[PATCH v2 2/2] board:pm9263 - Fix some typos in comments
Signed-off-by: Ilko Iliev iliev@ronetix.at --- board/ronetix/pm9263/pm9263.c | 10 +++++----- include/configs/pm9263.h | 2 +- 2 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/board/ronetix/pm9263/pm9263.c b/board/ronetix/pm9263/pm9263.c index 46494b043f..6dc080ac2c 100644 --- a/board/ronetix/pm9263/pm9263.c +++ b/board/ronetix/pm9263/pm9263.c @@ -25,7 +25,7 @@ DECLARE_GLOBAL_DATA_PTR;
/* ------------------------------------------------------------------------- */ /* - * Miscelaneous platform dependent initialisations + * Miscellaneous platform dependent initializations */
#ifdef CONFIG_CMD_NAND @@ -166,7 +166,7 @@ static void pm9263_lcd_hw_init(void) at91_set_pio_value(AT91_PIO_PORTA, 22, 0); /* power down */
#ifdef CONFIG_LCD_IN_PSRAM - /* initialize te PSRAM */ + /* initialize the PSRAM */ int stat = pm9263_lcd_hw_psram_init();
gd->fb_base = (stat == 0) ? PHYS_PSRAM : ATMEL_BASE_SRAM0; @@ -185,10 +185,10 @@ int board_early_init_f(void)
int board_init(void) { - /* arch number of AT91SAM9263EK-Board */ + /* arch number of PM9263 Board */ gd->bd->bi_arch_number = MACH_TYPE_PM9263;
- /* adress of boot parameters */ + /* address of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
#ifdef CONFIG_CMD_NAND @@ -205,7 +205,7 @@ int board_init(void)
int dram_init(void) { - /* dram_init must store complete ramsize in gd->ram_size */ + /* dram_init must store complete RAM size in gd->ram_size */ gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); return 0; diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index 7b028751bd..e825270de8 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -5,7 +5,7 @@ * Lead Tech Design <www.leadtechdesign.com> * Ilko Iliev <www.ronetix.at> * - * Configuation settings for the RONETIX PM9263 board. + * Configuration settings for the RONETIX PM9263 board. */
#ifndef __CONFIG_H -- 2.25.1
Applied with minor commit message change to u-boot-atmel/next, thanks !
Eugen.Hristev@microchip.com
Ilko Iliev
