[PATCH v4 0/5] fs/erofs: new filesystem
Changes since v3: - update tools/docker/Dockerfile;
Changes since v2: - sync up with erofs-utils 1.4; - update lib/lz4 to v1.8.3; - add test for filesystem functions;
Changes since v1: - fix the inconsistency between From and SoB; - add missing license header;
Huang Jianan (5): fs/erofs: add erofs filesystem support lib/lz4: update LZ4 decompressor module fs/erofs: add lz4 decompression support fs/erofs: add filesystem commands test/py: Add tests for the erofs
MAINTAINERS | 9 + cmd/Kconfig | 6 + cmd/Makefile | 1 + cmd/erofs.c | 42 ++ configs/sandbox_defconfig | 1 + fs/Kconfig | 2 + fs/Makefile | 1 + fs/erofs/Kconfig | 21 + fs/erofs/Makefile | 9 + fs/erofs/data.c | 311 +++++++++++++ fs/erofs/decompress.c | 78 ++++ fs/erofs/decompress.h | 24 + fs/erofs/erofs_fs.h | 436 ++++++++++++++++++ fs/erofs/fs.c | 267 +++++++++++ fs/erofs/internal.h | 313 +++++++++++++ fs/erofs/namei.c | 252 +++++++++++ fs/erofs/super.c | 105 +++++ fs/erofs/zmap.c | 601 ++++++++++++++++++++++++ fs/fs.c | 22 + include/erofs.h | 19 + include/fs.h | 1 + include/u-boot/lz4.h | 49 ++ lib/lz4.c | 679 ++++++++++++++++++++-------- lib/lz4_wrapper.c | 23 +- test/py/tests/test_fs/test_erofs.py | 211 +++++++++ tools/docker/Dockerfile | 1 + 26 files changed, 3269 insertions(+), 215 deletions(-) create mode 100644 cmd/erofs.c create mode 100644 fs/erofs/Kconfig create mode 100644 fs/erofs/Makefile create mode 100644 fs/erofs/data.c create mode 100644 fs/erofs/decompress.c create mode 100644 fs/erofs/decompress.h create mode 100644 fs/erofs/erofs_fs.h create mode 100644 fs/erofs/fs.c create mode 100644 fs/erofs/internal.h create mode 100644 fs/erofs/namei.c create mode 100644 fs/erofs/super.c create mode 100644 fs/erofs/zmap.c create mode 100644 include/erofs.h create mode 100644 test/py/tests/test_fs/test_erofs.py
This patch mainly deals with uncompressed files.
Signed-off-by: Huang Jianan jnhuang95@gmail.com --- MAINTAINERS | 7 + fs/Kconfig | 2 + fs/Makefile | 1 + fs/erofs/Kconfig | 12 ++ fs/erofs/Makefile | 7 + fs/erofs/data.c | 223 ++++++++++++++++++++++ fs/erofs/erofs_fs.h | 436 ++++++++++++++++++++++++++++++++++++++++++++ fs/erofs/fs.c | 267 +++++++++++++++++++++++++++ fs/erofs/internal.h | 313 +++++++++++++++++++++++++++++++ fs/erofs/namei.c | 252 +++++++++++++++++++++++++ fs/erofs/super.c | 105 +++++++++++ fs/fs.c | 22 +++ include/erofs.h | 19 ++ include/fs.h | 1 + 14 files changed, 1667 insertions(+) create mode 100644 fs/erofs/Kconfig create mode 100644 fs/erofs/Makefile create mode 100644 fs/erofs/data.c create mode 100644 fs/erofs/erofs_fs.h create mode 100644 fs/erofs/fs.c create mode 100644 fs/erofs/internal.h create mode 100644 fs/erofs/namei.c create mode 100644 fs/erofs/super.c create mode 100644 include/erofs.h
diff --git a/MAINTAINERS b/MAINTAINERS index 1c98029754..dd2ce8143c 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -808,6 +808,13 @@ S: Maintained F: doc/usage/environment.rst F: scripts/env2string.awk
+EROFS +M: Huang Jianan jnhuang95@gmail.com +L: linux-erofs@lists.ozlabs.org +S: Maintained +F: fs/erofs/ +F: include/erofs.h + FASTBOOT S: Orphaned F: cmd/fastboot.c diff --git a/fs/Kconfig b/fs/Kconfig index 620af7f044..cda9f66cc9 100644 --- a/fs/Kconfig +++ b/fs/Kconfig @@ -24,4 +24,6 @@ source "fs/yaffs2/Kconfig"
source "fs/squashfs/Kconfig"
+source "fs/erofs/Kconfig" + endmenu diff --git a/fs/Makefile b/fs/Makefile index 937cbcf6e8..f05a21c9e6 100644 --- a/fs/Makefile +++ b/fs/Makefile @@ -25,5 +25,6 @@ obj-$(CONFIG_CMD_UBIFS) += ubifs/ obj-$(CONFIG_YAFFS2) += yaffs2/ obj-$(CONFIG_CMD_ZFS) += zfs/ obj-$(CONFIG_FS_SQUASHFS) += squashfs/ +obj-$(CONFIG_FS_EROFS) += erofs/ endif obj-y += fs_internal.o diff --git a/fs/erofs/Kconfig b/fs/erofs/Kconfig new file mode 100644 index 0000000000..f4b2d51a23 --- /dev/null +++ b/fs/erofs/Kconfig @@ -0,0 +1,12 @@ +config FS_EROFS + bool "Enable EROFS filesystem support" + help + This provides support for reading images from EROFS filesystem. + EROFS (Enhanced Read-Only File System) is a lightweight read-only + file system for scenarios which need high-performance read-only + requirements. + + It also provides fixed-sized output compression support, which + improves storage density, keeps relatively higher compression + ratios, which is more useful to achieve high performance for + embedded devices with limited memory. diff --git a/fs/erofs/Makefile b/fs/erofs/Makefile new file mode 100644 index 0000000000..7398ab7a36 --- /dev/null +++ b/fs/erofs/Makefile @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-$(CONFIG_$(SPL_)FS_EROFS) = fs.o \ + super.o \ + namei.o \ + data.o diff --git a/fs/erofs/data.c b/fs/erofs/data.c new file mode 100644 index 0000000000..699975c1be --- /dev/null +++ b/fs/erofs/data.c @@ -0,0 +1,223 @@ +// SPDX-License-Identifier: GPL-2.0+ +#include "internal.h" + +static int erofs_map_blocks_flatmode(struct erofs_inode *inode, + struct erofs_map_blocks *map, + int flags) +{ + int err = 0; + erofs_blk_t nblocks, lastblk; + u64 offset = map->m_la; + struct erofs_inode *vi = inode; + bool tailendpacking = (vi->datalayout == EROFS_INODE_FLAT_INLINE); + + nblocks = DIV_ROUND_UP(inode->i_size, EROFS_BLKSIZ); + lastblk = nblocks - tailendpacking; + + /* there is no hole in flatmode */ + map->m_flags = EROFS_MAP_MAPPED; + + if (offset < blknr_to_addr(lastblk)) { + map->m_pa = blknr_to_addr(vi->u.i_blkaddr) + map->m_la; + map->m_plen = blknr_to_addr(lastblk) - offset; + } else if (tailendpacking) { + /* 2 - inode inline B: inode, [xattrs], inline last blk... */ + map->m_pa = iloc(vi->nid) + vi->inode_isize + + vi->xattr_isize + erofs_blkoff(map->m_la); + map->m_plen = inode->i_size - offset; + + /* inline data should be located in one meta block */ + if (erofs_blkoff(map->m_pa) + map->m_plen > PAGE_SIZE) { + erofs_err("inline data cross block boundary @ nid %" PRIu64, + vi->nid); + DBG_BUGON(1); + err = -EFSCORRUPTED; + goto err_out; + } + + map->m_flags |= EROFS_MAP_META; + } else { + erofs_err("internal error @ nid: %" PRIu64 " (size %llu), m_la 0x%" PRIx64, + vi->nid, (unsigned long long)inode->i_size, map->m_la); + DBG_BUGON(1); + err = -EIO; + goto err_out; + } + + map->m_llen = map->m_plen; +err_out: + return err; +} + +int erofs_map_blocks(struct erofs_inode *inode, + struct erofs_map_blocks *map, int flags) +{ + struct erofs_inode *vi = inode; + struct erofs_inode_chunk_index *idx; + u8 buf[EROFS_BLKSIZ]; + u64 chunknr; + unsigned int unit; + erofs_off_t pos; + int err = 0; + + map->m_deviceid = 0; + if (map->m_la >= inode->i_size) { + /* leave out-of-bound access unmapped */ + map->m_flags = 0; + map->m_plen = 0; + goto out; + } + + if (vi->datalayout != EROFS_INODE_CHUNK_BASED) + return erofs_map_blocks_flatmode(inode, map, flags); + + if (vi->u.chunkformat & EROFS_CHUNK_FORMAT_INDEXES) + unit = sizeof(*idx); /* chunk index */ + else + unit = EROFS_BLOCK_MAP_ENTRY_SIZE; /* block map */ + + chunknr = map->m_la >> vi->u.chunkbits; + pos = roundup(iloc(vi->nid) + vi->inode_isize + + vi->xattr_isize, unit) + unit * chunknr; + + err = erofs_blk_read(buf, erofs_blknr(pos), 1); + if (err < 0) + return -EIO; + + map->m_la = chunknr << vi->u.chunkbits; + map->m_plen = min_t(erofs_off_t, 1UL << vi->u.chunkbits, + roundup(inode->i_size - map->m_la, EROFS_BLKSIZ)); + + /* handle block map */ + if (!(vi->u.chunkformat & EROFS_CHUNK_FORMAT_INDEXES)) { + __le32 *blkaddr = (void *)buf + erofs_blkoff(pos); + + if (le32_to_cpu(*blkaddr) == EROFS_NULL_ADDR) { + map->m_flags = 0; + } else { + map->m_pa = blknr_to_addr(le32_to_cpu(*blkaddr)); + map->m_flags = EROFS_MAP_MAPPED; + } + goto out; + } + /* parse chunk indexes */ + idx = (void *)buf + erofs_blkoff(pos); + switch (le32_to_cpu(idx->blkaddr)) { + case EROFS_NULL_ADDR: + map->m_flags = 0; + break; + default: + map->m_deviceid = le16_to_cpu(idx->device_id) & + sbi.device_id_mask; + map->m_pa = blknr_to_addr(le32_to_cpu(idx->blkaddr)); + map->m_flags = EROFS_MAP_MAPPED; + break; + } +out: + map->m_llen = map->m_plen; + return err; +} + +int erofs_map_dev(struct erofs_sb_info *sbi, struct erofs_map_dev *map) +{ + struct erofs_device_info *dif; + int id; + + if (map->m_deviceid) { + if (sbi->extra_devices < map->m_deviceid) + return -ENODEV; + } else if (sbi->extra_devices) { + for (id = 0; id < sbi->extra_devices; ++id) { + erofs_off_t startoff, length; + + dif = sbi->devs + id; + if (!dif->mapped_blkaddr) + continue; + startoff = blknr_to_addr(dif->mapped_blkaddr); + length = blknr_to_addr(dif->blocks); + + if (map->m_pa >= startoff && + map->m_pa < startoff + length) { + map->m_pa -= startoff; + break; + } + } + } + return 0; +} + +static int erofs_read_raw_data(struct erofs_inode *inode, char *buffer, + erofs_off_t size, erofs_off_t offset) +{ + struct erofs_map_blocks map = { + .index = UINT_MAX, + }; + struct erofs_map_dev mdev; + int ret; + erofs_off_t ptr = offset; + + while (ptr < offset + size) { + char *const estart = buffer + ptr - offset; + erofs_off_t eend; + + map.m_la = ptr; + ret = erofs_map_blocks(inode, &map, 0); + if (ret) + return ret; + + DBG_BUGON(map.m_plen != map.m_llen); + + mdev = (struct erofs_map_dev) { + .m_deviceid = map.m_deviceid, + .m_pa = map.m_pa, + }; + ret = erofs_map_dev(&sbi, &mdev); + if (ret) + return ret; + + /* trim extent */ + eend = min(offset + size, map.m_la + map.m_llen); + DBG_BUGON(ptr < map.m_la); + + if (!(map.m_flags & EROFS_MAP_MAPPED)) { + if (!map.m_llen) { + /* reached EOF */ + memset(estart, 0, offset + size - ptr); + ptr = offset + size; + continue; + } + memset(estart, 0, eend - ptr); + ptr = eend; + continue; + } + + if (ptr > map.m_la) { + mdev.m_pa += ptr - map.m_la; + map.m_la = ptr; + } + + ret = erofs_dev_read(mdev.m_deviceid, estart, mdev.m_pa, + eend - map.m_la); + if (ret < 0) + return -EIO; + ptr = eend; + } + return 0; +} + +int erofs_pread(struct erofs_inode *inode, char *buf, + erofs_off_t count, erofs_off_t offset) +{ + switch (inode->datalayout) { + case EROFS_INODE_FLAT_PLAIN: + case EROFS_INODE_FLAT_INLINE: + case EROFS_INODE_CHUNK_BASED: + return erofs_read_raw_data(inode, buf, count, offset); + case EROFS_INODE_FLAT_COMPRESSION_LEGACY: + case EROFS_INODE_FLAT_COMPRESSION: + return -EOPNOTSUPP; + default: + break; + } + return -EINVAL; +} diff --git a/fs/erofs/erofs_fs.h b/fs/erofs/erofs_fs.h new file mode 100644 index 0000000000..6b62c7a4f5 --- /dev/null +++ b/fs/erofs/erofs_fs.h @@ -0,0 +1,436 @@ +/* SPDX-License-Identifier: GPL-2.0-only OR Apache-2.0 */ +/* + * EROFS (Enhanced ROM File System) on-disk format definition + * + * Copyright (C) 2017-2018 HUAWEI, Inc. + * http://www.huawei.com/ + * Copyright (C) 2021, Alibaba Cloud + */ +#ifndef __EROFS_FS_H +#define __EROFS_FS_H + +#include <asm/unaligned.h> +#include <fs.h> +#include <part.h> +#include <stdint.h> +#include <compiler.h> + +#define EROFS_SUPER_MAGIC_V1 0xE0F5E1E2 +#define EROFS_SUPER_OFFSET 1024 + +#define EROFS_FEATURE_COMPAT_SB_CHKSUM 0x00000001 + +/* + * Any bits that aren't in EROFS_ALL_FEATURE_INCOMPAT should + * be incompatible with this kernel version. + */ +#define EROFS_FEATURE_INCOMPAT_LZ4_0PADDING 0x00000001 +#define EROFS_FEATURE_INCOMPAT_COMPR_CFGS 0x00000002 +#define EROFS_FEATURE_INCOMPAT_BIG_PCLUSTER 0x00000002 +#define EROFS_FEATURE_INCOMPAT_CHUNKED_FILE 0x00000004 +#define EROFS_FEATURE_INCOMPAT_DEVICE_TABLE 0x00000008 +#define EROFS_ALL_FEATURE_INCOMPAT \ + (EROFS_FEATURE_INCOMPAT_LZ4_0PADDING | \ + EROFS_FEATURE_INCOMPAT_COMPR_CFGS | \ + EROFS_FEATURE_INCOMPAT_BIG_PCLUSTER | \ + EROFS_FEATURE_INCOMPAT_CHUNKED_FILE | \ + EROFS_FEATURE_INCOMPAT_DEVICE_TABLE) + +#define EROFS_SB_EXTSLOT_SIZE 16 + +struct erofs_deviceslot { + union { + u8 uuid[16]; /* used for device manager later */ + u8 userdata[64]; /* digest(sha256), etc. */ + } u; + __le32 blocks; /* total fs blocks of this device */ + __le32 mapped_blkaddr; /* map starting at mapped_blkaddr */ + u8 reserved[56]; +}; + +#define EROFS_DEVT_SLOT_SIZE sizeof(struct erofs_deviceslot) + +/* erofs on-disk super block (currently 128 bytes) */ +struct erofs_super_block { + __le32 magic; /* file system magic number */ + __le32 checksum; /* crc32c(super_block) */ + __le32 feature_compat; + __u8 blkszbits; /* support block_size == PAGE_SIZE only */ + __u8 sb_extslots; /* superblock size = 128 + sb_extslots * 16 */ + + __le16 root_nid; /* nid of root directory */ + __le64 inos; /* total valid ino # (== f_files - f_favail) */ + + __le64 build_time; /* inode v1 time derivation */ + __le32 build_time_nsec; /* inode v1 time derivation in nano scale */ + __le32 blocks; /* used for statfs */ + __le32 meta_blkaddr; /* start block address of metadata area */ + __le32 xattr_blkaddr; /* start block address of shared xattr area */ + __u8 uuid[16]; /* 128-bit uuid for volume */ + __u8 volume_name[16]; /* volume name */ + __le32 feature_incompat; + union { + /* bitmap for available compression algorithms */ + __le16 available_compr_algs; + /* customized sliding window size instead of 64k by default */ + __le16 lz4_max_distance; + } __packed u1; + __le16 extra_devices; /* # of devices besides the primary device */ + __le16 devt_slotoff; /* startoff = devt_slotoff * devt_slotsize */ + __u8 reserved2[38]; +}; + +/* + * erofs inode datalayout (i_format in on-disk inode): + * 0 - inode plain without inline data A: + * inode, [xattrs], ... | ... | no-holed data + * 1 - inode VLE compression B (legacy): + * inode, [xattrs], extents ... | ... + * 2 - inode plain with inline data C: + * inode, [xattrs], last_inline_data, ... | ... | no-holed data + * 3 - inode compression D: + * inode, [xattrs], map_header, extents ... | ... + * 4 - inode chunk-based E: + * inode, [xattrs], chunk indexes ... | ... + * 5~7 - reserved + */ +enum { + EROFS_INODE_FLAT_PLAIN = 0, + EROFS_INODE_FLAT_COMPRESSION_LEGACY = 1, + EROFS_INODE_FLAT_INLINE = 2, + EROFS_INODE_FLAT_COMPRESSION = 3, + EROFS_INODE_CHUNK_BASED = 4, + EROFS_INODE_DATALAYOUT_MAX +}; + +static inline bool erofs_inode_is_data_compressed(unsigned int datamode) +{ + return datamode == EROFS_INODE_FLAT_COMPRESSION || + datamode == EROFS_INODE_FLAT_COMPRESSION_LEGACY; +} + +/* bit definitions of inode i_advise */ +#define EROFS_I_VERSION_BITS 1 +#define EROFS_I_DATALAYOUT_BITS 3 + +#define EROFS_I_VERSION_BIT 0 +#define EROFS_I_DATALAYOUT_BIT 1 + +#define EROFS_I_ALL \ + ((1 << (EROFS_I_DATALAYOUT_BIT + EROFS_I_DATALAYOUT_BITS)) - 1) + +/* indicate chunk blkbits, thus 'chunksize = blocksize << chunk blkbits' */ +#define EROFS_CHUNK_FORMAT_BLKBITS_MASK 0x001F +/* with chunk indexes or just a 4-byte blkaddr array */ +#define EROFS_CHUNK_FORMAT_INDEXES 0x0020 + +#define EROFS_CHUNK_FORMAT_ALL \ + (EROFS_CHUNK_FORMAT_BLKBITS_MASK | EROFS_CHUNK_FORMAT_INDEXES) + +struct erofs_inode_chunk_info { + __le16 format; /* chunk blkbits, etc. */ + __le16 reserved; +}; + +/* 32-byte reduced form of an ondisk inode */ +struct erofs_inode_compact { + __le16 i_format; /* inode format hints */ + +/* 1 header + n-1 * 4 bytes inline xattr to keep continuity */ + __le16 i_xattr_icount; + __le16 i_mode; + __le16 i_nlink; + __le32 i_size; + __le32 i_reserved; + union { + /* file total compressed blocks for data mapping 1 */ + __le32 compressed_blocks; + __le32 raw_blkaddr; + + /* for device files, used to indicate old/new device # */ + __le32 rdev; + + /* for chunk-based files, it contains the summary info */ + struct erofs_inode_chunk_info c; + } i_u; + __le32 i_ino; /* only used for 32-bit stat compatibility */ + __le16 i_uid; + __le16 i_gid; + __le32 i_reserved2; +}; + +/* 32 bytes on-disk inode */ +#define EROFS_INODE_LAYOUT_COMPACT 0 +/* 64 bytes on-disk inode */ +#define EROFS_INODE_LAYOUT_EXTENDED 1 + +/* 64-byte complete form of an ondisk inode */ +struct erofs_inode_extended { + __le16 i_format; /* inode format hints */ + +/* 1 header + n-1 * 4 bytes inline xattr to keep continuity */ + __le16 i_xattr_icount; + __le16 i_mode; + __le16 i_reserved; + __le64 i_size; + union { + /* file total compressed blocks for data mapping 1 */ + __le32 compressed_blocks; + __le32 raw_blkaddr; + + /* for device files, used to indicate old/new device # */ + __le32 rdev; + + /* for chunk-based files, it contains the summary info */ + struct erofs_inode_chunk_info c; + } i_u; + + /* only used for 32-bit stat compatibility */ + __le32 i_ino; + + __le32 i_uid; + __le32 i_gid; + __le64 i_ctime; + __le32 i_ctime_nsec; + __le32 i_nlink; + __u8 i_reserved2[16]; +}; + +#define EROFS_MAX_SHARED_XATTRS (128) +/* h_shared_count between 129 ... 