[U-Boot] [PATCH] Minor corrections for i386 (v2008.10-rc2)
Several minor corrections to allow clean builds of new i386 and sc520 based boards based on 2008.10
Signed-off-by: Graeme Russ graeme.russ@gmail.com ---
diff --git a/cpu/i386/sc520.c b/cpu/i386/sc520.c index 640b255..b68dfd6 100644 --- a/cpu/i386/sc520.c +++ b/cpu/i386/sc520.c @@ -32,7 +32,7 @@ #include <config.h> #include <pci.h> #ifdef CONFIG_SC520_SSI -#include <ssi.h> +#include <asm/ic/ssi.h> #endif #include <asm/io.h> #include <asm/pci.h> diff --git a/examples/82559_eeprom.c b/examples/82559_eeprom.c index d99af26..5e2eee9 100644 --- a/examples/82559_eeprom.c +++ b/examples/82559_eeprom.c @@ -19,7 +19,6 @@ */
#define _PPC_STRING_H_ /* avoid unnecessary str/mem functions */ -#define _LINUX_STRING_H_ /* avoid unnecessary str/mem functions */
#include <common.h> #include <exports.h> diff --git a/include/asm-i386/ic/sc520.h b/include/asm-i386/ic/sc520.h index 0f7e7a5..5922e8e 100644 --- a/include/asm-i386/ic/sc520.h +++ b/include/asm-i386/ic/sc520.h @@ -24,6 +24,10 @@ #ifndef _ASM_IC_SC520_H_ #define _ASM_IC_SC520_H_ 1
+#ifdef CONFIG_PCI +#include <pci.h> +#endif + /* Memory mapped configuration registers, MMCR */ #define SC520_REVID 0x0000 /* ElanSC520 Microcontroller Revision ID Register */ #define SC520_CPUCTL 0x0002 /* Am5x86 CPU Control Register */ @@ -312,7 +316,8 @@ extern int sc520_pci_ints[];
void init_sc520(void); unsigned long init_sc520_dram(void); +#ifdef CONFIG_PCI void pci_sc520_init(struct pci_controller *hose); int pci_sc520_set_irq(int pci_pin, int irq); - +#endif #endif diff --git a/lib_i386/video_bios.c b/lib_i386/video_bios.c index ce96a3e..1541773 100644 --- a/lib_i386/video_bios.c +++ b/lib_i386/video_bios.c @@ -21,6 +21,8 @@ * MA 02111-1307 USA */
+#ifdef CONFIG_VIDEO + #include <common.h> #include <pci.h> #include <malloc.h> @@ -136,7 +138,6 @@ static u32 probe_pci_video(void)
#endif
-#ifdef CONFIG_VIDEO
static int probe_isa_video(void) {
Dear Graeme Russ,
Soory, but some parts of this cannot work:
Will this still build for other architectures, say ARM and MIPS and Power?
- MA 02111-1307 USA
This cannot work. CONFIG_VIDEO can only be set in the board config file, which gets included implicitly by #include <common.h>, but you use the variable before that, so it will always be undefined, which is probably not what you intend.
Graeme Russ
