[U-Boot] pull request: u-boot-tegra/master
Albert,
Please pull u-boot-tegra/master into arm master. Thanks.
The following changes since commit 137703b811502dfea364650fb3e17f20b4c21333:
overo: add SPL support (2012-01-16 08:40:13 +0100)
are available in the git repository at: git://git.denx.de/u-boot-tegra master
Simon Glass (9): tegra: Adjust funcmux config test to permit expansion tegra: Add enum to select from available funcmux configs tegra: Add I2C support to funcmux tegra: Add SDMMC support to funcmux tegra: Use funcmux for MMC on tamonten tegra: Use funcmux for MMC on harmony tegra: Use funcmux for MMC on seaboard tegra: mmc: Support operation with dcache enabled tegra2: Enable data cache
Stephen Warren (3): tegra2: Fix conflicting pinmux for UARTA tegra2: Fix default RAM size selection in odmdata tegra2: Add support for Compal Paz00 (Toshiba AC100)
MAINTAINERS | 1 + arch/arm/cpu/armv7/tegra2/board.c | 12 ++- arch/arm/cpu/armv7/tegra2/funcmux.c | 152 +++++++++++++++++++++++++--- arch/arm/include/asm/arch-tegra2/funcmux.h | 30 ++++++- board/avionic-design/common/tamonten.c | 10 +-- board/compal/paz00/Makefile | 41 ++++++++ board/compal/paz00/paz00.c | 81 +++++++++++++++ board/nvidia/harmony/harmony.c | 19 +--- board/nvidia/seaboard/seaboard.c | 21 +--- boards.cfg | 1 + drivers/mmc/tegra2_mmc.c | 16 +++ include/configs/paz00.h | 51 +++++++++ 12 files changed, 379 insertions(+), 56 deletions(-) create mode 100644 board/compal/paz00/Makefile create mode 100644 board/compal/paz00/paz00.c create mode 100644 include/configs/paz00.h
----------------------------------------------------------------------------------- This email message is for the sole use of the intended recipient(s) and may contain confidential information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message. -----------------------------------------------------------------------------------
Hi Tom,
Le 19/01/2012 01:01, Tom Warren a écrit :
Albert,
Applied to u-boot-arm/master, thanks!
Would it be possible, though, not to have this in your mails to the list?
Amicalement,
Albert,
-----Original Message----- From: Albert ARIBAUD [mailto:albert.u.boot@aribaud.net] Sent: Saturday, January 21, 2012 4:07 AM To: Tom Warren Cc: Wolfgang Denk; u-boot@lists.denx.de; Stephen Warren; Simon Glass Subject: Re: pull request: u-boot-tegra/master
Hi Tom,
Albert,
Thank you!
I'm told that I need to add 'nvpublic' to my message to have our exchange server skip the confidentiality statement. I've done so in this reply, and I'll do so in all future postings to u-boot@lists.denx.de.
Tom
-- nvpublic
Amicalement,
Albert.
Albert ARIBAUD
Tom Warren