255 are special # */ +#define EROFS_SHARED_XATTR_EXTENT (255) + +/* + * inline xattrs (n == i_xattr_icount): + * erofs_xattr_ibody_header(1) + (n - 1) * 4 bytes + * 12 bytes / \ + * / \ + * /-----------------------\ + * | erofs_xattr_entries+ | + * +-----------------------+ + * inline xattrs must starts in erofs_xattr_ibody_header, + * for read-only fs, no need to introduce h_refcount + */ +struct erofs_xattr_ibody_header { + __le32 h_reserved; + __u8 h_shared_count; + __u8 h_reserved2[7]; + __le32 h_shared_xattrs[0]; /* shared xattr id array */ +}; + +/* Name indexes */ +#define EROFS_XATTR_INDEX_USER 1 +#define EROFS_XATTR_INDEX_POSIX_ACL_ACCESS 2 +#define EROFS_XATTR_INDEX_POSIX_ACL_DEFAULT 3 +#define EROFS_XATTR_INDEX_TRUSTED 4 +#define EROFS_XATTR_INDEX_LUSTRE 5 +#define EROFS_XATTR_INDEX_SECURITY 6 + +/* xattr entry (for both inline & shared xattrs) */ +struct erofs_xattr_entry { + __u8 e_name_len; /* length of name */ + __u8 e_name_index; /* attribute name index */ + __le16 e_value_size; /* size of attribute value */ + /* followed by e_name and e_value */ + char e_name[0]; /* attribute name */ +}; + +static inline unsigned int erofs_xattr_ibody_size(__le16 i_xattr_icount) +{ + if (!i_xattr_icount) + return 0; + + return sizeof(struct erofs_xattr_ibody_header) + + sizeof(__u32) * (le16_to_cpu(i_xattr_icount) - 1); +} + +#define EROFS_XATTR_ALIGN(size) round_up(size, sizeof(struct erofs_xattr_entry)) + +static inline unsigned int erofs_xattr_entry_size(struct erofs_xattr_entry *e) +{ + return EROFS_XATTR_ALIGN(sizeof(struct erofs_xattr_entry) + + e->e_name_len + le16_to_cpu(e->e_value_size)); +} + +/* represent a zeroed chunk (hole) */ +#define EROFS_NULL_ADDR -1 + +/* 4-byte block address array */ +#define EROFS_BLOCK_MAP_ENTRY_SIZE sizeof(__le32) + +/* 8-byte inode chunk indexes */ +struct erofs_inode_chunk_index { + __le16 advise; /* always 0, don't care for now */ + __le16 device_id; /* back-end storage id (with bits masked) */ + __le32 blkaddr; /* start block address of this inode chunk */ +}; + +/* maximum supported size of a physical compression cluster */ +#define Z_EROFS_PCLUSTER_MAX_SIZE (1024 * 1024) + +/* available compression algorithm types (for h_algorithmtype) */ +enum { + Z_EROFS_COMPRESSION_LZ4 = 0, + Z_EROFS_COMPRESSION_LZMA = 1, + Z_EROFS_COMPRESSION_MAX +}; + +#define Z_EROFS_ALL_COMPR_ALGS (1 << (Z_EROFS_COMPRESSION_MAX - 1)) + +/* 14 bytes (+ length field = 16 bytes) */ +struct z_erofs_lz4_cfgs { + __le16 max_distance; + __le16 max_pclusterblks; + u8 reserved[10]; +} __packed; + +/* 14 bytes (+ length field = 16 bytes) */ +struct z_erofs_lzma_cfgs { + __le32 dict_size; + __le16 format; + u8 reserved[8]; +} __packed; +#define Z_EROFS_LZMA_MAX_DICT_SIZE (8 * Z_EROFS_PCLUSTER_MAX_SIZE) + +/* + * bit 0 : COMPACTED_2B indexes (0 - off; 1 - on) + * e.g. for 4k logical cluster size, 4B if compacted 2B is off; + * (4B) + 2B + (4B) if compacted 2B is on. + * bit 1 : HEAD1 big pcluster (0 - off; 1 - on) + * bit 2 : HEAD2 big pcluster (0 - off; 1 - on) + */ +#define Z_EROFS_ADVISE_COMPACTED_2B 0x0001 +#define Z_EROFS_ADVISE_BIG_PCLUSTER_1 0x0002 +#define Z_EROFS_ADVISE_BIG_PCLUSTER_2 0x0004 + +struct z_erofs_map_header { + __le32 h_reserved1; + __le16 h_advise; + /* + * bit 0-3 : algorithm type of head 1 (logical cluster type 01); + * bit 4-7 : algorithm type of head 2 (logical cluster type 11). + */ + __u8 h_algorithmtype; + /* + * bit 0-2 : logical cluster bits - 12, e.g. 0 for 4096; + * bit 3-7 : reserved. + */ + __u8 h_clusterbits; +}; + +#define Z_EROFS_VLE_LEGACY_HEADER_PADDING 8 + +/* + * Fixed-sized output compression ondisk Logical Extent cluster type: + * 0 - literal (uncompressed) cluster + * 1 - compressed cluster (for the head logical cluster) + * 2 - compressed cluster (for the other logical clusters) + * + * In detail, + * 0 - literal (uncompressed) cluster, + * di_advise = 0 + * di_clusterofs = the literal data offset of the cluster + * di_blkaddr = the blkaddr of the literal cluster + * + * 1 - compressed cluster (for the head logical cluster) + * di_advise = 1 + * di_clusterofs = the decompressed data offset of the cluster + * di_blkaddr = the blkaddr of the compressed cluster + * + * 2 - compressed cluster (for the other logical clusters) + * di_advise = 2 + * di_clusterofs = + * the decompressed data offset in its own head cluster + * di_u.delta[0] = distance to its corresponding head cluster + * di_u.delta[1] = distance to its corresponding tail cluster + * (di_advise could be 0, 1 or 2) + */ +enum { + Z_EROFS_VLE_CLUSTER_TYPE_PLAIN = 0, + Z_EROFS_VLE_CLUSTER_TYPE_HEAD = 1, + Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD = 2, + Z_EROFS_VLE_CLUSTER_TYPE_RESERVED = 3, + Z_EROFS_VLE_CLUSTER_TYPE_MAX +}; + +#define Z_EROFS_VLE_DI_CLUSTER_TYPE_BITS 2 +#define Z_EROFS_VLE_DI_CLUSTER_TYPE_BIT 0 + +/* + * D0_CBLKCNT will be marked _only_ at the 1st non-head lcluster to store the + * compressed block count of a compressed extent (in logical clusters, aka. + * block count of a pcluster). + */ +#define Z_EROFS_VLE_DI_D0_CBLKCNT (1 << 11) + +struct z_erofs_vle_decompressed_index { + __le16 di_advise; + /* where to decompress in the head cluster */ + __le16 di_clusterofs; + + union { + /* for the head cluster */ + __le32 blkaddr; + /* + * for the rest clusters + * eg. for 4k page-sized cluster, maximum 4K*64k = 256M) + * [0] - pointing to the head cluster + * [1] - pointing to the tail cluster + */ + __le16 delta[2]; + } di_u; +}; + +#define Z_EROFS_VLE_LEGACY_INDEX_ALIGN(size) \ + (round_up(size, sizeof(struct z_erofs_vle_decompressed_index)) + \ + sizeof(struct z_erofs_map_header) + Z_EROFS_VLE_LEGACY_HEADER_PADDING) + +#define Z_EROFS_VLE_EXTENT_ALIGN(size) round_up(size, \ + sizeof(struct z_erofs_vle_decompressed_index)) + +/* dirent sorts in alphabet order, thus we can do binary search */ +struct erofs_dirent { + __le64 nid; /* node number */ + __le16 nameoff; /* start offset of file name */ + __u8 file_type; /* file type */ + __u8 reserved; /* reserved */ +} __packed; + +/* file types used in inode_info->flags */ +enum { + EROFS_FT_UNKNOWN, + EROFS_FT_REG_FILE, + EROFS_FT_DIR, + EROFS_FT_CHRDEV, + EROFS_FT_BLKDEV, + EROFS_FT_FIFO, + EROFS_FT_SOCK, + EROFS_FT_SYMLINK, + EROFS_FT_MAX +}; + +#define EROFS_NAME_LEN 255 + +/* check the EROFS on-disk layout strictly at compile time */ +static inline void erofs_check_ondisk_layout_definitions(void) +{ + BUILD_BUG_ON(sizeof(struct erofs_super_block) != 128); + BUILD_BUG_ON(sizeof(struct erofs_inode_compact) != 32); + BUILD_BUG_ON(sizeof(struct erofs_inode_extended) != 64); + BUILD_BUG_ON(sizeof(struct erofs_xattr_ibody_header) != 12); + BUILD_BUG_ON(sizeof(struct erofs_xattr_entry) != 4); + BUILD_BUG_ON(sizeof(struct erofs_inode_chunk_info) != 4); + BUILD_BUG_ON(sizeof(struct erofs_inode_chunk_index) != 8); + BUILD_BUG_ON(sizeof(struct z_erofs_map_header) != 8); + BUILD_BUG_ON(sizeof(struct z_erofs_vle_decompressed_index) != 8); + BUILD_BUG_ON(sizeof(struct erofs_dirent) != 12); + /* keep in sync between 2 index structures for better extendibility */ + BUILD_BUG_ON(sizeof(struct erofs_inode_chunk_index) != + sizeof(struct z_erofs_vle_decompressed_index)); + BUILD_BUG_ON(sizeof(struct erofs_deviceslot) != 128); + + BUILD_BUG_ON(BIT(Z_EROFS_VLE_DI_CLUSTER_TYPE_BITS) < + Z_EROFS_VLE_CLUSTER_TYPE_MAX - 1); +} + +#endif diff --git a/fs/erofs/fs.c b/fs/erofs/fs.c new file mode 100644 index 0000000000..89269750f8 --- /dev/null +++ b/fs/erofs/fs.c @@ -0,0 +1,267 @@ +// SPDX-License-Identifier: GPL-2.0+ +#include "internal.h" +#include <fs_internal.h> + +struct erofs_sb_info sbi; + +static struct erofs_ctxt { + struct disk_partition cur_part_info; + struct blk_desc *cur_dev; +} ctxt; + +int erofs_dev_read(int device_id, void *buf, u64 offset, size_t len) +{ + lbaint_t sect = offset >> ctxt.cur_dev->log2blksz; + int off = offset & (ctxt.cur_dev->blksz - 1); + + if (!ctxt.cur_dev) + return -EIO; + + if (fs_devread(ctxt.cur_dev, &ctxt.cur_part_info, sect, + off, len, buf)) + return 0; + return -EIO; +} + +int erofs_blk_read(void *buf, erofs_blk_t start, u32 nblocks) +{ + return erofs_dev_read(0, buf, blknr_to_addr(start), + blknr_to_addr(nblocks)); +} + +int erofs_probe(struct blk_desc *fs_dev_desc, + struct disk_partition *fs_partition) +{ + int ret; + + ctxt.cur_dev = fs_dev_desc; + ctxt.cur_part_info = *fs_partition; + + ret = erofs_read_superblock(); + if (ret) + goto error; + + return 0; +error: + ctxt.cur_dev = NULL; + return ret; +} + +struct erofs_dir_stream { + struct fs_dir_stream fs_dirs; + struct fs_dirent dirent; + + struct erofs_inode inode; + char dblk[EROFS_BLKSIZ]; + unsigned int maxsize, de_end; + erofs_off_t pos; +}; + +static int erofs_readlink(struct erofs_inode *vi) +{ + size_t len = vi->i_size; + char *target; + int err; + + target = malloc(len + 1); + if (!target) + return -ENOMEM; + target[len] = '\0'; + + err = erofs_pread(vi, target, len, 0); + if (err) + goto err_out; + + err = erofs_ilookup(target, vi); + if (err) + goto err_out; + +err_out: + free(target); + return err; +} + +int erofs_opendir(const char *filename, struct fs_dir_stream **dirsp) +{ + struct erofs_dir_stream *dirs; + int err; + + dirs = calloc(1, sizeof(*dirs)); + if (!dirs) + return -ENOMEM; + + err = erofs_ilookup(filename, &dirs->inode); + if (err) + goto err_out; + + if (S_ISLNK(dirs->inode.i_mode)) { + err = erofs_readlink(&dirs->inode); + if (err) + goto err_out; + } + + if (!S_ISDIR(dirs->inode.i_mode)) { + err = -ENOTDIR; + goto err_out; + } + *dirsp = (struct fs_dir_stream *)dirs; + return 0; +err_out: + free(dirs); + return err; +} + +int erofs_readdir(struct fs_dir_stream *fs_dirs, struct fs_dirent **dentp) +{ + struct erofs_dir_stream *dirs = (struct erofs_dir_stream *)fs_dirs; + struct fs_dirent *dent = &dirs->dirent; + erofs_off_t pos = dirs->pos; + unsigned int nameoff, de_namelen; + struct erofs_dirent *de; + char *de_name; + int err; + + if (pos >= dirs->inode.i_size) + return 1; + + if (!dirs->maxsize) { + dirs->maxsize = min_t(unsigned int, EROFS_BLKSIZ, + dirs->inode.i_size - pos); + + err = erofs_pread(&dirs->inode, dirs->dblk, + dirs->maxsize, pos); + if (err) + return err; + + de = (struct erofs_dirent *)dirs->dblk; + dirs->de_end = le16_to_cpu(de->nameoff); + if (dirs->de_end < sizeof(struct erofs_dirent) || + dirs->de_end >= EROFS_BLKSIZ) { + erofs_err("invalid de[0].nameoff %u @ nid %llu", + dirs->de_end, de->nid | 0ULL); + return -EFSCORRUPTED; + } + } + + de = (struct erofs_dirent *)(dirs->dblk + erofs_blkoff(pos)); + nameoff = le16_to_cpu(de->nameoff); + de_name = (char *)dirs->dblk + nameoff; + + /* the last dirent in the block? */ + if (de + 1 >= (struct erofs_dirent *)(dirs->dblk + dirs->de_end)) + de_namelen = strnlen(de_name, dirs->maxsize - nameoff); + else + de_namelen = le16_to_cpu(de[1].nameoff) - nameoff; + + /* a corrupted entry is found */ + if (nameoff + de_namelen > dirs->maxsize || + de_namelen > EROFS_NAME_LEN) { + erofs_err("bogus dirent @ nid %llu", de->nid | 0ULL); + DBG_BUGON(1); + return -EFSCORRUPTED; + } + + memcpy(dent->name, de_name, de_namelen); + dent->name[de_namelen] = '\0'; + + if (de->file_type == EROFS_FT_DIR) { + dent->type = FS_DT_DIR; + } else if (de->file_type == EROFS_FT_SYMLINK) { + dent->type = FS_DT_LNK; + } else { + struct erofs_inode vi; + + dent->type = FS_DT_REG; + vi.nid = de->nid; + + err = erofs_read_inode_from_disk(&vi); + if (err) + return err; + dent->size = vi.i_size; + } + *dentp = dent; + + pos += sizeof(*de); + if (erofs_blkoff(pos) >= dirs->de_end) { + pos = blknr_to_addr(erofs_blknr(pos) + 1); + dirs->maxsize = 0; + } + dirs->pos = pos; + return 0; +} + +void erofs_closedir(struct fs_dir_stream *fs_dirs) +{ + free(fs_dirs); +} + +int erofs_exists(const char *filename) +{ + struct erofs_inode vi; + int err; + + err = erofs_ilookup(filename, &vi); + return err == 0; +} + +int erofs_size(const char *filename, loff_t *size) +{ + struct erofs_inode vi; + int err; + + err = erofs_ilookup(filename, &vi); + if (err) + return err; + *size = vi.i_size; + return 0; +} + +int erofs_read(const char *filename, void *buf, loff_t offset, loff_t len, + loff_t *actread) +{ + struct erofs_inode vi; + int err; + + err = erofs_ilookup(filename, &vi); + if (err) + return err; + + if (S_ISLNK(vi.i_mode)) { + err = erofs_readlink(&vi); + if (err) + return err; + } + + if (!len) + len = vi.i_size; + + err = erofs_pread(&vi, buf, len, offset); + if (err) { + *actread = 0; + return err; + } + + if (offset >= vi.i_size) + *actread = 0; + else if (offset + len > vi.i_size) + *actread = vi.i_size - offset; + else + *actread = len; + return 0; +} + +void erofs_close(void) +{ + ctxt.cur_dev = NULL; +} + +int erofs_uuid(char *uuid_str) +{ + if (IS_ENABLED(CONFIG_LIB_UUID)) { + if (ctxt.cur_dev) + uuid_bin_to_str(sbi.uuid, uuid_str, + UUID_STR_FORMAT_STD); + return 0; + } + return -ENOSYS; +} diff --git a/fs/erofs/internal.h b/fs/erofs/internal.h new file mode 100644 index 0000000000..4af7c91560 --- /dev/null +++ b/fs/erofs/internal.h @@ -0,0 +1,313 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +#ifndef __EROFS_INTERNAL_H +#define __EROFS_INTERNAL_H + +#define __packed __attribute__((__packed__)) + +#include <linux/stat.h> +#include <linux/bug.h> +#include <linux/err.h> +#include <linux/printk.h> +#include <linux/log2.h> +#include <inttypes.h> +#include "erofs_fs.h" + +#define erofs_err(fmt, ...) \ + pr_err(fmt "\n", ##__VA_ARGS__) + +#define erofs_info(fmt, ...) \ + pr_info(fmt "\n", ##__VA_ARGS__) + +#define erofs_dbg(fmt, ...) \ + pr_debug(fmt "\n", ##__VA_ARGS__) + +#define DBG_BUGON(condition) BUG_ON(condition) + +/* no obvious reason to support explicit PAGE_SIZE != 4096 for now */ +#if PAGE_SIZE != 4096 +#error incompatible PAGE_SIZE is already defined +#endif + +#define PAGE_MASK (~(PAGE_SIZE - 1)) + +#define LOG_BLOCK_SIZE (12) +#define EROFS_BLKSIZ (1U << LOG_BLOCK_SIZE) + +#define EROFS_ISLOTBITS 5 +#define EROFS_SLOTSIZE (1U << EROFS_ISLOTBITS) + +typedef u64 erofs_off_t; +typedef u64 erofs_nid_t; +/* data type for filesystem-wide blocks number */ +typedef u32 erofs_blk_t; + +#define NULL_ADDR ((unsigned int)-1) +#define NULL_ADDR_UL ((unsigned long)-1) + +#define erofs_blknr(addr) ((addr) / EROFS_BLKSIZ) +#define erofs_blkoff(addr) ((addr) % EROFS_BLKSIZ) +#define blknr_to_addr(nr) ((erofs_off_t)(nr) * EROFS_BLKSIZ) + +#define BLK_ROUND_UP(addr) DIV_ROUND_UP(addr, EROFS_BLKSIZ) + +struct erofs_buffer_head; + +struct erofs_device_info { + u32 blocks; + u32 mapped_blkaddr; +}; + +struct erofs_sb_info { + struct erofs_device_info *devs; + + u64 total_blocks; + u64 