[U-Boot] [PATCH 1/2] phylib: phy_startup() should return an error code on failure
phy_startup() calls the PHY driver's startup function, but it ignores the return code from that function, and so it never returns any failures.
Signed-off-by: Timur Tabi timur@freescale.com --- drivers/net/phy/phy.c | 5 ++++- 1 files changed, 4 insertions(+), 1 deletions(-)
diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index 7d327f7..baef60f 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -723,10 +723,13 @@ struct phy_device *phy_connect(struct mii_dev *bus, int addr, return phydev; }
+/* + * Start the PHY. Returns 0 on success, or a negative error code. + */ int phy_startup(struct phy_device *phydev) { if (phydev->drv->startup) - phydev->drv->startup(phydev); + return phydev->drv->startup(phydev);
return 0; }
Now that phy_startup() can return an actual error code, check for that error code and abort network initialization if the PHY fails.
Signed-off-by: Timur Tabi timur@freescale.com --- drivers/net/fec_mxc.c | 7 ++++++- drivers/net/fm/eth.c | 9 ++++++++- drivers/net/sh_eth.c | 6 +++++- drivers/net/tsec.c | 8 +++++++- drivers/net/xilinx_axi_emac.c | 6 +++++- drivers/net/xilinx_ll_temac.c | 8 +++++++- 6 files changed, 38 insertions(+), 6 deletions(-)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index eee41d7..7a3d16b 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -510,7 +510,12 @@ static int fec_open(struct eth_device *edev) fec_eth_phy_config(edev); if (fec->phydev) { /* Start up the PHY */ - phy_startup(fec->phydev); + int ret = phy_startup(fec->phydev); + if (ret) { + printf("Could not initialize PHY %s\n", + fm_eth->phydev->dev->name); + return ret; + } speed = fec->phydev->speed; } else { speed = _100BASET; diff --git a/drivers/net/fm/eth.c b/drivers/net/fm/eth.c index f34f4db..2b616ad 100644 --- a/drivers/net/fm/eth.c +++ b/drivers/net/fm/eth.c @@ -363,6 +363,9 @@ static int fm_eth_open(struct eth_device *dev, bd_t *bd) { struct fm_eth *fm_eth; struct fsl_enet_mac *mac; +#ifdef CONFIG_PHYLIB + int ret; +#endif
fm_eth = (struct fm_eth *)dev->priv; mac = fm_eth->mac; @@ -384,7 +387,11 @@ static int fm_eth_open(struct eth_device *dev, bd_t *bd) fmc_tx_port_graceful_stop_disable(fm_eth);
#ifdef CONFIG_PHYLIB - phy_startup(fm_eth->phydev); + ret = phy_startup(fm_eth->phydev); + if (ret) { + printf("%s: Could not initialize\n", fm_eth->phydev->dev->name); + return ret; + } #else fm_eth->phydev->speed = SPEED_1000; fm_eth->phydev->link = 1; diff --git a/drivers/net/sh_eth.c b/drivers/net/sh_eth.c index bb57e4d..268d884 100644 --- a/drivers/net/sh_eth.c +++ b/drivers/net/sh_eth.c @@ -415,7 +415,11 @@ static int sh_eth_config(struct sh_eth_dev *eth, bd_t *bd) goto err_phy_cfg; } phy = port_info->phydev; - phy_startup(phy); + ret = phy_startup(phy); + if (ret) { + printf(SHETHER_NAME ": phy startup failure\n"); + return ret; + }
val = 0;
diff --git a/drivers/net/tsec.c b/drivers/net/tsec.c index 3c1c8f0..f5e314b 100644 --- a/drivers/net/tsec.c +++ b/drivers/net/tsec.c @@ -480,6 +480,7 @@ static int tsec_init(struct eth_device *dev, bd_t * bd) int i; struct tsec_private *priv = (struct tsec_private *)dev->priv; tsec_t *regs = priv->regs; + int ret;
/* Make sure the controller is stopped */ tsec_halt(dev); @@ -511,7 +512,12 @@ static int tsec_init(struct eth_device *dev, bd_t * bd) startup_tsec(dev);
/* Start up the PHY */ - phy_startup(priv->phydev); + ret = phy_startup(priv->phydev); + if (ret) { + printf("Could not initialize PHY %s\n", + priv->phydev->dev->name); + return ret; + }
adjust_link(priv, priv->phydev);
diff --git a/drivers/net/xilinx_axi_emac.c b/drivers/net/xilinx_axi_emac.c index 7854a04..d777144 100644 --- a/drivers/net/xilinx_axi_emac.c +++ b/drivers/net/xilinx_axi_emac.c @@ -272,7 +272,11 @@ static int setup_phy(struct eth_device *dev) phydev->advertising = phydev->supported; priv->phydev = phydev; phy_config(phydev); - phy_startup(phydev); + if (phy_startup(phydev)) { + printf("axiemac: could not initialize PHY %s\n", + phydev->dev->name); + return 0; + }
switch (phydev->speed) { case 1000: diff --git a/drivers/net/xilinx_ll_temac.c b/drivers/net/xilinx_ll_temac.c index 27dafc1..b67153b 100644 --- a/drivers/net/xilinx_ll_temac.c +++ b/drivers/net/xilinx_ll_temac.c @@ -232,6 +232,7 @@ static void ll_temac_halt(struct eth_device *dev) static int ll_temac_init(struct eth_device *dev, bd_t *bis) { struct ll_temac *ll_temac = dev->priv; + int ret;
printf("%s: Xilinx XPS LocalLink Tri-Mode Ether MAC #%d at 0x%08X.\n", dev->name, dev->index, dev->iobase); @@ -240,7 +241,12 @@ static int ll_temac_init(struct eth_device *dev, bd_t *bis) return -1;
/* Start up the PHY */ - phy_startup(ll_temac->phydev); + ret = phy_startup(ll_temac->phydev); + if (ret) { + printf("%s: Could not initialize PHY %s\n", + dev->name, ll_temac->phydev->dev->name); + return ret; + }
if (!ll_temac_adjust_link(dev)) { ll_temac_halt(dev);
2012/7/6 Timur Tabi timur@freescale.com:
if (ret) {
Probably this is fec, not fm_eth.
return ret;
int ret;
if (ret) {
return ret;
phy_startup(phy);
if (ret) {
return ret;
} val = 0;
int ret; /* Make sure the controller is stopped */ tsec_halt(dev);
if (ret) {
return ret;
} adjust_link(priv, priv->phydev);
phydev->dev->name);
} switch (phydev->speed) { case 1000:
Why doesn't this driver use a ret variable? Other driver's patch used this.
int ret; printf("%s: Xilinx XPS LocalLink Tri-Mode Ether MAC #%d at 0x%08X.\n", dev->name, dev->index, dev->iobase);
if (ret) {
return ret;
} if (!ll_temac_adjust_link(dev)) { ll_temac_halt(dev);
-- 1.7.3.4
I acked sh_eth's part. Thank you.
Acked-by: Nobuhiro Iwamamatsu nobuhiro.iwamatsu.yj@renesas.com
Best regards, Nobuhiro
if (ret) {
Thanks. I thought I was being diligent, and I ran MAKEALL, but I guess it wasn't enough.
phydev->dev->name);
Because setup_phy() returns either 0 (failure) or 1 (success).
Hi Timur Tabi,
Applied to next, thanks.
-Joe
Joe Hershberger
Nobuhiro Iwamatsu
Tabi Timur-B04825
Timur Tabi
