2041_ids.o COBJS-$(CONFIG_PPC_P3041) += p3041_ids.o COBJS-$(CONFIG_PPC_P4080) += p4080_ids.o COBJS-$(CONFIG_PPC_P5020) += p5020_ids.o +COBJS-$(CONFIG_PPC_P5040) += p5040_ids.o
COBJS-$(CONFIG_QE) += qe_io.o COBJS-$(CONFIG_CPM2) += serial_scc.o @@ -110,6 +112,7 @@ COBJS-$(CONFIG_PPC_P2041) += p2041_serdes.o COBJS-$(CONFIG_PPC_P3041) += p3041_serdes.o COBJS-$(CONFIG_PPC_P4080) += p4080_serdes.o COBJS-$(CONFIG_PPC_P5020) += p5020_serdes.o +COBJS-$(CONFIG_PPC_P5040) += p5040_serdes.o
COBJS = $(COBJS-y) COBJS += cpu.o diff --git a/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c b/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c index 2a68060..e6b1b1b 100644 --- a/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c +++ b/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c @@ -92,10 +92,17 @@ static const struct { { 17, 163, FSL_SRDS_BANK_2 }, { 18, 164, FSL_SRDS_BANK_2 }, { 19, 165, FSL_SRDS_BANK_2 }, +#ifdef CONFIG_PPC_P4080 { 20, 170, FSL_SRDS_BANK_3 }, { 21, 171, FSL_SRDS_BANK_3 }, { 22, 172, FSL_SRDS_BANK_3 }, { 23, 173, FSL_SRDS_BANK_3 }, +#else + { 20, 166, FSL_SRDS_BANK_3 }, + { 21, 167, FSL_SRDS_BANK_3 }, + { 22, 168, FSL_SRDS_BANK_3 }, + { 23, 169, FSL_SRDS_BANK_3 }, +#endif };
int serdes_get_lane_idx(int lane) @@ -493,6 +500,9 @@ void fsl_serdes_init(void) ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); int cfg; serdes_corenet_t *srds_regs; +#ifdef CONFIG_PPC_P5040 + serdes_corenet_t *srds2_regs; +#endif int lane, bank, idx; int have_bank[SRDS_MAX_BANK] = {}; #ifdef CONFIG_SYS_P4080_ERRATUM_SERDES8 @@ -574,6 +584,34 @@ void fsl_serdes_init(void) } }
+#ifdef CONFIG_PPC_P5040 + /* + * Lanes on bank 4 on P5040 are commented-out, but for some SERDES + * protocols, these lanes are routed to SATA. We use serdes_prtcl_map + * to decide whether a protocol is supported on a given lane, so SATA + * will be identified as not supported, and therefore not initialized. + * So for protocols which use SATA on bank4, we add SATA support in + * serdes_prtcl_map. + */ + switch (cfg) { + case 0x0: + case 0x1: + case 0x2: + case 0x3: + case 0x4: + case 0x5: + case 0x6: + case 0x7: + serdes_prtcl_map |= 1 << SATA1 | 1 << SATA2; + break; + default: + srds2_regs = (void *)CONFIG_SYS_FSL_CORENET_SERDES2_ADDR; + + /* We don't need bank 4, so power it down */ + setbits_be32(&srds2_regs->bank[0].rstctl, SRDS_RSTCTL_SDPD); + } +#endif + soc_serdes_init();
#ifdef CONFIG_SYS_P4080_ERRATUM_SERDES8 @@ -617,6 +655,38 @@ void fsl_serdes_init(void) } }
+#ifdef CONFIG_SYS_FSL_ERRATUM_A004699 + /* + * To avoid the situation that resulted in the P4080 erratum + * SERDES-8, a given SerDes bank will use the PLLs from the previous + * bank if one of the PLL frequencies is a multiple of the other. For + * instance, if bank 3 is running at 2.5GHz and bank 2 is at 1.25GHz, + * then bank 3 will use bank 2's PLL. P5040 Erratum A-004699 says + * that, in this situation, lane synchronization is not initiated. So + * when we detect a