Re: [U-Boot] [PATCH 2/2] riscv: Access CSRs using CSR numbers
From: Bin Meng [mailto:bmeng.cn@gmail.com] Sent: Thursday, July 11, 2019 2:43 PM To: Rick Jian-Zhi Chen(陳建志); Anup Patel; Lukas Auer; U-Boot Mailing List Subject: [PATCH 2/2] riscv: Access CSRs using CSR numbers
We should prefer accessing CSRs using their CSR numbers because:
- It compiles fine with older toolchains.
- We can use latest CSR names in #define macro names of CSR numbers as-per RISC-V spec.
- We can access newly added CSRs even if toolchain does not recognize newly added CSRs by name.
This commit is inspired from Linux kernel commit a3182c91ef4e ("RISC-V: Access CSRs using CSR numbers").
Signed-off-by: Bin Meng bmeng.cn@gmail.com
arch/riscv/cpu/cpu.c | 9 +- arch/riscv/cpu/start.S | 3 +- arch/riscv/include/asm/csr.h | 12 ++ arch/riscv/include/asm/encoding.h | 238 +------------------------------------- 4 files changed, 19 insertions(+), 243 deletions(-)
diff --git a/arch/riscv/cpu/cpu.c b/arch/riscv/cpu/cpu.c index e9a8b43..5ca1857 100644 --- a/arch/riscv/cpu/cpu.c +++ b/arch/riscv/cpu/cpu.c @@ -7,7 +7,6 @@ #include <cpu.h> #include <dm.h> #include <log.h> -#include <asm/csr.h> #include <asm/encoding.h> #include <dm/uclass-internal.h>
@@ -48,7 +47,7 @@ static inline bool supports_extension(char ext) return false; #else /* !CONFIG_CPU */ #ifdef CONFIG_RISCV_MMODE
return csr_read(misa) & (1 << (ext - 'a'));
return csr_read(CSR_MISA) & (1 << (ext - 'a'));
#else /* !CONFIG_RISCV_MMODE */ #warning "There is no way to determine the available extensions in S-mode." #warning "Please convert your board to use the RISC-V CPU driver." @@ -82,7 +81,7 @@ int arch_cpu_init_dm(void) /* Enable FPU */ if (supports_extension('d') || supports_extension('f')) { csr_set(MODE_PREFIX(status), MSTATUS_FS);
csr_write(fcsr, 0);
csr_write(CSR_FCSR, 0); } if (CONFIG_IS_ENABLED(RISCV_MMODE)) {
@@ -90,11 +89,11 @@ int arch_cpu_init_dm(void) * Enable perf counters for cycle, time, * and instret counters only */
csr_write(mcounteren, GENMASK(2, 0));
csr_write(CSR_MCOUNTEREN, GENMASK(2, 0)); /* Disable paging */ if (supports_extension('s'))
csr_write(satp, 0);
csr_write(CSR_SATP, 0); } return 0;
diff --git a/arch/riscv/cpu/start.S b/arch/riscv/cpu/start.S index 60ac8c6..e06db40 100644 --- a/arch/riscv/cpu/start.S +++ b/arch/riscv/cpu/start.S @@ -13,7 +13,6 @@ #include <config.h> #include <common.h> #include <elf.h> -#include <asm/csr.h> #include <asm/encoding.h> #include <generated/asm-offsets.h>
@@ -41,7 +40,7 @@ secondary_harts_relocation_error: .globl _start _start: #ifdef CONFIG_RISCV_MMODE
csrr a0, mhartid
csrr a0, CSR_MHARTID
#endif
/* save hart id and dtb pointer */
diff --git a/arch/riscv/include/asm/csr.h b/arch/riscv/include/asm/csr.h index 1a6bcfc..d152074 100644 --- a/arch/riscv/include/asm/csr.h +++ b/arch/riscv/include/asm/csr.h @@ -75,6 +75,7 @@ #define SIE_STIE (_AC(0x1, UL) << IRQ_S_TIMER) #define SIE_SEIE (_AC(0x1, UL) << IRQ_S_EXT)
