[U-Boot] [PATCH1/1] socfpga: Separating the configuration file for Virtual Target and real hardware Cyclone V development kit
Signed-off-by: Chin Liang See clsee@altera.com --- include/configs/socfpga_cyclone5.h | 28 +++++++++++++++++++++------- 1 files changed, 21 insertions(+), 7 deletions(-)
diff --git a/include/configs/socfpga_cyclone5.h b/include/configs/socfpga_cyclone5.h index 5633d2a..86563b7 100644 --- a/include/configs/socfpga_cyclone5.h +++ b/include/configs/socfpga_cyclone5.h @@ -22,6 +22,8 @@ /* * High level configuration */ +/* Running on virtual target or real hardware */ #define +CONFIG_SOCFPGA_VIRTUAL_TARGET
#define CONFIG_ARMV7 #define CONFIG_L2_OFF @@ -32,11 +34,12 @@ #define CONFIG_SINGLE_BOOTLOADER #define CONFIG_SOCFPGA
+/* base address for .text section */ +#ifdef CONFIG_SOCFPGA_VIRTUAL_TARGET #define CONFIG_SYS_TEXT_BASE 0x08000040 -#define V_NS16550_CLK 1000000 -#define CONFIG_BAUDRATE 57600 -#define CONFIG_SYS_HZ 1000 -#define CONFIG_TIMER_CLOCK_KHZ 2400 +#else +#define CONFIG_SYS_TEXT_BASE 0x01000040 +#endif #define CONFIG_SYS_LOAD_ADDR 0x7fc0
/* Console I/O Buffer Size */ @@ -165,7 +168,7 @@ /* SDRAM Bank #1 */ #define CONFIG_SYS_SDRAM_BASE 0x00000000 /* SDRAM memory size */ -#define PHYS_SDRAM_1_SIZE 0x80000000 +#define PHYS_SDRAM_1_SIZE 0x40000000
#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE #define CONFIG_SYS_MEMTEST_START 0x00000000 @@ -181,8 +184,13 @@ #define CONFIG_SYS_NS16550_CLK V_NS16550_CLK #define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_COM1 UART0_BASE - #define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600, 115200} +#ifdef CONFIG_SOCFPGA_VIRTUAL_TARGET +#define V_NS16550_CLK 1000000 +#else +#define V_NS16550_CLK 100000000 +#endif +#define CONFIG_BAUDRATE 115200
/* * FLASH @@ -195,9 +203,15 @@ /* This timer use eosc1 where the clock frequency is fixed * throughout any condition */ #define CONFIG_SYS_TIMERBASE SOCFPGA_OSC1TIMER0_ADDRESS - /* reload value when timer count to zero */ #define TIMER_LOAD_VAL 0xFFFFFFFF +/* Timer info */ +#define CONFIG_SYS_HZ 1000 +#ifdef CONFIG_SOCFPGA_VIRTUAL_TARGET +#define CONFIG_TIMER_CLOCK_KHZ 2400 +#else +#define CONFIG_TIMER_CLOCK_KHZ 25000 +#endif
#define CONFIG_ENV_IS_NOWHERE
-- 1.7.7.4
Hi!
- High level configuration
Unfortunately, it came word-wrapped. Looks ok otherwise.
Reviewed-by: Pavel Machek pavel@denx.de
Thanks, Pavel
Hi Pavel,
On Fri, 2013-06-28 at 13:22 +0200, ZY - pavel wrote:
Hi!
Hmmm... seems the mail client did this when sending. I will resubmit this patch with new mail client. Thanks
Chin Liang
Thanks, Pavel
Hi Chin Liang,
It always recommended to use "git send-email" for patch submission.
Best regards, Stefan
Signed-off-by: Chin Liang See clsee@altera.com --- include/configs/socfpga_cyclone5.h | 28 +++++++++++++++++++++------- 1 file changed, 21 insertions(+), 7 deletions(-)
diff --git a/include/configs/socfpga_cyclone5.h b/include/configs/socfpga_cyclone5.h index 5633d2a..be3799b 100644 --- a/include/configs/socfpga_cyclone5.h +++ b/include/configs/socfpga_cyclone5.h @@ -22,6 +22,8 @@ /* * High level configuration */ +/* Virtual target or real hardware */ +#define CONFIG_SOCFPGA_VIRTUAL_TARGET
Dear Chin Liang See,
In message 1372451028.11240.2.camel@drezykow-VirtualBox.altera.com you wrote:
Please keep the Subject SHORT - it should be 50 characters or less!
And please do not repeat the Subject in the commit messgae - this is redundant and thus makes no sense.
Chose a short and descriptive Subject, and provide prosa in the commit mesage.
Thanks!!
Hi Wolfgang,
Noted with thanks. Let me fix it on next revision
Chin Liang
Thanks!!
participants (5)
Chin Liang See
Chin Liang See
Pavel Machek
Stefan Roese