primarydevice_blocks; + + erofs_blk_t meta_blkaddr; + erofs_blk_t xattr_blkaddr; + + u32 feature_compat; + u32 feature_incompat; + u64 build_time; + u32 build_time_nsec; + + unsigned char islotbits; + + /* what we really care is nid, rather than ino.. */ + erofs_nid_t root_nid; + /* used for statfs, f_files - f_favail */ + u64 inos; + + u8 uuid[16]; + + u16 available_compr_algs; + u16 lz4_max_distance; + u32 checksum; + u16 extra_devices; + union { + u16 devt_slotoff; /* used for mkfs */ + u16 device_id_mask; /* used for others */ + }; +}; + +/* global sbi */ +extern struct erofs_sb_info sbi; + +static inline erofs_off_t iloc(erofs_nid_t nid) +{ + return blknr_to_addr(sbi.meta_blkaddr) + (nid << sbi.islotbits); +} + +#define EROFS_FEATURE_FUNCS(name, compat, feature) \ +static inline bool erofs_sb_has_##name(void) \ +{ \ + return sbi.feature_##compat & EROFS_FEATURE_##feature; \ +} \ +static inline void erofs_sb_set_##name(void) \ +{ \ + sbi.feature_##compat |= EROFS_FEATURE_##feature; \ +} \ +static inline void erofs_sb_clear_##name(void) \ +{ \ + sbi.feature_##compat &= ~EROFS_FEATURE_##feature; \ +} + +EROFS_FEATURE_FUNCS(lz4_0padding, incompat, INCOMPAT_LZ4_0PADDING) +EROFS_FEATURE_FUNCS(compr_cfgs, incompat, INCOMPAT_COMPR_CFGS) +EROFS_FEATURE_FUNCS(big_pcluster, incompat, INCOMPAT_BIG_PCLUSTER) +EROFS_FEATURE_FUNCS(chunked_file, incompat, INCOMPAT_CHUNKED_FILE) +EROFS_FEATURE_FUNCS(device_table, incompat, INCOMPAT_DEVICE_TABLE) +EROFS_FEATURE_FUNCS(sb_chksum, compat, COMPAT_SB_CHKSUM) + +#define EROFS_I_EA_INITED (1 << 0) +#define EROFS_I_Z_INITED (1 << 1) + +struct erofs_inode { + struct list_head i_hash, i_subdirs, i_xattrs; + + union { + /* (erofsfuse) runtime flags */ + unsigned int flags; + /* (mkfs.erofs) device ID containing source file */ + u32 dev; + }; + unsigned int i_count; + struct erofs_inode *i_parent; + + umode_t i_mode; + erofs_off_t i_size; + + u64 i_ino[2]; + u32 i_uid; + u32 i_gid; + u64 i_ctime; + u32 i_ctime_nsec; + u32 i_nlink; + + union { + u32 i_blkaddr; + u32 i_blocks; + u32 i_rdev; + struct { + unsigned short chunkformat; + unsigned char chunkbits; + }; + } u; + + unsigned char datalayout; + unsigned char inode_isize; + /* inline tail-end packing size */ + unsigned short idata_size; + + unsigned int xattr_isize; + unsigned int extent_isize; + + erofs_nid_t nid; + struct erofs_buffer_head *bh; + struct erofs_buffer_head *bh_inline, *bh_data; + + void *idata; + + union { + void *compressmeta; + void *chunkindexes; + struct { + uint16_t z_advise; + uint8_t z_algorithmtype[2]; + uint8_t z_logical_clusterbits; + uint8_t z_physical_clusterblks; + }; + }; +}; + +static inline bool is_inode_layout_compression(struct erofs_inode *inode) +{ + return erofs_inode_is_data_compressed(inode->datalayout); +} + +static inline unsigned int erofs_bitrange(unsigned int value, unsigned int bit, + unsigned int bits) +{ + return (value >> bit) & ((1 << bits) - 1); +} + +static inline unsigned int erofs_inode_version(unsigned int value) +{ + return erofs_bitrange(value, EROFS_I_VERSION_BIT, + EROFS_I_VERSION_BITS); +} + +static inline unsigned int erofs_inode_datalayout(unsigned int value) +{ + return erofs_bitrange(value, EROFS_I_DATALAYOUT_BIT, + EROFS_I_DATALAYOUT_BITS); +} + +#define IS_ROOT(x) ((x) == (x)->i_parent) + +struct erofs_dentry { + struct list_head d_child; /* child of parent list */ + + unsigned int type; + char name[EROFS_NAME_LEN]; + union { + struct erofs_inode *inode; + erofs_nid_t nid; + }; +}; + +static inline bool is_dot_dotdot(const char *name) +{ + if (name[0] != '.') + return false; + + return name[1] == '\0' || (name[1] == '.' && name[2] == '\0'); +} + +enum { + BH_Meta, + BH_Mapped, + BH_Encoded, + BH_FullMapped, +}; + +/* Has a disk mapping */ +#define EROFS_MAP_MAPPED (1 << BH_Mapped) +/* Located in metadata (could be copied from bd_inode) */ +#define EROFS_MAP_META (1 << BH_Meta) +/* The extent is encoded */ +#define EROFS_MAP_ENCODED (1 << BH_Encoded) +/* The length of extent is full */ +#define EROFS_MAP_FULL_MAPPED (1 << BH_FullMapped) + +struct erofs_map_blocks { + char mpage[EROFS_BLKSIZ]; + + erofs_off_t m_pa, m_la; + u64 m_plen, m_llen; + + unsigned short m_deviceid; + char m_algorithmformat; + unsigned int m_flags; + erofs_blk_t index; +}; + +/* + * Used to get the exact decompressed length, e.g. fiemap (consider lookback + * approach instead if possible since it's more metadata lightweight.) + */ +#define EROFS_GET_BLOCKS_FIEMAP 0x0002 + +enum { + Z_EROFS_COMPRESSION_SHIFTED = Z_EROFS_COMPRESSION_MAX, + Z_EROFS_COMPRESSION_RUNTIME_MAX +}; + +struct erofs_map_dev { + erofs_off_t m_pa; + unsigned int m_deviceid; +}; + +/* fs.c */ +int erofs_blk_read(void *buf, erofs_blk_t start, u32 nblocks); +int erofs_dev_read(int device_id, void *buf, u64 offset, size_t len); + +/* super.c */ +int erofs_read_superblock(void); + +/* namei.c */ +int erofs_read_inode_from_disk(struct erofs_inode *vi); +int erofs_ilookup(const char *path, struct erofs_inode *vi); +int erofs_read_inode_from_disk(struct erofs_inode *vi); + +/* data.c */ +int erofs_pread(struct erofs_inode *inode, char *buf, + erofs_off_t count, erofs_off_t offset); +int erofs_map_blocks(struct erofs_inode *inode, + struct erofs_map_blocks *map, int flags); +int erofs_map_dev(struct erofs_sb_info *sbi, struct erofs_map_dev *map); +/* zmap.c */ +int z_erofs_fill_inode(struct erofs_inode *vi); +int z_erofs_map_blocks_iter(struct erofs_inode *vi, + struct erofs_map_blocks *map, int flags); + +#ifdef EUCLEAN +#define EFSCORRUPTED EUCLEAN /* Filesystem is corrupted */ +#else +#define EFSCORRUPTED EIO +#endif + +#define CRC32C_POLY_LE 0x82F63B78 +static inline u32 erofs_crc32c(u32 crc, const u8 *in, size_t len) +{ + int i; + + while (len--) { + crc ^= *in++; + for (i = 0; i < 8; i++) + crc = (crc >> 1) ^ ((crc & 1) ? CRC32C_POLY_LE : 0); + } + return crc; +} + +#endif diff --git a/fs/erofs/namei.c b/fs/erofs/namei.c new file mode 100644 index 0000000000..f1195a09ea --- /dev/null +++ b/fs/erofs/namei.c @@ -0,0 +1,252 @@ +// SPDX-License-Identifier: GPL-2.0+ +#include "internal.h" + +int erofs_read_inode_from_disk(struct erofs_inode *vi) +{ + int ret, ifmt; + char buf[sizeof(struct erofs_inode_extended)]; + struct erofs_inode_compact *dic; + struct erofs_inode_extended *die; + const erofs_off_t inode_loc = iloc(vi->nid); + + ret = erofs_dev_read(0, buf, inode_loc, sizeof(*dic)); + if (ret < 0) + return -EIO; + + dic = (struct erofs_inode_compact *)buf; + ifmt = le16_to_cpu(dic->i_format); + + vi->datalayout = erofs_inode_datalayout(ifmt); + if (vi->datalayout >= EROFS_INODE_DATALAYOUT_MAX) { + erofs_err("unsupported datalayout %u of nid %llu", + vi->datalayout, vi->nid | 0ULL); + return -EOPNOTSUPP; + } + switch (erofs_inode_version(ifmt)) { + case EROFS_INODE_LAYOUT_EXTENDED: + vi->inode_isize = sizeof(struct erofs_inode_extended); + + ret = erofs_dev_read(0, buf + sizeof(*dic), inode_loc + sizeof(*dic), + sizeof(*die) - sizeof(*dic)); + if (ret < 0) + return -EIO; + + die = (struct erofs_inode_extended *)buf; + vi->xattr_isize = erofs_xattr_ibody_size(die->i_xattr_icount); + vi->i_mode = le16_to_cpu(die->i_mode); + + switch (vi->i_mode & S_IFMT) { + case S_IFREG: + case S_IFDIR: + case S_IFLNK: + vi->u.i_blkaddr = le32_to_cpu(die->i_u.raw_blkaddr); + break; + case S_IFCHR: + case S_IFBLK: + vi->u.i_rdev = 0; + break; + case S_IFIFO: + case S_IFSOCK: + vi->u.i_rdev = 0; + break; + default: + goto bogusimode; + } + + vi->i_uid = le32_to_cpu(die->i_uid); + vi->i_gid = le32_to_cpu(die->i_gid); + vi->i_nlink = le32_to_cpu(die->i_nlink); + + vi->i_ctime = le64_to_cpu(die->i_ctime); + vi->i_ctime_nsec = le64_to_cpu(die->i_ctime_nsec); + vi->i_size = le64_to_cpu(die->i_size); + if (vi->datalayout == EROFS_INODE_CHUNK_BASED) + /* fill chunked inode summary info */ + vi->u.chunkformat = le16_to_cpu(die->i_u.c.format); + break; + case EROFS_INODE_LAYOUT_COMPACT: + vi->inode_isize = sizeof(struct erofs_inode_compact); + vi->xattr_isize = erofs_xattr_ibody_size(dic->i_xattr_icount); + vi->i_mode = le16_to_cpu(dic->i_mode); + + switch (vi->i_mode & S_IFMT) { + case S_IFREG: + case S_IFDIR: + case S_IFLNK: + vi->u.i_blkaddr = le32_to_cpu(dic->i_u.raw_blkaddr); + break; + case S_IFCHR: + case S_IFBLK: + vi->u.i_rdev = 0; + break; + case S_IFIFO: + case S_IFSOCK: + vi->u.i_rdev = 0; + break; + default: + goto bogusimode; + } + + vi->i_uid = le16_to_cpu(dic->i_uid); + vi->i_gid = le16_to_cpu(dic->i_gid); + vi->i_nlink = le16_to_cpu(dic->i_nlink); + + vi->i_ctime = sbi.build_time; + vi->i_ctime_nsec = sbi.build_time_nsec; + + vi->i_size = le32_to_cpu(dic->i_size); + if (vi->datalayout == EROFS_INODE_CHUNK_BASED) + vi->u.chunkformat = le16_to_cpu(dic->i_u.c.format); + break; + default: + erofs_err("unsupported on-disk inode version %u of nid %llu", + erofs_inode_version(ifmt), vi->nid | 0ULL); + return -EOPNOTSUPP; + } + + vi->flags = 0; + if (vi->datalayout == EROFS_INODE_CHUNK_BASED) { + if (vi->u.chunkformat & ~EROFS_CHUNK_FORMAT_ALL) { + erofs_err("unsupported chunk format %x of nid %llu", + vi->u.chunkformat, vi->nid | 0ULL); + return -EOPNOTSUPP; + } + vi->u.chunkbits = LOG_BLOCK_SIZE + + (vi->u.chunkformat & EROFS_CHUNK_FORMAT_BLKBITS_MASK); + } else if (erofs_inode_is_data_compressed(vi->datalayout)) + return -EOPNOTSUPP; + return 0; +bogusimode: + erofs_err("bogus i_mode (%o) @ nid %llu", vi->i_mode, vi->nid | 0ULL); + return -EFSCORRUPTED; +} + +struct erofs_dirent *find_target_dirent(erofs_nid_t pnid, + void *dentry_blk, + const char *name, unsigned int len, + unsigned int nameoff, + unsigned int maxsize) +{ + struct erofs_dirent *de = dentry_blk; + const struct erofs_dirent *end = dentry_blk + nameoff; + + while (de < end) { + const char *de_name; + unsigned int de_namelen; + + nameoff = le16_to_cpu(de->nameoff); + de_name = (char *)dentry_blk + nameoff; + + /* the last dirent in the block? */ + if (de + 1 >= end) + de_namelen = strnlen(de_name, maxsize - nameoff); + else + de_namelen = le16_to_cpu(de[1].nameoff) - nameoff; + + /* a corrupted entry is found */ + if (nameoff + de_namelen > maxsize || + de_namelen > EROFS_NAME_LEN) { + erofs_err("bogus dirent @ nid %llu", pnid | 0ULL); + DBG_BUGON(1); + return ERR_PTR(-EFSCORRUPTED); + } + + if (len == de_namelen && !memcmp(de_name, name, de_namelen)) + return de; + ++de; + } + return NULL; +} + +struct nameidata { + erofs_nid_t nid; + unsigned int ftype; +}; + +int erofs_namei(struct nameidata *nd, + const char *name, unsigned int len) +{ + erofs_nid_t nid = nd->nid; + int ret; + char buf[EROFS_BLKSIZ]; + struct erofs_inode vi = { .nid = nid }; + erofs_off_t offset; + + ret = erofs_read_inode_from_disk(&vi); + if (ret) + return ret; + + offset = 0; + while (offset < vi.i_size) { + erofs_off_t maxsize = min_t(erofs_off_t, + vi.i_size - offset, EROFS_BLKSIZ); + struct erofs_dirent *de = (void *)buf; + unsigned int nameoff; + + ret = erofs_pread(&vi, buf, maxsize, offset); + if (ret) + return ret; + + nameoff = le16_to_cpu(de->nameoff); + if (nameoff < sizeof(struct erofs_dirent) || + nameoff >= PAGE_SIZE) { + erofs_err("invalid de[0].nameoff %u @ nid %llu", + nameoff, nid | 0ULL); + return -EFSCORRUPTED; + } + + de = find_target_dirent(nid, buf, name, len, + nameoff, maxsize); + if (IS_ERR(de)) + return PTR_ERR(de); + + if (de) { + nd->nid = le64_to_cpu(de->nid); + return 0; + } + offset += maxsize; + } + return -ENOENT; +} + +static int link_path_walk(const char *name, struct nameidata *nd) +{ + nd->nid = sbi.root_nid; + + while (*name == '/') + name++; + + /* At this point we know we have a real path component. */ + while (*name != '\0') { + const char *p = name; + int ret; + + do { + ++p; + } while (*p != '\0' && *p != '/'); + + DBG_BUGON(p <= name); + ret = erofs_namei(nd, name, p - name); + if (ret) + return ret; + + name = p; + /* Skip until no more slashes. */ + for (name = p; *name == '/'; ++name) + ; + } + return 0; +} + +int erofs_ilookup(const char *path, struct erofs_inode *vi) +{ + int ret; + struct nameidata nd; + + ret = link_path_walk(path, &nd); + if (ret) + return ret; + + vi->nid = nd.nid; + return erofs_read_inode_from_disk(vi); +} diff --git a/fs/erofs/super.c b/fs/erofs/super.c new file mode 100644 index 0000000000..4cca322b9e --- /dev/null +++ b/fs/erofs/super.c @@ -0,0 +1,105 @@ +// SPDX-License-Identifier: GPL-2.0+ +#include "internal.h" + +static bool check_layout_compatibility(struct erofs_sb_info *sbi, + struct erofs_super_block *dsb) +{ + const unsigned int feature = le32_to_cpu(dsb->feature_incompat); + + sbi->feature_incompat = feature; + + /* check if current kernel meets all mandatory requirements */ + if (feature & (~EROFS_ALL_FEATURE_INCOMPAT)) { + erofs_err("unidentified incompatible feature %x, please upgrade kernel version", + feature & ~EROFS_ALL_FEATURE_INCOMPAT); + return false; + } + return true; +} + +static int erofs_init_devices(struct erofs_sb_info *sbi, + struct erofs_super_block *dsb) +{ + unsigned int ondisk_extradevs, i; + erofs_off_t pos; + + sbi->total_blocks = sbi->primarydevice_blocks; + + if (!erofs_sb_has_device_table()) + ondisk_extradevs = 0; + else + ondisk_extradevs = le16_to_cpu(dsb->extra_devices); + + if (ondisk_extradevs != sbi->extra_devices) { + erofs_err("extra devices don't match (ondisk %u, given %u)", + ondisk_extradevs, sbi->extra_devices); + return -EINVAL; + } + if (!ondisk_extradevs) + return 0; + + sbi->device_id_mask = roundup_pow_of_two(ondisk_extradevs + 1) - 1; + sbi->devs = calloc(ondisk_extradevs, sizeof(*sbi->devs)); + pos = le16_to_cpu(dsb->devt_slotoff) * EROFS_DEVT_SLOT_SIZE; + for (i = 0; i < ondisk_extradevs; ++i) { + struct erofs_deviceslot dis; + int ret; + + ret = erofs_dev_read(0, &dis, pos, sizeof(dis)); + if (ret < 0) + return ret; + + sbi->devs[i].mapped_blkaddr = dis.mapped_blkaddr; + sbi->total_blocks += dis.blocks; + pos += EROFS_DEVT_SLOT_SIZE; + } + return 0; +} + +int erofs_read_superblock(void) +{ + char data[EROFS_BLKSIZ]; + struct erofs_super_block *dsb; + unsigned int blkszbits; + int ret; + + ret = erofs_blk_read(data, 0, 1); + if (ret < 0) { + erofs_err("cannot read erofs superblock: %d", ret); + return -EIO; + } + dsb = (struct erofs_super_block *)(data + EROFS_SUPER_OFFSET); + + ret = -EINVAL; + if (le32_to_cpu(dsb->magic) != EROFS_SUPER_MAGIC_V1) { + erofs_err("cannot find valid erofs superblock"); + return ret; + } + + sbi.feature_compat = le32_to_cpu(dsb->feature_compat); + + blkszbits = dsb->blkszbits; + /* 9(512 bytes) + LOG_SECTORS_PER_BLOCK == LOG_BLOCK_SIZE */ + if (blkszbits != LOG_BLOCK_SIZE) { + erofs_err("blksize %u isn't supported on this platform", + 1 << blkszbits); + return ret; + } + + if (!check_layout_compatibility(&sbi, dsb)) + return ret; + + sbi.primarydevice_blocks = le32_to_cpu(dsb->blocks); + sbi.meta_blkaddr = le32_to_cpu(dsb->meta_blkaddr); + sbi.xattr_blkaddr = le32_to_cpu(dsb->xattr_blkaddr); + sbi.islotbits = EROFS_ISLOTBITS; + sbi.root_nid = le16_to_cpu(dsb->root_nid); + sbi.inos = le64_to_cpu(dsb->inos); + sbi.checksum = le32_to_cpu(dsb->checksum); + + sbi.build_time = le64_to_cpu(dsb->build_time); + sbi.build_time_nsec = le32_to_cpu(dsb->build_time_nsec); + + memcpy(&sbi.uuid, dsb->uuid, sizeof(dsb->uuid)); + return erofs_init_devices(&sbi, dsb); +} diff --git a/fs/fs.c b/fs/fs.c index 023f89cafe..99dac0fd79 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -26,6 +26,7 @@ #include <linux/math64.h> #include <efi_loader.h> #include <squashfs.h> +#include <erofs.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -304,6 +305,27 @@ static struct fstype_info fstypes[] = { .unlink = fs_unlink_unsupported, .mkdir = fs_mkdir_unsupported, }, +#endif +#if IS_ENABLED(CONFIG_FS_EROFS) + { + .fstype = FS_TYPE_EROFS, + .name = "erofs", + .null_dev_desc_ok = false, + .probe = erofs_probe, + .opendir = erofs_opendir, + .readdir = erofs_readdir, + .ls = fs_ls_generic, + .read = erofs_read, + .size = erofs_size, + .close = erofs_close, + .closedir = erofs_closedir, + .exists = erofs_exists, + .uuid = fs_uuid_unsupported, + .write = fs_write_unsupported, + .ln = fs_ln_unsupported, + .unlink = fs_unlink_unsupported, + .mkdir = fs_mkdir_unsupported, + }, #endif { .fstype = FS_TYPE_ANY, diff --git a/include/erofs.h b/include/erofs.h new file mode 100644 index 0000000000..1fbe82bf72 --- /dev/null +++ b/include/erofs.h @@ -0,0 +1,19 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +#ifndef _EROFS_H_ +#define _EROFS_H_ + +struct disk_partition; + +int erofs_opendir(const char *filename, struct fs_dir_stream **dirsp); +int erofs_readdir(struct fs_dir_stream *dirs, struct fs_dirent **dentp); +int erofs_probe(struct blk_desc *fs_dev_desc, + struct disk_partition *fs_partition); +int erofs_read(const char *filename, void *buf, loff_t offset, + loff_t len, loff_t *actread); +int erofs_size(const char *filename, loff_t *size); +int erofs_exists(const char *filename); +void erofs_close(void); +void erofs_closedir(struct fs_dir_stream *dirs); +int erofs_uuid(char *uuid_str); + +#endif /* _EROFS_H */ diff --git a/include/fs.h b/include/fs.h index c8df3886ac..b607b0028d 100644 --- a/include/fs.h +++ b/include/fs.h @@ -17,6 +17,7 @@ struct cmd_tbl; #define FS_TYPE_UBIFS 4 #define FS_TYPE_BTRFS 5 #define FS_TYPE_SQUASHFS 6 +#define FS_TYPE_EROFS 7
