[U-Boot] [PATCH 3/4] include: usb: Move USB controller base address mapping
Move USB controller Base address mapping from ls102xa immap to fsl xhci header. This is required to remove any warnings when controller base addresses are mapped for multiple platforms in their respective files.
Signed-off-by: Nikhil Badola nikhil.badola@freescale.com --- arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 9 --------- include/linux/usb/xhci-fsl.h | 7 +++++++ 2 files changed, 7 insertions(+), 9 deletions(-)
diff --git a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h index 8e5fcdc..2abfc4d 100644 --- a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h +++ b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h @@ -396,13 +396,4 @@ struct ccsr_cci400 { u8 res_e004[0x10000 - 0xe004]; };
-/* USB-XHCI */ -#define FSL_XHCI_BASE 0x3100000 -#define FSL_OCP1_SCP_BASE 0x4a084c00 -#define FSL_OTG_WRAPPER_BASE 0x4A020000 - -#define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_LS102XA_XHCI_USB1_ADDR -#define CONFIG_SYS_FSL_XHCI_USB2_ADDR 0 -#define FSL_USB_XHCI_ADDR {CONFIG_SYS_FSL_XHCI_USB1_ADDR, \ - CONFIG_SYS_FSL_XHCI_USB2_ADDR} #endif /* __ASM_ARCH_LS102XA_IMMAP_H_ */ diff --git a/include/linux/usb/xhci-fsl.h b/include/linux/usb/xhci-fsl.h index 8eaab2c..b07bf19 100644 --- a/include/linux/usb/xhci-fsl.h +++ b/include/linux/usb/xhci-fsl.h @@ -51,4 +51,11 @@ struct fsl_xhci { struct dwc3 *dwc3_reg; };
+#if defined(CONFIG_LS102XA) +#define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_LS102XA_XHCI_USB1_ADDR +#define CONFIG_SYS_FSL_XHCI_USB2_ADDR 0 +#endif + +#define FSL_USB_XHCI_ADDR {CONFIG_SYS_FSL_XHCI_USB1_ADDR, \ + CONFIG_SYS_FSL_XHCI_USB2_ADDR} #endif /* _ASM_ARCH_XHCI_FSL_H_ */
Nikhil Badola
