[U-Boot-Users] [PATCH v2 RESEND] MMC: Consolidate MMC/SD command definitions
This moves the MMC and SD Card command definitions from include/asm/arch/mmc.h into include/mmc.h. These definitions are given by the MMC and SD Card standards, not by any particular architecture.
There's a lot more room for consolidation in the MMC drivers which I'm hoping to get done eventually, but this patch is a start.
Compile-tested for all avr32 boards as well as lpc2292sodimm and lubbock. This should cover all three mmc drivers in the tree.
Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- This patch was originally posted Thu, 22 May 2008 11:09:59 +0200
Changes since v1: * Split very long line in cpu/pxa/mmc.c * Fix whitespace damage copied from original mmc headers prior to the big whitespace cleanup.
cpu/at32ap/atmel_mci.c | 4 ++-- cpu/pxa/mmc.c | 11 +++++++---- include/asm-arm/arch-pxa/mmc.h | 17 ----------------- include/asm-avr32/arch-at32ap700x/mmc.h | 19 ------------------- include/mmc.h | 24 ++++++++++++++++++++++++ 5 files changed, 33 insertions(+), 42 deletions(-)
diff --git a/cpu/at32ap/atmel_mci.c b/cpu/at32ap/atmel_mci.c index 3795add..61aa184 100644 --- a/cpu/at32ap/atmel_mci.c +++ b/cpu/at32ap/atmel_mci.c @@ -349,7 +349,7 @@ static int sd_init_card(struct mmc_cid *cid, int verbose)
mmc_idle_cards(); for (i = 0; i < 1000; i++) { - ret = mmc_acmd(MMC_ACMD_SD_SEND_OP_COND, CFG_MMC_OP_COND, + ret = mmc_acmd(SD_CMD_APP_SEND_OP_COND, CFG_MMC_OP_COND, resp, R3 | NID); if (ret || (resp[0] & 0x80000000)) break; @@ -367,7 +367,7 @@ static int sd_init_card(struct mmc_cid *cid, int verbose) mmc_dump_cid(cid);
/* Get RCA of the card that responded */ - ret = mmc_cmd(MMC_CMD_SD_SEND_RELATIVE_ADDR, 0, resp, R6 | NCR); + ret = mmc_cmd(SD_CMD_SEND_RELATIVE_ADDR, 0, resp, R6 | NCR); if (ret) return ret;
diff --git a/cpu/pxa/mmc.c b/cpu/pxa/mmc.c index 039ce0f..4495a80 100644 --- a/cpu/pxa/mmc.c +++ b/cpu/pxa/mmc.c @@ -119,7 +119,7 @@ mmc_block_read(uchar * dst, ulong src, ulong len) MMC_RDTO = 0xffff; MMC_NOB = 1; MMC_BLKLEN = len; - mmc_cmd(MMC_CMD_READ_BLOCK, argh, argl, + mmc_cmd(MMC_CMD_READ_SINGLE_BLOCK, argh, argl, MMC_CMDAT_R1 | MMC_CMDAT_READ | MMC_CMDAT_BLOCK | MMC_CMDAT_DATA_EN);
@@ -568,7 +568,7 @@ mmc_init(int verbose) MMC_SPI = MMC_SPI_DISABLE;
/* reset */ - mmc_cmd(MMC_CMD_RESET, 0, 0, MMC_CMDAT_INIT | MMC_CMDAT_R0); + mmc_cmd(MMC_CMD_GO_IDLE_STATE, 0, 0, MMC_CMDAT_INIT | MMC_CMDAT_R0); udelay(200000); retries = 3; while (retries--) { @@ -578,7 +578,10 @@ mmc_init(int verbose) break; }
- resp = mmc_cmd(SD_CMD_APP_OP_COND, 0x0020, 0, MMC_CMDAT_R3 | (retries < 2 ? 0 : MMC_CMDAT_INIT)); /* Select 3.2-3.3 and 3.3-3.4V */ + /* Select 3.2-3.3 and 3.3-3.4V */ + resp = mmc_cmd(SD_CMD_APP_SEND_OP_COND, 0x0020, 0, + MMC_CMDAT_R3 | (retries < 2 ? 0 + : MMC_CMDAT_INIT)); if (resp[0] & 0x80000000) { mmc_dev.if_type = IF_TYPE_SD; debug("Detected SD card\n"); @@ -616,7 +619,7 @@ mmc_init(int verbose) memcpy(cid_resp, resp, sizeof(cid_resp));
