Pull request: u-boot-rockchip-20200820
Hi Tom,
Please pull the rockchip updates/fixes: - Fix rk3399 evb sdcard support - Fix for SPL_LED support
Gitlab ci: https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip/pipelines/4456
Thanks, - Kever
The following changes since commit 2a4484a5c54cd64d5c4f8fd9aaa56f739d1b2b9d:
Merge branch '2020-08-19-mediatek-updates' (2020-08-20 08:38:10 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip.git tags/u-boot-rockchip-20200820
for you to fetch changes up to b5b81f2490628650137c9fee3679c995f5fac757:
rockchip: firefly-rk3288: Fix the code support for SPL_LED (2020-08-21 19:56:19 +0800)
---------------------------------------------------------------- Kever Yang (4): rockchip: dts: rk3399-evb: add sdmmc node rockchip: config: evb-rk3399: Add rockchip dwmmc support rockchip: rk3188: Fix the code support for SPL_LED rockchip: firefly-rk3288: Fix the code support for SPL_LED
arch/arm/dts/rk3399-evb-u-boot.dtsi | 13 +++++++++++++ arch/arm/mach-rockchip/rk3188/rk3188.c | 4 +++- board/firefly/firefly-rk3288/firefly-rk3288.c | 4 +++- configs/evb-rk3399_defconfig | 1 + 4 files changed, 20 insertions(+), 2 deletions(-)
On Tue, Aug 25, 2020 at 02:39:11PM +0800, Kever Yang wrote:
Hi Tom,
Thanks,
- Kever
Kever Yang
