[U-Boot] [PATCH 1/2] arm: Add minimal support for Cortex-R5
This minimal support will be used by Xilinx ZynqMP R5 cpu.
arch/arm/Kconfig | 6 ++++++ arch/arm/cpu/armv7r/Makefile | 4 ++++ arch/arm/cpu/armv7r/config.mk | 3 +++ arch/arm/cpu/armv7r/cpu.c | 24 ++++++++++++++++++++++++ arch/arm/cpu/armv7r/start.S | 17 +++++++++++++++++ 5 files changed, 54 insertions(+) create mode 100644 arch/arm/cpu/armv7r/Makefile create mode 100644 arch/arm/cpu/armv7r/config.mk create mode 100644 arch/arm/cpu/armv7r/cpu.c create mode 100644 arch/arm/cpu/armv7r/start.S
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index b5fbce03667d..b10804f55224 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -192,6 +192,10 @@ config CPU_V7M select THUMB2_KERNEL select SYS_CACHE_SHIFT_5
+config CPU_V7R + bool + select SYS_CACHE_SHIFT_6 + config CPU_PXA bool select SYS_CACHE_SHIFT_5 @@ -209,6 +213,7 @@ config SYS_CPU default "arm1176" if CPU_ARM1176 default "armv7" if CPU_V7 default "armv7m" if CPU_V7M + default "armv7r" if CPU_V7R default "pxa" if CPU_PXA default "sa1100" if CPU_SA1100 default "armv8" if ARM64 @@ -223,6 +228,7 @@ config SYS_ARM_ARCH default 6 if CPU_ARM1176 default 7 if CPU_V7 default 7 if CPU_V7M + default 7 if CPU_V7R default 5 if CPU_PXA default 4 if CPU_SA1100 default 8 if ARM64 diff --git a/arch/arm/cpu/armv7r/Makefile b/arch/arm/cpu/armv7r/Makefile new file mode 100644 index 000000000000..3c66976dfa62 --- /dev/null +++ b/arch/arm/cpu/armv7r/Makefile @@ -0,0 +1,4 @@ +# SPDX-License-Identifier: GPL-2.0 + +extra-y := start.o +obj-y += cpu.o diff --git a/arch/arm/cpu/armv7r/config.mk b/arch/arm/cpu/armv7r/config.mk new file mode 100644 index 000000000000..224d191ff846 --- /dev/null +++ b/arch/arm/cpu/armv7r/config.mk @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0 + +PLATFORM_CPPFLAGS += -mcpu=cortex-r5 -DARMR5 diff --git a/arch/arm/cpu/armv7r/cpu.c b/arch/arm/cpu/armv7r/cpu.c new file mode 100644 index 000000000000..e384a530c5e0 --- /dev/null +++ b/arch/arm/cpu/armv7r/cpu.c @@ -0,0 +1,24 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * (C) Copyright 2018 Xilinx, Inc. (Michal Simek) + */ + +#include <common.h> + +/* + * This is called right before passing control to + * the Linux kernel point. + */ +int cleanup_before_linux(void) +{ + return 0; +} + +/* + * Perform the low-level reset. + */ +void reset_cpu(ulong addr) +{ + while (1) + ; +} diff --git a/arch/arm/cpu/armv7r/start.S b/arch/arm/cpu/armv7r/start.S new file mode 100644 index 000000000000..d6e8eecf54b7 --- /dev/null +++ b/arch/arm/cpu/armv7r/start.S @@ -0,0 +1,17 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2015 + * Kamil Lulko, kamil.lulko@gmail.com + * + */ + +#include <asm/assembler.h> + +.globl reset +.type reset, %function +reset: + W(b) _main + +.globl c_runtime_cpu_setup +c_runtime_cpu_setup: + mov pc, lr
Xilinx ZynqMP also contains dual Cortex R5 which can run U-Boot. This patch is adding minimal support to get U-Boot boot. U-Boot on R5 runs out of DDR with default configuration that's why DDR needs to be partitioned if there is something else running on arm64. Console is done via Cadence uart driver and the first Cadence Triple Timer Counter is used for time.
This configuration with uart1 was tested on zcu100-revC.
