[U-Boot] [PATCH] spi: sh_qspi: Add header file that defines the address of registers
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- drivers/spi/sh_qspi.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/spi/sh_qspi.c b/drivers/spi/sh_qspi.c index edeb42d..77ede6b 100644 --- a/drivers/spi/sh_qspi.c +++ b/drivers/spi/sh_qspi.c @@ -10,6 +10,7 @@ #include <common.h> #include <malloc.h> #include <spi.h> +#include <asm/arch/rmobile.h> #include <asm/io.h>
/* SH QSPI register bit masks <REG>_<BIT> */ @@ -170,7 +171,7 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, return NULL; }
- ss->regs = (struct sh_qspi_regs *)CONFIG_SH_QSPI_BASE; + ss->regs = (struct sh_qspi_regs *)SH_QSPI_BASE;
/* Init SH QSPI */ sh_qspi_init(ss);
Hi Nobuhiro Iwamatsu,
On Wed, Jan 8, 2014 at 6:46 AM, Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com wrote:
I really don't understand where you define this macro.
This macro was changed by following patch. http://patchwork.ozlabs.org/patch/307934/
I should have been CC to you this.
Best regards, Nobuhiro
2014/1/9 Jagan Teki jagannadh.teki@gmail.com:
-- Thanks, Jagan. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Nobuhiro,
On Thu, Jan 9, 2014 at 9:49 AM, Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com wrote:
OK. I will pick this once Albert pop your PR.
Any more spi patches?
Hi, Jagan.
Hi Nobuhiro,
I dont have SPI patches. Thank you.
2014/1/14 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com:
Hi, Jagan.
Hi Nobuhiro,
Or there is also a path you take in this patch. This patch is set. If you are not taken at the same time, this will not be build.
Albert, do you think about this?
-- Nobuhiro Iwamatsu
Hi Nobuhiro,
On Tue, Jan 14, 2014 at 5:42 AM, Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com wrote:
Hi, Jagan.
Hi Nobuhiro,
OK. I will mark the reviewed-by tag on this patch so-that we can send PR all together to Albert. is it fine for you?
Hi, Jagan.
2014/1/14 Jagan Teki jagannadh.teki@gmail.com:
Hi Nobuhiro,
Hi, Jagan.
Hi Nobuhiro,
Yes, it is fine to me. Thanks!
On Wed, Jan 8, 2014 at 6:46 AM, Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com wrote: > Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com > --- > drivers/spi/sh_qspi.c | 3 ++- > 1 file changed, 2 insertions(+), 1 deletion(-) > > diff --git a/drivers/spi/sh_qspi.c b/drivers/spi/sh_qspi.c > index edeb42d..77ede6b 100644 > --- a/drivers/spi/sh_qspi.c > +++ b/drivers/spi/sh_qspi.c > @@ -10,6 +10,7 @@ > #include <common.h> > #include <malloc.h> > #include <spi.h> > +#include <asm/arch/rmobile.h> > #include <asm/io.h> > > /* SH QSPI register bit masks <REG>_<BIT> */ > @@ -170,7 +171,7 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, > return NULL; > } > > - ss->regs = (struct sh_qspi_regs *)CONFIG_SH_QSPI_BASE; > + ss->regs = (struct sh_qspi_regs *)SH_QSPI_BASE;
ss->regs = (struct sh_qspi_regs *)SH_QSPI_BASE; /* Init SH QSPI */ sh_qspi_init(ss);
-- 1.8.5
Reviewed-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com
2014/1/15 Jagan Teki jagannadh.teki@gmail.com:
-- 1.8.5
Thanks!
Jagan Teki
Nobuhiro Iwamatsu
