[U-Boot] [PATCH 1/1] efi_loader: Delete() return EFI_WARN_DELETE_FAILURE
If EFI_FILE_PROTOCOL.Delete() fails, always close the handle and return EFI_WARN_DELETE_FAILURE.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_file.c | 10 ++-------- 1 file changed, 2 insertions(+), 8 deletions(-)
diff --git a/lib/efi_loader/efi_file.c b/lib/efi_loader/efi_file.c index 182d735e6b..36ca719a82 100644 --- a/lib/efi_loader/efi_file.c +++ b/lib/efi_loader/efi_file.c @@ -307,16 +307,10 @@ static efi_status_t EFIAPI efi_file_delete(struct efi_file_handle *file)
EFI_ENTRY("%p", file);
- if (set_blk_dev(fh)) { - ret = EFI_DEVICE_ERROR; - goto error; - } + if (set_blk_dev(fh) || fs_unlink(fh->path)) + ret = EFI_WARN_DELETE_FAILURE;
- if (fs_unlink(fh->path)) - ret = EFI_DEVICE_ERROR; file_close(fh); - -error: return EFI_EXIT(ret); }
-- 2.20.1
