[U-Boot] [PATCH 1/4] arm: exynos: arndale: Replace Chander Kashyap inactive maintainer
Last activity from Arndale (Exynos5250) board maintainer Chander Kashyap was in January 2014 (Signed-off). Recently his samsung.com email bounces with 550 (5.1.1 Recipient address rejected: User unknown).
Add Krzysztof Kozlowski as odd fixer for this board.
Signed-off-by: Krzysztof Kozlowski krzk@kernel.org
Although I do not have this particular board, but still I can try to take care about odd fixes. Instead I have few other boards based on Exynos4412 (Odroids) and 542x (Arndale Octa, Odroids). I also run automated Linux kernel boot tests for my boards and I maintain the Samsung SoCs in Linux kernel. --- board/samsung/arndale/MAINTAINERS | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/samsung/arndale/MAINTAINERS b/board/samsung/arndale/MAINTAINERS index 7dc17854d1b3..98ccaa42a86e 100644 --- a/board/samsung/arndale/MAINTAINERS +++ b/board/samsung/arndale/MAINTAINERS @@ -1,6 +1,6 @@ ARNDALE BOARD -M: Chander Kashyap k.chander@samsung.com -S: Maintained +M: Krzysztof Kozlowski krzk@kernel.org +S: Odd Fixes F: board/samsung/arndale/ F: include/configs/arndale.h F: configs/arndale_defconfig
When including other header from configs, use consistent <> syntax.
Signed-off-by: Krzysztof Kozlowski krzk@kernel.org --- include/configs/odroid_xu3.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/odroid_xu3.h b/include/configs/odroid_xu3.h index f178549a7223..7f4cff186151 100644 --- a/include/configs/odroid_xu3.h +++ b/include/configs/odroid_xu3.h @@ -7,7 +7,7 @@ #ifndef __CONFIG_ODROID_XU3_H #define __CONFIG_ODROID_XU3_H
-#include "exynos5420-common.h" +#include <configs/exynos5420-common.h> #include <configs/exynos5-common.h>
#define CONFIG_BOARD_COMMON
On Fri, 22 Feb 2019 19:36:41 +0100 Krzysztof Kozlowski krzk@kernel.org wrote:
Reviewed-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
applied to u-boot-samsung.
Thanks, Minkyu Kang.
File mixed space and tab indentation. Unify it.
Signed-off-by: Krzysztof Kozlowski krzk@kernel.org --- include/configs/odroid_xu3.h | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/include/configs/odroid_xu3.h b/include/configs/odroid_xu3.h index 7f4cff186151..5e765a2b2b02 100644 --- a/include/configs/odroid_xu3.h +++ b/include/configs/odroid_xu3.h @@ -18,7 +18,7 @@
#define TZPC_BASE_OFFSET 0x10000
-#define SDRAM_BANK_SIZE (256UL << 20UL) /* 256 MB */ +#define SDRAM_BANK_SIZE (256UL << 20UL) /* 256 MB */ /* Reserve the last 22 MiB for the secure firmware */ #define CONFIG_SYS_MEM_TOP_HIDE (22UL << 20UL) #define CONFIG_TZSW_RESERVED_DRAM_SIZE CONFIG_SYS_MEM_TOP_HIDE @@ -28,7 +28,7 @@ #define CONFIG_ENV_SIZE (SZ_1K * 16) #define CONFIG_ENV_OFFSET (SZ_1K * 3136) /* ~3 MiB offset */
-#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - 0x1000000) +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - 0x1000000)
#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0"
@@ -38,7 +38,7 @@ /* DFU */ #define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M #define DFU_DEFAULT_POLL_TIMEOUT 300 -#define DFU_MANIFEST_POLL_TIMEOUT 25000 +#define DFU_MANIFEST_POLL_TIMEOUT 25000
/* THOR */ #define CONFIG_G_DNL_THOR_VENDOR_NUM CONFIG_USB_GADGET_VENDOR_NUM @@ -85,11 +85,11 @@ #define CONFIG_SET_DFU_ALT_BUF_LEN (SZ_1K)
/* Set soc_rev, soc_id, board_rev, boardname, fdtfile */ -#define CONFIG_ODROID_REV_AIN 9 +#define CONFIG_ODROID_REV_AIN 9 #define CONFIG_REVISION_TAG
#undef CONFIG_SYS_BOARD -#define CONFIG_SYS_BOARD "odroid" +#define CONFIG_SYS_BOARD "odroid"
/* Define new extra env settings, including DFU settings */ #undef CONFIG_EXTRA_ENV_SETTINGS
On Fri, 22 Feb 2019 19:36:42 +0100 Krzysztof Kozlowski krzk@kernel.org wrote:
-#define SDRAM_BANK_SIZE (256UL << 20UL) /* 256 MB */ +#define SDRAM_BANK_SIZE (256UL << 20UL) /* 256 MB */ /* Reserve the last 22 MiB for the secure firmware */ #define CONFIG_SYS_MEM_TOP_HIDE (22UL << 20UL) #define CONFIG_TZSW_RESERVED_DRAM_SIZE CONFIG_SYS_MEM_TOP_HIDE @@ -28,7 +28,7 @@ #define CONFIG_ENV_SIZE (SZ_1K * 16) #define CONFIG_ENV_OFFSET (SZ_1K * 3136) /* ~3 MiB offset */ -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - 0x1000000) +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - 0x1000000) #define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" @@ -38,7 +38,7 @@ /* DFU */ #define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M #define DFU_DEFAULT_POLL_TIMEOUT 300 -#define DFU_MANIFEST_POLL_TIMEOUT 25000 +#define DFU_MANIFEST_POLL_TIMEOUT 25000
Lukasz Majewski
Various places in the code set "boardname" env property. It was used for booting from ITB images and choosing proper DTB file name. Instead of duplicating it, use existing U-Boot wide - "board_name".