+#define CSR_FCSR 0x003 #define CSR_CYCLE 0xc00 #define CSR_TIME 0xc01 #define CSR_INSTRET 0xc02 @@ -88,9 +89,20 @@ #define CSR_STVAL 0x143 #define CSR_SIP 0x144 #define CSR_SATP 0x180 +#define CSR_MSTATUS 0x300 +#define CSR_MISA 0x301 +#define CSR_MIE 0x304 +#define CSR_MTVEC 0x305 +#define CSR_MCOUNTEREN 0x306 +#define CSR_MSCRATCH 0x340 +#define CSR_MEPC 0x341 +#define CSR_MCAUSE 0x342 +#define CSR_MTVAL 0x343 +#define CSR_MIP 0x344 #define CSR_CYCLEH 0xc80 #define CSR_TIMEH 0xc81 #define CSR_INSTRETH 0xc82 +#define CSR_MHARTID 0xf14
#ifndef __ASSEMBLY__
diff --git a/arch/riscv/include/asm/encoding.h b/arch/riscv/include/asm/encoding.h index 772668c..c450eb9 100644 --- a/arch/riscv/include/asm/encoding.h +++ b/arch/riscv/include/asm/encoding.h @@ -7,6 +7,8 @@ #ifndef RISCV_CSR_ENCODING_H #define RISCV_CSR_ENCODING_H
+#include <asm/csr.h>
#ifdef CONFIG_RISCV_SMODE #define MODE_PREFIX(__suffix) s##__suffix #else @@ -49,13 +51,10 @@ #define SSTATUS64_SD 0x8000000000000000
#define MIP_SSIP BIT(IRQ_S_SOFT) -#define MIP_HSIP BIT(IRQ_H_SOFT) #define MIP_MSIP BIT(IRQ_M_SOFT) #define MIP_STIP BIT(IRQ_S_TIMER) -#define MIP_HTIP BIT(IRQ_H_TIMER) #define MIP_MTIP BIT(IRQ_M_TIMER) #define MIP_SEIP BIT(IRQ_S_EXT) -#define MIP_HEIP BIT(IRQ_H_EXT) #define MIP_MEIP BIT(IRQ_M_EXT)
#define SIP_SSIP MIP_SSIP @@ -73,18 +72,6 @@ #define VM_SV39 9 #define VM_SV48 10
-#define IRQ_S_SOFT 1 -#define IRQ_H_SOFT 2 -#define IRQ_M_SOFT 3 -#define IRQ_S_TIMER 5 -#define IRQ_H_TIMER 6 -#define IRQ_M_TIMER 7 -#define IRQ_S_EXT 9 -#define IRQ_H_EXT 10 -#define IRQ_M_EXT 11 -#define IRQ_COP 12 -#define IRQ_HOST 13
#define CAUSE_MISALIGNED_FETCH 0 #define CAUSE_FETCH_ACCESS 1 #define CAUSE_ILLEGAL_INSTRUCTION 2 @@ -167,227 +154,6 @@ #define RISCV_PGSHIFT 12 #define RISCV_PGSIZE BIT(RISCV_PGSHIFT)
-/* CSR numbers */ -#define CSR_FFLAGS 0x1 -#define CSR_FRM 0x2 -#define CSR_FCSR 0x3
-#define CSR_SSTATUS 0x100 -#define CSR_SEDELEG 0x102 -#define CSR_SIDELEG 0x103 -#define CSR_SIE 0x104 -#define CSR_STVEC 0x105 -#define CSR_SCOUNTEREN 0x106 -#define CSR_SSCRATCH 0x140 -#define CSR_SEPC 0x141 -#define CSR_SCAUSE 0x142 -#define CSR_STVAL 0x143 -#define CSR_SIP 0x144 -#define CSR_SATP 0x180
-#define CSR_MSTATUS 0x300 -#define CSR_MISA 0x301 -#define CSR_MEDELEG 0x302 -#define CSR_MIDELEG 0x303 -#define CSR_MIE 0x304 -#define CSR_MTVEC 0x305 -#define CSR_MCOUNTEREN 0x306 -#define CSR_MHPMEVENT3 0x323 -#define CSR_MHPMEVENT4 0x324 -#define CSR_MHPMEVENT5 0x325 -#define CSR_MHPMEVENT6 0x326 -#define CSR_MHPMEVENT7 0x327 -#define CSR_MHPMEVENT8 0x328 -#define CSR_MHPMEVENT9 0x329 -#define CSR_MHPMEVENT10 0x32a -#define CSR_MHPMEVENT11 0x32b -#define CSR_MHPMEVENT12 0x32c -#define CSR_MHPMEVENT13 0x32d -#define CSR_MHPMEVENT14 0x32e -#define CSR_MHPMEVENT15 0x32f -#define CSR_MHPMEVENT16 