[U-Boot] [PATCH] POST: Remove duplicated post_hotkey_pressed() functions
This patch introduces a weak default function for post_hotkey_pressed(), returning 0, for boards without hotkey support. The long-running tests won't be started on those boards. This default function was implemented in many board directories. By implementing this weak default we can remove all those duplicate versions.
Boards with hotkey support, can override this weak default function by defining one in their board specific code.
Signed-off-by: Stefan Roese sr@denx.de --- board/amcc/katmai/katmai.c | 11 ----------- board/amcc/kilauea/kilauea.c | 11 ----------- board/amcc/makalu/makalu.c | 11 ----------- board/amcc/ocotea/ocotea.c | 12 ------------ board/amcc/sequoia/sequoia.c | 11 ----------- board/amcc/taishan/taishan.c | 11 ----------- board/amcc/yucca/yucca.c | 11 ----------- board/cm5200/cm5200.c | 8 -------- board/esd/pmc440/pmc440.c | 11 ----------- board/gen860t/gen860t.c | 11 ----------- board/korat/korat.c | 11 ----------- board/kup/common/kup.c | 11 ----------- board/mpl/mip405/mip405.c | 11 ----------- board/netstal/hcu4/hcu4.c | 11 ----------- board/netstal/hcu5/hcu5.c | 11 ----------- board/netstal/mcu25/mcu25.c | 11 ----------- board/netta/netta.c | 11 ----------- board/prodrive/alpr/alpr.c | 12 ------------ board/sacsng/sacsng.c | 12 ------------ board/ssv/adnpesc1/adnpesc1.c | 11 ----------- board/uc100/uc100.c | 12 ------------ post/post.c | 16 ++++++++++++++++ 22 files changed, 16 insertions(+), 232 deletions(-)
diff --git a/board/amcc/katmai/katmai.c b/board/amcc/katmai/katmai.c index 908f1a5..7c2c976 100644 --- a/board/amcc/katmai/katmai.c +++ b/board/amcc/katmai/katmai.c @@ -441,17 +441,6 @@ void pcie_setup_hoses(int busno) } #endif /* defined(CONFIG_PCI) */
-#ifdef CONFIG_POST -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return (ctrlc()); -} -#endif - int board_eth_init(bd_t *bis) { cpu_eth_init(bis); diff --git a/board/amcc/kilauea/kilauea.c b/board/amcc/kilauea/kilauea.c index 5cd822a..efcc75b 100644 --- a/board/amcc/kilauea/kilauea.c +++ b/board/amcc/kilauea/kilauea.c @@ -366,14 +366,3 @@ void pcie_setup_hoses(int busno) } } #endif - -#if defined(CONFIG_POST) -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} -#endif /* CONFIG_POST */ diff --git a/board/amcc/makalu/makalu.c b/board/amcc/makalu/makalu.c index d4277dd..b069a6c 100644 --- a/board/amcc/makalu/makalu.c +++ b/board/amcc/makalu/makalu.c @@ -322,14 +322,3 @@ void pcie_setup_hoses(int busno) } } #endif - -#if defined(CONFIG_POST) -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} -#endif /* CONFIG_POST */ diff --git a/board/amcc/ocotea/ocotea.c b/board/amcc/ocotea/ocotea.c index 0aa317e..9e26067 100644 --- a/board/amcc/ocotea/ocotea.c +++ b/board/amcc/ocotea/ocotea.c @@ -496,15 +496,3 @@ void fpga_init(void)
return; } - -#ifdef CONFIG_POST -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - - return (ctrlc()); -} -#endif diff --git a/board/amcc/sequoia/sequoia.c b/board/amcc/sequoia/sequoia.c index 00f6408..4896fba 100644 --- a/board/amcc/sequoia/sequoia.c +++ b/board/amcc/sequoia/sequoia.c @@ -530,17 +530,6 @@ int is_pci_host(struct pci_controller *hose) } #endif /* defined(CONFIG_PCI) */
-#if defined(CONFIG_POST) -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} -#endif /* CONFIG_POST */ - #if defined(CONFIG_NAND_U_BOOT) || defined(CONFIG_SYS_RAMBOOT) /* * On NAND-booting sequoia, we need to patch the chips select numbers diff --git a/board/amcc/taishan/taishan.c b/board/amcc/taishan/taishan.c index 0c20faf..a14792b 100644 --- a/board/amcc/taishan/taishan.c +++ b/board/amcc/taishan/taishan.c @@ -302,17 +302,6 @@ int is_pci_host(struct pci_controller *hose) } #endif /* defined(CONFIG_PCI) */
-#ifdef CONFIG_POST -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return (ctrlc()); -} -#endif - int board_eth_init(bd_t *bis) { cpu_eth_init(bis); diff --git a/board/amcc/yucca/yucca.c b/board/amcc/yucca/yucca.c index d8f4bcb..02cf62d 100644 --- a/board/amcc/yucca/yucca.c +++ b/board/amcc/yucca/yucca.c @@ -929,17 +929,6 @@ void fpga_init(void) return; }
