[PATCH] drivers: ddr: lc_common_dimm_params.c : Fix Divison by zero issue
Adds check for memory clock variable before calculating caslat_actual.
Set mclk_ps to slowest DIMM supported if mclk_ps is found zero.
Signed-off-by: Maninder Singh maninder.singh_1@nxp.com --- drivers/ddr/fsl/lc_common_dimm_params.c | 10 ++++++++-- 1 file changed, 8 insertions(+), 2 deletions(-)
diff --git a/drivers/ddr/fsl/lc_common_dimm_params.c b/drivers/ddr/fsl/lc_common_dimm_params.c index d299d763db..d738ae3a7c 100644 --- a/drivers/ddr/fsl/lc_common_dimm_params.c +++ b/drivers/ddr/fsl/lc_common_dimm_params.c @@ -1,7 +1,7 @@ // SPDX-License-Identifier: GPL-2.0 /* * Copyright 2008-2016 Freescale Semiconductor, Inc. - * Copyright 2017-2018 NXP Semiconductor + * Copyright 2017-2021 NXP Semiconductor */
#include <common.h> @@ -23,7 +23,7 @@ compute_cas_latency(const unsigned int ctrl_num, unsigned int caslat_actual; unsigned int retry = 16; unsigned int tmp = ~0; - const unsigned int mclk_ps = get_memory_clk_period_ps(ctrl_num); + unsigned int mclk_ps = get_memory_clk_period_ps(ctrl_num); #ifdef CONFIG_SYS_FSL_DDR3 const unsigned int taamax = 20000; #else @@ -37,6 +37,12 @@ compute_cas_latency(const unsigned int ctrl_num, } common_caslat = tmp;
+ if (!mclk_ps) { + printf("DDR clock (MCLK cycle was 0 ps), So setting it to slowest DIMM(s) (tCKmin %u ps).\n", + outpdimm->tckmin_x_ps); + mclk_ps = outpdimm->tckmin_x_ps; + } + /* validate if the memory clk is in the range of dimms */ if (mclk_ps < outpdimm->tckmin_x_ps) { printf("DDR clock (MCLK cycle %u ps) is faster than "
Maninder Singh
