[U-Boot] [PULL] u-boot-pxa/master
Dear Albert ARIBAUD,
The following changes since commit 3513896e57c6757c411e0633ccb5da08c36ad7d4:
Fix erroneous 32-bit access to hw_clkctrl_frac0 and hw_clkctrl_frac1 registers (2012-03-05 13:36:36 +0100)
git://git.denx.de/u-boot-pxa.git master
for you to fetch changes up to d85feeff3e8fc458654274835b2cf8e61070cdf4:
IXP: Fix GPIO_INT_ACT_LOW_SET() (2012-03-06 11:57:43 +0100)
---------------------------------------------------------------- Marek Vasut (7): Examples: Properly append LDFLAGS to LD command IXP: Make IXP buildable with arm-linux- toolchains IXP: Fix missing MACH_TYPE_{ACTUX?,PNB3,DVLHOST} IXP: Squash warnings in IXP NPE IXP: Move PDNB3 and SCPU from Makefile to boards.cfg IXP: Fix NAND build warning on PDNB3 and SCPU IXP: Fix GPIO_INT_ACT_LOW_SET()
Makefile | 12 ------------ arch/arm/cpu/ixp/config.mk | 3 +++ arch/arm/cpu/ixp/npe/IxEthAcc.c | 2 +- arch/arm/cpu/ixp/npe/IxEthDBAPISupport.c | 3 --- arch/arm/cpu/ixp/npe/IxQMgrDispatcher.c | 3 --- arch/arm/include/asm/arch-ixp/ixp425.h | 10 ++++++++-- board/actux1/actux1.c | 2 -- board/actux2/actux2.c | 2 -- board/actux3/actux3.c | 2 -- board/actux4/actux4.c | 2 -- board/dvlhost/dvlhost.c | 2 -- board/prodrive/pdnb3/nand.c | 16 +++------------- board/prodrive/pdnb3/pdnb3.c | 3 --- boards.cfg | 2 ++ examples/standalone/Makefile | 2 +- include/configs/actux1.h | 2 ++ include/configs/actux2.h | 2 ++ include/configs/actux3.h | 2 ++ include/configs/actux4.h | 2 ++ include/configs/dvlhost.h | 2 ++ include/configs/pdnb3.h | 2 ++ 21 files changed, 30 insertions(+), 48 deletions(-)
Best regards, Marek Vasut
Hi Marek,
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
