[PATCH] usb: eth: add print of device name on usb_ether registration
When a USB Ethernet device is detected and registered there is no way to know the device-name in order to use it with the ethact env variable.
Add a print to display the device name that is registered.
Example using an AX88x72A USB Ethernet device:
GW6404-B> usb start starting USB... Bus xhci_pci: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.00 Bus xhci_pci: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.00 scanning bus xhci_pci for devices... found ethernet device: asix_eth
GW6404-B> setenv ethact asix_eth # select usb ethernet
Signed-off-by: Tim Harvey tharvey@gateworks.com --- drivers/usb/eth/usb_ether.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/usb/eth/usb_ether.c b/drivers/usb/eth/usb_ether.c index e368ecda0d..916c4e1c85 100644 --- a/drivers/usb/eth/usb_ether.c +++ b/drivers/usb/eth/usb_ether.c @@ -86,6 +86,7 @@ int usb_ether_register(struct udevice *dev, struct ueth_data *ueth, int rxsize) return ret; } ueth->pusb_dev = udev; + printf("\n found ethernet device: %s\n", dev->name);
return 0; }
- printf("\n found ethernet device: %s\n", dev->name);
What if I have 2 asix_eth plugged in ? Do I get two identical prints ?
btw. it might be useful to have some "net list" command, like "mmc list" which would list all ethernet devices in the system.
Marek,
Yes, two identical prints in this case which is not good.
Which makes me wonder why 'setenv asix_eth' even works here as drivers/usb/eth/asix.c's get_info function creates a unique instance name.
That's what I was wondering as well. There are the following subcommands in the usb cmd: usb storage - show details of USB storage devices usb dev [dev] - show or set current USB storage device usb part [dev] - print partition table of one or all USB storage devices
So I was wondering if we should add a: usb net - show details of USB network devices
by the way, here are a few other devices I have on hand showing the vid:pid, ethact name, driver Kconfig, and device: // vid:pid ethact uboot-driver device-name 0bda:8153 r8152_eth USB_ETHER_RTL8152 CableCreation CD0026: USB3 GbE 0b95:1790 ax88179_eth USB_ETHER_ASIX88179 plugable USB3-E1000: USB 3.0 10/100/1000mbps 0b95:7720 asix_eth USB_ETHER_ASIX plugable USB2-E100: USB2.0 10/100 ASIX AX88772A
Tim
Marek,
Seems a bit further investigation into this might be necessary.
I don't think such a command should be limited to USB network devices, it should be something applicable to all network devices.
Marek,
It looks to me like the eth dev names are uniquely indexed for the non DM_ETH case where each driver has a 'get_info' function that returns an indexed name but for the DM_ETH case the eth_dev name is simply the udevice name which is not unique.
Yes, I agree.
I'll look into adding this in the near future.
Thanks,
Tim
Nice. I've also stumbled upon this problem a few times but always failed to implement such a small "fix".
Thanks, Stefan
return 0; }
Viele Grüße, Stefan
Stefan Roese
Tim Harvey