-#ifdef CONFIG_POST -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return (ctrlc()); -} -#endif - /*---------------------------------------------------------------------------+ | onboard_pci_arbiter_selected => from EPLD +---------------------------------------------------------------------------*/ diff --git a/board/cm5200/cm5200.c b/board/cm5200/cm5200.c index 9e2f1a5..0b5412b 100644 --- a/board/cm5200/cm5200.c +++ b/board/cm5200/cm5200.c @@ -330,14 +330,6 @@ int board_early_init_r(void) }
-#ifdef CONFIG_POST -int post_hotkeys_pressed(void) -{ - return 0; -} -#endif /* CONFIG_POST */ - - #if defined(CONFIG_POST) || defined(CONFIG_LOGBUFFER) void post_word_store(ulong a) { diff --git a/board/esd/pmc440/pmc440.c b/board/esd/pmc440/pmc440.c index ec92552..189c836 100644 --- a/board/esd/pmc440/pmc440.c +++ b/board/esd/pmc440/pmc440.c @@ -741,17 +741,6 @@ int is_pci_host(struct pci_controller *hose) } #endif /* defined(CONFIG_PCI) */
-#if defined(CONFIG_POST) -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} -#endif /* CONFIG_POST */ - #ifdef CONFIG_RESET_PHY_R void reset_phy(void) { diff --git a/board/gen860t/gen860t.c b/board/gen860t/gen860t.c index 008f765..b37a0f2 100644 --- a/board/gen860t/gen860t.c +++ b/board/gen860t/gen860t.c @@ -292,14 +292,3 @@ void board_poweroff (void) puts ("### Please power off the board ###\n"); while (1); } - -#ifdef CONFIG_POST -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed (void) -{ - return 0; /* No hotkeys supported */ -} -#endif diff --git a/board/korat/korat.c b/board/korat/korat.c index 8c674a2..235d830 100644 --- a/board/korat/korat.c +++ b/board/korat/korat.c @@ -769,17 +769,6 @@ int is_pci_host(struct pci_controller *hose) } #endif /* defined(CONFIG_PCI) */
-#if defined(CONFIG_POST) -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} -#endif /* CONFIG_POST */ - #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) void ft_board_setup(void *blob, bd_t *bd) { diff --git a/board/kup/common/kup.c b/board/kup/common/kup.c index fec5407..2418d59 100644 --- a/board/kup/common/kup.c +++ b/board/kup/common/kup.c @@ -70,14 +70,3 @@ void poweron_key (void) else setenv ("key1", "on"); } - -#ifdef CONFIG_POST -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed (void) -{ - return (0); -} -#endif diff --git a/board/mpl/mip405/mip405.c b/board/mpl/mip405/mip405.c index 495e9bd..af3a98a 100644 --- a/board/mpl/mip405/mip405.c +++ b/board/mpl/mip405/mip405.c @@ -706,17 +706,6 @@ void print_mip405_rev (void) }
-#ifdef CONFIG_POST -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} -#endif - extern int mk_date (char *, struct rtc_time *);
int last_stage_init (void) diff --git a/board/netstal/hcu4/hcu4.c b/board/netstal/hcu4/hcu4.c index ba3e9c3..8efbc23 100644 --- a/board/netstal/hcu4/hcu4.c +++ b/board/netstal/hcu4/hcu4.c @@ -174,17 +174,6 @@ phys_size_t initdram(int board_type) return dram_size; }
-#if defined(CONFIG_POST) -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} -#endif /* CONFIG_POST */ - #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) void ft_board_setup(void *blob, bd_t *bd) { diff --git a/board/netstal/hcu5/hcu5.c b/board/netstal/hcu5/hcu5.c index 946c3f3..93bf7e6 100644 --- a/board/netstal/hcu5/hcu5.c +++ b/board/netstal/hcu5/hcu5.c @@ -481,17 +481,6 @@ int is_pci_host(struct pci_controller *hose) } #endif /* defined(CONFIG_PCI) */
-#if defined(CONFIG_POST) -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} -#endif /* CONFIG_POST */ - #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) void ft_board_setup(void *blob, bd_t *bd) { diff --git a/board/netstal/mcu25/mcu25.c b/board/netstal/mcu25/mcu25.c index 945d79a..c66ab97 100644 --- a/board/netstal/mcu25/mcu25.c +++ b/board/netstal/mcu25/mcu25.c @@ -173,17 +173,6 @@ phys_size_t initdram(int board_type) return dram_size; }
-#if defined(CONFIG_POST) -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} -#endif /* CONFIG_POST */ - #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) void ft_board_setup(void *blob, bd_t *bd) { diff --git a/board/netta/netta.c b/board/netta/netta.c index 38c9d89..5c935f4 100644 --- a/board/netta/netta.c +++ b/board/netta/netta.c @@ -564,17 +564,6 @@ int pcmcia_init(void)
#endif
-#ifdef CONFIG_POST -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} -#endif - #ifdef CONFIG_HW_WATCHDOG