struct blk_desc;
Update the LZ4 compression module based on LZ4 v1.8.3 in order to use the newest LZ4_decompress_safe_partial() which can now decode exactly the nb of bytes requested.
Signed-off-by: Huang Jianan jnhuang95@gmail.com --- include/u-boot/lz4.h | 49 ++++ lib/lz4.c | 679 +++++++++++++++++++++++++++++++------------ lib/lz4_wrapper.c | 23 +- 3 files changed, 536 insertions(+), 215 deletions(-)
diff --git a/include/u-boot/lz4.h b/include/u-boot/lz4.h index e18b39a5dc..655adbfcd1 100644 --- a/include/u-boot/lz4.h +++ b/include/u-boot/lz4.h @@ -21,4 +21,53 @@ */ int ulz4fn(const void *src, size_t srcn, void *dst, size_t *dstn);
+/** + * LZ4_decompress_safe() - Decompression protected against buffer overflow + * @source: source address of the compressed data + * @dest: output buffer address of the uncompressed data + * which must be already allocated + * @compressedSize: is the precise full size of the compressed block + * @maxDecompressedSize: is the size of 'dest' buffer + * + * Decompresses data from 'source' into 'dest'. + * If the source stream is detected malformed, the function will + * stop decoding and return a negative result. + * This function is protected against buffer overflow exploits, + * including malicious data packets. It never writes outside output buffer, + * nor reads outside input buffer. + * + * Return: number of bytes decompressed into destination buffer + * (necessarily <= maxDecompressedSize) + * or a negative result in case of error + */ +int LZ4_decompress_safe(const char *source, char *dest, + int compressedSize, int maxDecompressedSize); + +/** + * LZ4_decompress_safe_partial() - Decompress a block of size 'compressedSize' + * at position 'source' into buffer 'dest' + * @source: source address of the compressed data + * @dest: output buffer address of the decompressed data which must be + * already allocated + * @compressedSize: is the precise full size of the compressed block. + * @targetOutputSize: the decompression operation will try + * to stop as soon as 'targetOutputSize' has been reached + * @maxDecompressedSize: is the size of destination buffer + * + * This function decompresses a compressed block of size 'compressedSize' + * at position 'source' into destination buffer 'dest' + * of size 'maxDecompressedSize'. + * The function tries to stop decompressing operation as soon as + * 'targetOutputSize' has been reached, reducing decompression time. + * This function never writes outside of output buffer, + * and never reads outside of input buffer. + * It is therefore protected against malicious data packets. + * + * Return: the number of bytes decoded in the destination buffer + * (necessarily <= maxDecompressedSize) + * or a negative result in case of error + * + */ +int LZ4_decompress_safe_partial(const char *src, char *dst, + int compressedSize, int targetOutputSize, int dstCapacity); #endif diff --git a/lib/lz4.c b/lib/lz4.c index 046c34e390..5337842126 100644 --- a/lib/lz4.c +++ b/lib/lz4.c @@ -1,13 +1,63 @@ -// SPDX-License-Identifier: BSD-2-Clause +// SPDX-License-Identifier: GPL 2.0+ OR BSD-2-Clause /* - LZ4 - Fast LZ compression algorithm - Copyright (C) 2011-2015, Yann Collet. + * LZ4 - Fast LZ compression algorithm + * Copyright (C) 2011 - 2016, Yann Collet. + * BSD 2 - Clause License (http://www.opensource.org/licenses/bsd - license.php) + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions are + * met: + * * Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * * Redistributions in binary form must reproduce the above + * copyright notice, this list of conditions and the following disclaimer + * in the documentation and/or other materials provided with the + * distribution. + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS + * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT + * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR + * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT + * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, + * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT + * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, + * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY + * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE + * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + * You can contact the author at : + * - LZ4 homepage : http://www.lz4.org + * - LZ4 source repository : https://github.com/lz4/lz4 + */ +#include <common.h> +#include <compiler.h> +#include <linux/kernel.h> +#include <linux/types.h> +#include <linux/bug.h> +#include <asm/unaligned.h> +#include <u-boot/lz4.h> + +#define FORCE_INLINE inline __attribute__((always_inline)) + +static FORCE_INLINE u16 LZ4_readLE16(const void *src) +{ + return get_unaligned_le16(src); +}
- You can contact the author at : - - LZ4 source repository : https://github.com/Cyan4973/lz4 - - LZ4 public forum : https://groups.google.com/forum/#!forum/lz4c -*/ +static FORCE_INLINE void LZ4_copy8(void *dst, const void *src) +{ + put_unaligned(get_unaligned((const u64 *)src), (u64 *)dst); +} + +typedef uint8_t BYTE; +typedef uint16_t U16; +typedef uint32_t U32; +typedef int32_t S32; +typedef uint64_t U64; +typedef uintptr_t uptrval;
+static FORCE_INLINE void LZ4_write32(void *memPtr, U32 value) +{ + put_unaligned(value, (U32 *)memPtr); +}
/************************************** * Reading and writing into memory @@ -28,14 +78,17 @@ static void LZ4_wildCopy(void* dstPtr, const void* srcPtr, void* dstEnd) **************************************/ #define MINMATCH 4
-#define COPYLENGTH 8 +#define WILDCOPYLENGTH 8 #define LASTLITERALS 5 -#define MFLIMIT (COPYLENGTH+MINMATCH) -static const int LZ4_minLength = (MFLIMIT+1); +#define MFLIMIT (WILDCOPYLENGTH + MINMATCH)
-#define KB *(1 <<10) -#define MB *(1 <<20) -#define GB *(1U<<30) +/* + * ensure it's possible to write 2 x wildcopyLength + * without overflowing output buffer + */ +#define MATCH_SAFEGUARD_DISTANCE ((2 * WILDCOPYLENGTH) - MINMATCH) + +#define KB (1 <<10)
#define MAXD_LOG 16 #define MAX_DISTANCE ((1 << MAXD_LOG) - 1) @@ -45,198 +98,438 @@ static const int LZ4_minLength = (MFLIMIT+1); #define RUN_BITS (8-ML_BITS) #define RUN_MASK ((1U<<RUN_BITS)-1)
+#define LZ4_STATIC_ASSERT(c) BUILD_BUG_ON(!(c))
/************************************** * Local Structures and types **************************************/ typedef enum { noDict = 0, withPrefix64k, usingExtDict } dict_directive; typedef enum { endOnOutputSize = 0, endOnInputSize = 1 } endCondition_directive; -typedef enum { full = 0, partial = 1 } earlyEnd_directive; +typedef enum { decode_full_block = 0, partial_decode = 1 } earlyEnd_directive;
+#define DEBUGLOG(l, ...) {} /* disabled */
+#ifndef assert +#define assert(condition) ((void)0) +#endif
-/******************************* -* Decompression functions -*******************************/ /* - * This generic decompression function cover all use cases. - * It shall be instantiated several times, using different sets of directives - * Note that it is essential this generic function is really inlined, + * LZ4_decompress_generic() : + * This generic decompression function covers all use cases. + * It shall be instantiated several times, using different sets of directives. + * Note that it is important for performance that this function really get inlined, * in order to remove useless branches during compilation optimization. */ -FORCE_INLINE int LZ4_decompress_generic( - const char* const source, - char* const dest, - int inputSize, - int outputSize, /* If endOnInput==endOnInputSize, this value is the max size of Output Buffer. */ - - int endOnInput, /* endOnOutputSize, endOnInputSize */ - int partialDecoding, /* full, partial */ - int targetOutputSize, /* only used if partialDecoding==partial */ - int dict, /* noDict, withPrefix64k, usingExtDict */ - const BYTE* const lowPrefix, /* == dest if dict == noDict */ - const BYTE* const dictStart, /* only if dict==usingExtDict */ - const size_t dictSize /* note : = 0 if noDict */ - ) +static FORCE_INLINE int LZ4_decompress_generic( + const char * const src, + char * const dst, + int srcSize, + /* + * If endOnInput == endOnInputSize, + * this value is `dstCapacity` + */ + int outputSize, + /* endOnOutputSize, endOnInputSize */ + endCondition_directive endOnInput, + /* full, partial */ + earlyEnd_directive partialDecoding, + /* noDict, withPrefix64k, usingExtDict */ + dict_directive dict, + /* always <= dst, == dst when no prefix */ + const BYTE * const lowPrefix, + /* only if dict == usingExtDict */ + const BYTE * const dictStart, + /* note : = 0 if noDict */ + const size_t dictSize + ) { - /* Local Variables */ - const BYTE* ip = (const BYTE*) source; - const BYTE* const iend = ip + inputSize; - - BYTE* op = (BYTE*) dest; - BYTE* const oend = op + outputSize; - BYTE* cpy; - BYTE* oexit = op + targetOutputSize; - const BYTE* const lowLimit = lowPrefix - dictSize; - - const BYTE* const dictEnd = (const BYTE*)dictStart + dictSize; - const size_t dec32table[] = {4, 1, 2, 1, 4, 4, 4, 4}; - const size_t dec64table[] = {0, 0, 0, (size_t)-1, 0, 1, 2, 3}; - - const int safeDecode = (endOnInput==endOnInputSize); - const int checkOffset = ((safeDecode) && (dictSize < (int)(64 KB))); - - - /* Special cases */ - if ((partialDecoding) && (oexit> oend-MFLIMIT)) oexit = oend-MFLIMIT; /* targetOutputSize too high => decode everything */ - if ((endOnInput) && (unlikely(outputSize==0))) return ((inputSize==1) && (*ip==0)) ? 0 : -1; /* Empty output buffer */ - if ((!endOnInput) && (unlikely(outputSize==0))) return (*ip==0?1:-1); - - - /* Main Loop */ - while (1) - { - unsigned token; - size_t length; - const BYTE* match; - - /* get literal length */ - token = *ip++; - if ((length=(token>>ML_BITS)) == RUN_MASK) - { - unsigned s; - do - { - s = *ip++; - length += s; - } - while (likely((endOnInput)?ip<iend-RUN_MASK:1) && (s==255)); - if ((safeDecode) && unlikely((size_t)(op+length)<(size_t)(op))) goto _output_error; /* overflow detection */ - if ((safeDecode) && unlikely((size_t)(ip+length)<(size_t)(ip))) goto _output_error; /* overflow detection */ - } - - /* copy literals */ - cpy = op+length; - if (((endOnInput) && ((cpy>(partialDecoding?oexit:oend-MFLIMIT)) || (ip+length>iend-(2+1+LASTLITERALS))) ) - || ((!endOnInput) && (cpy>oend-COPYLENGTH))) - { - if (partialDecoding) - { - if (cpy > oend) goto _output_error; /* Error : write attempt beyond end of output buffer */ - if ((endOnInput) && (ip+length > iend)) goto _output_error; /* Error : read attempt beyond end of input buffer */ - } - else - { - if ((!endOnInput) && (cpy != oend)) goto _output_error; /* Error : block decoding must stop exactly there */ - if ((endOnInput) && ((ip+length != iend) || (cpy > oend))) goto _output_error; /* Error : input must be consumed */ - } - memcpy(op, ip, length); - ip += length; - op += length; - break; /* Necessarily EOF, due to parsing restrictions */ - } - LZ4_wildCopy(op, ip, cpy); - ip += length; op = cpy; - - /* get offset */ - match = cpy - LZ4_readLE16(ip); ip+=2; - if ((checkOffset) && (unlikely(match < lowLimit))) goto _output_error; /* Error : offset outside destination buffer */ - - /* get matchlength */ - length = token & ML_MASK; - if (length == ML_MASK) - { - unsigned s; - do - { - if ((endOnInput) && (ip > iend-LASTLITERALS)) goto _output_error; - s = *ip++; - length += s; - } while (s==255); - if ((safeDecode) && unlikely((size_t)(op+length)<(size_t)op)) goto _output_error; /* overflow detection */ - } - length += MINMATCH; - - /* check external dictionary */ - if ((dict==usingExtDict) && (match < lowPrefix)) - { - if (unlikely(op+length > oend-LASTLITERALS)) goto _output_error; /* doesn't respect parsing restriction */ - - if (length <= (size_t)(lowPrefix-match)) - { - /* match can be copied as a single segment from external dictionary */ - match = dictEnd - (lowPrefix-match); - memmove(op, match, length); op += length; - } - else - { - /* match encompass external dictionary and current segment */ - size_t copySize = (size_t)(lowPrefix-match); - memcpy(op, dictEnd - copySize, copySize); - op += copySize; - copySize = length - copySize; - if (copySize > (size_t)(op-lowPrefix)) /* overlap within current segment */ - { - BYTE* const endOfMatch = op + copySize; - const BYTE* copyFrom = lowPrefix; - while (op < endOfMatch) *op++ = *copyFrom++; - } - else - { - memcpy(op, lowPrefix, copySize); - op += copySize; - } - } - continue; - } - - /* copy repeated sequence */ - cpy = op + length; - if (unlikely((op-match)<8)) - { - const size_t dec64 = dec64table[op-match]; - op[0] = match[0]; - op[1] = match[1]; - op[2] = match[2]; - op[3] = match[3]; - match += dec32table[op-match]; - LZ4_copy4(op+4, match); - op += 8; match -= dec64; - } else { LZ4_copy8(op, match); op+=8; match+=8; } - - if (unlikely(cpy>oend-12)) - { - if (cpy > oend-LASTLITERALS) goto _output_error; /* Error : last LASTLITERALS bytes must be literals */ - if (op < oend-8) - { - LZ4_wildCopy(op, match, oend-8); - match += (oend-8) - op; - op = oend-8; - } - while (op<cpy) *op++ = *match++; - } - else - LZ4_wildCopy(op, match, cpy); - op=cpy; /* correction */ - } - - /* end of decoding */ - if (endOnInput) - return (int) (((char*)op)-dest); /* Nb of output bytes decoded */ - else - return (int) (((const char*)ip)-source); /* Nb of input bytes read */ - - /* Overflow error detected */ + const BYTE *ip = (const BYTE *) src; + const BYTE * const iend = ip + srcSize; + + BYTE *op = (BYTE *) dst; + BYTE * const oend = op + outputSize; + BYTE *cpy; + + const BYTE * const dictEnd = (const BYTE *)dictStart + dictSize; + static const unsigned int inc32table[8] = {0, 1, 2, 1, 0, 4, 4, 4}; + static const int dec64table[8] = {0, 0, 0, -1, -4, 1, 2, 3}; + + const int safeDecode = (endOnInput == endOnInputSize); + const int checkOffset = ((safeDecode) && (dictSize < (int)(64 * KB))); + + /* Set up the "end" pointers for the shortcut. */ + const BYTE *const shortiend = iend - + (endOnInput ? 