[PATCH] Update Winbond SPI NOR Flash ID table
From f76b538a6a8081f9e21012a0de665a263cc6fa16 Mon Sep 17 00:00:00 2001
From: Steam Lin Stlin2@winbond.com Date: Wed, 8 Jul 2020 16:51:41 +0800 Subject: [PATCH] Update Winbond device ID in ID table
Update Winbond SPI NOR Flash id table for uboot
Update 512Mbit, 1Gbit device ID and correct JEDEC ID = 0xEF7019 device's name.
Signed-off-by: Steam Lin Stlin2@winbond.com ---
drivers/mtd/spi/spi-nor-ids.c | 67 ++++++++++++++++++++++++++++++++++- 1 file changed, 66 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index 114ebacde1..37895e714d 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -304,7 +304,72 @@ const struct flash_info spi_nor_ids[] = { SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) }, { - INFO("w25q256jw", 0xef7019, 0, 64 * 1024, 512, + INFO("w25q256jvxxIM", 0xef7019, 0, 64 * 1024, 512, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + INFO("w25q256jwxxIM", 0xef8019, 0, 64 * 1024, 512, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + INFO("w25q512jvxxIQ", 0xef4020, 0, 64 * 1024, 1024, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + INFO("w25q512jvxxIM", 0xef7020, 0, 64 * 1024, 1024, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + INFO("w25H512jvxxIM", 0xef9020, 0, 64 * 1024, 1024, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + INFO("w25q512jwxxIQ", 0xef6020, 0, 64 * 1024, 1024, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + INFO("w25q512jvxxIM", 0xef8020, 0, 64 * 1024, 1024, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + INFO("w25H512jvxxIM", 0xefA020, 0, 64 * 1024, 1024, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + INFO("w25q01jvxxIQ", 0xef4021, 0, 64 * 1024, 2048, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + INFO("w25q01jvxxIM", 0xef7021, 0, 64 * 1024, 2048, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + INFO("w25H01jvxxIM", 0xef9021, 0, 64 * 1024, 2048, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + INFO("w25q01jwxxIQ", 0xef6021, 0, 64 * 1024, 2048, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + INFO("w25q01jwxxIM", 0xef8021, 0, 64 * 1024, 2048, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + INFO("w25H01jwxxIM", 0xefA021, 0, 64 * 1024, 2048, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) }, -- 2.17.1
________________________________
The privileged confidential information contained in this email is intended for use only by the addressees as indicated by the original sender of this email. If you are not the addressee indicated in this email or are not responsible for delivery of the email to such a person, please kindly reply to the sender indicating this fact and delete all copies of it from your computer and network server immediately. Your cooperation is highly appreciated. It is advised that any unauthorized use of confidential information of Winbond is strictly prohibited; and any information in this email irrelevant to the official business of Winbond shall be deemed as neither given nor endorsed by Winbond.
On Wed, Jul 8, 2020 at 3:17 PM STLin2@winbond.com STLin2@winbond.com wrote:
From f76b538a6a8081f9e21012a0de665a263cc6fa16 Mon Sep 17 00:00:00 2001 From: Steam Lin Stlin2@winbond.com Date: Wed, 8 Jul 2020 16:51:41 +0800 Subject: [PATCH] Update Winbond device ID in ID table
Please work with the commit message head.
mtd: spi: Update Winbond SPI NOR Flash ID table
and rebase on the master.
Dear Jagan sir:
Many thanks for your response. Sorry that it is my first time to apply the patch, if there is any problem, your comment would be appreciated.
Follow my understanding, I rebase the master and the branch "UpdateWinbondID" is up to date. I use patman to check my work. It show 0 errors and 0 warning. But no sending. Is there anything I need to do to continue the patch work?
I resend the patch as follow.
Sincerely
From bed4ebba8cba95d1be7f2473563e5254f6f1eab0 Mon Sep 17 00:00:00 2001 From: Steam Lin Stlin2@winbond.com Date: Tue, 21 Jul 2020 16:48:19 +0800 Subject: [PATCH 1/1] Update Winbond SPI NOR Flash ID table for U-boot
Update 512Mbit, 1GMbit device ID.
Update correct JEDEC ID = 0xEF7019 device's name
-----Original Message----- From: Jagan Teki [mailto:jagan@amarulasolutions.com] Sent: Tuesday, July 21, 2020 1:10 AM To: PN10 STLin2 STLin2@winbond.com Cc: u-boot@lists.denx.de; Vignesh R vigneshr@ti.com Subject: Re: [PATCH] Update Winbond SPI NOR Flash ID table
Jagan Teki
STLin2@winbond.com
