[U-Boot] PATCH: Fixed PPC4xx compilation warning in 4xx_enet.c
This patch fixes a compilation warning for some Ethernet PHY-less PPC4xx platforms (440SPE based ones) and a potential compilation error for 440SP platforms (use of undefined 'ethgroup' variable). In the original code and in case of 440SPE platforms, 'ethgroup' is initialized to -1 and never modified. Later in the function, within an #ifdef statement, an 'if statement' executes code only if 'ethgroup' is set to 4, therefore it is harmless to avoid executing the 'if statement' by removing the CONFIG_440SPE from the affected #ifdefs. In case of 440SP platforms with on-board Ethernet PHY, 'ethgroup' is undefined but used (there are not such platforms in the repository yet). All other architectures are not affected by this change. This is the current warning message with a Ethernet PHY-less 440SPE platform build (there is not such platform in the repository yet):
4xx_enet.c: In function 'ppc_4xx_eth_init': 4xx_enet.c:880: warning: unused variable 'ethgroup'
Signed-off-by: Alessio Centazzo acpatin {AT} yahoo {DOT} com
diff -Nau u-boot-2009.06/drivers/net/4xx_enet.c.orig u-boot-2009.06/drivers/net/4xx_enet.c --- u-boot-2009.06/drivers/net/4xx_enet.c.orig 2009-06-14 12:30:39.000000000 -0700 +++ u-boot-2009.06/drivers/net/4xx_enet.c 2009-06-17 08:34:54.000000000 -0700 @@ -873,7 +873,7 @@ defined(CONFIG_405EX) u32 opbfreq; sys_info_t sysinfo; -#if defined(CONFIG_440GX) || defined(CONFIG_440SPE) || \ +#if defined(CONFIG_440GX) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ defined(CONFIG_405EX) @@ -1122,7 +1122,6 @@
#if defined(CONFIG_440GX) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ - defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ defined(CONFIG_405EX)
Hi Alessio,
same comment to this patch as in my previous review. Please use git tools to create and send patches. Patch doesn't apply:
[stefan@stefan-desktop u-boot-ppc4xx (master)]$ git am patches_misc/PATCH:\ Fixed\ PPC4xx\ compilation\ warning\ in\ 4xx_enet.mbox Applying: PATCH: Fixed PPC4xx compilation warning in 4xx_enet.c error: patch failed: drivers/net/4xx_enet.c:873 error: drivers/net/4xx_enet.c: patch does not apply Patch failed at 0001 PATCH: Fixed PPC4xx compilation warning in 4xx_enet.c When you have resolved this problem run "git am --resolved". If you would prefer to skip this patch, instead run "git am --skip". To restore the original branch and stop patching run "git am --abort".
Please fix and resubmit. Thanks.
Best regards, Stefan
Alessio Centazzo
Stefan Roese