void hw_watchdog_reset(void) diff --git a/board/prodrive/alpr/alpr.c b/board/prodrive/alpr/alpr.c index 51335c4..077d29e 100644 --- a/board/prodrive/alpr/alpr.c +++ b/board/prodrive/alpr/alpr.c @@ -287,15 +287,3 @@ void pci_master_init(struct pci_controller *hose) out32r(PCIL0_POM1SA, ~(0x10000000 - 1) | 1); /* 256MB + enable region */ } #endif /* defined(CONFIG_PCI) && defined(CONFIG_SYS_PCI_MASTER_INIT) */ - -#ifdef CONFIG_POST -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - - return (ctrlc()); -} -#endif diff --git a/board/sacsng/sacsng.c b/board/sacsng/sacsng.c index 2513937..49d8bba 100644 --- a/board/sacsng/sacsng.c +++ b/board/sacsng/sacsng.c @@ -869,15 +869,3 @@ void spi_cs_deactivate(struct spi_slave *slave) #endif
#endif /* CONFIG_MISC_INIT_R */ - -#ifdef CONFIG_POST -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} - -#endif diff --git a/board/ssv/adnpesc1/adnpesc1.c b/board/ssv/adnpesc1/adnpesc1.c index 72810d0..802bfba 100644 --- a/board/ssv/adnpesc1/adnpesc1.c +++ b/board/ssv/adnpesc1/adnpesc1.c @@ -91,17 +91,6 @@ void spi_cs_deactivate(struct spi_slave *slave)
#endif
-#if defined(CONFIG_POST) -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} -#endif /* CONFIG_POST */ - #ifdef CONFIG_CMD_NET int board_eth_init(bd_t *bis) { diff --git a/board/uc100/uc100.c b/board/uc100/uc100.c index 38c7be6..4dba290 100644 --- a/board/uc100/uc100.c +++ b/board/uc100/uc100.c @@ -268,15 +268,3 @@ int misc_init_r (void)
return 0; } - - -#ifdef CONFIG_POST -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed (void) -{ - return 0; /* No hotkeys supported */ -} -#endif diff --git a/post/post.c b/post/post.c index b74e762..b29eb87 100644 --- a/post/post.c +++ b/post/post.c @@ -58,6 +58,22 @@ int post_init_f (void) return res; }
+/* + * Supply a default implementation for post_hotkeys_pressed() for boards + * without hotkey support. We always return 0 here, so that the + * long-running tests won't be started. + * + * Boards with hotkey support can override this weak default function + * by defining one in their board specific code. + */ +int __post_hotkeys_pressed(void) +{ + return 0; /* No hotkeys supported */ +} +int post_hotkeys_pressed(void) + __attribute__((weak, alias("__post_hotkeys_pressed"))); + + void post_bootmode_init (void) { int bootmode = post_bootmode_get (0);
Dear Stefan Roese,
Hm... but the implementations were actually different. Some boards used ctrlc() so they would catch a (prebably previously pressed) ^C:
- return (ctrlc());
-} -#endif
...while others unconditionally return 09, without checking for ^C:
Are you sure the suggested change does not change the behavious on any of these boards?
Hi Wolfgang,
- return (ctrlc());
-} -#endif
Yes. The boards with this ctrlc() checking don't have POST support enabled at all (e.g. Katmai). So the behaviour is not changed.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Dear Stefan Roese,
Sorry, but this patch does not apply - please rebase against the "next" branch and resubmit:
Applying: POST: Remove duplicated post_hotkey_pressed() functions error: patch failed: board/amcc/kilauea/kilauea.c:366 error: board/amcc/kilauea/kilauea.c: patch does not apply error: patch failed: board/amcc/makalu/makalu.c:322 error: board/amcc/makalu/makalu.c: patch does not apply error: patch failed: board/amcc/sequoia/sequoia.c:530 error: board/amcc/sequoia/sequoia.c: patch does not apply error: patch failed: board/amcc/taishan/taishan.c:302 error: board/amcc/taishan/taishan.c: patch does not apply error: patch failed: board/korat/korat.c:769 error: board/korat/korat.c: patch does not apply Using index info to reconstruct a base tree... Falling back to patching base and 3-way merge... Auto-merging board/amcc/katmai/katmai.c Auto-merging board/amcc/kilauea/kilauea.c CONFLICT (content): Merge conflict in board/amcc/kilauea/kilauea.c Auto-merging board/amcc/makalu/makalu.c CONFLICT (content): Merge conflict in board/amcc/makalu/makalu.c Auto-merging board/amcc/ocotea/ocotea.c Auto-merging board/amcc/sequoia/sequoia.c CONFLICT (content): Merge conflict in board/amcc/sequoia/sequoia.c Auto-merging board/amcc/taishan/taishan.c CONFLICT (content): Merge conflict in board/amcc/taishan/taishan.c Auto-merging board/amcc/yucca/yucca.c Auto-merging board/esd/pmc440/pmc440.c Auto-merging board/korat/korat.c CONFLICT (content): Merge conflict in board/korat/korat.c Auto-merging board/netstal/hcu5/hcu5.c Auto-merging board/prodrive/alpr/alpr.c Failed to merge in the changes. Patch failed at 0001 POST: Remove duplicated post_hotkey_pressed() functions
Stefan Roese
