[v2] Pull request: Please pull u-boot-imx-master-20240108
Hi Tom,
This is v2. Fixed the summary log.
Please pull from u-boot-imx, thanks.
The following changes since commit 93d91e9485d902a1836a22e72d1a545b587adf36:
Merge branch 'next' (2024-01-08 12:00:18 -0500)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-master-20240108
for you to fetch changes up to 54e1aa236f7d934ea81d727fe27b6d05902643be:
Add imx93-var-som support (2024-01-08 14:37:57 -0300)
u-boot-imx-master-20240108 --------------------------
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/19232
- Removed fdt_addr from verdin-imx8mm to fix booting via bootefi. - Support Ethernet PHY autodection on Data Modul i.MX8M Mini/Plus eDM SBC - Add i.MX93 binman support - Add support for imx93-var-som ---------------------------------------------------------------- Francesco Dolcini (1): verdin-imx8mm: Remove stale fdt_addr env variable
Marek Vasut (1): ARM: imx: Auto-detect PHY on Data Modul i.MX8M Mini/Plus eDM SBC
Mathieu Othacehe (4): spl: binman: Disable u_boot_any symbols for i.MX93 boards mach-imx: Add i.MX93 binman support. imx9: imx93_evk: Add binman support. Add imx93-var-som support
arch/arm/dts/Makefile | 3 +- arch/arm/dts/imx8mp-data-modul-edm-sbc-u-boot.dtsi | 6 - arch/arm/dts/imx93-11x11-evk-u-boot.dtsi | 2 + arch/arm/dts/imx93-u-boot.dtsi | 88 ++ arch/arm/dts/imx93-var-som-symphony-u-boot.dtsi | 266 ++++ arch/arm/dts/imx93-var-som-symphony.dts | 305 ++++ arch/arm/dts/imx93-var-som.dtsi | 111 ++ arch/arm/include/asm/arch-imx9/clock.h | 1 + arch/arm/mach-imx/Makefile | 27 +- arch/arm/mach-imx/imx9/Kconfig | 8 + arch/arm/mach-imx/imx9/container.cfg | 10 + arch/arm/mach-imx/imx9/imximage.cfg | 10 + .../imx8mm_edm_sbc/imx8mm_data_modul_edm_sbc.c | 42 + .../imx8mp_edm_sbc/imx8mp_data_modul_edm_sbc.c | 50 + board/variscite/common/eth.c | 58 + board/variscite/common/eth.h | 12 + board/variscite/common/imx9_eeprom.c | 190 +++ board/variscite/common/imx9_eeprom.h | 83 ++ board/variscite/common/mmc.c | 47 + board/variscite/imx93_var_som/Kconfig | 12 + board/variscite/imx93_var_som/MAINTAINERS | 7 + board/variscite/imx93_var_som/Makefile | 17 + board/variscite/imx93_var_som/imx93_var_som.c | 126 ++ board/variscite/imx93_var_som/imx93_var_som.env | 99 ++ board/variscite/imx93_var_som/lpddr4x_timing.c | 1488 ++++++++++++++++++++ board/variscite/imx93_var_som/spl.c | 143 ++ common/spl/Kconfig | 2 +- common/spl/Kconfig.tpl | 2 +- common/spl/Kconfig.vpl | 2 +- configs/imx8mm_data_modul_edm_sbc_defconfig | 1 + configs/imx8mp_data_modul_edm_sbc_defconfig | 1 + configs/imx93_11x11_evk_defconfig | 2 + configs/imx93_11x11_evk_ld_defconfig | 2 + configs/imx93_var_som_defconfig | 156 ++ doc/board/nxp/imx93_11x11_evk.rst | 68 + doc/board/nxp/index.rst | 1 + doc/board/variscite/imx93_var_som.rst | 68 + doc/board/variscite/index.rst | 1 + include/configs/imx93_var_som.h | 48 + include/configs/verdin-imx8mm.h | 1 - tools/imx9_image.sh | 31 + 41 files changed, 3585 insertions(+), 12 deletions(-) create mode 100644 arch/arm/dts/imx93-u-boot.dtsi create mode 100644 arch/arm/dts/imx93-var-som-symphony-u-boot.dtsi create mode 100644 arch/arm/dts/imx93-var-som-symphony.dts create mode 100644 arch/arm/dts/imx93-var-som.dtsi create mode 100644 arch/arm/mach-imx/imx9/container.cfg create mode 100644 arch/arm/mach-imx/imx9/imximage.cfg create mode 100644 board/variscite/common/eth.c create mode 100644 board/variscite/common/eth.h create mode 100644 board/variscite/common/imx9_eeprom.c create mode 100644 board/variscite/common/imx9_eeprom.h create mode 100644 board/variscite/common/mmc.c create mode 100644 board/variscite/imx93_var_som/Kconfig create mode 100644 board/variscite/imx93_var_som/MAINTAINERS create mode 100644 board/variscite/imx93_var_som/Makefile create mode 100644 board/variscite/imx93_var_som/imx93_var_som.c create mode 100644 board/variscite/imx93_var_som/imx93_var_som.env create mode 100644 board/variscite/imx93_var_som/lpddr4x_timing.c create mode 100644 board/variscite/imx93_var_som/spl.c create mode 100644 configs/imx93_var_som_defconfig create mode 100644 doc/board/nxp/imx93_11x11_evk.rst create mode 100644 doc/board/variscite/imx93_var_som.rst create mode 100644 include/configs/imx93_var_som.h create mode 100755 tools/imx9_image.sh
On Mon, Jan 08, 2024 at 03:37:09PM -0300, Fabio Estevam wrote:
Hi Tom,
Fabio Estevam