14 : 8) /*maxLL*/ - 2 /*offset*/; + const BYTE *const shortoend = oend - + (endOnInput ? 14 : 8) /*maxLL*/ - 18 /*maxML*/; + + DEBUGLOG(5, "%s (srcSize:%i, dstSize:%i)", __func__, + srcSize, outputSize); + + /* Special cases */ + assert(lowPrefix <= op); + assert(src != NULL); + + /* Empty output buffer */ + if ((endOnInput) && (unlikely(outputSize == 0))) + return ((srcSize == 1) && (*ip == 0)) ? 0 : -1; + + if ((!endOnInput) && (unlikely(outputSize == 0))) + return (*ip == 0 ? 1 : -1); + + if ((endOnInput) && unlikely(srcSize == 0)) + return -1; + + /* Main Loop : decode sequences */ + while (1) { + size_t length; + const BYTE *match; + size_t offset; + + /* get literal length */ + unsigned int const token = *ip++; + length = token>>ML_BITS; + + /* ip < iend before the increment */ + assert(!endOnInput || ip <= iend); + + /* + * A two-stage shortcut for the most common case: + * 1) If the literal length is 0..14, and there is enough + * space, enter the shortcut and copy 16 bytes on behalf + * of the literals (in the fast mode, only 8 bytes can be + * safely copied this way). + * 2) Further if the match length is 4..18, copy 18 bytes + * in a similar manner; but we ensure that there's enough + * space in the output for those 18 bytes earlier, upon + * entering the shortcut (in other words, there is a + * combined check for both stages). + * + * The & in the likely() below is intentionally not && so that + * some compilers can produce better parallelized runtime code + */ + if ((endOnInput ? length != RUN_MASK : length <= 8) + /* + * strictly "less than" on input, to re-enter + * the loop with at least one byte + */ + && likely((endOnInput ? ip < shortiend : 1) & + (op <= shortoend))) { + /* Copy the literals */ + memcpy(op, ip, endOnInput ? 16 : 8); + op += length; ip += length; + + /* + * The second stage: + * prepare for match copying, decode full info. + * If it doesn't work out, the info won't be wasted. + */ + length = token & ML_MASK; /* match length */ + offset = LZ4_readLE16(ip); + ip += 2; + match = op - offset; + assert(match <= op); /* check overflow */ + + /* Do not deal with overlapping matches. */ + if ((length != ML_MASK) && + (offset >= 8) && + (dict == withPrefix64k || match >= lowPrefix)) { + /* Copy the match. */ + memcpy(op + 0, match + 0, 8); + memcpy(op + 8, match + 8, 8); + memcpy(op + 16, match + 16, 2); + op += length + MINMATCH; + /* Both stages worked, load the next token. */ + continue; + } + + /* + * The second stage didn't work out, but the info + * is ready. Propel it right to the point of match + * copying. + */ + goto _copy_match; + } + + /* decode literal length */ + if (length == RUN_MASK) { + unsigned int s; + + if (unlikely(endOnInput ? ip >= iend - RUN_MASK : 0)) { + /* overflow detection */ + goto _output_error; + } + do { + s = *ip++; + length += s; + } while (likely(endOnInput + ? ip < iend - RUN_MASK + : 1) & (s == 255)); + + if ((safeDecode) + && unlikely((uptrval)(op) + + length < (uptrval)(op))) { + /* overflow detection */ + goto _output_error; + } + if ((safeDecode) + && unlikely((uptrval)(ip) + + length < (uptrval)(ip))) { + /* overflow detection */ + goto _output_error; + } + } + + /* copy literals */ + cpy = op + length; + LZ4_STATIC_ASSERT(MFLIMIT >= WILDCOPYLENGTH); + + if (((endOnInput) && ((cpy > oend - MFLIMIT) + || (ip + length > iend - (2 + 1 + LASTLITERALS)))) + || ((!endOnInput) && (cpy > oend - WILDCOPYLENGTH))) { + if (partialDecoding) { + if (cpy > oend) { + /* + * Partial decoding : + * stop in the middle of literal segment + */ + cpy = oend; + length = oend - op; + } + if ((endOnInput) + && (ip + length > iend)) { + /* + * Error : + * read attempt beyond + * end of input buffer + */ + goto _output_error; + } + } else { + if ((!endOnInput) + && (cpy != oend)) { + /* + * Error : + * block decoding must + * stop exactly there + */ + goto _output_error; + } + if ((endOnInput) + && ((ip + length != iend) + || (cpy > oend))) { + /* + * Error : + * input must be consumed + */ + goto _output_error; + } + } + + /* + * supports overlapping memory regions; only matters + * for in-place decompression scenarios + */ + memmove(op, ip, length); + ip += length; + op += length; + + /* Necessarily EOF, due to parsing restrictions */ + if (!partialDecoding || (cpy == oend)) + break; + } else { + /* may overwrite up to WILDCOPYLENGTH beyond cpy */ + LZ4_wildCopy(op, ip, cpy); + ip += length; + op = cpy; + } + + /* get offset */ + offset = LZ4_readLE16(ip); + ip += 2; + match = op - offset; + + /* get matchlength */ + length = token & ML_MASK; + +_copy_match: + if ((checkOffset) && (unlikely(match + dictSize < lowPrefix))) { + /* Error : offset outside buffers */ + goto _output_error; + } + + /* costs ~1%; silence an msan warning when offset == 0 */ + /* + * note : when partialDecoding, there is no guarantee that + * at least 4 bytes remain available in output buffer + */ + if (!partialDecoding) { + assert(oend > op); + assert(oend - op >= 4); + + LZ4_write32(op, (U32)offset); + } + + if (length == ML_MASK) { + unsigned int s; + + do { + s = *ip++; + + if ((endOnInput) && (ip > iend - LASTLITERALS)) + goto _output_error; + + length += s; + } while (s == 255); + + if ((safeDecode) + && unlikely( + (uptrval)(op) + length < (uptrval)op)) { + /* overflow detection */ + goto _output_error; + } + } + + length += MINMATCH; + + /* match starting within external dictionary */ + if ((dict == usingExtDict) && (match < lowPrefix)) { + if (unlikely(op + length > oend - LASTLITERALS)) { + /* doesn't respect parsing restriction */ + if (!partialDecoding) + goto _output_error; + length = min(length, (size_t)(oend - op)); + } + + if (length <= (size_t)(lowPrefix - match)) { + /* + * match fits entirely within external + * dictionary : just copy + */ + memmove(op, dictEnd - (lowPrefix - match), + length); + op += length; + } else { + /* + * match stretches into both external + * dictionary and current block + */ + size_t const copySize = (size_t)(lowPrefix - match); + size_t const restSize = length - copySize; + + memcpy(op, dictEnd - copySize, copySize); + op += copySize; + if (restSize > (size_t)(op - lowPrefix)) { + /* overlap copy */ + BYTE * const endOfMatch = op + restSize; + const BYTE *copyFrom = lowPrefix; + + while (op < endOfMatch) + *op++ = *copyFrom++; + } else { + memcpy(op, lowPrefix, restSize); + op += restSize; + } + } + continue; + } + + /* copy match within block */ + cpy = op + length; + + /* + * partialDecoding : + * may not respect endBlock parsing restrictions + */ + assert(op <= oend); + if (partialDecoding && + (cpy > oend - MATCH_SAFEGUARD_DISTANCE)) { + size_t const mlen = min(length, (size_t)(oend - op)); + const BYTE * const matchEnd = match + mlen; + BYTE * const copyEnd = op + mlen; + + if (matchEnd > op) { + /* overlap copy */ + while (op < copyEnd) + *op++ = *match++; + } else { + memcpy(op, match, mlen); + } + op = copyEnd; + if (op == oend) + break; + continue; + } + + if (unlikely(offset < 8)) { + op[0] = match[0]; + op[1] = match[1]; + op[2] = match[2]; + op[3] = match[3]; + match += inc32table[offset]; + memcpy(op + 4, match, 4); + match -= dec64table[offset]; + } else { + LZ4_copy8(op, match); + match += 8; + } + + op += 8; + + if (unlikely(cpy > oend - MATCH_SAFEGUARD_DISTANCE)) { + BYTE * const oCopyLimit = oend - (WILDCOPYLENGTH - 1); + + if (cpy > oend - LASTLITERALS) { + /* + * Error : last LASTLITERALS bytes + * must be literals (uncompressed) + */ + goto _output_error; + } + + if (op < oCopyLimit) { + LZ4_wildCopy(op, match, oCopyLimit); + match += oCopyLimit - op; + op = oCopyLimit; + } + while (op < cpy) + *op++ = *match++; + } else { + LZ4_copy8(op, match); + if (length > 16) + LZ4_wildCopy(op + 8, match + 8, cpy); + } + op = cpy; /* wildcopy correction */ + } + + /* end of decoding */ + if (endOnInput) { + /* Nb of output bytes decoded */ + return (int) (((char *)op) - dst); + } else { + /* Nb of input bytes read */ + return (int) (((const char *)ip) - src); + } + + /* Overflow error detected */ _output_error: - return (int) (-(((const char*)ip)-source))-1; + return (int) (-(((const char *)ip) - src)) - 1; +} + +int LZ4_decompress_safe(const char *source, char *dest, + int compressedSize, int maxDecompressedSize) +{ + return LZ4_decompress_generic(source, dest, + compressedSize, maxDecompressedSize, + endOnInputSize, decode_full_block, + noDict, (BYTE *)dest, NULL, 0); +} + +int LZ4_decompress_safe_partial(const char *src, char *dst, + int compressedSize, int targetOutputSize, int dstCapacity) +{ + dstCapacity = min(targetOutputSize, dstCapacity); + return LZ4_decompress_generic(src, dst, compressedSize, dstCapacity, + endOnInputSize, partial_decode, + noDict, (BYTE *)dst, NULL, 0); } diff --git a/lib/lz4_wrapper.c b/lib/lz4_wrapper.c index ebcb5c09a2..0d2a3655a8 100644 --- a/lib/lz4_wrapper.c +++ b/lib/lz4_wrapper.c @@ -11,27 +11,6 @@ #include <asm/unaligned.h> #include <u-boot/lz4.h>
-static u16 LZ4_readLE16(const void *src) -{ - return get_unaligned_le16(src); -} -static void LZ4_copy4(void *dst, const void *src) -{ - put_unaligned(get_unaligned((const u32 *)src), (u32 *)dst); -} -static void LZ4_copy8(void *dst, const void *src) -{ - put_unaligned(get_unaligned((const u64 *)src), (u64 *)dst); -} - -typedef uint8_t BYTE; -typedef uint16_t U16; -typedef uint32_t U32; -typedef int32_t S32; -typedef uint64_t U64; - -#define FORCE_INLINE static inline __attribute__((always_inline)) - /* lz4.c is unaltered (except removing unrelated code) from github.com/Cyan4973/lz4. */ #include "lz4.c" /* #include for inlining, do not link! */
@@ -112,7 +91,7 @@ int ulz4fn(const void *src, size_t srcn, void *dst, size_t *dstn) /* constant folding essential, do not touch params! */ ret = LZ4_decompress_generic(in, out, block_size, end - out, endOnInputSize, - full, 0, noDict, out, NULL, 0); + decode_full_block, noDict, out, NULL, 0); if (ret < 0) { ret = -EPROTO; /* decompression error */ break;
Hi Jianan,
I noticed after this commit LZ4 decompression is slower. ulz4fn function call takes 1.209670 seconds with this commit. After reverting this commit, the ulz4fn function call takes 0.587032 seconds.
I am decompressing a LZ4 compressed kernel (compressed with lz4 v1.9.4 using -9 option for maximum compression) on RK3399.
Any ideas why it is slower with this commit and how the performance regression can be fixed?
Thanks.
Regards, Jonathan
On 2024/5/24 22:26, Jonathan Liu wrote:
Hi Jianan,
Just the quick glance, I think the issue may be due to memcpy/memmove since it seems the main difference between these two codebases (I'm not sure which LZ4 version the old codebase was based on) and the new version mainly relies on memcpy/memmove instead of its own versions.
Would you mind to check the assembly how memcpy/memset is generated on your platform?
Thanks, Gao Xiang
Thanks.
Regards, Jonathan
Hi Gao,
Hi Jianan,
Here is the assembly (-mcpu=cortex-a72.cortex-a53 -march=armv8-a+crc+crypto): 000000000028220c <memset>: #if !CONFIG_IS_ENABLED(TINY_MEMSET) unsigned long cl = 0; int i;
/* do it one word at a time (32 bits or 64 bits) while possible */ if ( ((ulong)s & (sizeof(*sl) - 1)) == 0) { 28220c: f2400803 ands x3, x0, #0x7 282210: 540002c1 b.ne 282268 <memset+0x5c> // b.any for (i = 0; i < sizeof(*sl); i++) { cl <<= 8; cl |= c & 0xff; 282214: 92401c26 and x6, x1, #0xff unsigned long cl = 0; 282218: d2800004 mov x4, #0x0 // #0 28221c: 52800105 mov w5, #0x8 // #8 cl |= c & 0xff; 282220: aa0420c4 orr x4, x6, x4, lsl #8 for (i = 0; i < sizeof(*sl); i++) { 282224: 710004a5 subs w5, w5, #0x1 282228: 54ffffc1 b.ne 282220 <memset+0x14> // b.any } while (count >= sizeof(*sl)) { 28222c: cb030045 sub x5, x2, x3 282230: f1001cbf cmp x5, #0x7 282234: 54000148 b.hi 28225c <memset+0x50> // b.pmore 282238: d343fc43 lsr x3, x2, #3 28223c: 928000e4 mov x4, #0xfffffffffffffff8 // #-8 282240: 9b047c63 mul x3, x3, x4 282244: 8b030042 add x2, x2, x3 282248: cb030003 sub x3, x0, x3 unsigned long *sl = (unsigned long *) s; 28224c: d2800004 mov x4, #0x0 // #0 count -= sizeof(*sl); } } #endif /* fill 8 bits at a time */ s8 = (char *)sl; while (count--) 282250: eb04005f cmp x2, x4 282254: 540000e1 b.ne 282270 <memset+0x64> // b.any *s8++ = c;
return s; } 282258: d65f03c0 ret *sl++ = cl; 28225c: f8236804 str x4, [x0, x3] count -= sizeof(*sl); 282260: 91002063 add x3, x3, #0x8 282264: 17fffff2 b 28222c <memset+0x20> unsigned long *sl = (unsigned long *) s; 282268: aa0003e3 mov x3, x0 28226c: 17fffff8 b 28224c <memset+0x40> *s8++ = c; 282270: 38246861 strb w1, [x3, x4] 282274: 91000484 add x4, x4, #0x1 282278: 17fffff6 b 282250 <memset+0x44>
000000000028227c <memcpy>: __used void * memcpy(void *dest, const void *src, size_t count) { unsigned long *dl = (unsigned long *)dest, *sl = (unsigned long *)src; char *d8, *s8;
if (src == dest) 28227c: eb01001f cmp x0, x1 282280: 54000100 b.eq 2822a0 <memcpy+0x24> // b.none return dest;
/* while all data is aligned (common case), copy a word at a time */ if ( (((ulong)dest | (ulong)src) & (sizeof(*dl) - 1)) == 0) { 282284: aa010003 orr x3, x0, x1 282288: f2400863 ands x3, x3, #0x7 28228c: 54000120 b.eq 2822b0 <memcpy+0x34> // b.none 282290: aa0003e4 mov x4, x0 282294: d2800003 mov x3, #0x0 // #0 } } /* copy the reset one byte at a time */ d8 = (char *)dl; s8 = (char *)sl; while (count--) 282298: eb03005f cmp x2, x3 28229c: 540001e1 b.ne 2822d8 <memcpy+0x5c> // b.any *d8++ = *s8++;
return dest; } 2822a0: d65f03c0 ret *dl++ = *sl++; 2822a4: f8636824 ldr x4, [x1, x3] 2822a8: f8236804 str x4, [x0, x3] count -= sizeof(*dl); 2822ac: 91002063 add x3, x3, #0x8 while (count >= sizeof(*dl)) { 2822b0: cb030044 sub x4, x2, x3 2822b4: f1001c9f cmp x4, #0x7 2822b8: 54ffff68 b.hi 2822a4 <memcpy+0x28> // b.pmore 2822bc: d343fc43 lsr x3, x2, #3 2822c0: 928000e4 mov x4, #0xfffffffffffffff8 // #-8 2822c4: 9b047c63 mul x3, x3, x4 2822c8: 8b030042 add x2, x2, x3 2822cc: cb030004 sub x4, x0, x3 2822d0: cb030021 sub x1, x1, x3 2822d4: 17fffff0 b 282294 <memcpy+0x18> *d8++ = *s8++; 2822d8: 38636825 ldrb w5, [x1, x3] 2822dc: 38236885 strb w5, [x4, x3] 2822e0: 91000463 add x3, x3, #0x1 2822e4: 17ffffed b 282298 <memcpy+0x1c>
I tried enabling CONFIG_USE_ARCH_MEMCPY=y, CONFIG_USE_ARCH_MEMSET=y in the .config (but leaving it disabled in SPL/TPL) and it results in Synchronous Abort: U-Boot SPL 2024.04 (Apr 02 2024 - 10:58:58 +0000) Trying to boot from MMC1 NOTICE: BL31: v1.3(release):8f40012ab NOTICE: BL31: Built : 14:20:53, Feb 16 2023 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: plat_rockchip_pmu_init(1203): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 "Synchronous Abort" handler, esr 0x96000021, far 0x2957e1 elr: 000000000020233c lr : 000000000026a388 x0 : 00000000002fbf38 x1 : 00000000002957e1 x2 : 0000000000000008 x3 : 0000000000000065 x4 : 00000000002957e9 x5 : 00000000002fbf40 x6 : 0000000000000065 x7 : 0000000000000003 x8 : 00000000002c7960 x9 : 000000000000ffd0 x10: 00000000002fbc5c x11: 00000000000132e8 x12: 00000000002fbce8 x13: 00000000002c7960 x14: 00000000002c7960 x15: 0000000000000000 x16: 0000000000000000 x17: 0000000000000000 x18: 00000000002fbe30 x19: 0000000000000007 x20: 00000000002957d8 x21: 0000000000000009 x22: 000000000029d189 x23: 0000000000000020 x24: 00000000002fbf38 x25: 00000000002957e7 x26: 00000000002957b2 x27: 0000000000007fff x28: 0000000000000000 x29: 00000000002fbcc0
Code: a9001c06 a93f34ac d65f03c0 361800c2 (f9400026) Resetting CPU ...
resetting ...
