[PATCH] Convert CONFIG_NETCONSOLE to Kconfig
This converts the following to Kconfig: CONFIG_NETCONSOLE
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/mach-kirkwood/include/mach/config.h | 1 - configs/SBx81LIFKW_defconfig | 1 + configs/SBx81LIFXCAT_defconfig | 1 + configs/brppt1_mmc_defconfig | 1 + configs/brppt1_nand_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/brppt2_defconfig | 1 + configs/d2net_v2_defconfig | 1 + configs/db-88f6281-bp-nand_defconfig | 1 + configs/db-88f6281-bp-spi_defconfig | 1 + configs/dns325_defconfig | 1 + configs/dockstar_defconfig | 1 + configs/dreamplug_defconfig | 1 + configs/ds109_defconfig | 1 + configs/edminiv2_defconfig | 1 + configs/goflexhome_defconfig | 1 + configs/guruplug_defconfig | 1 + configs/gwventana_emmc_defconfig | 1 + configs/gwventana_gw5904_defconfig | 1 + configs/gwventana_nand_defconfig | 1 + configs/ib62x0_defconfig | 1 + configs/iconnect_defconfig | 1 + configs/inetspace_v2_defconfig | 1 + configs/km_kirkwood_128m16_defconfig | 1 + configs/km_kirkwood_defconfig | 1 + configs/km_kirkwood_pci_defconfig | 1 + configs/kmcoge5un_defconfig | 1 + configs/kmnusa_defconfig | 1 + configs/kmsuse2_defconfig | 1 + configs/lschlv2_defconfig | 1 + configs/lsxhl_defconfig | 1 + configs/mx6qsabrelite_defconfig | 1 + configs/nas220_defconfig | 1 + configs/net2big_v2_defconfig | 1 + configs/netspace_lite_v2_defconfig | 1 + configs/netspace_max_v2_defconfig | 1 + configs/netspace_mini_v2_defconfig | 1 + configs/netspace_v2_defconfig | 1 + configs/nitrogen6dl2g_defconfig | 1 + configs/nitrogen6dl_defconfig | 1 + configs/nitrogen6q2g_defconfig | 1 + configs/nitrogen6q_defconfig | 1 + configs/nitrogen6s1g_defconfig | 1 + configs/nitrogen6s_defconfig | 1 + configs/novena_defconfig | 1 + configs/nsa310s_defconfig | 1 + configs/openrd_base_defconfig | 1 + configs/openrd_client_defconfig | 1 + configs/openrd_ultimate_defconfig | 1 + configs/pogo_e02_defconfig | 1 + configs/sansa_fuze_plus_defconfig | 1 + configs/sheevaplug_defconfig | 1 + configs/xfi3_defconfig | 1 + include/configs/SBx81LIFKW.h | 1 - include/configs/SBx81LIFXCAT.h | 1 - include/configs/bur_cfg_common.h | 1 - include/configs/dns325.h | 1 - include/configs/edb93xx.h | 1 - include/configs/edminiv2.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/lacie_kw.h | 1 - include/configs/nitrogen6x.h | 1 - include/configs/novena.h | 1 - include/configs/nsa310s.h | 1 - include/configs/sansa_fuze_plus.h | 2 -- include/configs/xfi3.h | 2 -- 66 files changed, 52 insertions(+), 16 deletions(-)
diff --git a/arch/arm/mach-kirkwood/include/mach/config.h b/arch/arm/mach-kirkwood/include/mach/config.h index beedc125b63e..3bd032e08790 100644 --- a/arch/arm/mach-kirkwood/include/mach/config.h +++ b/arch/arm/mach-kirkwood/include/mach/config.h @@ -58,7 +58,6 @@ * Ethernet Driver configuration */ #ifdef CONFIG_CMD_NET -#define CONFIG_NETCONSOLE /* include NetConsole support */ #define CONFIG_SYS_FAULT_ECHO_LINK_DOWN /* detect link using phy */ #define CONFIG_RESET_PHY_R /* use reset_phy() to init mv8831116 PHY */ #endif /* CONFIG_CMD_NET */ diff --git a/configs/SBx81LIFKW_defconfig b/configs/SBx81LIFKW_defconfig index f5143b231b68..a1abbc13bf25 100644 --- a/configs/SBx81LIFKW_defconfig +++ b/configs/SBx81LIFKW_defconfig @@ -30,6 +30,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=20000000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y diff --git a/configs/SBx81LIFXCAT_defconfig b/configs/SBx81LIFXCAT_defconfig index b2c3b1bde3de..81e090748323 100644 --- a/configs/SBx81LIFXCAT_defconfig +++ b/configs/SBx81LIFXCAT_defconfig @@ -32,6 +32,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=20000000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index 48c1b16cf856..6ecea550f194 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -74,6 +74,7 @@ CONFIG_SYS_MMC_ENV_DEV=1 CONFIG_SYS_MMC_ENV_PART=2 CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index 7c04ea194e90..5dfe1ac30625 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -75,6 +75,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index bc0ae75d7dc5..fa8ef5bb458c 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -81,6 +81,7 @@ CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/brppt2_defconfig b/configs/brppt2_defconfig index d6f7ea2bc72a..4d5cd44ca80c 100644 --- a/configs/brppt2_defconfig +++ b/configs/brppt2_defconfig @@ -65,6 +65,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_NETCONSOLE=y # CONFIG_DM_DEVICE_REMOVE is not set CONFIG_SPL_DM_SEQ_ALIAS=y # CONFIG_OF_TRANSLATE is not set diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index be8cfa2d6033..0b6b907a8e1d 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -40,6 +40,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=20000000 CONFIG_ENV_ADDR=0x70000 +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y CONFIG_BLK=y diff --git a/configs/db-88f6281-bp-nand_defconfig b/configs/db-88f6281-bp-nand_defconfig index b690cd24baa9..4fff3269aff1 100644 --- a/configs/db-88f6281-bp-nand_defconfig +++ b/configs/db-88f6281-bp-nand_defconfig @@ -39,6 +39,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_MVSATA_IDE=y CONFIG_MTD=y diff --git a/configs/db-88f6281-bp-spi_defconfig b/configs/db-88f6281-bp-spi_defconfig index 90d6259150b5..07e9db7f41b2 100644 --- a/configs/db-88f6281-bp-spi_defconfig +++ b/configs/db-88f6281-bp-spi_defconfig @@ -39,6 +39,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_MVSATA_IDE=y CONFIG_MTD=y diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index 63743f8844ac..8a04e1492c0a 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -34,6 +34,7 @@ CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_MVSATA_IDE=y CONFIG_BLK=y diff --git a/configs/dockstar_defconfig b/configs/dockstar_defconfig index 44327cd21e6d..0b434f46a097 100644 --- a/configs/dockstar_defconfig +++ b/configs/dockstar_defconfig @@ -30,6 +30,7 @@ CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_NETCONSOLE=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/dreamplug_defconfig b/configs/dreamplug_defconfig index ea8c2522c048..2c27726fcde4 100644 --- a/configs/dreamplug_defconfig +++ b/configs/dreamplug_defconfig @@ -32,6 +32,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_ENV_ADDR=0x100000 +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_MVSATA_IDE=y CONFIG_BLK=y diff --git a/configs/ds109_defconfig b/configs/ds109_defconfig index e49488737824..e412e3f5937c 100644 --- a/configs/ds109_defconfig +++ b/configs/ds109_defconfig @@ -28,6 +28,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_ENV_ADDR=0x3D0000 +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_MVSATA_IDE=y CONFIG_BLK=y diff --git a/configs/edminiv2_defconfig b/configs/edminiv2_defconfig index 7c9cfdd03455..916775e9ed17 100644 --- a/configs/edminiv2_defconfig +++ b/configs/edminiv2_defconfig @@ -31,6 +31,7 @@ CONFIG_ISO_PARTITION=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0xFFF84000 +CONFIG_NETCONSOLE=y CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/goflexhome_defconfig b/configs/goflexhome_defconfig index 694268233a68..b271822dcbfd 100644 --- a/configs/goflexhome_defconfig +++ b/configs/goflexhome_defconfig @@ -35,6 +35,7 @@ CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_MVSATA_IDE=y CONFIG_BLK=y diff --git a/configs/guruplug_defconfig b/configs/guruplug_defconfig index 5833f1273316..f7e934bcf89e 100644 --- a/configs/guruplug_defconfig +++ b/configs/guruplug_defconfig @@ -36,6 +36,7 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_MVSATA_IDE=y CONFIG_BLK=y diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index 537cbdf15215..497a54ba5d57 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -67,6 +67,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_PART=1 +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_SUPPORT_EMMC_RPMB=y diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index 16ac54fb45cd..d9352eb727e6 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -67,6 +67,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_PART=1 +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_SUPPORT_EMMC_RPMB=y diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index 94d42a415fb5..f618b74a9ddd 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -69,6 +69,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_SUPPORT_EMMC_RPMB=y diff --git a/configs/ib62x0_defconfig b/configs/ib62x0_defconfig index 52dba55e66ed..1fbf03442d0c 100644 --- a/configs/ib62x0_defconfig +++ b/configs/ib62x0_defconfig @@ -34,6 +34,7 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set CONFIG_MTD=y diff --git a/configs/iconnect_defconfig b/configs/iconnect_defconfig index 6b484c83a3b0..d3aea6ead2eb 100644 --- a/configs/iconnect_defconfig +++ b/configs/iconnect_defconfig @@ -30,6 +30,7 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index 6871adc9c163..819f5e0cea73 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -40,6 +40,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=20000000 CONFIG_ENV_ADDR=0x70000 +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y CONFIG_BLK=y diff --git a/configs/km_kirkwood_128m16_defconfig b/configs/km_kirkwood_128m16_defconfig index 50bcb79865f8..3416c575f69b 100644 --- a/configs/km_kirkwood_128m16_defconfig +++ b/configs/km_kirkwood_128m16_defconfig @@ -38,6 +38,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_EEPROM=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y # CONFIG_MMC is not set diff --git a/configs/km_kirkwood_defconfig b/configs/km_kirkwood_defconfig index bf732c823410..51d41cc99440 100644 --- a/configs/km_kirkwood_defconfig +++ b/configs/km_kirkwood_defconfig @@ -38,6 +38,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_EEPROM=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y # CONFIG_MMC is not set diff --git a/configs/km_kirkwood_pci_defconfig b/configs/km_kirkwood_pci_defconfig index 2cf3a994a653..80ff773ca01c 100644 --- a/configs/km_kirkwood_pci_defconfig +++ b/configs/km_kirkwood_pci_defconfig @@ -39,6 +39,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_EEPROM=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y # CONFIG_MMC is not set diff --git a/configs/kmcoge5un_defconfig b/configs/kmcoge5un_defconfig index 97b10af42e5e..51721bb497f1 100644 --- a/configs/kmcoge5un_defconfig +++ b/configs/kmcoge5un_defconfig @@ -42,6 +42,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y # CONFIG_MMC is not set diff --git a/configs/kmnusa_defconfig b/configs/kmnusa_defconfig index 2b3a3d2c73ff..96200b5fd718 100644 --- a/configs/kmnusa_defconfig +++ b/configs/kmnusa_defconfig @@ -42,6 +42,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y # CONFIG_MMC is not set diff --git a/configs/kmsuse2_defconfig b/configs/kmsuse2_defconfig index 82dc9ff2e210..b5c7ebfa79fa 100644 --- a/configs/kmsuse2_defconfig +++ b/configs/kmsuse2_defconfig @@ -43,6 +43,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y # CONFIG_MMC is not set diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index 133905010bbb..80ab7108dec6 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -33,6 +33,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y CONFIG_BLK=y diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index e52ed1872c74..6c8a9e1277c0 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -33,6 +33,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y CONFIG_BLK=y diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index 216e21ad79d2..3e874593a7ff 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -42,6 +42,7 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_USB_FUNCTION_FASTBOOT=y diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index 8b4385b2db26..e89b6b9e14d6 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -36,6 +36,7 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_MVSATA_IDE=y CONFIG_BLK=y diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index 13e7956780cc..e2e8341a4e6f 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -40,6 +40,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=20000000 CONFIG_ENV_ADDR=0x70000 +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y CONFIG_BLK=y diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index d8b5ce20ec11..ce681ce53854 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -40,6 +40,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=20000000 CONFIG_ENV_ADDR=0x70000 +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y CONFIG_BLK=y diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index 3168641272b2..af55d385d496 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -40,6 +40,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=20000000 CONFIG_ENV_ADDR=0x70000 +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y CONFIG_BLK=y diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index 6d07e873dd51..45c16d9d166c 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -38,6 +38,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=20000000 CONFIG_ENV_ADDR=0x70000 +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y CONFIG_BLK=y diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index e99ea75b01d1..6b813b5c8444 