[U-Boot] phy ic isn't reset
Hi: I work on one board based on at9g25evk board now. I find one issue that phy IC isn't reset, so network can't work. Only the different crystal with evk board is connected to PHY IC. I copy the phy-reset part of at9260 to at9g25. It can work now. Please the maintainer of at9gx5 check this. The modification I do is as below:
+ +#ifdef CONFIG_MACB +int at91sam9x5ek_macb_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; + struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC; + unsigned long erstl; + + /* Enable EMAC clock */ + writel(1 << ATMEL_ID_EMAC0, &pmc->pcer); + + erstl = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK; + + /* Need to reset PHY -> 500ms reset */ + writel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(13) | + AT91_RSTC_MR_URSTEN, &rstc->mr); + + writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr); + + /* Wait for end hardware reset */ + while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL)) + ; + + /* Restore NRST value */ + writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN, + &rstc->mr); + + at91_macb_hw_init(); +} +#endif
Best Regards, Alex
Hi Alex,
As you mentioned, you use different crystal, please specify this in detail.
&rstc->mr);
+} +#endif
On at91sam9g25ek, it don't need this patch. The network work properly.
Btw, please help provide the log information for why not ethernet doesn't work.
Best Regards, Bo Shen
Best Regards, Alex
At 2013-04-18 09:23:48,"Bo Shen" voice.shen@atmel.com wrote:
Hi Alex,
S3225A package, 50Mhz crystal oscillator. ocean comonents ltd. ---> can work. asem series:ASEM1-50.000MHZ-LC-T ---->can't work.
&rstc->mr);
+} +#endif
Btw, please help provide the log information for why not ethernet doesn't work. From at91sam9g25ek side, no any error. If you only plug network line , the network traffic led is always off, that is, DM9161AEP doesn't check this change.
Even if I add this patch, no any defect, right?
Best Regards, Alex
Hi Alex
Hi Alex,
&rstc->mr);
+} +#endif
From at91sam9g25ek side, no any error. If you only plug network line , the network traffic led is always off, that is,DM9161AEP doesn't check this change. Even if I add this patch, no any defect, right?
I won't suggest do like this, if you use reset controller, it will assert nRST pin. If one more device use nRST, it will also reset other device. if only PHY use nRST and no other consideration, I think it is OK.
At 2013-04-18 14:32:52,"Bo Shen" voice.shen@atmel.com wrote:
Hi Alex
Hi Alex,
More information. asem crystal: only plug the network line, and then powerup, it can work.
&rstc->mr);
+} +#endif
On my board, only PHY use nRST. Understand, and thanks for your reply.
Dear Bo Shen,
On 04/18/2013 08:32 AM, Bo Shen wrote:
Hi Alex
Hi Alex,
&rstc->mr);
+} +#endif
I would like to point out that older atmel eval kits use this trick heavily. This is due to missing pullup/pulldown on the board, therefore it is required to setup some gpio first and then issue a reset (again) to the PHY cause it is misconfigured. Maybe this can also be esablished with some (R)MII communication, but thats how it is implemented currently.
Regarding the crystal, what is the root cause of your issue? Does it not oscillate or is your PHY 'mis-configured' in means of wrong initial setup on configuration lines? In both cases I recommend to find a HW solution for the final product.
Best regards
Andreas Bießmann
Hi Andreas,
On 4/18/2013 15:50, Andreas Bießmann wrote:
Dear Bo Shen,
Hi Alex
Hi Alex,
&rstc->mr);
+} +#endif
Thanks for this information.
Hi Alex, Please check your issue according to Andreas' suggestion. And try to fix it through HW solution.
Best regards
Andreas Bießmann
alex
Andreas Bießmann
Bo Shen