bank with a "borrowed" PLL, we have to manually + * initiate lane synchronization. + */ + for (bank = FSL_SRDS_BANK_2; bank <= FSL_SRDS_BANK_3; bank++) { + /* Determine the first lane for this bank */ + unsigned int lane; + + for (lane = 0; lane < SRDS_MAX_LANES; lane++) + if (lanes[lane].bank == bank) + break; + idx = lanes[lane].idx; + + /* + * Check if the PLL for the bank is borrowed. The UOTHL + * bit of the first lane will tell us that. + */ + if (in_be32(&srds_regs->lane[idx].gcr0) & SRDS_GCR0_UOTHL) { + /* Manually start lane synchronization */ + setbits_be32(&srds_regs->bank[bank].pllcr0, + SRDS_PLLCR0_PVCOCNT_EN); + } + } +#endif + #if defined(CONFIG_SYS_P4080_ERRATUM_SERDES8) || defined (CONFIG_SYS_P4080_ERRATUM_SERDES9) for (lane = 0; lane < SRDS_MAX_LANES; lane++) { enum srds_prtcl lane_prtcl; diff --git a/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.h b/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.h index f261351..c82060d 100644 --- a/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.h +++ b/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.h @@ -22,6 +22,11 @@ #ifndef __FSL_CORENET_SERDES_H #define __FSL_CORENET_SERDES_H
+/* + * Note: For P5040, the fourth SerDes bank is on SerDes2, but U-boot currently + * only supports one SerDes controller. For now, pretend that we have three + * banks and 18 lanes on the P5040. + */ #define SRDS_MAX_LANES 18 #define SRDS_MAX_BANK 3
diff --git a/arch/powerpc/cpu/mpc85xx/p5040_ids.c b/arch/powerpc/cpu/mpc85xx/p5040_ids.c new file mode 100644 index 0000000..878ee3e --- /dev/null +++ b/arch/powerpc/cpu/mpc85xx/p5040_ids.c @@ -0,0 +1,127 @@ +/* + * Copyright 2010-2011 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_portals.h> +#include <asm/fsl_liodn.h> + +#ifdef CONFIG_SYS_DPAA_QBMAN +struct qportal_info qp_info[CONFIG_SYS_QMAN_NUM_PORTALS] = { + /* dqrr liodn, frame data liodn, liodn off, sdest */ + SET_QP_INFO(1, 2, 1, 0), + SET_QP_INFO(3, 4, 2, 1), + SET_QP_INFO(5, 6, 3, 2), + SET_QP_INFO(7, 8, 4, 3), + SET_QP_INFO(9, 10, 5, 0), + SET_QP_INFO(11, 12, 6, 1), + SET_QP_INFO(13, 14, 7, 2), + SET_QP_INFO(15, 16, 8, 3), + SET_QP_INFO(17, 18, 9, 0), /* for now, set sdest to 0 */ + SET_QP_INFO(19, 20, 10, 0), /* for now, set sdest to 0 */ +}; +#endif + +struct liodn_id_table liodn_tbl[] = { +#ifdef CONFIG_SYS_DPAA_QBMAN + SET_QMAN_LIODN(31), + SET_BMAN_LIODN(32), +#endif + + SET_SDHC_LIODN(1, 64), + + SET_USB_LIODN(1, "fsl-usb2-mph", 93), + SET_USB_LIODN(2, "fsl-usb2-dr", 94), + + SET_SATA_LIODN(1, 95), + SET_SATA_LIODN(2, 96), + + SET_PCI_LIODN_BASE(CONFIG_SYS_FSL_PCIE_COMPAT, 1, 195), + SET_PCI_LIODN_BASE(CONFIG_SYS_FSL_PCIE_COMPAT, 2, 196), + SET_PCI_LIODN_BASE(CONFIG_SYS_FSL_PCIE_COMPAT, 3, 197), + + SET_DMA_LIODN(1, 193), + SET_DMA_LIODN(2, 194), +}; +int liodn_tbl_sz = ARRAY_SIZE(liodn_tbl); + +#ifdef CONFIG_SYS_DPAA_FMAN +struct liodn_id_table fman1_liodn_tbl[] = { + SET_FMAN_RX_1G_LIODN(1, 0, 6), + SET_FMAN_RX_1G_LIODN(1, 1, 