[PATCH v1] board: toradex: verdin-imx8mp: enable usb device and fastboot support
Enable USB device and fastboot support which may be used to load the Toradex Easy Installer FIT image.
While at it also enable USB mass storage aka UMS support.
Note that the i.MX 8M Plus recovery mode support is based on the USB boot stage of the BOOTROM and does NOT require USB SDP SPL aka serial downloader support.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
configs/verdin-imx8mp_defconfig | 16 +++++++++++++++- 1 file changed, 15 insertions(+), 1 deletion(-)
diff --git a/configs/verdin-imx8mp_defconfig b/configs/verdin-imx8mp_defconfig index 2df0f4f3443..4c6650c3453 100644 --- a/configs/verdin-imx8mp_defconfig +++ b/configs/verdin-imx8mp_defconfig @@ -79,6 +79,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_READ=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_BOOTCOUNT=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y @@ -108,6 +109,12 @@ CONFIG_BOOTCOUNT_ENV=y CONFIG_CLK_COMPOSITE_CCF=y CONFIG_CLK_IMX8MP=y CONFIG_FSL_CAAM=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x42800000 +CONFIG_FASTBOOT_BUF_SIZE=0x40000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_UUU_SUPPORT=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 CONFIG_GPIO_HOG=y CONFIG_SPL_GPIO_HOG=y CONFIG_MXC_GPIO=y @@ -138,6 +145,7 @@ CONFIG_DWC_ETH_QOS_IMX=y CONFIG_FEC_MXC=y CONFIG_RGMII=y CONFIG_MII=y +CONFIG_PHY=y CONFIG_PHY_IMX8MQ_USB=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y @@ -160,14 +168,20 @@ CONFIG_SYSRESET_WATCHDOG=y CONFIG_DM_THERMAL=y CONFIG_IMX_TMU=y CONFIG_USB=y +# CONFIG_SPL_DM_USB is not set +CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y CONFIG_USB_EHCI_HCD=y -CONFIG_MXC_USB_OTG_HACTIVE=y +# CONFIG_USB_EHCI_MX7 is not set CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Toradex" +CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 +CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_IMX_WATCHDOG=y CONFIG_HEXDUMP=y
Hi Marcel,
Reviewed-by: Fabio Estevam festevam@denx.de
Hi Stefano
Maybe you missed that one (i.MX 8M Plus vs. Mini)? Thanks!
Cheers
Marcel
On Mon, 2023-08-28 at 19:24 -0300, Fabio Estevam wrote:
Hi Marcel,
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com Reviewed-by: Fabio Estevam festevam@denx.de
Fabio Estevam
Marcel Ziswiler
Marcel Ziswiler