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -40,6 +40,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=20000000 CONFIG_ENV_ADDR=0x70000 +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y CONFIG_BLK=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index 3131c51bdeda..1c1016a4173b 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -46,6 +46,7 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index 86c2c4ff13dc..310d42eb487d 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -46,6 +46,7 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index 16cf5f3e5b19..545548eb693f 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -47,6 +47,7 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_USB_FUNCTION_FASTBOOT=y diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index ea9098ad68a5..0846b40e9328 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -47,6 +47,7 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_USB_FUNCTION_FASTBOOT=y diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 8a67b419e0fc..05ba13a9a2ec 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -46,6 +46,7 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index 71dff7ae857b..b28cd640bee8 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -46,6 +46,7 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 33cda1b383c4..20c3aa1af9bf 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -48,6 +48,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_FSL_USDHC=y diff --git a/configs/nsa310s_defconfig b/configs/nsa310s_defconfig index d9470f171ae5..bec1707ddc13 100644 --- a/configs/nsa310s_defconfig +++ b/configs/nsa310s_defconfig @@ -31,6 +31,7 @@ CONFIG_ISO_PARTITION=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set CONFIG_MTD=y diff --git a/configs/openrd_base_defconfig b/configs/openrd_base_defconfig index e0309db43ff1..ebe22ab877d9 100644 --- a/configs/openrd_base_defconfig +++ b/configs/openrd_base_defconfig @@ -36,6 +36,7 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_MVSATA_IDE=y # CONFIG_MMC_HW_PARTITIONING is not set CONFIG_MTD=y diff --git a/configs/openrd_client_defconfig b/configs/openrd_client_defconfig index 2bf18dbe66ca..04fcea2d0d4f 100644 --- a/configs/openrd_client_defconfig +++ b/configs/openrd_client_defconfig @@ -36,6 +36,7 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_MVSATA_IDE=y # CONFIG_MMC_HW_PARTITIONING is not set CONFIG_MTD=y diff --git a/configs/openrd_ultimate_defconfig b/configs/openrd_ultimate_defconfig index 35962333ea44..de7526dd7086 100644 --- a/configs/openrd_ultimate_defconfig +++ b/configs/openrd_ultimate_defconfig @@ -36,6 +36,7 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_MVSATA_IDE=y # CONFIG_MMC_HW_PARTITIONING is not set CONFIG_MTD=y diff --git a/configs/pogo_e02_defconfig b/configs/pogo_e02_defconfig index ee76b44382b7..34d1226686e1 100644 --- a/configs/pogo_e02_defconfig +++ b/configs/pogo_e02_defconfig @@ -30,6 +30,7 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/sansa_fuze_plus_defconfig b/configs/sansa_fuze_plus_defconfig index 1b5288ca9ad2..0cf85955844b 100644 --- a/configs/sansa_fuze_plus_defconfig +++ b/configs/sansa_fuze_plus_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y CONFIG_CONS_INDEX=0 diff --git a/configs/sheevaplug_defconfig b/configs/sheevaplug_defconfig index 40d50d66e577..34da356b8e2a 100644 --- a/configs/sheevaplug_defconfig +++ b/configs/sheevaplug_defconfig @@ -37,6 +37,7 @@ CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_MVSATA_IDE=y CONFIG_MTD=y diff --git a/configs/xfi3_defconfig b/configs/xfi3_defconfig index bc95e19c28dc..c529f2f06dd1 100644 --- a/configs/xfi3_defconfig +++ b/configs/xfi3_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NETCONSOLE=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y CONFIG_CONS_INDEX=0 diff --git a/include/configs/SBx81LIFKW.h b/include/configs/SBx81LIFKW.h index b85f27164352..eaa6b9246c98 100644 --- a/include/configs/SBx81LIFKW.h +++ b/include/configs/SBx81LIFKW.h @@ -84,7 +84,6 @@ * Ethernet Driver configuration */ #ifdef CONFIG_CMD_NET -#define CONFIG_NETCONSOLE /* include NetConsole support */ #define CONFIG_NET_MULTI /* specify more that one ports available */ #define CONFIG_MVGBE /* Enable kirkwood Gbe Controller Driver */ #define CONFIG_MVGBE_PORTS {1, 0} /* enable a single port */ diff --git a/include/configs/SBx81LIFXCAT.h b/include/configs/SBx81LIFXCAT.h