Using CONFIG_SPL_POST_MEM_SUPPORT
Hi folks,
I would like to run the memory tests implemented in drivers/post/memory.c. I'm interested in the CONFIG_SPL_POST_MEM_SUPPORT configuration (common/spl/Kconfig), but enabling it just seems to compile everything under post/drivers folder, it does not run the memory tests. Should I call the test functions directly? Which file/function would be a good place to call them? If not, which would be the correct way of executing those tests?
I'm working with an ARM platform: iMX.8, using a forked repository of u-boot: git://source.codeaurora.org/external/imx/uboot-imx.git, branch: imx_v2018.03_4.14.78_1.0.0_ga. But it seems that the original u-boot source does not differ regarding the CONFIG_SPL_POST_MEM_SUPPORT configuration.
Appreciate any help!
Best regards, Hector
hector@ikatu.com
