[U-Boot-Users] [PATCH 3/8] [SH] SuperH support
6 May
2007
6 May
'07
10:14 p.m.
Hi, all.
I wrote the code in which u-boot was supported for SH [0]. I am maintaining SH-IPL+g[1] that is the boot loader only for SH now. However, I think that I will maintain u-boot in the future.
Now, 0. SDRAM controler 1. Internal serial device 2. Flash 3. Timer working.
I plan to adopt it as a boot loader of the main in the future though only several boards are supported now.
Please apply this patch .
regards, Nobuhiro
[0] : http://america.renesas.com/fmwk.jsp?cnt=superh_family_landing.jsp&fp=/pr... [1] : http://git.nigauri.org
Nobuhiro Iwamatsu
E-Mail : iwamatsu@nigauri.org
GPG ID : 3170EBE9
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org
diff --git a/cpu/sh4/watchdog.c b/cpu/sh4/watchdog.c
new file mode 100644
index 0000000..e2bc820
--- /dev/null
+++ b/cpu/sh4/watchdog.c
@@ -0,0 +1,50 @@
+ * This program is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU General Public License as
+ * published by the Free Software Foundation; either version 2 of
+ * the License, or (at your option) any later version.
+ * This program is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with this program; if not, write to the Free Software
+ * Foundation, Inc., 59 Temple Place, Suite 330, Boston,
+ * MA 02111-1307 USA
+#include <common.h>
+#include <asm/processor.h>
+#define WDT_BASE WTCNT
+static unsigned char cnt_read (void){
+ return *((volatile unsigned char *)(WDT_BASE + 0x00));
+static unsigned char csr_read (void){
+ return *((volatile unsigned char *)(WDT_BASE + 0x04));
+static void cnt_write (unsigned char value){
+ while (csr_read() & (1 << 5)) {
+ /* delay */
+ *((volatile unsigned short *)(WDT_BASE + 0x00)) = ((unsigned short) value) | 0x5A00;
+static void csr_write (unsigned char value){
+ *((volatile unsigned short *)(WDT_BASE + 0x04)) = ((unsigned short) value) | 0xA500;
+int watchdog_init (void){ return 0; }
+void reset_cpu (unsigned long ignored)
+ while(1);
diff --git a/drivers/Makefile b/drivers/Makefile
index d68cba6..a3a9986 100644
--- a/drivers/Makefile
+++ b/drivers/Makefile
@@ -41,7 +41,7 @@ COBJS = 3c589.o 5701rls.o ali512x.o atmel_usart.o \
rtl8019.o rtl8139.o rtl8169.o \
s3c4510b_eth.o s3c4510b_uart.o \
sed13806.o sed156x.o \
- serial.o serial_max3100.o \
+ serial.o serial_max3100.o serial_sh.o \
serial_pl010.o serial_pl011.o serial_xuartlite.o \
sl811_usb.o sm501.o smc91111.o smiLynxEM.o \
status_led.o sym53c8xx.o systemace.o ahci.o \
diff --git a/drivers/serial_sh.c b/drivers/serial_sh.c
index 0000000..fca92fd
--- /dev/null
+++ b/drivers/serial_sh.c
@@ -0,0 +1,177 @@
+ * SuperH SCIF device driver.
+ * Copyright (c) 2007 Nobuhiro Iwamatsu
+ * This program is free software; you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation; either version 2 of the License, or
+ * (at your option) any later version.
+ * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
+#ifdef CFG_SCIF_CONSOLE
+#if defined (CONFIG_CONS_SCIF0)
+#define SCIF_BASE SCIF0_BASE
+#elif defined (CONFIG_CONS_SCIF1)
+#define SCIF_BASE SCIF1_BASE
+#else
+#error "Default SCIF doesn't set....."