0x330 -#define CSR_MHPMEVENT17 0x331 -#define CSR_MHPMEVENT18 0x332 -#define CSR_MHPMEVENT19 0x333 -#define CSR_MHPMEVENT20 0x334 -#define CSR_MHPMEVENT21 0x335 -#define CSR_MHPMEVENT22 0x336 -#define CSR_MHPMEVENT23 0x337 -#define CSR_MHPMEVENT24 0x338 -#define CSR_MHPMEVENT25 0x339 -#define CSR_MHPMEVENT26 0x33a -#define CSR_MHPMEVENT27 0x33b -#define CSR_MHPMEVENT28 0x33c -#define CSR_MHPMEVENT29 0x33d -#define CSR_MHPMEVENT30 0x33e -#define CSR_MHPMEVENT31 0x33f -#define CSR_MSCRATCH 0x340 -#define CSR_MEPC 0x341 -#define CSR_MCAUSE 0x342 -#define CSR_MTVAL 0x343 -#define CSR_MIP 0x344 -#define CSR_PMPCFG0 0x3a0 -#define CSR_PMPCFG1 0x3a1 -#define CSR_PMPCFG2 0x3a2 -#define CSR_PMPCFG3 0x3a3 -#define CSR_PMPADDR0 0x3b0 -#define CSR_PMPADDR1 0x3b1 -#define CSR_PMPADDR2 0x3b2 -#define CSR_PMPADDR3 0x3b3 -#define CSR_PMPADDR4 0x3b4 -#define CSR_PMPADDR5 0x3b5 -#define CSR_PMPADDR6 0x3b6 -#define CSR_PMPADDR7 0x3b7 -#define CSR_PMPADDR8 0x3b8 -#define CSR_PMPADDR9 0x3b9 -#define CSR_PMPADDR10 0x3ba -#define CSR_PMPADDR11 0x3bb -#define CSR_PMPADDR12 0x3bc -#define CSR_PMPADDR13 0x3bd -#define CSR_PMPADDR14 0x3be -#define CSR_PMPADDR15 0x3bf
-#define CSR_TSELECT 0x7a0 -#define CSR_TDATA1 0x7a1 -#define CSR_TDATA2 0x7a2 -#define CSR_TDATA3 0x7a3 -#define CSR_DCSR 0x7b0 -#define CSR_DPC 0x7b1 -#define CSR_DSCRATCH 0x7b2
-#define CSR_MCYCLE 0xb00 -#define CSR_MINSTRET 0xb02 -#define CSR_MHPMCOUNTER3 0xb03 -#define CSR_MHPMCOUNTER4 0xb04 -#define CSR_MHPMCOUNTER5 0xb05 -#define CSR_MHPMCOUNTER6 0xb06 -#define CSR_MHPMCOUNTER7 0xb07 -#define CSR_MHPMCOUNTER8 0xb08 -#define CSR_MHPMCOUNTER9 0xb09 -#define CSR_MHPMCOUNTER10 0xb0a -#define CSR_MHPMCOUNTER11 0xb0b -#define CSR_MHPMCOUNTER12 0xb0c -#define CSR_MHPMCOUNTER13 0xb0d -#define CSR_MHPMCOUNTER14 0xb0e -#define CSR_MHPMCOUNTER15 0xb0f -#define CSR_MHPMCOUNTER16 0xb10 -#define CSR_MHPMCOUNTER17 0xb11 -#define CSR_MHPMCOUNTER18 0xb12 -#define CSR_MHPMCOUNTER19 0xb13 -#define CSR_MHPMCOUNTER20 0xb14 -#define CSR_MHPMCOUNTER21 0xb15 -#define CSR_MHPMCOUNTER22 0xb16 -#define CSR_MHPMCOUNTER23 0xb17 -#define CSR_MHPMCOUNTER24 0xb18 -#define CSR_MHPMCOUNTER25 0xb19 -#define CSR_MHPMCOUNTER26 0xb1a -#define CSR_MHPMCOUNTER27 0xb1b -#define CSR_MHPMCOUNTER28 0xb1c -#define CSR_MHPMCOUNTER29 0xb1d -#define CSR_MHPMCOUNTER30 0xb1e -#define CSR_MHPMCOUNTER31 0xb1f -#define CSR_MCYCLEH 0xb80 -#define CSR_MINSTRETH 0xb82 -#define CSR_MHPMCOUNTER3H 0xb83 -#define CSR_MHPMCOUNTER4H 0xb84 -#define CSR_MHPMCOUNTER5H 0xb85 -#define CSR_MHPMCOUNTER6H 0xb86 -#define CSR_MHPMCOUNTER7H 0xb87 -#define CSR_MHPMCOUNTER8H 0xb88 -#define CSR_MHPMCOUNTER9H 0xb89 -#define CSR_MHPMCOUNTER10H 0xb8a -#define CSR_MHPMCOUNTER11H 0xb8b -#define CSR_MHPMCOUNTER12H 0xb8c -#define CSR_MHPMCOUNTER13H 0xb8d -#define CSR_MHPMCOUNTER14H 0xb8e -#define CSR_MHPMCOUNTER15H 0xb8f -#define CSR_MHPMCOUNTER16H 