index 84f24400fa9d..c0dc3d38c123 100644 --- a/include/configs/SBx81LIFXCAT.h +++ b/include/configs/SBx81LIFXCAT.h @@ -84,7 +84,6 @@ * Ethernet Driver configuration */ #ifdef CONFIG_CMD_NET -#define CONFIG_NETCONSOLE /* include NetConsole support */ #define CONFIG_NET_MULTI /* specify more that one ports available */ #define CONFIG_MVGBE /* Enable kirkwood Gbe Controller Driver */ #define CONFIG_MVGBE_PORTS {1, 0} /* enable a single port */ diff --git a/include/configs/bur_cfg_common.h b/include/configs/bur_cfg_common.h index 325ef1e754c1..05915b4cffdf 100644 --- a/include/configs/bur_cfg_common.h +++ b/include/configs/bur_cfg_common.h @@ -27,7 +27,6 @@ #define CONFIG_NET_RETRY_COUNT 10
/* Network console */ -#define CONFIG_NETCONSOLE 1 #define CONFIG_BOOTP_MAY_FAIL /* if we don't have DHCP environment */
/* As stated above, the following choices are optional. */ diff --git a/include/configs/dns325.h b/include/configs/dns325.h index 62107625e256..ea8d28b5b536 100644 --- a/include/configs/dns325.h +++ b/include/configs/dns325.h @@ -33,7 +33,6 @@ */ #ifdef CONFIG_CMD_NET #define CONFIG_MVGBE_PORTS {1, 0} /* enable port 0 only */ -#define CONFIG_NETCONSOLE #endif
/* diff --git a/include/configs/edb93xx.h b/include/configs/edb93xx.h index 3b35b5ce11ce..2f302b921bc4 100644 --- a/include/configs/edb93xx.h +++ b/include/configs/edb93xx.h @@ -83,7 +83,6 @@ /* Network hardware configuration */ #define CONFIG_DRIVER_EP93XX_MAC #define CONFIG_MII_SUPPRESS_PREAMBLE -#undef CONFIG_NETCONSOLE
/* SDRAM configuration */ #if defined(CONFIG_EDB9301) || defined(CONFIG_EDB9302) || \ diff --git a/include/configs/edminiv2.h b/include/configs/edminiv2.h index 19a923b5013d..dd16e3fbda43 100644 --- a/include/configs/edminiv2.h +++ b/include/configs/edminiv2.h @@ -114,7 +114,6 @@ #define CONFIG_SKIP_LOCAL_MAC_RANDOMIZATION /* don't randomize MAC */ #define CONFIG_PHY_BASE_ADR 0x8 #define CONFIG_RESET_PHY_R /* use reset_phy() to init mv8831116 PHY */ -#define CONFIG_NETCONSOLE /* include NetConsole support */ #define CONFIG_SYS_FAULT_ECHO_LINK_DOWN /* detect link using phy */ #endif
diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index a666d420e4b6..768836010735 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -115,7 +115,6 @@ #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0 #define CONFIG_USBD_HS -#define CONFIG_NETCONSOLE
/* Framebuffer and LCD */ #define CONFIG_VIDEO_LOGO diff --git a/include/configs/lacie_kw.h b/include/configs/lacie_kw.h index 031bc995e3ba..420c1d49b08e 100644 --- a/include/configs/lacie_kw.h +++ b/include/configs/lacie_kw.h @@ -77,7 +77,6 @@ */ #ifdef CONFIG_CMD_NET #define CONFIG_MVGBE_PORTS {1, 0} /* enable port 0 only */ -#define CONFIG_NETCONSOLE #endif
/* diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index 0598224f6678..fdcf43f44d18 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -17,7 +17,6 @@ #define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024)
#define CONFIG_MXC_UART_BASE UART2_BASE
diff --git a/include/configs/novena.h b/include/configs/novena.h index 62faef0703e4..8aabf06fa2a2 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -98,7 +98,6 @@ #define CONFIG_MXC_USB_FLAGS 0 /* Gadget part */ #define CONFIG_USBD_HS -#define CONFIG_NETCONSOLE #endif
/* Video output */ diff --git a/include/configs/nsa310s.h b/include/configs/nsa310s.h index 13812c43a122..1cb0d68b5af2 100644 --- a/include/configs/nsa310s.h +++ b/include/configs/nsa310s.h @@ -40,7 +40,6 @@
/* Ethernet driver configuration */ #ifdef CONFIG_CMD_NET -#define CONFIG_NETCONSOLE #define CONFIG_MVGBE_PORTS {1, 0} /* enable port 0 only */ #define CONFIG_PHY_BASE_ADR 1 #define CONFIG_RESET_PHY_R diff --git a/include/configs/sansa_fuze_plus.h b/include/configs/sansa_fuze_plus.h index 5b0ea9a335e9..853a89ced129 100644 --- a/include/configs/sansa_fuze_plus.h +++ b/include/configs/sansa_fuze_plus.h @@ -31,8 +31,6 @@ #ifdef CONFIG_CMD_USB #define CONFIG_EHCI_MXS_PORT0 #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 - -#define CONFIG_NETCONSOLE #endif
/* The rest of the configuration is shared */ diff --git a/include/configs/xfi3.h b/include/configs/xfi3.h index 4fc7154fff51..80849129b931 100644 --- a/include/configs/xfi3.h +++ b/include/configs/xfi3.h @@ -31,8 +31,6 @@ #ifdef CONFIG_CMD_USB #define CONFIG_EHCI_MXS_PORT0 #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 - -#define CONFIG_NETCONSOLE #endif
