[U-Boot] Fwd: arch/x86/cpu/x86_64/built-in.o: In function `checkcpu': (.text.checkcpu+0x0): multiple definition of `checkcpu' arch/x86/cpu/efi/built-in.o:(.text.checkcpu+0x0): first defined here
Apologies, I was using the wrong sender address.
---------- Forwarded message ---------- From: Jeroen Roovers jeroen.roovers@airfi.aero Date: 10 May 2017 at 12:12 Subject: arch/x86/cpu/x86_64/built-in.o: In function `checkcpu': (.text.checkcpu+0x0): multiple definition of `checkcpu' arch/x86/cpu/efi/built-in.o:(.text.checkcpu+0x0): first defined here To: u-boot@lists.denx.de
Trying to compile an x86_64 u-boot with EFI support:
arch/x86/cpu/x86_64/built-in.o: In function `checkcpu': (.text.checkcpu+0x0): multiple definition of `checkcpu' arch/x86/cpu/efi/built-in.o:(.text.checkcpu+0x0): first defined here arch/x86/cpu/x86_64/built-in.o: In function `arch_setup_gd': /home/jer/airfi/airfi-base/buildroot-2016.02-apollo/output/build/uboot-2017.05/arch/x86/cpu/x86_64/cpu.c:18: multiple definition of `misc_init_r' arch/x86/cpu/efi/built-in.o:(.text.misc_init_r+0x0): first defined here arch/x86/cpu/x86_64/built-in.o: In function `arch_setup_gd': /home/jer/airfi/airfi-base/buildroot-2016.02-apollo/output/build/uboot-2017.05/arch/x86/cpu/x86_64/cpu.c:18: multiple definition of `print_cpuinfo' arch/x86/cpu/efi/built-in.o:(.text.print_cpuinfo+0x0): first defined here make[2]: *** [scripts/Makefile.build:359: arch/x86/cpu/built-in.o] Error 1 make[1]: *** [Makefile:1234: arch/x86/cpu] Error 2 make[1]: *** Waiting for unfinished jobs....
with the attached configuration. Am I doing it wrong?
Kind regards, jer
+Simon
I don't have the environment to test but did you use efi-x86_defconfig?
Regards, Bin
On 11 May 2017 at 06:31, Bin Meng bmeng.cn@gmail.com wrote:
+Simon
No, the config I attached has been edited because when I use efi-x86_defconfig I get a mix of 32-bit and 64-bit objects:
/home/jer/airfi/airfi-base/apollo/output/host/usr/bin/x86_64-buildroot-linux-gnu-ld.bfd: Relocatable linking with relocations from format elf32-i386 (board/efi/efi-x86/efi.o) to format elf64-x86-64 (board/efi/efi-x86/built-in.o) is not supported make[2]: *** [scripts/Makefile.build:359: board/efi/efi-x86/built-in.o] Error 1 make[1]: *** [Makefile:1234: board/efi/efi-x86] Error 2 make[1]: *** Waiting for unfinished jobs....
So I needed to adapt it for a 64-bit target by enabling CONFIG_X86_RUN_64BIT
Kind regards, jer
+Simon
How did you provoke this build error? Did something change?
Hi Jeroen,
+Simon
CONFIG_X86_RUN_64BIT is supposed to be turned on a 64-bit U-Boot build, not for EFI application.
Regards, Bin
Right, so I cannot use u-boot on a 64-bit only UEFI system?
Kind regards, jer
Hi Jeroen,
You can - you need to build U-Boot as 32-bit and use the 64-bit stub. This should be described in the README.x86 but please post if you have questions.
Once U-Boot 64-bit support is fully complete you'll be able to run U-Boot in 64-bit if you like. Even when running 32-bit U-Boot does support natively starting a 64-bit kernel.
Kind regards, jer
Bin Meng
Jeroen Roovers
