[U-Boot] [PATCH v2 1/2] armv8: mmu: remove unused macro definition
Macro VA_BITS and PTE_BLOCK_BITS are not used in the code, so remove them.
Signed-off-by: Andy Yan andy.yan@rock-chips.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Changes in v2: - remove CONFIG_SYS_PTL2_BITS from the whitelist
arch/arm/include/asm/armv8/mmu.h | 9 --------- scripts/config_whitelist.txt | 2 -- 2 files changed, 11 deletions(-)
diff --git a/arch/arm/include/asm/armv8/mmu.h b/arch/arm/include/asm/armv8/mmu.h index a349903..7752741 100644 --- a/arch/arm/include/asm/armv8/mmu.h +++ b/arch/arm/include/asm/armv8/mmu.h @@ -8,15 +8,6 @@ #ifndef _ASM_ARMV8_MMU_H_ #define _ASM_ARMV8_MMU_H_
-/***************************************************************/ -/* - * The following definitions are related each other, shoud be - * calculated specifically. - */ - -#define VA_BITS CONFIG_SYS_VA_BITS -#define PTE_BLOCK_BITS CONFIG_SYS_PTL2_BITS - /* * block/section address mask and size definitions. */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index db28457..63b8b25 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -4440,7 +4440,6 @@ CONFIG_SYS_PSDPAR CONFIG_SYS_PSSR_VAL CONFIG_SYS_PTCPAR CONFIG_SYS_PTDPAR -CONFIG_SYS_PTL2_BITS CONFIG_SYS_PTV CONFIG_SYS_PUAPAR CONFIG_SYS_QE_FMAN_FW_IN_MMC @@ -4815,7 +4814,6 @@ CONFIG_SYS_USE_SERIALFLASH CONFIG_SYS_USE_SPIFLASH CONFIG_SYS_USR_EXCEP CONFIG_SYS_U_BOOT_OFFS -CONFIG_SYS_VA_BITS CONFIG_SYS_VCXK_ACKNOWLEDGE_DDR CONFIG_SYS_VCXK_ACKNOWLEDGE_PIN CONFIG_SYS_VCXK_ACKNOWLEDGE_PORT
Add space around operator "+", make it match the coding style.
Signed-off-by: Andy Yan andy.yan@rock-chips.com ---
Changes in v2: None
arch/arm/include/asm/armv8/mmu.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/armv8/mmu.h b/arch/arm/include/asm/armv8/mmu.h index 7752741..6121aab 100644 --- a/arch/arm/include/asm/armv8/mmu.h +++ b/arch/arm/include/asm/armv8/mmu.h @@ -16,7 +16,7 @@ #undef PAGE_SIZE #define PAGE_SHIFT 12 #define PAGE_SIZE (1 << PAGE_SHIFT) -#define PAGE_MASK (~(PAGE_SIZE-1)) +#define PAGE_MASK (~(PAGE_SIZE - 1))
Changes in v2: None
Changes in v2: None
Changes in v2: None
Reviewed-by: York Sun york.sun@nxp.com
Signed-off-by: Andy Yan andy.yan@rock-chips.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: York Sun york.sun@nxp.com
ping
Changes in v2:
- The following definitions are related each other, shoud be
- calculated specifically.
- block/section address mask and size definitions.
Changes in v2:
Andy Yan
Philipp Tomsich
York Sun
