[U-Boot] [PATCH v5] arm: socfpga: fix SPL booting from fpga OnChip RAM
This patch prevents disabling the FPGA bridges when SPL or U-Boot is executed from FPGA onchip RAM.
Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com ---
Changes in v5: - changed inline function 'socfpga_is_fpga_slaves_addr(addr)' to 'socfpga_is_booting_from_fpga()'
Changes in v4: - use an inline function in misc.h to check for the address range instead of a macro in base_addr_ac5.h
Changes in v3: - use __image_copy_start to check if we are executing from FPGA
Changes in v2: - use less ifdefs and more C code for address checks (but this gives a checkpatch warning because of comparing two upper case constants) - changed comments
arch/arm/mach-socfpga/include/mach/base_addr_ac5.h | 1 + arch/arm/mach-socfpga/include/mach/misc.h | 9 +++++++++ arch/arm/mach-socfpga/misc_gen5.c | 9 ++++++++- arch/arm/mach-socfpga/spl_gen5.c | 10 +++++++--- 4 files changed, 25 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-socfpga/include/mach/base_addr_ac5.h b/arch/arm/mach-socfpga/include/mach/base_addr_ac5.h index bb9e3faa29..2725e9fcc3 100644 --- a/arch/arm/mach-socfpga/include/mach/base_addr_ac5.h +++ b/arch/arm/mach-socfpga/include/mach/base_addr_ac5.h @@ -6,6 +6,7 @@ #ifndef _SOCFPGA_BASE_ADDRS_H_ #define _SOCFPGA_BASE_ADDRS_H_
+#define SOCFPGA_FPGA_SLAVES_ADDRESS 0xc0000000 #define SOCFPGA_STM_ADDRESS 0xfc000000 #define SOCFPGA_DAP_ADDRESS 0xff000000 #define SOCFPGA_EMAC0_ADDRESS 0xff700000 diff --git a/arch/arm/mach-socfpga/include/mach/misc.h b/arch/arm/mach-socfpga/include/mach/misc.h index 4fc9570a04..26609927c8 100644 --- a/arch/arm/mach-socfpga/include/mach/misc.h +++ b/arch/arm/mach-socfpga/include/mach/misc.h @@ -6,6 +6,8 @@ #ifndef _MISC_H_ #define _MISC_H_
+#include <asm/sections.h> + void dwmac_deassert_reset(const unsigned int of_reset_id, const u32 phymode);
struct bsel { @@ -23,6 +25,13 @@ static inline void socfpga_fpga_add(void) {}
#ifdef CONFIG_TARGET_SOCFPGA_GEN5 void socfpga_sdram_remap_zero(void); +static inline bool socfpga_is_booting_from_fpga(void) +{ + if ((__image_copy_start >= (char *)SOCFPGA_FPGA_SLAVES_ADDRESS) && + (__image_copy_start < (char *)SOCFPGA_STM_ADDRESS)) + return true; + return false; +} #endif
#ifdef CONFIG_TARGET_SOCFPGA_ARRIA10 diff --git a/arch/arm/mach-socfpga/misc_gen5.c b/arch/arm/mach-socfpga/misc_gen5.c index 429c3d6cd5..5fa40937c4 100644 --- a/arch/arm/mach-socfpga/misc_gen5.c +++ b/arch/arm/mach-socfpga/misc_gen5.c @@ -177,6 +177,8 @@ static void socfpga_nic301_slave_ns(void)
void socfpga_sdram_remap_zero(void) { + u32 remap; + socfpga_nic301_slave_ns();
/* @@ -187,7 +189,12 @@ void socfpga_sdram_remap_zero(void) setbits_le32(&scu_regs->sacr, 0xfff);
/* Configure the L2 controller to make SDRAM start at 0 */ - writel(0x1, &nic301_regs->remap); /* remap.mpuzero */ + remap = 0x1; /* remap.mpuzero */ + /* Keep fpga bridge enabled when running from FPGA onchip RAM */ + if (socfpga_is_booting_from_fpga()) + remap |= 0x8; /* remap.hps2fpga */ + writel(remap, &nic301_regs->remap); + writel(0x1, &pl310->pl310_addr_filter_start); }
diff --git a/arch/arm/mach-socfpga/spl_gen5.c b/arch/arm/mach-socfpga/spl_gen5.c index be318cc0d9..ccdc661d05 100644 --- a/arch/arm/mach-socfpga/spl_gen5.c +++ b/arch/arm/mach-socfpga/spl_gen5.c @@ -92,8 +92,11 @@ void board_init_f(ulong dummy)
/* Put everything into reset but L4WD0. */ socfpga_per_reset_all(); - /* Put FPGA bridges into reset too. */ - socfpga_bridges_reset(1); + + if (!socfpga_is_booting_from_fpga()) { + /* Put FPGA bridges into reset too. */ + socfpga_bridges_reset(1); + }
socfpga_per_reset(SOCFPGA_RESET(SDR), 0); socfpga_per_reset(SOCFPGA_RESET(UART0), 0); @@ -163,5 +166,6 @@ void board_init_f(ulong dummy) hang(); }
- socfpga_bridges_reset(1); + if (!socfpga_is_booting_from_fpga()) + socfpga_bridges_reset(1); }
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
- changed comments
- if ((__image_copy_start >= (char *)SOCFPGA_FPGA_SLAVES_ADDRESS) &&
return true;
- return false;
+} #endif
u32 remap;
- remap = 0x1; /* remap.mpuzero */
- /* Keep fpga bridge enabled when running from FPGA onchip RAM */
- if (socfpga_is_booting_from_fpga())
- writel(remap, &nic301_regs->remap);
- writel(0x1, &pl310->pl310_addr_filter_start);
- if (!socfpga_is_booting_from_fpga())
Applied, thanks !