Thanks, Gao Xiang
Regards, Jonathan
Hi Jonathan,
Could you please try the following patch ? It replaces all memcpy() calls in lz4 with __builtin_memcpy().
diff --git a/lib/lz4.c b/lib/lz4.c index d365dc727c..2afe31c1c3 100644 --- a/lib/lz4.c +++ b/lib/lz4.c @@ -34,6 +34,8 @@ #include <asm/unaligned.h> #include <u-boot/lz4.h>
+#define LZ4_memcpy(dst, src, size) __builtin_memcpy(dst, src, size) + #define FORCE_INLINE inline __attribute__((always_inline))
static FORCE_INLINE u16 LZ4_readLE16(const void *src) @@ -215,7 +217,7 @@ static FORCE_INLINE int LZ4_decompress_generic( && likely((endOnInput ? ip < shortiend : 1) & (op <= shortoend))) { /* Copy the literals */ - memcpy(op, ip, endOnInput ? 16 : 8); + LZ4_memcpy(op, ip, endOnInput ? 16 : 8); op += length; ip += length;
/* @@ -234,9 +236,9 @@ static FORCE_INLINE int LZ4_decompress_generic( (offset >= 8) && (dict == withPrefix64k || match >= lowPrefix)) { /* Copy the match. */ - memcpy(op + 0, match + 0, 8); - memcpy(op + 8, match + 8, 8); - memcpy(op + 16, match + 16, 2); + LZ4_memcpy(op + 0, match + 0, 8); + LZ4_memcpy(op + 8, match + 8, 8); + LZ4_memcpy(op + 16, match + 16, 2); op += length + MINMATCH; /* Both stages worked, load the next token. */ continue; @@ -416,7 +418,7 @@ _copy_match: size_t const copySize = (size_t)(lowPrefix - match); size_t const restSize = length - copySize;
- memcpy(op, dictEnd - copySize, copySize); + LZ4_memcpy(op, dictEnd - copySize, copySize); op += copySize; if (restSize > (size_t)(op - lowPrefix)) { /* overlap copy */ @@ -426,7 +428,7 @@ _copy_match: while (op < endOfMatch) *op++ = *copyFrom++; } else { - memcpy(op, lowPrefix, restSize); + LZ4_memcpy(op, lowPrefix, restSize); op += restSize; } } @@ -452,7 +454,7 @@ _copy_match: while (op < copyEnd) *op++ = *match++; } else { - memcpy(op, match, mlen); + LZ4_memcpy(op, match, mlen); } op = copyEnd; if (op == oend) @@ -466,7 +468,7 @@ _copy_match: op[2] = match[2]; op[3] = match[3]; match += inc32table[offset]; - memcpy(op + 4, match, 4); + LZ4_memcpy(op + 4, match, 4); match -= dec64table[offset]; } else { LZ4_copy8(op, match); diff --git a/lib/lz4_wrapper.c b/lib/lz4_wrapper.c index 4d48e7b0e8..e09c8d7057 100644 --- a/lib/lz4_wrapper.c +++ b/lib/lz4_wrapper.c @@ -80,7 +80,7 @@ int ulz4fn(const void *src, size_t srcn, void *dst, size_t *dstn)
if (block_header & LZ4F_BLOCKUNCOMPRESSED_FLAG) { size_t size = min((ptrdiff_t)block_size, (ptrdiff_t)(end - out)); - memcpy(out, in, size); + LZ4_memcpy(out, in, size); out += size; if (size < block_size) { ret = -ENOBUFS; /* output overrun */
Thanks,
Jianan On 2024/5/26 16:06, Jonathan Liu wrote:
Hi Gao,
On Sat, 25 May 2024 at 02:52, Gao Xiang hsiangkao@linux.alibaba.com hsiangkao@linux.alibaba.com wrote:
Hi Jianan,
On Sat, 26 Feb 2022 at 18:05, Huang Jianan jnhuang95@gmail.com jnhuang95@gmail.com wrote:
Signed-off-by: Huang Jianan jnhuang95@gmail.com jnhuang95@gmail.com
resetting ...
Thanks, Gao Xiang
Regards, Jonathan
Hi Jianan,
Here are the LZ4 decompression times I got running "time unlz4 ..." on Rock 4 SE with RK3399 CPU.
v2024.04: 1.329 seconds v2024.04 with 26c7fdadcb7 ("lib/lz4: update LZ4 decompressor module") reverted: 0.665 seconds v2024.04 with your patch: 1.216 seconds
I managed to get better performance by optimizing it myself. v2024.04 with my patch: 0.785 seconds
With my patch, it makes no difference if I use __builtin_memcpy or memcpy in lz4.c and lz4_wrapper.c so I just left it using memcpy. It is still slower than reverting the LZ4 update though.
My patch: --- a/lib/lz4.c +++ b/lib/lz4.c @@ -41,6 +41,16 @@ static FORCE_INLINE u16 LZ4_readLE16(const void *src) return get_unaligned_le16(src); }
+static FORCE_INLINE void LZ4_copy2(void *dst, const void *src) +{ + put_unaligned(get_unaligned((const u16 *)src), (u16 *)dst); +} + +static FORCE_INLINE void LZ4_copy4(void *dst, const void *src) +{ + put_unaligned(get_unaligned((const u32 *)src), (u32 *)dst); +} + static FORCE_INLINE void LZ4_copy8(void *dst, const void *src) { put_unaligned(get_unaligned((const u64 *)src), (u64 *)dst); @@ -215,7 +225,10 @@ static FORCE_INLINE int LZ4_decompress_generic( && likely((endOnInput ? ip < shortiend : 1) & (op <= shortoend))) { /* Copy the literals */ - memcpy(op, ip, endOnInput ? 16 : 8); + LZ4_copy8(op, ip); + if (endOnInput) + LZ4_copy8(op + 8, ip + 8); + op += length; ip += length;
/* @@ -234,9 +247,9 @@ static FORCE_INLINE int LZ4_decompress_generic( (offset >= 8) && (dict == withPrefix64k || match >= lowPrefix)) { /* Copy the match. */ - memcpy(op + 0, match + 0, 8); - memcpy(op + 8, match + 8, 8); - memcpy(op + 16, match + 16, 2); + LZ4_copy8(op, match); + LZ4_copy8(op + 8, match + 8); + LZ4_copy2(op + 16, match + 16); op += length + MINMATCH; /* Both stages worked, load the next token. */ continue; @@ -466,7 +479,7 @@ _copy_match: op[2] = match[2]; op[3] = match[3]; match += inc32table[offset]; - memcpy(op + 4, match, 4); + LZ4_copy4(op + 4, match); match -= dec64table[offset]; } else { LZ4_copy8(op, match);
Let me know if you have any further suggestions.
Thanks.
Regards, Jonathan
On Sun, 26 May 2024 at 22:18, Jianan Huang jnhuang95@gmail.com wrote:
Hi Jonathan,
- LZ4_memcpy(op + 0, match + 0, 8);
- LZ4_memcpy(op + 8, match + 8, 8);
- LZ4_memcpy(op + 16, match + 16, 2); op += length + MINMATCH; /* Both stages worked, load the next token. */ continue;
- LZ4_memcpy(op, dictEnd - copySize, copySize); op += copySize; if (restSize > (size_t)(op - lowPrefix)) { /* overlap copy */
- LZ4_memcpy(op, lowPrefix, restSize); op += restSize; } }
- LZ4_memcpy(op, match, mlen); } op = copyEnd; if (op == oend)
- LZ4_memcpy(op + 4, match, 4); match -= dec64table[offset]; } else { LZ4_copy8(op, match);
- LZ4_memcpy(out, in, size); out += size; if (size < block_size) { ret = -ENOBUFS; /* output overrun */
Thanks,
Jianan
Hi Gao,
Hi Jianan,
return s;
if (src == dest)
return dest;
resetting ...
Thanks, Gao Xiang
Regards, Jonathan
On 2024/5/28 21:28, Jonathan Liu wrote:
Hi Jianan,
I'm not sure what's the old version come from, but from the copyright itself it seems some earlier 2015 version. Note that there is no absolute outperform between old version and new version, old version may be lack of some necessary boundary check or lead to some msan warning or something, like a new commit of year 2016: https://github.com/lz4/lz4/commit/f094f531441140f10fd461ba769f49d10f5cd581
/* costs ~1%; silence an msan warning when offset == 0 */ /* * note : when partialDecoding, there is no guarantee that * at least 4 bytes remain available in output buffer */ if (!partialDecoding) { assert(oend > op); assert(oend - op >= 4);
LZ4_write32(op, (U32)offset); } For the example above, you could completely remove the line above if you don't care about such warning, as it claims ~1% performance loss.
Also since no u-boot user uses in-place decompression and if you memmove() doesn't behave well, you could update the following line /* * supports overlapping memory regions; only matters * for in-place decompression scenarios */ memmove(op, ip, length); into memcpy() instead.
The new lz4 codebase relies on memcpy() / memmove() code optimization more than old version, if memcpy() assembly doesn't generate well on your platform, it might have some issue.
Thanks, Gao Xiang
- put_unaligned(get_unaligned((const u16 *)src), (u16 *)dst);
- static FORCE_INLINE void LZ4_copy8(void *dst, const void *src) { put_unaligned(get_unaligned((const u64 *)src), (u64 *)dst);
LZ4_copy8(op, ip);
if (endOnInput)
op += length; ip += length; /*
Thanks.
Regards, Jonathan
Hi Jonathan,
Thanks,
Jianan
Hi Gao,
Hi Jianan,
return s;
if (src == dest)
return dest;
resetting ...
Thanks, Gao Xiang
Regards, Jonathan
Support EROFS lz4 compressed files.
Signed-off-by: Huang Jianan jnhuang95@gmail.com --- fs/erofs/Kconfig | 9 + fs/erofs/Makefile | 4 +- fs/erofs/data.c | 90 ++++++- fs/erofs/decompress.c | 78 ++++++ fs/erofs/decompress.h | 24 ++ fs/erofs/namei.c | 2 +- fs/erofs/zmap.c | 601 ++++++++++++++++++++++++++++++++++++++++++ 7 files changed, 805 insertions(+), 3 deletions(-) create mode 100644 fs/erofs/decompress.c create mode 100644 fs/erofs/decompress.h create mode 100644 fs/erofs/zmap.c
diff --git a/fs/erofs/Kconfig b/fs/erofs/Kconfig index f4b2d51a23..ee4e777c5c 100644 --- a/fs/erofs/Kconfig +++ b/fs/erofs/Kconfig @@ -10,3 +10,12 @@ config FS_EROFS improves storage density, keeps relatively higher compression ratios, which is more useful to achieve high performance for embedded devices with limited memory. + +config FS_EROFS_ZIP + bool "EROFS Data Compression Support" + depends on FS_EROFS + select LZ4 + default y + help + Enable fixed-sized output compression for EROFS. + If you don't want to enable compression feature, say N. diff --git a/fs/erofs/Makefile b/fs/erofs/Makefile index 7398ab7a36..58af6a68e4 100644 --- a/fs/erofs/Makefile +++ b/fs/erofs/Makefile @@ -4,4 +4,6 @@ obj-$(CONFIG_$(SPL_)FS_EROFS) = fs.o \ super.o \ namei.o \ - data.o + data.o \ + decompress.o \ + zmap.o diff --git a/fs/erofs/data.c b/fs/erofs/data.c index 699975c1be..761896054c 100644 --- a/fs/erofs/data.c +++ b/fs/erofs/data.c @@ -1,5 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ #include "internal.h" +#include "decompress.h"
static int erofs_map_blocks_flatmode(struct erofs_inode *inode, struct erofs_map_blocks *map, @@ -205,6 +206,93 @@ static int erofs_read_raw_data(struct erofs_inode *inode, char *buffer, return 0; }
+static int z_erofs_read_data(struct erofs_inode *inode, char *buffer, + erofs_off_t size, erofs_off_t offset) +{ + erofs_off_t end, length, skip; + struct erofs_map_blocks map = { + .index = UINT_MAX, + }; + struct erofs_map_dev mdev; + bool partial; + unsigned int bufsize = 0; + char *raw = NULL; + int ret = 0; + + end = offset + size; + while (end > offset) { + map.m_la = end - 1; + + ret = z_erofs_map_blocks_iter(inode, &map, 0); + if (ret) + break; + + /* no device id here, thus it will always succeed */ + mdev = (struct erofs_map_dev) { + .m_pa = map.m_pa, + }; + ret = erofs_map_dev(&sbi, &mdev); + if (ret) { + DBG_BUGON(1); + break; + } + + /* + * trim to the needed size if the returned extent is quite + * larger than requested, and set up partial flag as well. + */ + if (end < map.m_la + map.m_llen) { + length = end - map.m_la; + partial = true; + } else { + DBG_BUGON(end != map.m_la + map.m_llen); + length = map.m_llen; + partial = !(map.m_flags & EROFS_MAP_FULL_MAPPED); + } + + if (map.m_la < offset) { + skip = offset - map.m_la; + end = offset; + } else { + skip = 0; + end = map.m_la; + } + + if (!(map.m_flags & EROFS_MAP_MAPPED)) { + memset(buffer + end - offset, 0, length); + end = map.m_la; + continue; + } + + if (map.m_plen > bufsize) { + bufsize = map.m_plen; + raw = realloc(raw, bufsize); + if (!raw) { + ret = -ENOMEM; + break; + } + } + ret = erofs_dev_read(mdev.m_deviceid, raw, mdev.m_pa, map.m_plen); + if (ret < 0) + break; + + ret = z_erofs_decompress(&(struct z_erofs_decompress_req) { + .in = raw, + .out = buffer + end - offset, + .decodedskip = skip, + .inputsize = map.m_plen, + .decodedlength = length, + .alg = map.m_algorithmformat, + .partial_decoding = partial + }); + if (ret < 0) + break; + } + if (raw) + free(raw); + return ret < 0 ? ret : 0; +} + int erofs_pread(struct erofs_inode *inode, char *buf, erofs_off_t count, erofs_off_t offset) { @@ -215,7 +303,7 @@ int erofs_pread(struct erofs_inode *inode, char *buf, return erofs_read_raw_data(inode, buf, count, offset); case EROFS_INODE_FLAT_COMPRESSION_LEGACY: case EROFS_INODE_FLAT_COMPRESSION: - return -EOPNOTSUPP; + return z_erofs_read_data(inode, buf, count, offset); default: break; } diff --git a/fs/erofs/decompress.c b/fs/erofs/decompress.c new file mode 100644 index 0000000000..2be3b844cf --- /dev/null +++ b/fs/erofs/decompress.c @@ -0,0 +1,78 @@ +// SPDX-License-Identifier: GPL-2.0+ +#include "decompress.h" + +#if IS_ENABLED(CONFIG_LZ4) +#include <u-boot/lz4.h> +static int z_erofs_decompress_lz4(struct z_erofs_decompress_req *rq) +{ + int ret = 0; + char *dest = rq->out; + char *src = rq->in; + char *buff = NULL; + bool support_0padding = false; + unsigned int inputmargin = 0; + + if (erofs_sb_has_lz4_0padding()) { + support_0padding = true; + + while (!src[inputmargin & ~PAGE_MASK]) + if (!(++inputmargin & ~PAGE_MASK)) + break; + + if (inputmargin >= rq->inputsize) + return -EIO; + } + + if (rq->decodedskip) { + buff = malloc(rq->decodedlength); + if (!buff) + return -ENOMEM; + dest = buff; + } + + if (rq->partial_decoding || !support_0padding) + ret = LZ4_decompress_safe_partial(src + inputmargin, dest, + rq->inputsize - inputmargin, + rq->decodedlength, rq->decodedlength); + else + ret = LZ4_decompress_safe(src + inputmargin, dest, + rq->inputsize - inputmargin, + rq->decodedlength); + + if (ret != (int)rq->decodedlength) { + ret = -EIO; + goto out; + } + + if (rq->decodedskip) + memcpy(rq->out, dest + rq->decodedskip, + rq->decodedlength - rq->decodedskip); + +out: + if (buff) + free(buff); + + return ret; +} +#endif + +int z_erofs_decompress(struct z_erofs_decompress_req *rq) +{ + if (rq->alg == Z_EROFS_COMPRESSION_SHIFTED) { + if (rq->inputsize != EROFS_BLKSIZ) + return -EFSCORRUPTED; + + DBG_BUGON(rq->decodedlength > EROFS_BLKSIZ); + DBG_BUGON(rq->decodedlength < rq->decodedskip); + + memcpy(rq->out, rq->in + rq->decodedskip, + rq->decodedlength - rq->decodedskip); + return 0; + } + +#if IS_ENABLED(CONFIG_LZ4) + if (rq->alg == Z_EROFS_COMPRESSION_LZ4) + return z_erofs_decompress_lz4(rq); +#endif + return -EOPNOTSUPP; +} diff --git a/fs/erofs/decompress.h b/fs/erofs/decompress.h new file mode 100644 index 0000000000..81d5fb84f6 --- /dev/null +++ b/fs/erofs/decompress.h @@ -0,0 +1,24 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +#ifndef __EROFS_DECOMPRESS_H +#define __EROFS_DECOMPRESS_H + +#include "internal.h" + +struct z_erofs_decompress_req { + char *in, *out; + + /* + * initial decompressed bytes that need to be skipped + * when finally copying to output buffer + */ + unsigned int decodedskip; + unsigned int inputsize, decodedlength; + + /* indicate the algorithm will be used for decompression */ + unsigned int alg; + bool partial_decoding; +}; + +int z_erofs_decompress(struct z_erofs_decompress_req *rq); + +#endif diff --git a/fs/erofs/namei.c b/fs/erofs/namei.c index f1195a09ea..d1d4757c50 100644 --- a/fs/erofs/namei.c +++ b/fs/erofs/namei.c @@ -114,7 +114,7 @@ int erofs_read_inode_from_disk(struct erofs_inode *vi) vi->u.chunkbits = LOG_BLOCK_SIZE + (vi->u.chunkformat & EROFS_CHUNK_FORMAT_BLKBITS_MASK); } else if (erofs_inode_is_data_compressed(vi->datalayout)) - return -EOPNOTSUPP; + z_erofs_fill_inode(vi); return 0; bogusimode: erofs_err("bogus i_mode (%o) @ nid %llu", vi->i_mode, vi->nid | 0ULL); diff --git a/fs/erofs/zmap.c b/fs/erofs/zmap.c new file mode 100644 index 0000000000..be2599ac4f --- /dev/null +++ b/fs/erofs/zmap.c @@ -0,0 +1,601 @@ +// SPDX-License-Identifier: GPL-2.0+ +#include "internal.h" + +int z_erofs_fill_inode(struct erofs_inode *vi) +{ + if (!erofs_sb_has_big_pcluster() && + vi->datalayout == EROFS_INODE_FLAT_COMPRESSION_LEGACY) { + vi->z_advise = 0; + vi->z_algorithmtype[0] = 0; + vi->z_algorithmtype[1] = 0; + vi->z_logical_clusterbits = LOG_BLOCK_SIZE; + + vi->flags |= EROFS_I_Z_INITED; + } + return 0; +} + +static int z_erofs_fill_inode_lazy(struct erofs_inode *vi) +{ + int ret; + erofs_off_t pos; + struct z_erofs_map_header *h; + char buf[sizeof(struct z_erofs_map_header)]; + + if (vi->flags & EROFS_I_Z_INITED) + return 0; + + DBG_BUGON(!erofs_sb_has_big_pcluster() && + vi->datalayout == EROFS_INODE_FLAT_COMPRESSION_LEGACY); + pos = round_up(iloc(vi->nid) + vi->inode_isize + vi->xattr_isize, 8); + + ret = erofs_dev_read(0, buf, pos, sizeof(buf)); + if (ret < 0) + return -EIO; + + h = (struct z_erofs_map_header *)buf; + vi->z_advise = le16_to_cpu(h->h_advise); + vi->z_algorithmtype[0] = h->h_algorithmtype & 15; + vi->z_algorithmtype[1] = h->h_algorithmtype >> 4; + + if (vi->z_algorithmtype[0] >= Z_EROFS_COMPRESSION_MAX) { + erofs_err("unknown compression format %u for nid %llu", + vi->z_algorithmtype[0], (unsigned long long)vi->nid); + return -EOPNOTSUPP; + } + + vi->z_logical_clusterbits = LOG_BLOCK_SIZE + (h->h_clusterbits & 7); + if (vi->datalayout == EROFS_INODE_FLAT_COMPRESSION && + !