+#define SCSMR (volatile unsigned short *)(SCIF_BASE + 0x0)
+#define SCBRR (volatile unsigned char *)(SCIF_BASE + 0x4)
+#define SCSCR (volatile unsigned short *)(SCIF_BASE + 0x8)
+#define SCFTDR (volatile unsigned char *)(SCIF_BASE + 0xC)
+#define SCFSR (volatile unsigned short *)(SCIF_BASE + 0x10)
+#define SCFRDR (volatile unsigned char *)(SCIF_BASE + 0x14)
+#define SCFCR (volatile unsigned short *)(SCIF_BASE + 0x18)
+#define SCFDR (volatile unsigned short *)(SCIF_BASE + 0x1C)
+#if defined(CONFIG_SH4A)
+#define SCRFDR (volatile unsigned short *)(SCIF_BASE + 0x20)
+#define SCSPTR (volatile unsigned short *)(SCIF_BASE + 0x24)
+#define SCLSR (volatile unsigned short *)(SCIF_BASE + 0x28)
+#define SCRER (volatile unsigned short *)(SCIF_BASE + 0x2C)
+#elif defined (CONFIG_SH4)
+#define SCSPTR (volatile unsigned short *)(SCIF_BASE + 0x20)
+#define SCLSR (volatile unsigned short *)(SCIF_BASE + 0x24)
+#elif defined (CONFIG_SH3)
+#define SCR_RE (1 << 4)
+#define SCR_TE (1 << 5)
+#define FCR_RFRST (1 << 1) /* RFCL */
+#define FCR_TFRST (1 << 2) /* TFCL */
+#define FSR_DR (1 << 0)
+#define FSR_RDF (1 << 1)
+#define FSR_FER (1 << 3)
+#define FSR_BRK (1 << 4)
+#define FSR_TEND (1 << 6)
+#define FSR_ER (1 << 7)
+void serial_setbrg (void)
+ DECLARE_GLOBAL_DATA_PTR;
+ int divisor = gd->baudrate * 32;
+ *SCBRR = (CONFIG_SYS_CLK_FREQ + (divisor / 2)) /
+ (gd->baudrate * 32) - 1;
+int serial_init (void)
+ *SCSCR = (SCR_RE | SCR_TE);
+ *SCSMR = 0 ;
+ *SCSMR = 0;
+ *SCFCR = (FCR_RFRST | FCR_TFRST);
+ *SCFCR;
+ *SCFCR = 0;
+ serial_setbrg();
+ return 0;
+static int serial_tx_fifo_level (void)
+ return (*SCFDR >> 8) & 0x1F;
+static int serial_rx_fifo_level (void)
+ return (*SCFDR >> 0) & 0x1F;
+void serial_raw_putc (const char c)
+ unsigned int fsr_bits_to_clear;
+ while (1) {
+ if (*SCFSR & FSR_TEND) { /* Tx fifo is empty */
+ fsr_bits_to_clear = FSR_TEND;
+ break;
+ *SCFTDR = c;
+ if (fsr_bits_to_clear != 0)
+ *SCFSR &= ~fsr_bits_to_clear;
+void serial_putc (const char c)
+ if (c == '\n')
+ serial_raw_putc ('\r');
+ serial_raw_putc (c);
+void serial_puts (const char *s)
+ char c;
+ while ((c = *s++) != 0)
+ serial_putc (c);
+int serial_tstc (void)
+ return serial_rx_fifo_level() ? 1 : 0;
+#define FSR_ERR_CLEAR 0x0063
+#define RDRF_CLEAR 0x00fc
+#define LSR_ORER 1
+void handle_error( void ){
+ (void)*SCFSR ;
+ *SCFSR = FSR_ERR_CLEAR ;
+ (void)*SCLSR ;
+ *SCLSR = 0x00 ;
+int serial_getc_check( void ){
+ unsigned short status;
+ status = *SCFSR ;
+ if (status & (FSR_FER | FSR_FER | FSR_ER | FSR_BRK))
+ handle_error();
+ if( *SCLSR & LSR_ORER )
+ handle_error();
+ return (status & ( FSR_DR | FSR_RDF ));
+int serial_getc (void)
+ unsigned short status ;
+ char ch;
+ while(!serial_getc_check());
+ ch = *SCFRDR;
+ status = *SCFSR ;
+ *SCFSR = RDRF_CLEAR ;
+ handle_error();
+ handle_error();
+ return ch ;
+#endif /* CFG_SCIF_CONSOLE */
diff --git a/examples/Makefile b/examples/Makefile
index e9b4974..71a8c7f 100644
--- a/examples/Makefile
+++ b/examples/Makefile
@@ -61,6 +61,11 @@ ifeq ($(ARCH),avr32)
LOAD_ADDR = 0x00000000
endif
+ifeq ($(ARCH),sh)
+LOAD_ADDR = 0x8C000000
+endif
include $(TOPDIR)/config.mk
ELF = hello_world
6576
Nobuhiro Iwamatsu