U-Boot 2018.05-rc2-00021-gd058a08d907d (Apr 18 2018 - 14:11:27 +0200)
Model: Xilinx ZynqMP R5 DRAM: 512 MiB WARNING: Caches not enabled MMC: In: serial@ff010000 Out: serial@ff010000 Err: serial@ff010000 Net: Net Initialization Skipped No ethernet found. ZynqMP r5>
There are two ways how to run this on ZynqMP. 1. Run from ZynqMP arm64 tftpb 20000000 u-boot-r5.elf setenv autostart no && bootelf -p 20000000 cpu 4 disable && cpu 4 release 10000000 lockstep or cpu 4 disable && cpu 4 release 10000000 split
2. Load via jtag when directly to R5
Changes compare to RFC - Use 500MHz instead of 600MHz - Remove fpu compilation flags - Split arm-r5 code and platform --- MAINTAINERS | 6 +++ arch/arm/Kconfig | 10 ++++ arch/arm/Makefile | 1 + arch/arm/dts/Makefile | 2 + arch/arm/dts/zynqmp-r5.dts | 73 ++++++++++++++++++++++++++++++ arch/arm/mach-zynqmp-r5/Kconfig | 27 +++++++++++ arch/arm/mach-zynqmp-r5/Makefile | 3 ++ arch/arm/mach-zynqmp-r5/cpu.c | 15 ++++++ board/xilinx/zynqmp_r5/MAINTAINERS | 7 +++ board/xilinx/zynqmp_r5/Makefile | 6 +++ board/xilinx/zynqmp_r5/board.c | 25 ++++++++++ configs/xilinx_zynqmp_r5_defconfig | 16 +++++++ drivers/serial/Kconfig | 2 +- include/configs/xilinx_zynqmp_r5.h | 49 ++++++++++++++++++++ 14 files changed, 241 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/zynqmp-r5.dts create mode 100644 arch/arm/mach-zynqmp-r5/Kconfig create mode 100644 arch/arm/mach-zynqmp-r5/Makefile create mode 100644 arch/arm/mach-zynqmp-r5/cpu.c create mode 100644 board/xilinx/zynqmp_r5/MAINTAINERS create mode 100644 board/xilinx/zynqmp_r5/Makefile create mode 100644 board/xilinx/zynqmp_r5/board.c create mode 100644 configs/xilinx_zynqmp_r5_defconfig create mode 100644 include/configs/xilinx_zynqmp_r5.h
diff --git a/MAINTAINERS b/MAINTAINERS index 147551f66fd3..e60d76dbad8a 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -295,6 +295,12 @@ F: include/zynqmppl.h F: tools/zynqimage.c N: zynqmp
+ARM ZYNQMP R5 +M: Michal Simek michal.simek@xilinx.com +S: Maintained +T: git git://git.denx.de/u-boot-microblaze.git +F: arch/arm/mach-zynqmp-r5/ + BUILDMAN M: Simon Glass sjg@chromium.org S: Maintained diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index b10804f55224..e09ab487b7d0 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -771,6 +771,14 @@ config ARCH_ZYNQ imply CMD_SPL imply ARCH_EARLY_INIT_R
+config ARCH_ZYNQMP_R5 + bool "Xilinx ZynqMP R5 based platform" + select CPU_V7R + select OF_CONTROL + select DM + select DM_SERIAL + select CLK + config ARCH_ZYNQMP bool "Xilinx ZynqMP based platform" select ARM64 @@ -1289,6 +1297,8 @@ source "arch/arm/cpu/armv7/vf610/Kconfig"
source "arch/arm/mach-zynq/Kconfig"
+source "arch/arm/mach-zynqmp-r5/Kconfig" + source "arch/arm/cpu/armv7/Kconfig"
source "arch/arm/cpu/armv8/zynqmp/Kconfig" diff --git a/arch/arm/Makefile b/arch/arm/Makefile index 4fa8b38397d9..b4b45f3c6328 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -76,6 +76,7 @@ machine-$(CONFIG_ARCH_STM32MP) += stm32mp machine-$(CONFIG_TEGRA) += tegra machine-$(CONFIG_ARCH_UNIPHIER) += uniphier machine-$(CONFIG_ARCH_ZYNQ) += zynq +machine-$(CONFIG_ARCH_ZYNQMP_R5) += zynqmp-r5
machdirs := $(patsubst %,arch/arm/mach-%/,$(machine-y))
