[U-Boot] [PATCH v2 1/2] dm: MIGRATION: Update migration plan for SPI
- v2019.04 for no dm conversion drivers - v2019.07 for partially converted drivers.
Note: there were many updates on this deadline, so better not update this again.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - %s/convertion/conversion - split SPI_FLASH warning in separate patch
Makefile | 11 +++++++++++ doc/driver-model/MIGRATION.txt | 10 +++++++--- 2 files changed, 18 insertions(+), 3 deletions(-)
diff --git a/Makefile b/Makefile index a8461dd611..c4d827f259 100644 --- a/Makefile +++ b/Makefile @@ -953,6 +953,17 @@ ifeq ($(CONFIG_OF_EMBED),y) @echo >&2 "CONFIG_OF_SEPARATE for boards in mainline." @echo >&2 "See doc/README.fdt-control for more info." @echo >&2 "====================================================" +endif +ifeq ($(CONFIG_SPI),y) +ifneq ($(CONFIG_DM_SPI)$(CONFIG_OF_CONTROL),yy) + @echo >&2 "===================== WARNING ======================" + @echo >&2 "This board does not use CONFIG_DM_SPI. Please update" + @echo >&2 "the board before v2019.04 for no dm conversion" + @echo >&2 "and v2019.07 for partially dm converted drivers." + @echo >&2 "Failure to update can lead to driver/board removal" + @echo >&2 "See doc/driver-model/MIGRATION.txt for more info." + @echo >&2 "====================================================" +endif endif @# Check that this build does not use CONFIG options that we do not @# know about unless they are in Kconfig. All the existing CONFIG diff --git a/doc/driver-model/MIGRATION.txt b/doc/driver-model/MIGRATION.txt index dce4aa3e1d..183d7f5293 100644 --- a/doc/driver-model/MIGRATION.txt +++ b/doc/driver-model/MIGRATION.txt @@ -55,9 +55,6 @@ CONFIG_DM_SPI_FLASH Board Maintainers should submit the patches for enabling DM_SPI and DM_SPI_FLASH to move the migration with in the deadline.
-Status: In progress -Deadline: 2018.09 - No dm conversion yet: drivers/spi/cf_spi.c drivers/spi/fsl_espi.c @@ -69,6 +66,9 @@ No dm conversion yet: drivers/spi/sh_spi.c drivers/spi/soft_spi_legacy.c
+ Status: In progress + Deadline: 2019.04 + Partially converted: drivers/spi/atcspi200_spi.c drivers/spi/davinci_spi.c @@ -79,6 +79,10 @@ Partially converted: drivers/spi/omap3_spi.c drivers/spi/ti_qspi.c
+ Status: In progress + Deadline: 2019.07 + -- Jagan Teki jagan@openedev.com +12/24/2018 03/14/2018
Migration plan for DM_SPI_FLASH is v2019.07 since it depends on DM_SPI migration.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - none
Makefile | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/Makefile b/Makefile index c4d827f259..3e926d839f 100644 --- a/Makefile +++ b/Makefile @@ -964,6 +964,16 @@ ifneq ($(CONFIG_DM_SPI)$(CONFIG_OF_CONTROL),yy) @echo >&2 "See doc/driver-model/MIGRATION.txt for more info." @echo >&2 "====================================================" endif +endif +ifeq ($(CONFIG_SPI_FLASH),y) +ifneq ($(CONFIG_DM_SPI_FLASH)$(CONFIG_OF_CONTROL),yy) + @echo >&2 "===================== WARNING ======================" + @echo >&2 "This board does not use CONFIG_DM_SPI_FLASH. Please update" + @echo >&2 "the board to use CONFIG_SPI_FLASH before the v2019.07 release." + @echo >&2 "Failure to update by the deadline may result in board removal." + @echo >&2 "See doc/driver-model/MIGRATION.txt for more info." + @echo >&2 "====================================================" +endif endif @# Check that this build does not use CONFIG options that we do not @# know about unless they are in Kconfig. All the existing CONFIG
Hi Jagan,
Changes for v2:
- none
Again i worry what happens if the board does not actually use SPI flash?
+endif endif @# Check that this build does not use CONFIG options that we do not @# know about unless they are in Kconfig. All the existing CONFIG -- 2.18.0.321.gffc6fa0e3
On Sat, Jan 5, 2019 at 7:27 AM Simon Glass sjg@chromium.org wrote:
Hi Jagan,
Changes for v2:
- none
If SPI_FLASH not used then it will not enter this loop since its ifeq (not even to check next ifneq). Did you find any config to enter even if not used, same case for SPI.
Hi Jagan,
Changes for v2:
- none
OK I see.
Applied to u-boot-spi/master
Jagan Teki