(vi->z_advise & Z_EROFS_ADVISE_BIG_PCLUSTER_1) ^ + !(vi->z_advise & Z_EROFS_ADVISE_BIG_PCLUSTER_2)) { + erofs_err("big pcluster head1/2 of compact indexes should be consistent for nid %llu", + vi->nid * 1ULL); + return -EFSCORRUPTED; + } + vi->flags |= EROFS_I_Z_INITED; + return 0; +} + +struct z_erofs_maprecorder { + struct erofs_inode *inode; + struct erofs_map_blocks *map; + void *kaddr; + + unsigned long lcn; + /* compression extent information gathered */ + u8 type, headtype; + u16 clusterofs; + u16 delta[2]; + erofs_blk_t pblk, compressedlcs; +}; + +static int z_erofs_reload_indexes(struct z_erofs_maprecorder *m, + erofs_blk_t eblk) +{ + int ret; + struct erofs_map_blocks *const map = m->map; + char *mpage = map->mpage; + + if (map->index == eblk) + return 0; + + ret = erofs_blk_read(mpage, eblk, 1); + if (ret < 0) + return -EIO; + + map->index = eblk; + + return 0; +} + +static int legacy_load_cluster_from_disk(struct z_erofs_maprecorder *m, + unsigned long lcn) +{ + struct erofs_inode *const vi = m->inode; + const erofs_off_t ibase = iloc(vi->nid); + const erofs_off_t pos = + Z_EROFS_VLE_LEGACY_INDEX_ALIGN(ibase + vi->inode_isize + + vi->xattr_isize) + + lcn * sizeof(struct z_erofs_vle_decompressed_index); + struct z_erofs_vle_decompressed_index *di; + unsigned int advise, type; + int err; + + err = z_erofs_reload_indexes(m, erofs_blknr(pos)); + if (err) + return err; + + m->lcn = lcn; + di = m->kaddr + erofs_blkoff(pos); + + advise = le16_to_cpu(di->di_advise); + type = (advise >> Z_EROFS_VLE_DI_CLUSTER_TYPE_BIT) & + ((1 << Z_EROFS_VLE_DI_CLUSTER_TYPE_BITS) - 1); + switch (type) { + case Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD: + m->clusterofs = 1 << vi->z_logical_clusterbits; + m->delta[0] = le16_to_cpu(di->di_u.delta[0]); + if (m->delta[0] & Z_EROFS_VLE_DI_D0_CBLKCNT) { + if (!(vi->z_advise & Z_EROFS_ADVISE_BIG_PCLUSTER_1)) { + DBG_BUGON(1); + return -EFSCORRUPTED; + } + m->compressedlcs = m->delta[0] & + ~Z_EROFS_VLE_DI_D0_CBLKCNT; + m->delta[0] = 1; + } + m->delta[1] = le16_to_cpu(di->di_u.delta[1]); + break; + case Z_EROFS_VLE_CLUSTER_TYPE_PLAIN: + case Z_EROFS_VLE_CLUSTER_TYPE_HEAD: + m->clusterofs = le16_to_cpu(di->di_clusterofs); + m->pblk = le32_to_cpu(di->di_u.blkaddr); + break; + default: + DBG_BUGON(1); + return -EOPNOTSUPP; + } + m->type = type; + return 0; +} + +static unsigned int decode_compactedbits(unsigned int lobits, + unsigned int lomask, + u8 *in, unsigned int pos, u8 *type) +{ + const unsigned int v = get_unaligned_le32(in + pos / 8) >> (pos & 7); + const unsigned int lo = v & lomask; + + *type = (v >> lobits) & 3; + return lo; +} + +static int get_compacted_la_distance(unsigned int lclusterbits, + unsigned int encodebits, + unsigned int vcnt, u8 *in, int i) +{ + const unsigned int lomask = (1 << lclusterbits) - 1; + unsigned int lo, d1 = 0; + u8 type; + + DBG_BUGON(i >= vcnt); + + do { + lo = decode_compactedbits(lclusterbits, lomask, + in, encodebits * i, &type); + + if (type != Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD) + return d1; + ++d1; + } while (++i < vcnt); + + /* vcnt - 1 (Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD) item */ + if (!(lo & Z_EROFS_VLE_DI_D0_CBLKCNT)) + d1 += lo - 1; + return d1; +} + +static int unpack_compacted_index(struct z_erofs_maprecorder *m, + unsigned int amortizedshift, + unsigned int eofs, bool lookahead) +{ + struct erofs_inode *const vi = m->inode; + const unsigned int lclusterbits = vi->z_logical_clusterbits; + const unsigned int lomask = (1 << lclusterbits) - 1; + unsigned int vcnt, base, lo, encodebits, nblk; + int i; + u8 *in, type; + bool big_pcluster; + + if (1 << amortizedshift == 4) + vcnt = 2; + else if (1 << amortizedshift == 2 && lclusterbits == 12) + vcnt = 16; + else + return -EOPNOTSUPP; + + big_pcluster = vi->z_advise & Z_EROFS_ADVISE_BIG_PCLUSTER_1; + encodebits = ((vcnt << amortizedshift) - sizeof(__le32)) * 8 / vcnt; + base = round_down(eofs, vcnt << amortizedshift); + in = m->kaddr + base; + + i = (eofs - base) >> amortizedshift; + + lo = decode_compactedbits(lclusterbits, lomask, + in, encodebits * i, &type); + m->type = type; + if (type == Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD) { + m->clusterofs = 1 << lclusterbits; + + /* figure out lookahead_distance: delta[1] if needed */ + if (lookahead) + m->delta[1] = get_compacted_la_distance(lclusterbits, + encodebits, + vcnt, in, i); + if (lo & Z_EROFS_VLE_DI_D0_CBLKCNT) { + if (!big_pcluster) { + DBG_BUGON(1); + return -EFSCORRUPTED; + } + m->compressedlcs = lo & ~Z_EROFS_VLE_DI_D0_CBLKCNT; + m->delta[0] = 1; + return 0; + } else if (i + 1 != (int)vcnt) { + m->delta[0] = lo; + return 0; + } + /* + * since the last lcluster in the pack is special, + * of which lo saves delta[1] rather than delta[0]. + * Hence, get delta[0] by the previous lcluster indirectly. + */ + lo = decode_compactedbits(lclusterbits, lomask, + in, encodebits * (i - 1), &type); + if (type != Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD) + lo = 0; + else if (lo & Z_EROFS_VLE_DI_D0_CBLKCNT) + lo = 1; + m->delta[0] = lo + 1; + return 0; + } + m->clusterofs = lo; + m->delta[0] = 0; + /* figout out blkaddr (pblk) for HEAD lclusters */ + if (!big_pcluster) { + nblk = 1; + while (i > 0) { + --i; + lo = decode_compactedbits(lclusterbits, lomask, + in, encodebits * i, &type); + if (type == Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD) + i -= lo; + + if (i >= 0) + ++nblk; + } + } else { + nblk = 0; + while (i > 0) { + --i; + lo = decode_compactedbits(lclusterbits, lomask, + in, encodebits * i, &type); + if (type == Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD) { + if (lo & Z_EROFS_VLE_DI_D0_CBLKCNT) { + --i; + nblk += lo & ~Z_EROFS_VLE_DI_D0_CBLKCNT; + continue; + } + if (lo == 1) { + DBG_BUGON(1); + /* --i; ++nblk; continue; */ + return -EFSCORRUPTED; + } + i -= lo - 2; + continue; + } + ++nblk; + } + } + in += (vcnt << amortizedshift) - sizeof(__le32); + m->pblk = le32_to_cpu(*(__le32 *)in) + nblk; + return 0; +} + +static int compacted_load_cluster_from_disk(struct z_erofs_maprecorder *m, + unsigned long lcn, bool lookahead) +{ + struct erofs_inode *const vi = m->inode; + const unsigned int lclusterbits = vi->z_logical_clusterbits; + const erofs_off_t ebase = round_up(iloc(vi->nid) + vi->inode_isize + + vi->xattr_isize, 8) + + sizeof(struct z_erofs_map_header); + const unsigned int totalidx = DIV_ROUND_UP(vi->i_size, EROFS_BLKSIZ); + unsigned int compacted_4b_initial, compacted_2b; + unsigned int amortizedshift; + erofs_off_t pos; + int err; + + if (lclusterbits != 12) + return -EOPNOTSUPP; + + if (lcn >= totalidx) + return -EINVAL; + + m->lcn = lcn; + /* used to align to 32-byte (compacted_2b) alignment */ + compacted_4b_initial = (32 - ebase % 32) / 4; + if (compacted_4b_initial == 32 / 4) + compacted_4b_initial = 0; + + if (vi->z_advise & Z_EROFS_ADVISE_COMPACTED_2B) + compacted_2b = rounddown(totalidx - compacted_4b_initial, 16); + else + compacted_2b = 0; + + pos = ebase; + if (lcn < compacted_4b_initial) { + amortizedshift = 2; + goto out; + } + pos += compacted_4b_initial * 4; + lcn -= compacted_4b_initial; + + if (lcn < compacted_2b) { + amortizedshift = 1; + goto out; + } + pos += compacted_2b * 2; + lcn -= compacted_2b; + amortizedshift = 2; +out: + pos += lcn * (1 << amortizedshift); + err = z_erofs_reload_indexes(m, erofs_blknr(pos)); + if (err) + return err; + return unpack_compacted_index(m, amortizedshift, erofs_blkoff(pos), + lookahead); +} + +static int z_erofs_load_cluster_from_disk(struct z_erofs_maprecorder *m, + unsigned int lcn, bool lookahead) +{ + const unsigned int datamode = m->inode->datalayout; + + if (datamode == EROFS_INODE_FLAT_COMPRESSION_LEGACY) + return legacy_load_cluster_from_disk(m, lcn); + + if (datamode == EROFS_INODE_FLAT_COMPRESSION) + return compacted_load_cluster_from_disk(m, lcn, lookahead); + + return -EINVAL; +} + +static int z_erofs_extent_lookback(struct z_erofs_maprecorder *m, + unsigned int lookback_distance) +{ + struct erofs_inode *const vi = m->inode; + struct erofs_map_blocks *const map = m->map; + const unsigned int lclusterbits = vi->z_logical_clusterbits; + unsigned long lcn = m->lcn; + int err; + + if (lcn < lookback_distance) { + erofs_err("bogus lookback distance @ nid %llu", + (unsigned long long)vi->nid); + DBG_BUGON(1); + return -EFSCORRUPTED; + } + + /* load extent head logical cluster if needed */ + lcn -= lookback_distance; + err = z_erofs_load_cluster_from_disk(m, lcn, false); + if (err) + return err; + + switch (m->type) { + case Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD: + if (!m->delta[0]) { + erofs_err("invalid lookback distance 0 @ nid %llu", + (unsigned long long)vi->nid); + DBG_BUGON(1); + return -EFSCORRUPTED; + } + return z_erofs_extent_lookback(m, m->delta[0]); + case Z_EROFS_VLE_CLUSTER_TYPE_PLAIN: + case Z_EROFS_VLE_CLUSTER_TYPE_HEAD: + m->headtype = m->type; + map->m_la = (lcn << lclusterbits) | m->clusterofs; + break; + default: + erofs_err("unknown type %u @ lcn %lu of nid %llu", + m->type, lcn, (unsigned long long)vi->nid); + DBG_BUGON(1); + return -EOPNOTSUPP; + } + return 0; +} + +static int z_erofs_get_extent_compressedlen(struct z_erofs_maprecorder *m, + unsigned int initial_lcn) +{ + struct erofs_inode *const vi = m->inode; + struct erofs_map_blocks *const map = m->map; + const unsigned int lclusterbits = vi->z_logical_clusterbits; + unsigned long lcn; + int err; + + DBG_BUGON(m->type != Z_EROFS_VLE_CLUSTER_TYPE_PLAIN && + m->type != Z_EROFS_VLE_CLUSTER_TYPE_HEAD); + if (m->headtype == Z_EROFS_VLE_CLUSTER_TYPE_PLAIN || + !(vi->z_advise & Z_EROFS_ADVISE_BIG_PCLUSTER_1)) { + map->m_plen = 1 << lclusterbits; + return 0; + } + + lcn = m->lcn + 1; + if (m->compressedlcs) + goto out; + + err = z_erofs_load_cluster_from_disk(m, lcn, false); + if (err) + return err; + + /* + * If the 1st NONHEAD lcluster has already been handled initially w/o + * valid compressedlcs, which means at least it mustn't be CBLKCNT, or + * an internal implemenatation error is detected. + * + * The following code can also handle it properly anyway, but let's + * BUG_ON in the debugging mode only for developers to notice that. + */ + DBG_BUGON(lcn == initial_lcn && + m->type == Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD); + + switch (m->type) { + case Z_EROFS_VLE_CLUSTER_TYPE_PLAIN: + case Z_EROFS_VLE_CLUSTER_TYPE_HEAD: + /* + * if the 1st NONHEAD lcluster is actually PLAIN or HEAD type + * rather than CBLKCNT, it's a 1 lcluster-sized pcluster. + */ + m->compressedlcs = 1; + break; + case Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD: + if (m->delta[0] != 1) + goto err_bonus_cblkcnt; + if (m->compressedlcs) + break; + /* fallthrough */ + default: + erofs_err("cannot found CBLKCNT @ lcn %lu of nid %llu", + lcn, vi->nid | 0ULL); + DBG_BUGON(1); + return -EFSCORRUPTED; + } +out: + map->m_plen = m->compressedlcs << lclusterbits; + return 0; +err_bonus_cblkcnt: + erofs_err("bogus CBLKCNT @ lcn %lu of nid %llu", + lcn, vi->nid | 0ULL); + DBG_BUGON(1); + return -EFSCORRUPTED; +} + +static int z_erofs_get_extent_decompressedlen(struct z_erofs_maprecorder *m) +{ + struct erofs_inode *const vi = m->inode; + struct erofs_map_blocks *map = m->map; + unsigned int lclusterbits = vi->z_logical_clusterbits; + u64 lcn = m->lcn, headlcn = map->m_la >> lclusterbits; + int err; + + do { + /* handle the last EOF pcluster (no next HEAD lcluster) */ + if ((lcn << lclusterbits) >= vi->i_size) { + map->m_llen = vi->i_size - map->m_la; + return 0; + } + + err = z_erofs_load_cluster_from_disk(m, lcn, true); + if (err) + return err; + + if (m->type == Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD) { + DBG_BUGON(!m->delta[1] && + m->clusterofs != 1 << lclusterbits); + } else if (m->type == Z_EROFS_VLE_CLUSTER_TYPE_PLAIN || + m->type == Z_EROFS_VLE_CLUSTER_TYPE_HEAD) { + /* go on until the next HEAD lcluster */ + if (lcn != headlcn) + break; + m->delta[1] = 1; + } else { + erofs_err("unknown type %u @ lcn %llu of nid %llu", + m->type, lcn | 0ULL, + (unsigned long long)vi->nid); + DBG_BUGON(1); + return -EOPNOTSUPP; + } + lcn += m->delta[1]; + } while (m->delta[1]); + + map->m_llen = (lcn << lclusterbits) + m->clusterofs - map->m_la; + return 0; +} + +int z_erofs_map_blocks_iter(struct erofs_inode *vi, + struct erofs_map_blocks *map, + int flags) +{ + struct z_erofs_maprecorder m = { + .inode = vi, + .map = map, + .kaddr = map->mpage, + }; + int err = 0; + unsigned int lclusterbits, endoff; + unsigned long initial_lcn; + unsigned long long ofs, end; + + /* when trying to read beyond EOF, leave it unmapped */ + if (map->m_la >= vi->i_size) { + map->m_llen = map->m_la + 1 - vi->i_size; + map->m_la = vi->i_size; + map->m_flags = 0; + goto out; + } + + err = z_erofs_fill_inode_lazy(vi); + if (err) + goto out; + + lclusterbits = vi->z_logical_clusterbits; + ofs = map->m_la; + initial_lcn = ofs >> lclusterbits; + endoff = ofs & ((1 << lclusterbits) - 1); + + err = z_erofs_load_cluster_from_disk(&m, initial_lcn, false); + if (err) + goto out; + + map->m_flags = EROFS_MAP_MAPPED | EROFS_MAP_ENCODED; + end = (m.lcn + 1ULL) << lclusterbits; + switch (m.type) { + case Z_EROFS_VLE_CLUSTER_TYPE_PLAIN: + case Z_EROFS_VLE_CLUSTER_TYPE_HEAD: + if (endoff >= m.clusterofs) { + m.headtype = m.type; + map->m_la = (m.lcn << lclusterbits) | m.clusterofs; + break; + } + /* m.lcn should be >= 1 if endoff < m.clusterofs */ + if (!m.lcn) { + erofs_err("invalid logical cluster 0 at nid %llu", + (unsigned long long)vi->nid); + err = -EFSCORRUPTED; + goto out; + } + end = (m.lcn << lclusterbits) | m.clusterofs; + map->m_flags |= EROFS_MAP_FULL_MAPPED; + m.delta[0] = 1; + /* fallthrough */ + case Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD: + /* get the correspoinding first chunk */ + err = z_erofs_extent_lookback(&m, m.delta[0]); + if (err) + goto out; + break; + default: + erofs_err("unknown type %u @ offset %llu of nid %llu", + m.type, ofs, (unsigned long long)vi->nid); + err = -EOPNOTSUPP; + goto out; + } + + map->m_llen = end - map->m_la; + map->m_pa = blknr_to_addr(m.pblk); + + err = z_erofs_get_extent_compressedlen(&m, initial_lcn); + if (err) + goto out; + + if (m.headtype == Z_EROFS_VLE_CLUSTER_TYPE_PLAIN) + map->m_algorithmformat = Z_EROFS_COMPRESSION_SHIFTED; + else + map->m_algorithmformat = vi->z_algorithmtype[0]; + + if (flags & EROFS_GET_BLOCKS_FIEMAP) { + err = z_erofs_get_extent_decompressedlen(&m); + if (!err) + map->m_flags |= EROFS_MAP_FULL_MAPPED; + } + +out: + erofs_dbg("m_la %" PRIu64 " m_pa %" PRIu64 " m_llen %" PRIu64 " m_plen %" PRIu64 " m_flags 0%o", + map->m_la, map->m_pa, + map->m_llen, map->m_plen, map->m_flags); + + DBG_BUGON(err < 0 && err != -ENOMEM); + return err; +}
Add 'ls' and 'load' commands.
