[U-Boot] [PATCH] spi: add support SuperH SPI module
SH7757 has SPI module. This patch supports it.
Signed-off-by: Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com --- drivers/spi/Makefile | 1 + drivers/spi/sh_spi.c | 295 ++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 296 insertions(+), 0 deletions(-) create mode 100644 drivers/spi/sh_spi.c
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index e34a124..d582fbb 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -37,6 +37,7 @@ COBJS-$(CONFIG_MPC8XXX_SPI) += mpc8xxx_spi.o COBJS-$(CONFIG_MXC_SPI) += mxc_spi.o COBJS-$(CONFIG_OMAP3_SPI) += omap3_spi.o COBJS-$(CONFIG_SOFT_SPI) += soft_spi.o +COBJS-$(CONFIG_SH_SPI) += sh_spi.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/spi/sh_spi.c b/drivers/spi/sh_spi.c new file mode 100644 index 0000000..89ea5e2 --- /dev/null +++ b/drivers/spi/sh_spi.c @@ -0,0 +1,295 @@ +/* + * SH SPI driver + * + * Copyright (C) 2011 Renesas Solutions Corp. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + * + */ + +#include <common.h> +#include <malloc.h> +#include <spi.h> +#include <asm/io.h> + +#define SPI_TBR 0x00 +#define SPI_RBR 0x00 +#define SPI_CR1 0x08 +#define SPI_CR2 0x10 +#define SPI_CR3 0x18 +#define SPI_CR4 0x20 + +/* CR1 */ +#define SPI_TBE 0x80 +#define SPI_TBF 0x40 +#define SPI_RBE 0x20 +#define SPI_RBF 0x10 +#define SPI_PFONRD 0x08 +#define SPI_SSDB 0x04 +#define SPI_SSD 0x02 +#define SPI_SSA 0x01 + +/* CR2 */ +#define SPI_RSTF 0x80 +#define SPI_LOOPBK 0x40 +#define SH_SPI_CPOL 0x20 +#define SH_SPI_CPHA 0x10 +#define SPI_L1M0 0x08 + +/* CR3 */ +#define SPI_MAX_BYTE 0xFF + +/* CR4 */ +#define SPI_TBEI 0x80 +#define SPI_TBFI 0x40 +#define SPI_RBEI 0x20 +#define SPI_RBFI 0x10 +#define SPI_WPABRT 0x04 +#define SPI_SSS 0x01 + +#define SPI_FIFO_SIZE 32 + +static void sh_spi_write(unsigned long data, unsigned long offset) +{ + writel(data, CONFIG_SH_SPI_BASE + offset); +} + +static unsigned long sh_spi_read(unsigned long offset) +{ + return readl(CONFIG_SH_SPI_BASE + offset); +} + +static void sh_spi_set_bit(unsigned long val, unsigned long offset) +{ + unsigned long tmp; + + tmp = sh_spi_read(offset); + tmp |= val; + sh_spi_write(tmp, offset); +} + +static void sh_spi_clear_bit(unsigned long val, unsigned long offset) +{ + unsigned long tmp; + + tmp = sh_spi_read(offset); + tmp &= ~val; + sh_spi_write(tmp, offset); +} + +static void clear_fifo(void) +{ + sh_spi_set_bit(SPI_RSTF, SPI_CR2); + sh_spi_clear_bit(SPI_RSTF, SPI_CR2); +} + +static int recvbuf_wait(void) +{ + while (sh_spi_read(SPI_CR1) & SPI_RBE) { + if (ctrlc()) + return 1; + udelay(10); + } + return 0; +} + +static int write_fifo_full_wait(void) +{ + while (sh_spi_read(SPI_CR1) & SPI_TBF) { + udelay(10); + if (ctrlc()) + return 1; + } + return 0; +} + +static int write_fifo_empty_wait(void) +{ + while (!(sh_spi_read(SPI_CR1) & SPI_TBE)) { + if (ctrlc()) + return 1; + udelay(10); + } + return 0; +} + +void spi_init(void) +{ + +} + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct spi_slave *slave; + + if (!spi_cs_is_valid(bus, cs)) + return NULL; + + slave = malloc(sizeof(struct spi_slave)); + if (!slave) + return NULL; + + slave->bus = bus; + slave->cs = cs; + + /* SPI sycle stop */ + sh_spi_write(0xfe, SPI_CR1); + /* CR1 init */ + sh_spi_write(0x00, SPI_CR1); + /* CR3 init */ + sh_spi_write(0x00, SPI_CR3); + + clear_fifo(); + + /* 1/8 clock */ + sh_spi_write(sh_spi_read(SPI_CR2) | 0x07, SPI_CR2); + udelay(10); + + return slave; +} + +void spi_free_slave(struct spi_slave *slave) +{ + free(slave); +} + +int spi_claim_bus(struct spi_slave *slave) +{ + return 0; +} + +void spi_release_bus(struct spi_slave *slave) +{ + sh_spi_write(sh_spi_read(SPI_CR1) & ~(SPI_SSA | SPI_SSDB | SPI_SSD), + SPI_CR1); +} + +static int sh_spi_send(const unsigned char *tx_data, unsigned int len, + unsigned long flags) +{ + int i, cur_len, ret = 0; + int remain = (int)len; + unsigned long tmp; + + if (len >= SPI_FIFO_SIZE) + sh_spi_set_bit(SPI_SSA, SPI_CR1); + + while (remain > 0) { + cur_len = (remain < SPI_FIFO_SIZE) ? remain : SPI_FIFO_SIZE; + for (i = 0; i < cur_len && + !