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 1fb36b3ecdb3..d44a4310081e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -165,6 +165,8 @@ dtb-$(CONFIG_ARCH_ZYNQMP) += \ zynqmp-zc1751-xm017-dc3.dtb \ zynqmp-zc1751-xm018-dc4.dtb \ zynqmp-zc1751-xm019-dc5.dtb +dtb-$(CONFIG_ARCH_ZYNQMP_R5) += \ + zynqmp-r5.dtb dtb-$(CONFIG_AM33XX) += am335x-boneblack.dtb am335x-bone.dtb \ am335x-draco.dtb \ am335x-evm.dtb \ diff --git a/arch/arm/dts/zynqmp-r5.dts b/arch/arm/dts/zynqmp-r5.dts new file mode 100644 index 000000000000..ba4d66a167c2 --- /dev/null +++ b/arch/arm/dts/zynqmp-r5.dts @@ -0,0 +1,73 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * dts file for Xilinx ZynqMP R5 + * + * (C) Copyright 2018, Xilinx, Inc. + * + * Michal Simek michal.simek@xilinx.com + */ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + compatible = "xlnx,zynqmp-r5"; + model = "Xilinx ZynqMP R5"; + + cpus { + #address-cells = <0x1>; + #size-cells = <0x0>; + + cpu@0 { + compatible = "arm,cortex-r5"; + device_type = "cpu"; + reg = <0>; + }; + }; + + aliases { + serial0 = &uart1; + }; + + memory@0 { + device_type = "memory"; + reg = <0x10000000 0x20000000>; + }; + + chosen { + bootargs = ""; + stdout-path = "serial0:115200n8"; + }; + + clk100: clk100 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <100000000>; + u-boot,dm-pre-reloc; + }; + + amba { + u-boot,dm-pre-reloc; + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + ttc0: timer@ff110000 { + compatible = "cdns,ttc"; + status = "okay"; + reg = <0xff110000 0x1000>; + timer-width = <32>; + clocks = <&clk100>; + }; + + uart1: serial@ff010000 { + u-boot,dm-pre-reloc; + compatible = "cdns,uart-r1p12", "xlnx,xuartps"; + reg = <0xff010000 0x1000>; + clock-names = "uart_clk", "pclk"; + clocks = <&clk100 &clk100>; + }; + }; +}; diff --git a/arch/arm/mach-zynqmp-r5/Kconfig b/arch/arm/mach-zynqmp-r5/Kconfig new file mode 100644 index 000000000000..5e0175413395 --- /dev/null +++ b/arch/arm/mach-zynqmp-r5/Kconfig @@ -0,0 +1,27 @@ +# SPDX-License-Identifier: GPL-2.0 + +if ARCH_ZYNQMP_R5 + +config SYS_BOARD + string "Board name" + default "zynqmp_r5" + +config SYS_VENDOR + string "Vendor name" + default "xilinx" + +config SYS_SOC + default "zynqmp-r5" + +config SYS_CONFIG_NAME + string "Board configuration name" + default "xilinx_zynqmp_r5" + help + This option contains information about board configuration name. + Based on this option include/configs/<CONFIG_SYS_CONFIG_NAME>.h header + will be used for board configuration. + +config SYS_MALLOC_F_LEN + default 0x600 + +endif diff --git a/arch/arm/mach-zynqmp-r5/Makefile b/arch/arm/mach-zynqmp-r5/Makefile new file mode 100644 index 000000000000..0d39e97dd371 --- /dev/null +++ b/arch/arm/mach-zynqmp-r5/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0 + +obj-y += cpu.o diff --git a/arch/arm/mach-zynqmp-r5/cpu.c b/arch/arm/mach-zynqmp-r5/cpu.c new file mode 100644 index 000000000000..0d86e2d1c886 --- /dev/null +++ b/arch/arm/mach-zynqmp-r5/cpu.c @@ -0,0 +1,15 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Xilinx, Inc. (Michal Simek) + */ + +#include <common.h> + +DECLARE_GLOBAL_DATA_PTR; + +int arch_cpu_init(void) +{ + gd->cpu_clk = CONFIG_CPU_FREQ_HZ; + + return 0; +} diff --git a/board/xilinx/zynqmp_r5/MAINTAINERS b/board/xilinx/zynqmp_r5/MAINTAINERS new file mode 100644 index 000000000000..ac267649781a --- /dev/null +++ b/board/xilinx/zynqmp_r5/MAINTAINERS @@ -0,0 +1,7 @@ +XILINX_ZYNQMP_R5 BOARDS +M: Michal Simek michal.simek@xilinx.com +S: Maintained +F: arch/arm/dts/zynqmp-r5* +F: board/xilinx/zynqmp_r5/ +F: include/configs/xilinx_zynqmp_r5_* +F: configs/xilinx_zynqmp_r5_* diff --git a/board/xilinx/zynqmp_r5/Makefile b/board/xilinx/zynqmp_r5/Makefile