Signed-off-by: Huang Jianan jnhuang95@gmail.com --- MAINTAINERS | 1 + cmd/Kconfig | 6 ++++++ cmd/Makefile | 1 + cmd/erofs.c | 42 ++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 50 insertions(+) create mode 100644 cmd/erofs.c
diff --git a/MAINTAINERS b/MAINTAINERS index dd2ce8143c..bd8835619e 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -812,6 +812,7 @@ EROFS M: Huang Jianan jnhuang95@gmail.com L: linux-erofs@lists.ozlabs.org S: Maintained +F: cmd/erofs.c F: fs/erofs/ F: include/erofs.h
diff --git a/cmd/Kconfig b/cmd/Kconfig index 5e25e45fd2..50b8f33434 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -2176,6 +2176,12 @@ config CMD_CRAMFS cramfsls - lists files in a cramfs image cramfsload - loads a file from a cramfs image
+config CMD_EROFS + bool "EROFS command support" + select FS_EROFS + help + Support for the EROFS fs + config CMD_EXT2 bool "ext2 command support" select FS_EXT4 diff --git a/cmd/Makefile b/cmd/Makefile index 166c652d98..d668b3c62d 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -60,6 +60,7 @@ obj-$(CONFIG_CMD_EEPROM) += eeprom.o obj-$(CONFIG_EFI) += efi.o obj-$(CONFIG_CMD_EFIDEBUG) += efidebug.o obj-$(CONFIG_CMD_ELF) += elf.o +obj-$(CONFIG_CMD_EROFS) += erofs.o obj-$(CONFIG_HUSH_PARSER) += exit.o obj-$(CONFIG_CMD_EXT4) += ext4.o obj-$(CONFIG_CMD_EXT2) += ext2.o diff --git a/cmd/erofs.c b/cmd/erofs.c new file mode 100644 index 0000000000..add80b8b59 --- /dev/null +++ b/cmd/erofs.c @@ -0,0 +1,42 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 Huang Jianan jnhuang95@gmail.com + * + * Author: Huang Jianan jnhuang95@gmail.com + * + * erofs.c: implements EROFS related commands + */ + +#include <command.h> +#include <fs.h> +#include <erofs.h> + +static int do_erofs_ls(struct cmd_tbl *cmdtp, int flag, int argc, char * const argv[]) +{ + return do_ls(cmdtp, flag, argc, argv, FS_TYPE_EROFS); +} + +U_BOOT_CMD(erofsls, 4, 1, do_erofs_ls, + "List files in directory. Default: root (/).", + "<interface> [<dev[:part]>] [directory]\n" + " - list files from 'dev' on 'interface' in 'directory'\n" +); + +static int do_erofs_load(struct cmd_tbl *cmdtp, int flag, int argc, char * const argv[]) +{ + return do_load(cmdtp, flag, argc, argv, FS_TYPE_EROFS); +} + +U_BOOT_CMD(erofsload, 7, 0, do_erofs_load, + "load binary file from a EROFS filesystem", + "<interface> [<dev[:part]> [<addr> [<filename> [bytes [pos]]]]]\n" + " - Load binary file 'filename' from 'dev' on 'interface'\n" + " to address 'addr' from EROFS filesystem.\n" + " 'pos' gives the file position to start loading from.\n" + " If 'pos' is omitted, 0 is used. 'pos' requires 'bytes'.\n" + " 'bytes' gives the size to load. If 'bytes' is 0 or omitted,\n" + " the load stops on end of file.\n" + " If either 'pos' or 'bytes' are not aligned to\n" + " ARCH_DMA_MINALIGN then a misaligned buffer warning will\n" + " be printed and performance will suffer for the load." +);
Add Python scripts to test 'ls' and 'load' commands, as well as test related filesystem functions.
Signed-off-by: Huang Jianan jnhuang95@gmail.com --- MAINTAINERS | 1 + configs/sandbox_defconfig | 1 + test/py/tests/test_fs/test_erofs.py | 211 ++++++++++++++++++++++++++++ tools/docker/Dockerfile | 1 + 4 files changed, 214 insertions(+) create mode 100644 test/py/tests/test_fs/test_erofs.py
diff --git a/MAINTAINERS b/MAINTAINERS index bd8835619e..e1c6b986f0 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -815,6 +815,7 @@ S: Maintained F: cmd/erofs.c F: fs/erofs/ F: include/erofs.h +F: test/py/tests/test_fs/test_erofs.py
FASTBOOT S: Orphaned diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 7ebeb89264..47fd33e8bc 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -105,6 +105,7 @@ CONFIG_CMD_TPM_TEST=y CONFIG_CMD_BTRFS=y CONFIG_CMD_CBFS=y CONFIG_CMD_CRAMFS=y +CONFIG_CMD_EROFS=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_SQUASHFS=y CONFIG_CMD_MTDPARTS=y diff --git a/test/py/tests/test_fs/test_erofs.py b/test/py/tests/test_fs/test_erofs.py new file mode 100644 index 0000000000..458a52ba79 --- /dev/null +++ b/test/py/tests/test_fs/test_erofs.py @@ -0,0 +1,211 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Huang Jianan jnhuang95@gmail.com +# Author: Huang Jianan jnhuang95@gmail.com + +import os +import pytest +import shutil +import subprocess + +EROFS_SRC_DIR = 'erofs_src_dir' +EROFS_IMAGE_NAME = 'erofs.img' + +def generate_file(name, size): + """ + Generates a file filled with 'x'. + """ + content = 'x' * size + file = open(name, 'w') + file.write(content) + file.close() + +def make_erofs_image(build_dir): + """ + Makes the EROFS images used for the test. + + The image is generated at build_dir with the following structure: + erofs_src_dir/ + ├── f4096 + ├── f7812 + ├── subdir/ + │ └── subdir-file + ├── symdir -> subdir + └── symfile -> f5096 + """ + root = os.path.join(build_dir, EROFS_SRC_DIR) + os.makedirs(root) + + # 4096: uncompressed file + generate_file(os.path.join(root, 'f4096'), 4096) + + # 7812: Compressed file + generate_file(os.path.join(root, 'f7812'), 7812) + + # sub-directory with a single file inside + subdir_path = os.path.join(root, 'subdir') + os.makedirs(subdir_path) + generate_file(os.path.join(subdir_path, 'subdir-file'), 100) + + # symlink + os.symlink('subdir', os.path.join(root, 'symdir')) + os.symlink('f7812', os.path.join(root, 'symfile')) + + input_path = os.path.join(build_dir, EROFS_SRC_DIR) + output_path = os.path.join(build_dir, EROFS_IMAGE_NAME) + args = ' '.join([output_path, input_path]) + subprocess.run(['mkfs.erofs -zlz4 ' + args], shell=True, check=True, + stdout=subprocess.DEVNULL) + +def clean_erofs_image(build_dir): + """ + Deletes the image and src_dir at build_dir. + """ + path = os.path.join(build_dir, EROFS_SRC_DIR) + shutil.rmtree(path) + image_path = os.path.join(build_dir, EROFS_IMAGE_NAME) + os.remove(image_path) + +def erofs_ls_at_root(u_boot_console): + """ + Test if all the present files and directories were listed. + """ + no_slash = u_boot_console.run_command('erofsls host 0') + slash = u_boot_console.run_command('erofsls host 0 /') + assert no_slash == slash + + expected_lines = ['./', '../', '4096 f4096', '7812 f7812', 'subdir/', + '<SYM> symdir', '<SYM> symfile', '4 file(s), 3 dir(s)'] + + output = u_boot_console.run_command('erofsls host 0') + for line in expected_lines: + assert line in output + +def erofs_ls_at_subdir(u_boot_console): + """ + Test if the path resolution works. + """ + expected_lines = ['./', '../', '100 subdir-file', '1 file(s), 2 dir(s)'] + output = u_boot_console.run_command('erofsls host 0 subdir') + for line in expected_lines: + assert line in output + +def erofs_ls_at_symlink(u_boot_console): + """ + Test if the symbolic link's target resolution works. + """ + output = u_boot_console.run_command('erofsls host 0 symdir') + output_subdir = u_boot_console.run_command('erofsls host 0 subdir') + assert output == output_subdir + + expected_lines = ['./', '../', '100 subdir-file', '1 file(s), 2 dir(s)'] + for line in expected_lines: + assert line in output + +def erofs_ls_at_non_existent_dir(u_boot_console): + """ + Test if the EROFS support will crash when get a nonexistent directory. + """ + out_non_existent = u_boot_console.run_command('erofsls host 0 fff') + out_not_dir = u_boot_console.run_command('erofsls host 0 f1000') + assert out_non_existent == out_not_dir + assert '' in out_non_existent + +def erofs_load_files(u_boot_console, files, sizes, address): + """ + Loads files and asserts their checksums. + """ + build_dir = u_boot_console.config.build_dir + for (file, size) in zip(files, sizes): + out = u_boot_console.run_command('erofsload host 0 {} {}'.format(address, file)) + + # check if the right amount of bytes was read + assert size in out + + # calculate u-boot file's checksum + out = u_boot_console.run_command('md5sum {} {}'.format(address, hex(int(size)))) + u_boot_checksum = out.split()[-1] + + # calculate original file's checksum + original_file_path = os.path.join(build_dir, EROFS_SRC_DIR + '/' + file) + out = subprocess.run(['md5sum ' + original_file_path], shell=True, check=True, + capture_output=True, text=True) + original_checksum = out.stdout.split()[0] + + # compare checksum + assert u_boot_checksum == original_checksum + +def erofs_load_files_at_root(u_boot_console): + """ + Test load file from the root directory. + """ + files = ['f4096', 'f7812'] + sizes = ['4096', '7812'] + address = '$kernel_addr_r' + erofs_load_files(u_boot_console, files, sizes, address) + +def erofs_load_files_at_subdir(u_boot_console): + """ + Test load file from the subdirectory. + """ + files = ['subdir/subdir-file'] + sizes = ['100'] + address = '$kernel_addr_r' + erofs_load_files(u_boot_console, files, sizes, address) + +def erofs_load_files_at_symlink(u_boot_console): + """ + Test load file from the symlink. + """ + files = ['symfile'] + sizes = ['7812'] + address = '$kernel_addr_r' + erofs_load_files(u_boot_console, files, sizes, address) + +def erofs_load_non_existent_file(u_boot_console): + """ + Test if the EROFS support will crash when load a nonexistent file. + """ + address = '$kernel_addr_r' + file = 'non-existent' + out = u_boot_console.run_command('erofsload host 0 {} {}'.format(address, file)) + assert 'Failed to load' in out + +def erofs_run_all_tests(u_boot_console): + """ + Runs all test cases. + """ + erofs_ls_at_root(u_boot_console) + erofs_ls_at_subdir(u_boot_console) + erofs_ls_at_symlink(u_boot_console) + erofs_ls_at_non_existent_dir(u_boot_console) + erofs_load_files_at_root(u_boot_console) + erofs_load_files_at_subdir(u_boot_console) + erofs_load_files_at_symlink(u_boot_console) + erofs_load_non_existent_file(u_boot_console) + +@pytest.mark.boardspec('sandbox') +@pytest.mark.buildconfigspec('cmd_fs_generic') +@pytest.mark.buildconfigspec('cmd_erofs') +@pytest.mark.buildconfigspec('fs_erofs') +@pytest.mark.requiredtool('mkfs.erofs') +@pytest.mark.requiredtool('md5sum') + +def test_erofs(u_boot_console): + """ + Executes the erofs test suite. + """ + build_dir = u_boot_console.config.build_dir + + try: + # setup test environment + make_erofs_image(build_dir) + image_path = os.path.join(build_dir, EROFS_IMAGE_NAME) + u_boot_console.run_command('host bind 0 {}'.format(image_path)) + # run all tests + erofs_run_all_tests(u_boot_console) + except: + clean_erofs_image(build_dir) + raise AssertionError + + # clean test environment + clean_erofs_image(build_dir) diff --git a/tools/docker/Dockerfile b/tools/docker/Dockerfile index 7a3f5cbade..8e7a4a7072 100644 --- a/tools/docker/Dockerfile +++ b/tools/docker/Dockerfile @@ -48,6 +48,7 @@ RUN apt-get update && apt-get install -y \ dosfstools \ e2fsprogs \ efitools \ + erofs-utils \ expect \ fakeroot \ flex \
Hi Tom,
Would you mind taking some time to check if this version meets the requirements ?So we could have a chance to be merged into the next version ?
I have triggered a CI via Github PR based on this version : https://github.com/u-boot/u-boot/pull/133
Thanks, Jianan
在 2022/2/26 15:05, Huang Jianan 写道:
Changes since v3:
- update tools/docker/Dockerfile;
Changes since v2:
- sync up with erofs-utils 1.4;
- update lib/lz4 to v1.8.3;
- add test for filesystem functions;
Changes since v1:
- fix the inconsistency between From and SoB;
- add missing license header;
Huang Jianan (5): fs/erofs: add erofs filesystem support lib/lz4: update LZ4 decompressor module fs/erofs: add lz4 decompression support fs/erofs: add filesystem commands test/py: Add tests for the erofs
MAINTAINERS | 9 + cmd/Kconfig | 6 + cmd/Makefile | 1 + cmd/erofs.c | 42 ++ configs/sandbox_defconfig | 1 + fs/Kconfig | 2 + fs/Makefile | 1 + fs/erofs/Kconfig | 21 + fs/erofs/Makefile | 9 + fs/erofs/data.c | 311 +++++++++++++ fs/erofs/decompress.c | 78 ++++ fs/erofs/decompress.h | 24 + fs/erofs/erofs_fs.h | 436 ++++++++++++++++++ fs/erofs/fs.c | 267 +++++++++++ fs/erofs/internal.h | 313 +++++++++++++ fs/erofs/namei.c | 252 +++++++++++ fs/erofs/super.c | 105 +++++ fs/erofs/zmap.c | 601 ++++++++++++++++++++++++ fs/fs.c | 22 + include/erofs.h | 19 + include/fs.h | 1 + include/u-boot/lz4.h | 49 ++ lib/lz4.c | 679 ++++++++++++++++++++-------- lib/lz4_wrapper.c | 23 +- test/py/tests/test_fs/test_erofs.py | 211 +++++++++ tools/docker/Dockerfile | 1 + 26 files changed, 3269 insertions(+), 215 deletions(-) create mode 100644 cmd/erofs.c create mode 100644 fs/erofs/Kconfig create mode 100644 fs/erofs/Makefile create mode 100644 fs/erofs/data.c create mode 100644 fs/erofs/decompress.c create mode 100644 fs/erofs/decompress.h create mode 100644 fs/erofs/erofs_fs.h create mode 100644 fs/erofs/fs.c create mode 100644 fs/erofs/internal.h create mode 100644 fs/erofs/namei.c create mode 100644 fs/erofs/super.c create mode 100644 fs/erofs/zmap.c create mode 100644 include/erofs.h create mode 100644 test/py/tests/test_fs/test_erofs.py
On Thu, Mar 03, 2022 at 10:51:18PM +0800, Huang Jianan wrote:
Hi Tom,
It seems fine, yes. The thing about that PR is that it doesn't use a custom build of the Docker container that also has the tools, so the FS tests aren't actually run. I'll do that when I get to testing and applying this, but if you can do that before hand to ensure the tests really do run and pass, especially on Azure where things can be a tiny bit trickier (since source directory is enforced read-only), that would be great.
Thanks, Jianan
Changes since v3:
Changes since v2:
Changes since v1:
在 2022/3/4 3:15, Tom Rini 写道:
Hi Tom,
I verified the test on my own machine, but I overlooked that the container used in CI is prebuilt ... I replaced the container in the .azure-pipelines.yml with my own build and re-triggered the CI on this PR. Now I can see from the log that the newly added test_erofs is working properly.
Thanks, Jianan
Thanks, Jianan
Changes since v3:
Changes since v2:
Changes since v1:
Hi Tom,
Great, thanks for confirming!
participants (5)
Gao Xiang
Huang Jianan
Jianan Huang
Jonathan Liu
