[U-Boot] [PATCH] includes: move openssl headers to include/u-boot
commit 18b06652cd "tools: include u-boot version of sha256.h" unconditionally forced the sha256.h from u-boot to be used for tools instead of the host version. This is fragile though as it will also include the host version. Therefore move it to include/u-boot to join u-boot/md5.h etc which were renamed for the same reason.
cc: Simon Glass sjg@chromium.org Signed-off-by: Jeroen Hofstee jeroen@myspectrum.nl --- build tested for ARM/powerpc/mips/sandbox --- board/gdsys/p1022/controlcenterd-id.c | 2 +- board/pcs440ep/pcs440ep.c | 2 +- common/cmd_sha1sum.c | 2 +- common/hash.c | 4 ++-- common/image-fit.c | 4 ++-- common/image-sig.c | 4 ++-- common/image.c | 2 +- drivers/crypto/ace_sha.c | 4 ++-- drivers/misc/cros_ec_sandbox.c | 2 +- drivers/mmc/rpmb.c | 2 +- include/image.h | 2 +- include/{ => u-boot}/rsa-checksum.h | 4 ++-- include/{ => u-boot}/rsa.h | 0 include/{ => u-boot}/sha1.h | 0 include/{ => u-boot}/sha256.h | 0 lib/rsa/rsa-checksum.c | 6 +++--- lib/rsa/rsa-verify.c | 6 +++--- lib/sha1.c | 2 +- lib/sha256.c | 2 +- lib/tpm.c | 2 +- tools/Makefile | 1 - tools/dumpimage.h | 2 +- tools/imagetool.h | 2 +- tools/mkimage.h | 2 +- tools/ubsha1.c | 2 +- 25 files changed, 30 insertions(+), 31 deletions(-) rename include/{ => u-boot}/rsa-checksum.h (91%) rename include/{ => u-boot}/rsa.h (100%) rename include/{ => u-boot}/sha1.h (100%) rename include/{ => u-boot}/sha256.h (100%)
diff --git a/board/gdsys/p1022/controlcenterd-id.c b/board/gdsys/p1022/controlcenterd-id.c index 3fca3c5..7e13c90 100644 --- a/board/gdsys/p1022/controlcenterd-id.c +++ b/board/gdsys/p1022/controlcenterd-id.c @@ -30,7 +30,7 @@ #include <i2c.h> #include <mmc.h> #include <tpm.h> -#include <sha1.h> +#include <u-boot/sha1.h> #include <asm/byteorder.h> #include <asm/unaligned.h> #include <pca9698.h> diff --git a/board/pcs440ep/pcs440ep.c b/board/pcs440ep/pcs440ep.c index f90e809..267c001 100644 --- a/board/pcs440ep/pcs440ep.c +++ b/board/pcs440ep/pcs440ep.c @@ -13,7 +13,7 @@ #include <asm/processor.h> #include <spd_sdram.h> #include <status_led.h> -#include <sha1.h> +#include <u-boot/sha1.h> #include <asm/io.h> #include <net.h> #include <ata.h> diff --git a/common/cmd_sha1sum.c b/common/cmd_sha1sum.c index 644b9a0..783ea2e 100644 --- a/common/cmd_sha1sum.c +++ b/common/cmd_sha1sum.c @@ -11,7 +11,7 @@ #include <common.h> #include <command.h> #include <hash.h> -#include <sha1.h> +#include <u-boot/sha1.h>
int do_sha1sum(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { diff --git a/common/hash.c b/common/hash.c index 237bd04..4417f36 100644 --- a/common/hash.c +++ b/common/hash.c @@ -15,8 +15,8 @@ #include <malloc.h> #include <hw_sha.h> #include <hash.h> -#include <sha1.h> -#include <sha256.h> +#include <u-boot/sha1.h> +#include <u-boot/sha256.h> #include <asm/io.h> #include <asm/errno.h>
diff --git a/common/image-fit.c b/common/image-fit.c index 732505a..75208c7 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -21,10 +21,10 @@ DECLARE_GLOBAL_DATA_PTR; #endif /* !USE_HOSTCC*/
#include <bootstage.h> -#include <sha1.h> -#include <sha256.h> #include <u-boot/crc.h> #include <u-boot/md5.h> +#include <u-boot/sha1.h> +#include <u-boot/sha256.h>
/*****************************************************************************/ /* New uImage format routines */ diff --git a/common/image-sig.c b/common/image-sig.c index 72284eb..21d5e51 100644 --- a/common/image-sig.c +++ b/common/image-sig.c @@ -13,8 +13,8 @@ DECLARE_GLOBAL_DATA_PTR; #endif /* !USE_HOSTCC*/ #include <image.h> -#include <rsa.h> -#include <rsa-checksum.h> +#include <u-boot/rsa.h> +#include <u-boot/rsa-checksum.h>
#define IMAGE_MAX_HASHED_NODES 100
diff --git a/common/image.c b/common/image.c index f33b175..e723944 100644 --- a/common/image.c +++ b/common/image.c @@ -34,7 +34,7 @@ #endif