/* MMC exists, get CSD too */ - resp = mmc_cmd(MMC_CMD_SET_RCA, 0, 0, MMC_CMDAT_R1); + resp = mmc_cmd(MMC_CMD_SET_RELATIVE_ADDR, 0, 0, MMC_CMDAT_R1); if (IF_TYPE_SD == mmc_dev.if_type) rca = ((resp[0] & 0xffff0000) >> 16); resp = mmc_cmd(MMC_CMD_SEND_CSD, rca, 0, MMC_CMDAT_R2); diff --git a/include/asm-arm/arch-pxa/mmc.h b/include/asm-arm/arch-pxa/mmc.h index 9440d80..85e144b 100644 --- a/include/asm-arm/arch-pxa/mmc.h +++ b/include/asm-arm/arch-pxa/mmc.h @@ -110,23 +110,6 @@ #define MMC_DEFAULT_RCA 1
#define MMC_BLOCK_SIZE 512 -#define MMC_CMD_RESET 0 -#define MMC_CMD_SEND_OP_COND 1 -#define MMC_CMD_ALL_SEND_CID 2 -#define MMC_CMD_SET_RCA 3 -#define MMC_CMD_SELECT_CARD 7 -#define MMC_CMD_SEND_CSD 9 -#define MMC_CMD_SEND_CID 10 -#define MMC_CMD_SEND_STATUS 13 -#define MMC_CMD_SET_BLOCKLEN 16 -#define MMC_CMD_READ_BLOCK 17 -#define MMC_CMD_RD_BLK_MULTI 18 -#define MMC_CMD_WRITE_BLOCK 24 -#define MMC_CMD_APP_CMD 55 - -#define SD_CMD_APP_SET_BUS_WIDTH 6 -#define SD_CMD_APP_OP_COND 41 - #define MMC_MAX_BLOCK_SIZE 512
#define MMC_R1_IDLE_STATE 0x01 diff --git a/include/asm-avr32/arch-at32ap700x/mmc.h b/include/asm-avr32/arch-at32ap700x/mmc.h index 6a33fef..9caba91 100644 --- a/include/asm-avr32/arch-at32ap700x/mmc.h +++ b/include/asm-avr32/arch-at32ap700x/mmc.h @@ -71,25 +71,6 @@ struct mmc_csd u8 one:1; };
-/* MMC Command numbers */ -#define MMC_CMD_GO_IDLE_STATE 0 -#define MMC_CMD_SEND_OP_COND 1 -#define MMC_CMD_ALL_SEND_CID 2 -#define MMC_CMD_SET_RELATIVE_ADDR 3 -#define MMC_CMD_SD_SEND_RELATIVE_ADDR 3 -#define MMC_CMD_SET_DSR 4 -#define MMC_CMD_SELECT_CARD 7 -#define MMC_CMD_SEND_CSD 9 -#define MMC_CMD_SEND_CID 10 -#define MMC_CMD_SEND_STATUS 13 -#define MMC_CMD_SET_BLOCKLEN 16 -#define MMC_CMD_READ_SINGLE_BLOCK 17 -#define MMC_CMD_READ_MULTIPLE_BLOCK 18 -#define MMC_CMD_WRITE_BLOCK 24 -#define MMC_CMD_APP_CMD 55 - -#define MMC_ACMD_SD_SEND_OP_COND 41 - #define R1_ILLEGAL_COMMAND (1 << 22) #define R1_APP_CMD (1 << 5)
diff --git a/include/mmc.h b/include/mmc.h index a271695..19c76fe 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -25,6 +25,30 @@ #define _MMC_H_ #include <asm/arch/mmc.h>
+/* MMC command numbers */ +#define MMC_CMD_GO_IDLE_STATE 0 +#define MMC_CMD_SEND_OP_COND 1 +#define MMC_CMD_ALL_SEND_CID 2 +#define MMC_CMD_SET_RELATIVE_ADDR 3 +#define MMC_CMD_SET_DSR 4 +#define MMC_CMD_SELECT_CARD 7 +#define MMC_CMD_SEND_CSD 9 +#define MMC_CMD_SEND_CID 10 +#define MMC_CMD_SEND_STATUS 13 +#define MMC_CMD_SET_BLOCKLEN 16 +#define MMC_CMD_READ_SINGLE_BLOCK 17 +#define MMC_CMD_READ_MULTIPLE_BLOCK 18 +#define MMC_CMD_WRITE_BLOCK 24 +#define MMC_CMD_APP_CMD 55 + +/* SD Card command numbers */ +#define SD_CMD_SEND_RELATIVE_ADDR 3 +#define SD_CMD_SWITCH 6 +#define SD_CMD_SEND_IF_COND 8 + +#define SD_CMD_APP_SET_BUS_WIDTH 6 +#define SD_CMD_APP_SEND_OP_COND 41 + int mmc_init(int verbose); int mmc_read(ulong src, uchar *dst, int size); int mmc_write(uchar *src, ulong dst, int size);
Haavard Skinnemoen