7), + SET_FMAN_RX_1G_LIODN(1, 2, 8), + SET_FMAN_RX_1G_LIODN(1, 3, 9), + SET_FMAN_RX_1G_LIODN(1, 4, 10), + SET_FMAN_RX_10G_LIODN(1, 0, 11), +}; +int fman1_liodn_tbl_sz = ARRAY_SIZE(fman1_liodn_tbl); + +#if (CONFIG_SYS_NUM_FMAN == 2) +struct liodn_id_table fman2_liodn_tbl[] = { + SET_FMAN_RX_1G_LIODN(2, 0, 12), + SET_FMAN_RX_1G_LIODN(2, 1, 13), + SET_FMAN_RX_1G_LIODN(2, 2, 14), + SET_FMAN_RX_1G_LIODN(2, 3, 15), + SET_FMAN_RX_1G_LIODN(2, 4, 16), + SET_FMAN_RX_10G_LIODN(2, 0, 17), +}; +int fman2_liodn_tbl_sz = ARRAY_SIZE(fman2_liodn_tbl); +#endif +#endif + +struct liodn_id_table sec_liodn_tbl[] = { + SET_SEC_JR_LIODN_ENTRY(0, 129, 130), + SET_SEC_JR_LIODN_ENTRY(1, 131, 132), + SET_SEC_JR_LIODN_ENTRY(2, 133, 134), + SET_SEC_JR_LIODN_ENTRY(3, 135, 136), + SET_SEC_RTIC_LIODN_ENTRY(a, 89), + SET_SEC_RTIC_LIODN_ENTRY(b, 90), + SET_SEC_RTIC_LIODN_ENTRY(c, 91), + SET_SEC_RTIC_LIODN_ENTRY(d, 92), + SET_SEC_DECO_LIODN_ENTRY(0, 139, 140), + SET_SEC_DECO_LIODN_ENTRY(1, 141, 142), + SET_SEC_DECO_LIODN_ENTRY(2, 143, 144), + SET_SEC_DECO_LIODN_ENTRY(3, 145, 146), +}; +int sec_liodn_tbl_sz = ARRAY_SIZE(sec_liodn_tbl); + +#ifdef CONFIG_SYS_FSL_RAID_ENGINE +struct liodn_id_table raide_liodn_tbl[] = { + SET_RAID_ENGINE_JQ_LIODN_ENTRY(0, 0, 60), + SET_RAID_ENGINE_JQ_LIODN_ENTRY(0, 1, 61), + SET_RAID_ENGINE_JQ_LIODN_ENTRY(1, 0, 62), + SET_RAID_ENGINE_JQ_LIODN_ENTRY(1, 1, 63), +}; +int raide_liodn_tbl_sz = ARRAY_SIZE(raide_liodn_tbl); +#endif + +struct liodn_id_table liodn_bases[] = { + [FSL_HW_PORTAL_SEC] = SET_LIODN_BASE_2(64, 101), +#ifdef CONFIG_SYS_DPAA_FMAN + [FSL_HW_PORTAL_FMAN1] = SET_LIODN_BASE_1(32), +#endif +#if (CONFIG_SYS_NUM_FMAN == 2) + [FSL_HW_PORTAL_FMAN2] = SET_LIODN_BASE_1(160), +#endif +#ifdef CONFIG_SYS_FSL_RAID_ENGINE + [FSL_HW_PORTAL_RAID_ENGINE] = SET_LIODN_BASE_1(49), +#endif +}; diff --git a/arch/powerpc/cpu/mpc85xx/p5040_serdes.c b/arch/powerpc/cpu/mpc85xx/p5040_serdes.c new file mode 100644 index 0000000..890b88e --- /dev/null +++ b/arch/powerpc/cpu/mpc85xx/p5040_serdes.c @@ -0,0 +1,117 @@ +/* + * Copyright 2009-2011 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_serdes.h> +#include <asm/processor.h> +#include <asm/io.h> +#include "fsl_corenet_serdes.h" + +/* + * Note: For P5040, the fourth SerDes bank (with two lanes) is on SerDes2, but + * U-boot only supports one SerDes controller. Therefore, we ignore bank 4 in + * this table. This works because most of the SerDes code is for errata + * work-arounds, and there are no P5040 errata that effect bank 4. + */ + +static u8 serdes_cfg_tbl[][SRDS_MAX_LANES] = { + [0x00] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, PCIE2, PCIE2, + SGMII_FM2_DTSEC3, SGMII_FM2_DTSEC4, SGMII_FM1_DTSEC1, + SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, + XAUI_FM2, XAUI_FM2, XAUI_FM2, XAUI_FM2, /* SATA1, SATA2, */ }, + [0x01] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, PCIE2, PCIE2, + SGMII_FM1_DTSEC3, SGMII_FM2_DTSEC4, XAUI_FM1, XAUI_FM1, + XAUI_FM1, XAUI_FM1, XAUI_FM2, XAUI_FM2, XAUI_FM2, + XAUI_FM2, /* SATA1, SATA2 */ }, + [0x02] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, SGMII_FM1_DTSEC3, + SGMII_FM1_DTSEC4, SGMII_FM2_DTSEC3, SGMII_FM2_DTSEC4, + XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM2, XAUI_FM2, + XAUI_FM2, XAUI_FM2, /* SATA1, SATA2 */ }, + [0x03] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, SGMII_FM2_DTSEC1, + SGMII_FM2_DTSEC2, SGMII_FM2_DTSEC3, SGMII_FM2_DTSEC4, + SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, + SGMII_FM1_DTSEC4, XAUI_FM2, XAUI_FM2, XAUI_FM2, XAUI_FM2, + /* SATA1, SATA2 */ }, + [0x04] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE3, SGMII_FM2_DTSEC1, + SGMII_FM2_DTSEC2, SGMII_FM2_DTSEC3, SGMII_FM2_DTSEC4, + SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, + SGMII_FM1_DTSEC4, XAUI_FM2, XAUI_FM2, XAUI_FM2, XAUI_FM2, + /* SATA1, SATA2 */ }, + [0x05] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE3, SGMII_FM1_DTSEC3, + SGMII_FM1_DTSEC4, SGMII_FM2_DTSEC3, SGMII_FM2_DTSEC4, + XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM2, XAUI_FM2, + XAUI_FM2, XAUI_FM2, /* SATA1, SATA2 */ }, + [0x06] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, + SGMII_FM2_DTSEC3, SGMII_FM2_DTSEC4, SGMII_FM1_DTSEC1, + SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, + XAUI_FM2, XAUI_FM2, XAUI_FM2, XAUI_FM2, /* SATA1, SATA2 */ }, + [0x07] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, + SGMII_FM1_DTSEC3, SGMII_FM2_DTSEC4, XAUI_FM1, XAUI_FM1, + XAUI_FM1, XAUI_FM1, XAUI_FM2, XAUI_FM2, XAUI_FM2, + XAUI_FM2, /* SATA1, SATA2 */ }, + [0x11] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, PCIE2, PCIE2, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, NONE, NONE, SATA1, SATA2, + /* NONE, NONE */ }, + [0x15] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, PCIE2, PCIE2, + AURORA, AURORA, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, + NONE, NONE, SATA1, SATA2, /* NONE, NONE */ }, + [0x2a] = {PCIE1, PCIE1, PCIE3, PCIE3, PCIE2, PCIE2, PCIE2, PCIE2, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, XAUI_FM2, XAUI_FM2, + XAUI_FM2, XAUI_FM2, /* NONE, NONE */ }, + [0x34] = {PCIE1, PCIE1, PCIE1, PCIE1, SGMII_FM1_DTSEC1, + SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, AURORA, + AURORA, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, NONE, + NONE, SATA1, SATA2, /* NONE, NONE */ }, + [0x35] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, AURORA, AURORA, XAUI_FM1, + XAUI_FM1, XAUI_FM1, XAUI_FM1, NONE, NONE, SATA1, SATA2, + /* NONE, NONE */ }, + [0x36] = {PCIE1, PCIE1, PCIE3, PCIE3, SGMII_FM1_DTSEC1, + SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, AURORA, + AURORA, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, NONE, + NONE, SATA1, SATA2, /* NONE, NONE */ }, +}; + +enum srds_prtcl serdes_get_prtcl(int cfg, int lane) +{ + if (!serdes_lane_enabled(lane)) + return NONE; + + return serdes_cfg_tbl[cfg][lane]; +} + +int is_serdes_prtcl_valid(u32 prtcl) +{ + int i; + + if (prtcl > ARRAY_SIZE(serdes_cfg_tbl)) + return 0; + + for (i = 0; i < SRDS_MAX_LANES; i++) { + if (serdes_cfg_tbl[prtcl][i] != NONE) + return 1; + } + + return 0; +} diff --git a/arch/powerpc/cpu/mpc85xx/speed.c b/arch/powerpc/cpu/mpc85xx/speed.c index abfeb26..6dd9e8d 100644 --- a/arch/powerpc/cpu/mpc85xx/speed.c +++ b/arch/powerpc/cpu/mpc85xx/speed.c @@ -112,6 +112,8 @@ void get_sys_info (sys_info_t * sysInfo) #define HWA_ASYNC_DIV 0x04000000 #if (CONFIG_SYS_FSL_NUM_CC_PLLS == 2) #define HWA_CC_PLL 1 +#elif (CONFIG_SYS_FSL_NUM_CC_PLLS == 3) +#define HWA_CC_PLL 2 #elif (CONFIG_SYS_FSL_NUM_CC_PLLS == 4) #define HWA_CC_PLL 2 #else diff --git a/arch/powerpc/cpu/mpc8xxx/cpu.c b/arch/powerpc/cpu/mpc8xxx/cpu.c index 78a8f92..fb78784 100644 --- a/arch/powerpc/cpu/mpc8xxx/cpu.c +++ b/arch/powerpc/cpu/mpc8xxx/cpu.c @@ -73,6 +73,8 @@ struct cpu_type cpu_type_list [] = { CPU_TYPE_ENTRY(P4080, P4080, 8), CPU_TYPE_ENTRY(P5010, P5010, 1), CPU_TYPE_ENTRY(P5020, P5020, 2), + CPU_TYPE_ENTRY(P5021, P5021, 2), + CPU_TYPE_ENTRY(P5040, P5040, 4), CPU_TYPE_ENTRY(BSC9130, 9130, 1), CPU_TYPE_ENTRY(BSC9131, 9131, 1), #elif defined(CONFIG_MPC86xx) diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index aa27741..f8a1c99 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -433,6 +433,35 @@ #define CONFIG_SYS_FSL_ERRATUM_A004510_SVR_REV 0x10 #define CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY 0xc0000000
+#elif defined(CONFIG_PPC_P5040) +#define CONFIG_SYS_FSL_QORIQ_CHASSIS1 +#define CONFIG_MAX_CPUS 4 +#define CONFIG_SYS_FSL_NUM_CC_PLLS 3 +#define CONFIG_SYS_FSL_NUM_LAWS 32 +#define CONFIG_SYS_FSL_SEC_COMPAT 4 +#define CONFIG_SYS_NUM_FMAN 2 +#define CONFIG_SYS_NUM_FM1_DTSEC 5 +#define CONFIG_SYS_NUM_FM1_10GEC 1 +#define CONFIG_SYS_NUM_FM2_DTSEC 5 +#define CONFIG_SYS_NUM_FM2_10GEC 1 +#define CONFIG_NUM_DDR_CONTROLLERS 2 +#define CONFIG_SYS_FM_MURAM_SIZE 0x28000 +#define CONFIG_SYS_FSL_TBCLK_DIV 16 +#define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.4" +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 +#define CONFIG_SYS_FSL_USB1_PHY_ENABLE +#define CONFIG_SYS_FSL_USB2_PHY_ENABLE +#define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY +#define CONFIG_SYS_FSL_ERRATUM_ESDHC111 +#define CONFIG_SYS_FSL_ERRATUM_USB138 +#define CONFIG_SYS_FSL_ERRATUM_DDR_A003 +#define CONFIG_SYS_FSL_ERRATUM_DDR_A003474 +#define CONFIG_SYS_FSL_ERRATUM_A004699 +#define CONFIG_SYS_FSL_ELBC_MULTIBIT_ECC +#define CONFIG_SYS_FSL_ERRATUM_A004510 +#define CONFIG_SYS_FSL_ERRATUM_A004510_SVR_REV 0x10 +#define CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY 0xf0000000 + #elif defined(CONFIG_BSC9131) #define CONFIG_MAX_CPUS 1 #define CONFIG_FSL_SDHC_V2_3 diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 6c11178..7c35b41 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -1761,6 +1761,7 @@ typedef struct ccsr_gur { #define FSL_CORENET_RCWSR5_DDR_SYNC 0x00000080 #define FSL_CORENET_RCWSR5_DDR_SYNC_SHIFT 7 #define