Tested only on Odroid XU3. Tests on other boards appreciated. --- board/samsung/common/bootscripts/autoboot.cmd | 10 +++++----- board/samsung/common/misc.c | 2 +- include/configs/odroid.h | 2 +- include/configs/odroid_xu3.h | 8 ++++++-- 4 files changed, 13 insertions(+), 9 deletions(-)
diff --git a/board/samsung/common/bootscripts/autoboot.cmd b/board/samsung/common/bootscripts/autoboot.cmd index 11c724c4e095..d66bcccf5d1c 100644 --- a/board/samsung/common/bootscripts/autoboot.cmd +++ b/board/samsung/common/bootscripts/autoboot.cmd @@ -3,7 +3,7 @@ # ./tools/mkimage -c none -A arm -T script -d autoboot.cmd boot.scr # # It requires a list of environment variables to be defined before load: -# platform dependent: boardname, fdtfile, console +# platform dependent: board_name, fdtfile, console # system dependent: mmcbootdev, mmcbootpart, mmcrootdev, mmcrootpart, rootfstype # setenv fdtaddr "40800000" @@ -35,17 +35,17 @@ else setenv initrd_addr -; fi;"
-#### Routine: boot_fit - check that env $boardname is set and boot proper config of ITB image +#### Routine: boot_fit - check that env $board_name is set and boot proper config of ITB image setenv setboot_fit " -if test -e '${boardname}'; then +if test -e '${board_name}'; then setenv fdt_addr ; setenv initrd_addr ; setenv kerneladdr 0x42000000; setenv kernelname Image.itb; - setenv itbcfg ""#${boardname}""; + setenv itbcfg ""#${board_name}""; setenv imgbootcmd bootm; else - echo Warning! Variable: $boardname is undefined!; + echo Warning! Variable: $board_name is undefined!; fi"
#### Routine: setboot_uimg - prepare env to boot uImage diff --git a/board/samsung/common/misc.c b/board/samsung/common/misc.c index 05243fc89659..53cd1b290703 100644 --- a/board/samsung/common/misc.c +++ b/board/samsung/common/misc.c @@ -101,7 +101,7 @@ void set_board_info(void) bdtype = "";
sprintf(info, "%s%s", bdname, bdtype); - env_set("boardname", info); + env_set("board_name", info); #endif snprintf(info, ARRAY_SIZE(info), "%s%x-%s%s.dtb", CONFIG_SYS_SOC, s5p_cpu_id, bdname, bdtype); diff --git a/include/configs/odroid.h b/include/configs/odroid.h index b8809c8dcc7c..9f2d43e3fa38 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -132,7 +132,7 @@ "setenv kernelname Image.itb;" \ "run loadkernel;" \ "run kernel_args;" \ - "bootm ${kernel_addr_r}#${boardname}\0" \ + "bootm ${kernel_addr_r}#${board_name}\0" \ "boot_uimg=" \ "setenv kernelname uImage;" \ "run check_dtb;" \ diff --git a/include/configs/odroid_xu3.h b/include/configs/odroid_xu3.h index 5e765a2b2b02..af6004eaf511 100644 --- a/include/configs/odroid_xu3.h +++ b/include/configs/odroid_xu3.h @@ -84,10 +84,14 @@ #define CONFIG_SET_DFU_ALT_INFO #define CONFIG_SET_DFU_ALT_BUF_LEN (SZ_1K)
-/* Set soc_rev, soc_id, board_rev, boardname, fdtfile */ +/* Set soc_rev, soc_id, board_rev, board_name, fdtfile */ #define CONFIG_ODROID_REV_AIN 9 #define CONFIG_REVISION_TAG
+/* + * Need to override existing one (smdk5420) with odroid so set_board_info will + * use proper prefix when creating full board_name (SYS_BOARD + type) + */ #undef CONFIG_SYS_BOARD #define CONFIG_SYS_BOARD "odroid"
@@ -101,7 +105,7 @@ "rootfstype=ext4\0" \ "console=" CONFIG_DEFAULT_CONSOLE \ "fdtfile=exynos5422-odroidxu3.dtb\0" \ - "boardname=odroidxu3\0" \ + "board_name=odroidxu3\0" \ "mmcbootdev=0\0" \ "mmcrootdev=0\0" \ "mmcbootpart=1\0" \
On Fri, 22 Feb 2019 19:36:43 +0100 Krzysztof Kozlowski krzk@kernel.org wrote:
- setenv itbcfg ""#${board_name}""; setenv imgbootcmd bootm;
else
- echo Warning! Variable: $board_name is undefined!;
fi"
- env_set("board_name", info);
"boot_uimg=" \ "setenv kernelname uImage;" \ "run check_dtb;" \"bootm ${kernel_addr_r}#${board_name}\0" \
- Need to override existing one (smdk5420) with odroid so
set_board_info will
- use proper prefix when creating full board_name (SYS_BOARD + type)
- "board_name=odroidxu3\0" \ "mmcbootdev=0\0" \ "mmcrootdev=0\0" \ "mmcbootpart=1\0" \
Lukasz Majewski
else
fi"
- Need to override existing one (smdk5420) with odroid so set_board_info will
On Fri, 22 Feb 2019 19:36:40 +0100 Krzysztof Kozlowski krzk@kernel.org wrote:
(Fully) Acked-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
Krzysztof Kozlowski
Lukasz Majewski
Minkyu Kang