#include <u-boot/md5.h> -#include <sha1.h> +#include <u-boot/sha1.h> #include <asm/errno.h> #include <asm/io.h>
diff --git a/drivers/crypto/ace_sha.c b/drivers/crypto/ace_sha.c index ed4f541..efef491 100644 --- a/drivers/crypto/ace_sha.c +++ b/drivers/crypto/ace_sha.c @@ -8,8 +8,8 @@ #include "ace_sha.h"
#ifdef CONFIG_SHA_HW_ACCEL -#include <sha256.h> -#include <sha1.h> +#include <u-boot/sha256.h> +#include <u-boot/sha1.h> #include <asm/errno.h>
/* SHA1 value for the message of zero length */ diff --git a/drivers/misc/cros_ec_sandbox.c b/drivers/misc/cros_ec_sandbox.c index 4bb1d60..8a04af5 100644 --- a/drivers/misc/cros_ec_sandbox.c +++ b/drivers/misc/cros_ec_sandbox.c @@ -13,7 +13,7 @@ #include <hash.h> #include <malloc.h> #include <os.h> -#include <sha256.h> +#include <u-boot/sha256.h> #include <spi.h> #include <asm/state.h> #include <asm/sdl.h> diff --git a/drivers/mmc/rpmb.c b/drivers/mmc/rpmb.c index 05936f5..9d0b8bc 100644 --- a/drivers/mmc/rpmb.c +++ b/drivers/mmc/rpmb.c @@ -11,7 +11,7 @@ #include <config.h> #include <common.h> #include <mmc.h> -#include <sha256.h> +#include <u-boot/sha256.h> #include "mmc_private.h"
/* Request codes */ diff --git a/include/image.h b/include/image.h index b71e4ba..8e8c72b 100644 --- a/include/image.h +++ b/include/image.h @@ -882,7 +882,7 @@ struct image_region { };
#if IMAGE_ENABLE_VERIFY -# include <rsa-checksum.h> +# include <u-boot/rsa-checksum.h> #endif struct checksum_algo { const char *name; diff --git a/include/rsa-checksum.h b/include/u-boot/rsa-checksum.h similarity index 91% rename from include/rsa-checksum.h rename to include/u-boot/rsa-checksum.h index 612db85..c996fb3 100644 --- a/include/rsa-checksum.h +++ b/include/u-boot/rsa-checksum.h @@ -9,8 +9,8 @@
#include <errno.h> #include <image.h> -#include <sha1.h> -#include <sha256.h> +#include <u-boot/sha1.h> +#include <u-boot/sha256.h>
extern const uint8_t padding_sha256_rsa4096[]; extern const uint8_t padding_sha256_rsa2048[]; diff --git a/include/rsa.h b/include/u-boot/rsa.h similarity index 100% rename from include/rsa.h rename to include/u-boot/rsa.h diff --git a/include/sha1.h b/include/u-boot/sha1.h similarity index 100% rename from include/sha1.h rename to include/u-boot/sha1.h diff --git a/include/sha256.h b/include/u-boot/sha256.h similarity index 100% rename from include/sha256.h rename to include/u-boot/sha256.h diff --git a/lib/rsa/rsa-checksum.c b/lib/rsa/rsa-checksum.c index 32d6602..8d8b59f 100644 --- a/lib/rsa/rsa-checksum.c +++ b/lib/rsa/rsa-checksum.c @@ -13,9 +13,9 @@ #else #include "fdt_host.h" #endif -#include <rsa.h> -#include <sha1.h> -#include <sha256.h> +#include <u-boot/rsa.h> +#include <u-boot/sha1.h> +#include <u-boot/sha256.h>
/* PKCS 1.5 paddings as described in the RSA PKCS#1 v2.1 standard. */
diff --git a/lib/rsa/rsa-verify.c b/lib/rsa/rsa-verify.c index 587da5b..bcb9063 100644 --- a/lib/rsa/rsa-verify.c +++ b/lib/rsa/rsa-verify.c @@ -17,9 +17,9 @@ #include "mkimage.h" #include <fdt_support.h> #endif -#include <rsa.h> -#include <sha1.h> -#include <sha256.h> +#include <u-boot/rsa.h> +#include <u-boot/sha1.h> +#include <u-boot/sha256.h>
#define UINT64_MULT32(v, multby) (((uint64_t)(v)) * ((uint32_t)(multby)))
diff --git a/lib/sha1.c b/lib/sha1.c index a121224..0a5f688 100644 --- a/lib/sha1.c +++ b/lib/sha1.c @@ -36,7 +36,7 @@ #include <string.h> #endif /* USE_HOSTCC */ #include <watchdog.h> -#include "sha1.h" +#include <u-boot/sha1.h>
/* * 32-bit integer manipulation macros (big endian) diff --git a/lib/sha256.c b/lib/sha256.c index b1085ea..bb338ba 100644 --- a/lib/sha256.c +++ b/lib/sha256.c @@ -13,7 +13,7 @@ #include <string.h> #endif /* USE_HOSTCC */ #include <watchdog.h> -#include <sha256.h> +#include <u-boot/sha256.h>
/* * 32-bit integer manipulation macros (big endian) diff --git a/lib/tpm.c b/lib/tpm.c index 967c8e6..d9789b0 100644 --- a/lib/tpm.c +++ b/lib/tpm.c @@ -7,7 +7,7 @@