FSL_CORENET_RCWSR5_SRDS_EN 0x00002000 +#define FSL_CORENET_RCWSR5_SRDS2_EN 0x00001000 #define FSL_CORENET_RCWSR6_BOOT_LOC 0x0f800000 #define FSL_CORENET_RCWSRn_SRDS_LPD_B2 0x3c000000 /* bits 162..165 */ #define FSL_CORENET_RCWSRn_SRDS_LPD_B3 0x003c0000 /* bits 170..173 */ @@ -1786,6 +1787,15 @@ typedef struct ccsr_gur { #define FSL_CORENET_RCWSR11_EC2_FM1_DTSEC5_MII 0x00100000 #define FSL_CORENET_RCWSR11_EC2_FM1_DTSEC5_NONE 0x00180000 #endif +#if defined(CONFIG_PPC_P5040) +#define FSL_CORENET_RCWSR11_EC1_FM1_DTSEC5_RGMII 0x00000000 +#define FSL_CORENET_RCWSR11_EC1_FM1_DTSEC5_MII 0x00800000 +#define FSL_CORENET_RCWSR11_EC1_FM1_DTSEC5_NONE 0x00c00000 +#define FSL_CORENET_RCWSR11_EC2 0x00180000 /* bits 363..364 */ +#define FSL_CORENET_RCWSR11_EC2_FM2_DTSEC5_RGMII 0x00000000 +#define FSL_CORENET_RCWSR11_EC2_FM2_DTSEC5_MII 0x00100000 +#define FSL_CORENET_RCWSR11_EC2_FM2_DTSEC5_NONE 0x00180000 +#endif u8 res18[192]; u32 scratchrw[4]; /* Scratch Read/Write */ u8 res19[240]; @@ -2395,6 +2405,7 @@ typedef struct serdes_corenet { #define SRDS_RSTCTL_SDPD 0x00000020 u32 pllcr0; /* PLL Control Register 0 */ #define SRDS_PLLCR0_RFCK_SEL_MASK 0x30000000 +#define SRDS_PLLCR0_PVCOCNT_EN 0x02000000 #define SRDS_PLLCR0_RFCK_SEL_100 0x00000000 #define SRDS_PLLCR0_RFCK_SEL_125 0x10000000 #define SRDS_PLLCR0_RFCK_SEL_156_25 0x20000000 @@ -2423,6 +2434,7 @@ typedef struct serdes_corenet { u32 gcr0; /* General Control Register 0 */ #define SRDS_GCR0_RRST 0x00400000 #define SRDS_GCR0_1STLANE 0x00010000 +#define SRDS_GCR0_UOTHL 0x00100000 u32 gcr1; /* General Control Register 1 */ #define SRDS_GCR1_REIDL_CTL_MASK 0x001f0000 #define SRDS_GCR1_REIDL_CTL_PCIE 0x00100000 @@ -2627,6 +2639,7 @@ struct ccsr_rman { #define CONFIG_SYS_FSL_CORENET_CLK_OFFSET 0xE1000 #define CONFIG_SYS_FSL_CORENET_RCPM_OFFSET 0xE2000 #define CONFIG_SYS_FSL_CORENET_SERDES_OFFSET 0xEA000 +#define CONFIG_SYS_FSL_CORENET_SERDES2_OFFSET 0xEB000 #define CONFIG_SYS_FSL_CPC_OFFSET 0x10000 #define CONFIG_SYS_MPC85xx_DMA1_OFFSET 0x100000 #define CONFIG_SYS_MPC85xx_DMA2_OFFSET 0x101000 @@ -2777,6 +2790,8 @@ struct ccsr_rman { (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_SERDES2_OFFSET) #define CONFIG_SYS_FSL_CORENET_SERDES_ADDR \ (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_SERDES_OFFSET) +#define CONFIG_SYS_FSL_CORENET_SERDES2_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_SERDES2_OFFSET) #define CONFIG_SYS_MPC85xx_USB_ADDR \ (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_USB_OFFSET) #define CONFIG_SYS_MPC85xx_USB1_PHY_ADDR \ diff --git a/arch/powerpc/include/asm/processor.h b/arch/powerpc/include/asm/processor.h index 36695e2..fd0160a 100644 --- a/arch/powerpc/include/asm/processor.h +++ b/arch/powerpc/include/asm/processor.h @@ -1095,6 +1095,8 @@ #define SVR_P4080 0x820000 #define SVR_P5010 0x822100 #define SVR_P5020 0x822000 +#define SVR_P5021 0X820500 +#define SVR_P5040 0x820400
#define SVR_8610 0x80A000 #define SVR_8641 0x809000
Timur Tabi