(sh_spi_read(SPI_CR4) & SPI_WPABRT) && + !(sh_spi_read(SPI_CR1) & SPI_TBF); + i++) + sh_spi_write(tx_data[i], SPI_TBR); + + cur_len = i; + + if (sh_spi_read(SPI_CR4) & SPI_WPABRT) { + /* Abort the transaction */ + flags |= SPI_XFER_END; + sh_spi_set_bit(SPI_WPABRT, SPI_CR4); + ret = 1; + break; + } + + remain -= cur_len; + tx_data += cur_len; + + if (remain > 0) + write_fifo_empty_wait(); + } + + if (flags & SPI_XFER_END) { + tmp = sh_spi_read(SPI_CR1); + tmp = tmp & ~(SPI_SSD | SPI_SSDB); + sh_spi_write(tmp, SPI_CR1); + sh_spi_set_bit(SPI_SSA, SPI_CR1); + udelay(100); + write_fifo_empty_wait(); + } + + return ret; +} + +static int sh_spi_receive(unsigned char *rx_data, unsigned int len, + unsigned long flags) +{ + int i; + unsigned long tmp; + + if (len > SPI_MAX_BYTE) + sh_spi_write(SPI_MAX_BYTE, SPI_CR3); + else + sh_spi_write(len, SPI_CR3); + + tmp = sh_spi_read(SPI_CR1); + tmp = tmp & ~(SPI_SSD | SPI_SSDB); + sh_spi_write(tmp, SPI_CR1); + sh_spi_set_bit(SPI_SSA, SPI_CR1); + + for (i = 0; i < len; i++) { + if (recvbuf_wait()) + return 0; + + rx_data[i] = (unsigned char)sh_spi_read(SPI_RBR); + } + sh_spi_write(0, SPI_CR3); + + return 0; +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, + void *din, unsigned long flags) +{ + const unsigned char *tx_data = dout; + unsigned char *rx_data = din; + unsigned int len = bitlen / 8; + int ret = 0; + + if (flags & SPI_XFER_BEGIN) + sh_spi_write(sh_spi_read(SPI_CR1) & ~SPI_SSA, SPI_CR1); + + if (tx_data) + ret = sh_spi_send(tx_data, len, flags); + + if (ret == 0 && rx_data) + ret = sh_spi_receive(rx_data, len, flags); + + if (flags & SPI_XFER_END) { + sh_spi_set_bit(SPI_SSD, SPI_CR1); + udelay(100); + + sh_spi_clear_bit(SPI_SSA | SPI_SSDB | SPI_SSD, SPI_CR1); + clear_fifo(); + } + + return ret; +} + +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return 1; +} + +void spi_cs_activate(struct spi_slave *slave) +{ + +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + +} +
Hi, Shioda-san.
2011/1/17 Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com:
- SH SPI driver
- Copyright (C) 2011 Renesas Solutions Corp.
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; version 2 of the License.
- Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
Please add prefix of "SH_".
- writel(data, CONFIG_SH_SPI_BASE + offset);
<snip>
- return 1;
Why does this function return "1" every time?
-- 1.7.1
Best regards, Nobuhiro
Hi, Iwamatsu-san,
Thank you for your review.
2011/01/17 19:28, Nobuhiro Iwamatsu wrote:
Hi, Shioda-san.
< snip >
Yes, I will add it.
return 1;
Oh, it's temporary code. I will fix this function.
Best regards, Yoshihiro Shimoda
Dear Yoshihiro Shimoda,
Please keep list sorted.
Please declare a poper C struct instead.
All this stuff should better go into a separate header file.
NAK. We do not allow the base + offset notation. Pleaseuse a proper C struct instead.
Please fix globally.
Dear Wolfgang Denk,
Thank you very much for your review.
I will fix it.
I will modify it.
OK, I will create the sh_spi.h file.
Yes, I will fix the driver.
Nobuhiro Iwamatsu
Yoshihiro Shimoda