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
changed comments
struct bsel {
return true;
- return false;
+} #endif
u32 remap;
- writel(0x1, &pl310->pl310_addr_filter_start); }
}socfpga_bridges_reset(1);
Applied, thanks !
Can this be merged to the main U-Boot repository soon? Or are you waiting for something from me for this?
I'd like to sync our internal branch with this soon, to be able to continue working on boot-from-FPGA (even if CONFIG_SPL_TEXT_BASE is still not configurable for this).
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
- changed comments
diff --git a/arch/arm/mach-socfpga/include/mach/base_addr_ac5.h b/arch/arm/mach-socfpga/include/mach/base_addr_ac5.h index bb9e3faa29..2725e9fcc3 100644 --- a/arch/arm/mach-socfpga/include/mach/base_addr_ac5.h +++ b/arch/arm/mach-socfpga/include/mach/base_addr_ac5.h @@ -6,6 +6,7 @@ #ifndef _SOCFPGA_BASE_ADDRS_H_ #define _SOCFPGA_BASE_ADDRS_H_ +#define SOCFPGA_FPGA_SLAVES_ADDRESS 0xc0000000 #define SOCFPGA_STM_ADDRESS 0xfc000000 #define SOCFPGA_DAP_ADDRESS 0xff000000 #define SOCFPGA_EMAC0_ADDRESS 0xff700000 diff --git a/arch/arm/mach-socfpga/include/mach/misc.h b/arch/arm/mach-socfpga/include/mach/misc.h index 4fc9570a04..26609927c8 100644 --- a/arch/arm/mach-socfpga/include/mach/misc.h +++ b/arch/arm/mach-socfpga/include/mach/misc.h @@ -6,6 +6,8 @@ #ifndef _MISC_H_ #define _MISC_H_ +#include <asm/sections.h>
void dwmac_deassert_reset(const unsigned int of_reset_id, const u32 phymode); struct bsel { @@ -23,6 +25,13 @@ static inline void socfpga_fpga_add(void) {} #ifdef CONFIG_TARGET_SOCFPGA_GEN5 void socfpga_sdram_remap_zero(void); +static inline bool socfpga_is_booting_from_fpga(void) +{ + if ((__image_copy_start >= (char *)SOCFPGA_FPGA_SLAVES_ADDRESS) && + (__image_copy_start < (char *)SOCFPGA_STM_ADDRESS)) + return true; + return false; +} #endif #ifdef CONFIG_TARGET_SOCFPGA_ARRIA10 diff --git a/arch/arm/mach-socfpga/misc_gen5.c b/arch/arm/mach-socfpga/misc_gen5.c index 429c3d6cd5..5fa40937c4 100644 --- a/arch/arm/mach-socfpga/misc_gen5.c +++ b/arch/arm/mach-socfpga/misc_gen5.c @@ -177,6 +177,8 @@ static void socfpga_nic301_slave_ns(void) void socfpga_sdram_remap_zero(void) { + u32 remap;
socfpga_nic301_slave_ns(); /* @@ -187,7 +189,12 @@ void socfpga_sdram_remap_zero(void) setbits_le32(&scu_regs->sacr, 0xfff); /* Configure the L2 controller to make SDRAM start at 0 */ - writel(0x1, &nic301_regs->remap); /* remap.mpuzero */ + remap = 0x1; /* remap.mpuzero */ + /* Keep fpga bridge enabled when running from FPGA onchip RAM */ + if (socfpga_is_booting_from_fpga()) + remap |= 0x8; /* remap.hps2fpga */ + writel(remap, &nic301_regs->remap);
writel(0x1, &pl310->pl310_addr_filter_start); } diff --git a/arch/arm/mach-socfpga/spl_gen5.c b/arch/arm/mach-socfpga/spl_gen5.c index be318cc0d9..ccdc661d05 100644 --- a/arch/arm/mach-socfpga/spl_gen5.c +++ b/arch/arm/mach-socfpga/spl_gen5.c @@ -92,8 +92,11 @@ void board_init_f(ulong dummy) /* Put everything into reset but L4WD0. */ socfpga_per_reset_all(); - /* Put FPGA bridges into reset too. */ - socfpga_bridges_reset(1);
+ if (!socfpga_is_booting_from_fpga()) { + /* Put FPGA bridges into reset too. */ + socfpga_bridges_reset(1); + } socfpga_per_reset(SOCFPGA_RESET(SDR), 0); socfpga_per_reset(SOCFPGA_RESET(UART0), 0); @@ -163,5 +166,6 @@ void board_init_f(ulong dummy) hang(); } - socfpga_bridges_reset(1); + if (!socfpga_is_booting_from_fpga()) + socfpga_bridges_reset(1); }
Applied, thanks !
It was blocked by the stratix 10 patches, now I dropped them and I'm waiting for the CI to finish.
Try u-boot-socfpga/master for that .
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
- changed comments
Applied, thanks !
OK, thanks.
I can (and did), but this is not something I can sync our internal branches to, since it changes...
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
- changed comments
Applied, thanks !
OK, thanks.
Well, the CI finished, PR is out. Thanks for pinging me about this.
Simon Goldschmidt
