[PATCH] arm: mach-k3: am642: Fix reset for workaround errata ID i2331
To workaround an issue in AM642 we reset the SoC in early boot. For that we first probed the sysreset driver by calling uclass_get_device(). The ti-sci sysreset driver is now probed during the ti-sci firmware probe. Update this call to probe the firmware driver which will then probe the sysreset driver allowing do_reset() to again function as expected.
Reported-by: Jonathan Humphreys j-humphreys@ti.com Fixes: fc5d40283483 ("firmware: ti_sci: Bind sysreset driver when enabled") Signed-off-by: Andrew Davis afd@ti.com --- arch/arm/mach-k3/am642_init.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-k3/am642_init.c b/arch/arm/mach-k3/am642_init.c index ddf47ef0a9b..80c3cb3479f 100644 --- a/arch/arm/mach-k3/am642_init.c +++ b/arch/arm/mach-k3/am642_init.c @@ -226,7 +226,7 @@ void board_init_f(ulong dummy) * The warm reset realigns internal clocks and prevents the lockup from * happening. */ - ret = uclass_first_device_err(UCLASS_SYSRESET, &dev); + ret = uclass_get_device_by_driver(UCLASS_FIRMWARE, DM_DRIVER_GET(ti_sci), &dev); if (ret) printf("\n%s:uclass device error [%d]\n",__func__,ret);
Am 18.04.24 um 19:58 schrieb Andrew Davis:
Tested-by: Wadim Egorov w.egorov@phytec.de
on phycore-am64x
- ret = uclass_get_device_by_driver(UCLASS_FIRMWARE, DM_DRIVER_GET(ti_sci), &dev); if (ret) printf("\n%s:uclass device error [%d]\n",__func__,ret);
Andrew Davis afd@ti.com writes:
-- 2.39.2
Tested-by: Kamlesh Gurudasani kamlesh@ti.com
on am64x-evm
Andrew Davis
Kamlesh Gurudasani
Wadim Egorov