new file mode 100644 index 000000000000..c5a3e3d328bd --- /dev/null +++ b/board/xilinx/zynqmp_r5/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0 +# +# (C) Copyright 2018 Xilinx, Inc. (Michal Simek) +# + +obj-y := board.o diff --git a/board/xilinx/zynqmp_r5/board.c b/board/xilinx/zynqmp_r5/board.c new file mode 100644 index 000000000000..70fb20235498 --- /dev/null +++ b/board/xilinx/zynqmp_r5/board.c @@ -0,0 +1,25 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * (C) Copyright 2018 Xilinx, Inc. (Michal Simek) + */ + +#include <common.h> +#include <fdtdec.h> + +int board_init(void) +{ + return 0; +} + +int dram_init_banksize(void) +{ + return fdtdec_setup_memory_banksize(); +} + +int dram_init(void) +{ + if (fdtdec_setup_memory_size() != 0) + return -EINVAL; + + return 0; +} diff --git a/configs/xilinx_zynqmp_r5_defconfig b/configs/xilinx_zynqmp_r5_defconfig new file mode 100644 index 000000000000..46715242e703 --- /dev/null +++ b/configs/xilinx_zynqmp_r5_defconfig @@ -0,0 +1,16 @@ +CONFIG_ARM=y +CONFIG_ARCH_ZYNQMP_R5=y +CONFIG_SYS_TEXT_BASE=0x10000000 +CONFIG_DEFAULT_DEVICE_TREE="zynqmp-r5" +CONFIG_DEBUG_UART=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SYS_PROMPT="ZynqMP r5> " +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_SETEXPR is not set +CONFIG_OF_EMBED=y +CONFIG_DEBUG_UART_ZYNQ=y +CONFIG_DEBUG_UART_BASE=0xff010000 +CONFIG_DEBUG_UART_CLOCK=100000000 +CONFIG_ZYNQ_SERIAL=y +CONFIG_TIMER=y +CONFIG_CADENCE_TTC_TIMER=y diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 3d5b2bf15f08..3292edbaf240 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -617,7 +617,7 @@ config STM32_SERIAL
config ZYNQ_SERIAL bool "Cadence (Xilinx Zynq) UART support" - depends on DM_SERIAL && (MICROBLAZE || ARCH_ZYNQ || ARCH_ZYNQMP) + depends on DM_SERIAL && (MICROBLAZE || ARCH_ZYNQ || ARCH_ZYNQMP || ARCH_ZYNQMP_R5) help This driver supports the Cadence UART. It is found e.g. in Xilinx Zynq/ZynqMP. diff --git a/include/configs/xilinx_zynqmp_r5.h b/include/configs/xilinx_zynqmp_r5.h new file mode 100644 index 000000000000..80bbf4d2159d --- /dev/null +++ b/include/configs/xilinx_zynqmp_r5.h @@ -0,0 +1,49 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * (C) Copyright 2018 Xilinx, Inc. (Michal Simek) + */ + +#ifndef __CONFIG_ZYNQMP_R5_H +#define __CONFIG_ZYNQMP_R5_H + +#define CONFIG_EXTRA_ENV_SETTINGS + +/* CPU clock */ +#define CONFIG_CPU_FREQ_HZ 500000000 + +/* Serial drivers */ +/* The following table includes the supported baudrates */ +#define CONFIG_SYS_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200, 230400} + +# define CONFIG_ENV_SIZE (128 << 10) + +/* Allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Boot configuration */ +#define CONFIG_SYS_LOAD_ADDR 0 /* default? */ + +#define CONFIG_SYS_MAXARGS 32 /* max number of command args */ + +#define CONFIG_NR_DRAM_BANKS 1 + +#define CONFIG_SYS_MALLOC_LEN 0x1400000 + +#define CONFIG_SYS_INIT_RAM_ADDR 0xFFFF0000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ + CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) + +/* Extend size of kernel image for uncompression */ +#define CONFIG_SYS_BOOTM_LEN (60 * 1024 * 1024) + +#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE + +#define CONFIG_SKIP_LOWLEVEL_INIT + +#define CONFIG_SYS_DCACHE_OFF +#define CONFIG_SYS_ICACHE_OFF + +#endif /* __CONFIG_ZYNQ_ZYNQMP_R5_H */
+config CPU_V7R
- bool
- select SYS_CACHE_SHIFT_6
select HAS_THUMB2 might be a good option?