#include <common.h> #include <stdarg.h> -#include <sha1.h> +#include <u-boot/sha1.h> #include <tpm.h> #include <asm/unaligned.h>
diff --git a/tools/Makefile b/tools/Makefile index 0088c1a..5235539 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -191,7 +191,6 @@ endif # !LOGO_BMP # Define _GNU_SOURCE to obtain the getline prototype from stdio.h # HOST_EXTRACFLAGS += -include $(srctree)/include/libfdt_env.h \ - -include $(srctree)/include/sha256.h \ $(patsubst -I%,-idirafter%, $(UBOOTINCLUDE)) \ -I$(srctree)/lib/libfdt \ -I$(srctree)/tools \ diff --git a/tools/dumpimage.h b/tools/dumpimage.h index d78523d..e415f14 100644 --- a/tools/dumpimage.h +++ b/tools/dumpimage.h @@ -18,7 +18,7 @@ #include <sys/stat.h> #include <time.h> #include <unistd.h> -#include <sha1.h> +#include <u-boot/sha1.h> #include "fdt_host.h" #include "imagetool.h"
diff --git a/tools/imagetool.h b/tools/imagetool.h index c480687..c8af0e8 100644 --- a/tools/imagetool.h +++ b/tools/imagetool.h @@ -18,7 +18,7 @@ #include <sys/stat.h> #include <time.h> #include <unistd.h> -#include <sha1.h> +#include <u-boot/sha1.h> #include "fdt_host.h"
#define ARRAY_SIZE(x) (sizeof(x) / sizeof((x)[0])) diff --git a/tools/mkimage.h b/tools/mkimage.h index d5491b6..3f369b7 100644 --- a/tools/mkimage.h +++ b/tools/mkimage.h @@ -18,7 +18,7 @@ #include <sys/stat.h> #include <time.h> #include <unistd.h> -#include <sha1.h> +#include <u-boot/sha1.h> #include "fdt_host.h" #include "imagetool.h"
diff --git a/tools/ubsha1.c b/tools/ubsha1.c index 1041588..4a17246 100644 --- a/tools/ubsha1.c +++ b/tools/ubsha1.c @@ -13,7 +13,7 @@ #include <errno.h> #include <string.h> #include <sys/stat.h> -#include "sha1.h" +#include <u-boot/sha1.h>
int main (int argc, char **argv) {
Hi Jeroen,
This seems like a much better solution. But I think you should keep the sort order - so u-boot/xxx should go after asm/xxx in the #includes I think.
On di, 2014-06-17 at 22:25 -0700, Simon Glass wrote:
Hi Jeroen,
I considered it, but e.g. common/image.c contains this before this patch:
#include <u-boot/md5.h> #include <sha1.h> #include <asm/errno.h> #include <asm/io.h>
While I can rearrange them, I think it should be a separate patch, since it is not sorted in the first place. Furthermore if possible I would prefer this commit to go into the current release and hence want to keep it as short as possible. What I hadn't realized with the original patch is that we don't replace the header but include them all.
On FreeBSD u-boot/sha256.h is included because the makefile said so, but the host version of sha256.h is included as well by the source code and the openssl/* will include similar headers again. And hence fails to compile in the end.
Likely the same holds for libfdt_env.h, but this likely works for the time being, since they have the same include guard.
Regards, Jeroen
Hi Jeroen,
OK with me, will await the follow-up patch.
Also I built it for everything and saw no regressions.
./tools/buildman/buildman -b try-jer -s Summary of 2 commits for 1198 boards (32 threads, 1 job per thread) 01: Merge branch 'master' of git://git.denx.de/u-boot-mmc blackfin: + bf609-ezkit m68k: + M5249EVB M54418TWR_serial_rmii M5253DEMO TASREG M5235EVB M54418TWR_nand_mii M54418TWR_nand_rmii_lowfreq M54418TWR_nand_rmii M54418TWR M5253EVBE M5235EVB_Flash32 M54418TWR_serial_mii M5272C3 powerpc: + neo io dlvision-10g P1022DS_36BIT iocon kilauea socrates O2DNT2_RAMBOOT rainier NSCU MPC832XEMDS_HOST_33 mcc200_highboot_SDRAM quantum sh: + rsk7269 rsk7264 rsk7203 nios2: + nios2-generic PCI5441 PK1C20 microblaze: + microblaze-generic openrisc: + openrisc-generic arm: + highbank lager_nor integratorcp_cm920t omap4_sdp4430 sama5d3_xplained_mmc mx53loco omap4_panda duovero Cubietruck lager k2hk_evm koelsch_nor koelsch trats2 02: includes: move openssl headers to include/u-boot
Jeroen Hofstee