0xb90 -#define CSR_MHPMCOUNTER17H 0xb91 -#define CSR_MHPMCOUNTER18H 0xb92 -#define CSR_MHPMCOUNTER19H 0xb93 -#define CSR_MHPMCOUNTER20H 0xb94 -#define CSR_MHPMCOUNTER21H 0xb95 -#define CSR_MHPMCOUNTER22H 0xb96 -#define CSR_MHPMCOUNTER23H 0xb97 -#define CSR_MHPMCOUNTER24H 0xb98 -#define CSR_MHPMCOUNTER25H 0xb99 -#define CSR_MHPMCOUNTER26H 0xb9a -#define CSR_MHPMCOUNTER27H 0xb9b -#define CSR_MHPMCOUNTER28H 0xb9c -#define CSR_MHPMCOUNTER29H 0xb9d -#define CSR_MHPMCOUNTER30H 0xb9e -#define CSR_MHPMCOUNTER31H 0xb9f
-#define CSR_CYCLE 0xc00 -#define CSR_TIME 0xc01 -#define CSR_INSTRET 0xc02 -#define CSR_HPMCOUNTER3 0xc03 -#define CSR_HPMCOUNTER4 0xc04 -#define CSR_HPMCOUNTER5 0xc05 -#define CSR_HPMCOUNTER6 0xc06 -#define CSR_HPMCOUNTER7 0xc07 -#define CSR_HPMCOUNTER8 0xc08 -#define CSR_HPMCOUNTER9 0xc09 -#define CSR_HPMCOUNTER10 0xc0a -#define CSR_HPMCOUNTER11 0xc0b -#define CSR_HPMCOUNTER12 0xc0c -#define CSR_HPMCOUNTER13 0xc0d -#define CSR_HPMCOUNTER14 0xc0e -#define CSR_HPMCOUNTER15 0xc0f -#define CSR_HPMCOUNTER16 0xc10 -#define CSR_HPMCOUNTER17 0xc11 -#define CSR_HPMCOUNTER18 0xc12 -#define CSR_HPMCOUNTER19 0xc13 -#define CSR_HPMCOUNTER20 0xc14 -#define CSR_HPMCOUNTER21 0xc15 -#define CSR_HPMCOUNTER22 0xc16 -#define CSR_HPMCOUNTER23 0xc17 -#define CSR_HPMCOUNTER24 0xc18 -#define CSR_HPMCOUNTER25 0xc19 -#define CSR_HPMCOUNTER26 0xc1a -#define CSR_HPMCOUNTER27 0xc1b -#define CSR_HPMCOUNTER28 0xc1c -#define CSR_HPMCOUNTER29 0xc1d -#define CSR_HPMCOUNTER30 0xc1e -#define CSR_HPMCOUNTER31 0xc1f -#define CSR_CYCLEH 0xc80 -#define CSR_TIMEH 0xc81 -#define CSR_INSTRETH 0xc82 -#define CSR_HPMCOUNTER3H 0xc83 -#define CSR_HPMCOUNTER4H 0xc84 -#define CSR_HPMCOUNTER5H 0xc85 -#define CSR_HPMCOUNTER6H 0xc86 -#define CSR_HPMCOUNTER7H 0xc87 -#define CSR_HPMCOUNTER8H 0xc88 -#define CSR_HPMCOUNTER9H 0xc89 -#define CSR_HPMCOUNTER10H 0xc8a -#define CSR_HPMCOUNTER11H 0xc8b -#define CSR_HPMCOUNTER12H 0xc8c -#define CSR_HPMCOUNTER13H 0xc8d -#define CSR_HPMCOUNTER14H 0xc8e -#define CSR_HPMCOUNTER15H 0xc8f -#define CSR_HPMCOUNTER16H 0xc90 -#define CSR_HPMCOUNTER17H 0xc91 -#define CSR_HPMCOUNTER18H 0xc92 -#define CSR_HPMCOUNTER19H 0xc93 -#define CSR_HPMCOUNTER20H 0xc94 -#define CSR_HPMCOUNTER21H 0xc95 -#define CSR_HPMCOUNTER22H 0xc96 -#define CSR_HPMCOUNTER23H 0xc97 -#define CSR_HPMCOUNTER24H 0xc98 -#define CSR_HPMCOUNTER25H 0xc99 -#define CSR_HPMCOUNTER26H 0xc9a -#define CSR_HPMCOUNTER27H 0xc9b -#define CSR_HPMCOUNTER28H 0xc9c -#define CSR_HPMCOUNTER29H 0xc9d -#define CSR_HPMCOUNTER30H 0xc9e -#define CSR_HPMCOUNTER31H 0xc9f
-#define CSR_MVENDORID 0xf11 -#define CSR_MARCHID 0xf12 -#define CSR_MIMPID 0xf13 -#define CSR_MHARTID 0xf14
#endif /* __riscv */
#endif /* RISCV_CSR_ENCODING_H */
Reviewed-by: Rick Chen rick@andestech.com
-- 2.7.4
Rick Chen rickchen36@gmail.com 於 2019年7月18日 週四 上午11:25寫道:
Applied to u-boot-riscv/master, thanks!
Rick
Rick Chen