- default "armv7r" if CPU_V7R default "pxa" if CPU_PXA default "sa1100" if CPU_SA1100 default "armv8" if ARM64
- default 7 if CPU_V7R default 5 if CPU_PXA default 4 if CPU_SA1100 default 8 if ARM64
I did a grep of CPU_V7, and you might want to update for CPU_V7R in the following places:
diff --git a/arch/arm/Makefile b/arch/arm/Makefile index 4fa8b38397..f4bc1f250d 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -18,6 +18,7 @@ arch-$(CONFIG_CPU_ARM1136) =-march=armv5 arch-$(CONFIG_CPU_ARM1176) =-march=armv5t arch-$(CONFIG_CPU_V7) =$(call cc-option, -march=armv7-a, \ $(call cc-option, -march=armv7, -march=armv5)) +arch-$(CONFIG_CPU_V7R) =-march=armv7-r arch-$(CONFIG_ARM64) =-march=armv8-a
# On Tegra systems we must build SPL for the armv4 core on the device @@ -41,6 +42,7 @@ tune-$(CONFIG_CPU_PXA) =-mcpu=xscale tune-$(CONFIG_CPU_ARM1136) = tune-$(CONFIG_CPU_ARM1176) = tune-$(CONFIG_CPU_V7) = +tune-$(CONFIG_CPU_V7R) = tune-$(CONFIG_ARM64) =
# Evaluate tune cc-option calls now
hmm..do we really need to create a separate folder? IIUC, the main difference between V7 and V7R is MMU vs MPU. IMHO, we should be able to get it using Kconfigs.
Thanks and regards, Lokesh
- (C) Copyright 2018 Xilinx, Inc. (Michal Simek)
- This is called right before passing control to
- the Linux kernel point.
- Perform the low-level reset.
- while (1)
- (C) Copyright 2015
- Kamil Lulko, kamil.lulko@gmail.com
- W(b) _main
- mov pc, lr
+config CPU_V7R
- bool
I didn't enable it because I didn't test it. It can be added when someone tests this.
I have setup PLATFORM_CPPFLAGS via config.mk
If both options are selected I am getting this compilation warning. cc1: warning: switch -mcpu=cortex-r5 conflicts with -march=armv7-r switch
Not sure which one is better or if it is better to have this arch flag via this makefile or as platform cppflags via config.mk. I choose the second option because it seems to me better if this is in subfolder. But not a problem to use different flag and put it to this Makefile.
The same style is used for cpu_v7m.
Again as above. I used v7m as pattern and there is also empty tune parameter. Is there any good reason to have it empty?
I have used V7 for the initial port and then was checking V7M which is already there and used it as pattern for writing this patch.
I have debugged V7 and found that I need to disable CONFIG_HAS_VBAR that's why I have created new symbol as for V7M.
Definitely I am open to hear your suggestions.
Thanks, Michal
Hi Michal,
+config CPU_V7R
- bool
hmm..that's strange. I guess it should be reported to gcc? Something similar has been reported for a15 as well[1].
But looking at the implementation of armv7 we just included march. may be we should stick to it?
v7-r is very much close to v7. I would prefer to compare with v7 implementation than v7-m :)
We should be able to create a kconfig symbol for that and select accordingly. Kernel does it the same way.
I just did a couple of quick experiments and able to get v7-r support along with v7 support. let me know if you would like to take a look at it. Then Ill pick your patch 1/2 and post the series.
[1] https://gcc.gnu.org/bugzilla/show_bug.cgi?id=57907
Thanks, Michal
On 24.4.2018 06:45, Lokesh Vutla wrote:
Hi Michal,
+config CPU_V7R
- bool
As I said I have not a problem to add there -march=armv7-r instead of -mcpu=cortex-r5.
I started with symlink to v7. And I didn't play with MPU. Anyway both ways works for me.
What kernel Kconfig option are you talking about? (I didn't look at Linux running on R5 but it is reasonable step).
It is really a question if adding new Kconfig symbol for VBAR is the right thing to do. I would need to add VBAR to every platform which has CPU_V7.
I am definitely confident that this will work because I used that in past. Definitely feel free to send it and I will take a look at retest on R5.
Thanks, Michal
Hi Michal,
Hi Michal,
+config CPU_V7R
- bool
Sorry, I did not mean this patch does not work. It definitely works. I am trying to tell that with some kconfig changes we should be able to re-use armv7 folder instead of creating new folder. Apologies if my reply has communicated wrongly.
Will post an RFC series for R5 support.
On 24.4.2018 14:49, Lokesh Vutla wrote:
Hi Michal,
Hi Michal,
+config CPU_V7R
- bool
I know that it will work. Please send it and I will take a look. The same is for v7m which can be also squashed with v7 + some Kconfig options.
Thanks, Michal
Lokesh Vutla
Michal Simek
